莱姆电子(中国)有限公司
  • 莱姆中国-工业电流电压传感器-HASS系列
  • 发布时间:2011/4/22 17:44:54   修改时间:2011/5/31 16:20:32 浏览次数:3663
  •   Panel mounted current transducers for unipolar +5V operation
      Main characteristics:
      ●7 standard models
      ●Panel mounting
      ●Currents' measurement from 50 to 600 ARMS nominal
      ●Unique design for all the models
      ●Small size for measurement up to 600
      ●Light: 55 g
      ●Operating temperature range: -40 to +85°C
      ●5 years warranty
      Features:
      ●Accurate (1% of IPN at 25°C without offset) DC, AC, pulse, small currents' measurements with galvanic isolation
      ●Single supply + 5V
      ●Non contact measurement
      ●Isolation test voltage: 3,3 KVRMS / 50Hz / 1min
      ●Voltage output
      ●Fixed offset and gain
      ●Reference access
      ●Open Loop technology combined with ASIC
      Standard Compliance:
      ●EN50178 for industrial applications such as:
      ●Home appliances
      ●Variable speed drives
      ●UPS's
      ●SMPS's
      ●Air conditioners
      ●Current monitoring
      ●Solar panels inverters
      ●Welding applications
      ●European Directive EMC 89 / 336 / EEC : CE Marking
      ●Using UL94-VO recognized materials
      ●Low voltage directive 72/23/EEC
      ●Safety IEC 61010-1
      Remarks:
      ●HASS brings an additional pin, at the output for more flexibility in applications. This pin provides access to the internal voltage reference of the ASIC which can then be fed to the reference of an A/D converter (Analog Digital) This extra pin can also receive the internal reference (from 2 to 2.8 V) of the DSP (Digital Signal Processor) or A/D converters commonly used in power electronics, allowing cancellation of the reference temperature drift.
      ●HASS is non potted.
    产品检索结果
    模块
    HASS 100-S
    HASS 200-S
    HASS 300-S
    HASS 400-S
    HASS 50-S
    HASS 500-S
    HASS 600-S
莱姆电子(中国)有限公司
联系人:郭超
地址:北京市顺义区林河工业区林河大街28号院
邮编:101300
电话:+86 10 89455202
传真:+86 10 80484303
公司网址:http://www.lem.com.cn
  • 路志远 在2024/10/25 14:23:00留言
  • 详细留言:LF 1005-S/SP16资料说明,便于设置使用参数
  • 梁小姐 在2024/9/24 13:16:00留言
  • 详细留言:开环霍尔电流传感器-(HAL 400-S)
  • 贺义清 在2024/9/4 9:45:00留言
  • 详细留言:得到HOB 130-P/SP1 三维模型
  • 熊先生 在2024/8/29 10:44:00留言
  • 详细留言:选型及技术支持
  • 在2024/8/22 13:32:00留言
  • 详细留言:选用贵公司HOB-P系列的电流传感器,希望得到贵公司的选型支持。
