珠海康宝莱仪表有限公司
  • KINAX WT710/711角位变送器
  • 发布时间:2007/7/12 10:24:15   修改时间:2007/7/12 10:24:15 浏览次数:1274
  • KINAX WT710/711
    现场装角位变送器
    The KINAX WT 710 converts the angular position of a shaft into a load-independent direct current signal, proportional to the angular position.
    * Measuring range limits 0...5 to 0...270°
    * Measuring output: DC current signal (load-independent, 2-, 3- or 4-wire connection)
    * Potentiometer for adjusting span / Optimum matching of desired measuring range
    * Direction of rotation: Output signal increases for clockwise or counter-clockwise rotation
    * Capacitive scanning system / No wear and low annual maintenance
    * Low influence from bearing play, < 0.1%
    * Accuracy =0.5% for ranges <150°
    * Torque < 0.001 Ncm
    * Drive shaft fully rotatable without stops at instruments without addional gear
    * Available with type of protection "Intrinsic safety" EEx ia IIC T6 / Can be mounted in hazardous areas
    * Unit in field type housing / Compact for building onto other equipment and plant
康宝莱仪表(珠海)有限公司(康宝莱中国行政中心)及销售中心设立在毗临港澳、风光秀丽的海滨城市—珠海经济特区,交通极其便利。宽敞的办公场地,为顾客提供全面的服务支援、咨询、产品展示,我们坚信康宝莱的自控产品及其相关的配套服务,将…  更多>>
珠海康宝莱仪表有限公司
联系人:叶先生
地址:珠海市香洲区华达工业区8栋5楼
邮编:200231
电话:13928079019,0756-3895880
传真:0756-3892788
公司网址:http://www.combine.cpooo.com/contact/
  • 何庆 在2023/7/5 11:55:00留言
  • 详细留言:询价 NIVOCONT料位计 RHL-305-6EX 数量1
