珠海康宝莱仪表有限公司
  • METRAport 3A折叠式万用表
  • 发布时间:2007/10/23 9:02:43   修改时间:2007/10/23 9:02:43 浏览次数:1360
    METRAport 3A metraport第3 a
    Folding Analog Multimeter for High Performance Applications折叠模拟万用表为高性能应用
    Universal folding multimeter with analog display and 52 measuring ranges for use in process engineering, electronics and electrical engineering, the testing laboratory, R&D, service and training in accordance with EN 31010-1 / VDE 0411 part 1.普及折叠万用表与模拟显示器和52测量范围为使用过程中工程,电子与电气工程,测试实验室,研发,服务和培训,按照恩31010-1 / vde 0411年第1部分。
    • For the measurement of voltage, current, resistance and level用于测量电压,电流,电阻和水平
    • With mirror-backed scale, accuracy class 1.5与镜背的规模,一流的准确性1.5
    • 10 M Ohm internal resistance for load-free voltage measurement 10米欧姆的内部电阻负载免费电压测量
    • Automatic battery shut-down when instrument is folded together电池自动关闭的力度时,仪器是折叠在一起
    • Scale can be tilted with folding lid which also provides protection during transport规模可倾斜与折叠盖子其中也规定保护运输过程中
    • 250 V~ overload protection in all ranges (except 10 A range) 250伏交流过载保护,在所有幅度(除10个射程)
    • Voltage measurement: direct and alternating voltage电压测量:直接和交流电压
      100 mV, 300 mV, 1 V,  3 V, 30 V, 100 V, 300 V and 600 V 100 mv时, 300 mv时,一日五,三五, 30五, 100五, 300 v和在600 v
    • Level measurement: in 9 measuring ranges from -40 dB to +62 dB液位测量: 9测量范围从-40分贝至62分贝
    • Current measurement: direct and alternating current in 7 measuring ranges for 10 uA, 100 uA, 1 mA, 10 mA, 100 mA, 1 A and 10 A电流测量:直接和交流电在7个测量范围为10个尿酸, 100尿酸, 1毫安, 10毫安, 100马, 1和10
    • Resistance measurement: 5 measuring ranges电阻测量: 5测量范围
      1 ohm to 2 k ohm, 10 ohm to 20 k ohm, 100 ohm to 200 k ohm, 一欧姆至2 k欧姆, 10欧姆至20 k欧姆, 100欧姆到200 k欧姆,
      1k ohm to 2 M ohm, 10 k ohm to 20 M ohm 1 k号欧姆至2米,欧姆, 10 k下欧姆至20米欧姆
    • Power supply: 9 V battery per IEC6F2 (commercially available) with 1000 h service life电力供应: 9 v电池每iec6f2 (商业) , 1000 h服务生活
    • Standard equipment: measuring instrument, cable set, battery and operating instructions标准装备:测量仪,有线,电池和操作说明书
    • Recommended accessories: FF1.6 fuse link / 700 V, FF16 / 600 V推荐配件: ff1.6保险丝连接/ 700五, ff16 /在600 v
康宝莱仪表(珠海)有限公司(康宝莱中国行政中心)及销售中心设立在毗临港澳、风光秀丽的海滨城市—珠海经济特区,交通极其便利。宽敞的办公场地,为顾客提供全面的服务支援、咨询、产品展示,我们坚信康宝莱的自控产品及其相关的配套服务,将…  更多>>
珠海康宝莱仪表有限公司
联系人:叶先生
地址:珠海市香洲区华达工业区8栋5楼
邮编:200231
电话:13928079019,0756-3895880
传真:0756-3892788
公司网址:http://www.combine.cpooo.com/contact/
  • 何庆 在2023/7/5 11:55:00留言
  • 详细留言:询价 NIVOCONT料位计 RHL-305-6EX 数量1
