Measuring, test, monitor and addressing instrument for the ASi bus and ASi slaves for professional initial start-up and troubleshooting
- Simple, menu-driven operation with function keys and matrix display
- Measurement of bus characteristics (voltage and current consumption)
- Recognition of protocol errors (e.g. duplicate addresses)
- Master mode operation at the ASi bus
- Programming and parameters configuration for ASi slaves
- PC gateway function
- Monitor function with address trigger for the display of error frequency
- Tool case and extensive accessories included
- Complete display of all parameters and addresses
- Compatible with existing installations and with the latest ASi standards (revision 2.11)
- Integrated 128 kB memory allows for the storage of complete systems and copying functions
- Firmware can be downloaded from a PC via IrDA interface for simplified expansion of functions at a later point in time
- Cost-effective documentation and management software (ASi-doc and ASi-access, optional) for efficient documentation, planning and initial start-up
METRAtest 36ASi (M236A) contains: AS-i addressing device and tester with neck strap, measurement cable, KS36A connecotr cable set, ground cable, NA 0100S charger, HC30 hard case
Set 36 ASi (M236B) contains: Same as M236A but with additionally, extensive connector accessories (modul base with adressing socket, KS36A, B, C, D, E connector cable sets), IrDA 0100S interface adapter and ASi-access software |
