珠海康宝莱仪表有限公司
  • METRAPHASE 1相序指示器
  • 发布时间:2007/10/23 11:27:16   修改时间:2007/10/23 11:27:16 浏览次数:1537
  • METRAPHASE 1相序指示器
  • METRAPHASE 1相序指示器
    METRAPHASE 1
    Phase Sequence Indicator
    600 Volts
    Phase sequence indicator with electronic rotary dial, frequency display and line voltage indicator.
    Phase sequence indicator in compliance with safety regulations.
    Many users prefer the Ferraris type rotary dial which, however, requires a mechanical movement. The size of the movement necessitates the use of a relatively large housing in order to assure that the required clearances and creepage distances are adhered to.
    For this reason, we have equipped our new METRAPHASE 1 phase sequence indicator with an electronic rotary dial.
    LEDs arranged in a circular array not only indicate the direction of rotation, but rather line frequency as well by means of LEDs which light up in various colors. The presence of voltage at each phase is indicated with additional LEDs as required by the regulation, as well as nominal line voltage. This new phase sequence indicator can be used as a 3-pole or a 2-pole indicator.
    - Power supply: 4 ea. mignon cell per IEC LR 6
康宝莱仪表(珠海)有限公司(康宝莱中国行政中心)及销售中心设立在毗临港澳、风光秀丽的海滨城市—珠海经济特区,交通极其便利。宽敞的办公场地,为顾客提供全面的服务支援、咨询、产品展示,我们坚信康宝莱的自控产品及其相关的配套服务,将…  更多>>
珠海康宝莱仪表有限公司
联系人:叶先生
地址:珠海市香洲区华达工业区8栋5楼
邮编:200231
电话:13928079019,0756-3895880
传真:0756-3892788
公司网址:http://www.combine.cpooo.com/contact/
  • 何庆 在2023/7/5 11:55:00留言
  • 详细留言:询价 NIVOCONT料位计 RHL-305-6EX 数量1
