2016年brusatori工厂上海欧航中国区销售![](http://www.cechina.cn/UpLoad/CompanyFile/2022/7/29/ae566a7b-15ef-443a-a0ea-c68b2b1e43f8.jpg)
brusatori电机、brusatori马达、brusatori泵、brusatori配件
上海航欧销售brusatori电机,brusatori马达
brusatori电机,brusatori马达brusatori泵brusatori配件
主要型号:BR120,553
BR140,871
BR161,193
BR221,160
BR241,985
BR262,415
BR28343
BR51221
BR52442
BR535,467
BR546,993
BR558,224
BR569,358
BR5710,482
BR5811,506
BR715,8228,1295
BR72117515,448
BR7315,32821,400
BR7419,58127,353
BR7522,53531,507
BR76269236,464
BR7730524225
BR78341647,690
BR82306248.026
BR8457.14385.309
BR8680.436115.612
BR88105.754147.938
BR9292.572120.787
BR94179.369236.603
BR96255.992338.251
BR98332.914442.181
Brushlessmotors-BRseries-EXPORT
Validfrom01/01/2015to31/12/2015
Prezzo
FEEDBACK
2 POLES
RESOLVER Include
2 POLES
RESOLVER Included in the price above
Incremental
encoder EF36K6-1024-only for BR1 / BR2 0
Incremental
encoder 1024 ppr 0
Incremental
encoder 2048 ppr 0
Incremental
encoder 4096 ppr 0
Incremental
encoder ERN 1323 4096 ppr 36
SinCos
encoder Heidenhain ERN 1385 00
EnDat
encoder Heidenhain EQN 1325 25
CONNECTORS
Flying
power connector for BR1 / BR2 3
Flying
signal connector for BR1 / BR2 3
Flying
power connector per BR3 / BR5 / BR7 5
Flying
signal connector per BR3 / BR5 / BR7 / BR8 / BR9 0
Strip
Phoenix clamps 5
BRAKES
Holding
brake BR1 00
Holding
brake BR2 27
Holding
brake BR5 7
Holding
brake BR7 07
Holding
brake BR8 60
Holding
brake BR92/BR94 57
Holding
brake BR96/BR98 22
FEET MOUNT
Feet for
BR5 5
Feet for
BR7 5
Feet for
BR8 1
Feet for
BR9 4
PROTECTION
DEGREE
IP65
protection 0
OBJ
INSULATION SYSTEM
BR5 10%
BR7 8%
BR8 5%
BR9 4%
SPECIAL
SHAFT (After technical approval)
Special
shaft for BR5 1
Special
shaft for BR7 1
Special
shaft for BR8 15
Special
shaft for BR9 15
VL 132 S
16 KW 95
VL 132 M
21 KW 05
VL 132 L
24 KW 18
VL 132 P
30 KW 35
VL 132 X
33 KW 30
VL 160 S
40 KW 30
VL 160 M
45 KW 02
VL 160 L
49 KW 12
VL 160 P
52 KW .012
VL 180 S
64 KW 40
VL 180 M
80 KW 80
VL 180 L
88 KW 45
VL 225 S
93 KW 80
VL 225 M
130 KW 20
VL 225 L
184 KW 10
VL 280 S
270 KW 550
VL 280 M
264 KW 645
VL 280 L
342 KW 970VL 132 S 23 KW 94
VL 132 M
31 KW 02
VL 132 L
34 KW 16
VL 132 P
39 KW 35
VL 132 X
42 KW 75
VL 160 S
63 KW 80
VL 160 M
71 KW 26
VL 160 L
82 KW 72
VL 160 P
88 KW .072
VL 180 S
100 KW 32
VL 180 M
124 KW 76
VL 180 L
138 KW 50
VL 225 S
144 KW 30
VL 225 M
190 KW .065
VL 225 L
280 KW .056
VL 280 S
407 KW 585
VL 280 M
401 KW 700
VL 280 L
524 KW 900VL132 VL160 VL180 VL225 VL280
-- 16 65
12 --
Flange
VL132
VL160 VL180 VL225
Mounting
B3/B5 5 5 45 70
Bearings
VL 132 VL
Ball
bearing Std Std Std Std
Insulated
bearing -- 60 40 40 .074
Brake
(Motor IP54)
K7 KTD K9
K9D K9D NIA63 NIA400
VL 132 65
20
VL 160 25
090
VL 180 420
VL 225 700
VL 280
Brake
(Motor IP23)
K7 KTD K9
VL 132 08
60
VL 160 056
260
VL 180 415
VL 225 700
VL 280
Feedback
VFS60 -
Incremental programmable encoder 15
VT 71 M
0,37 2,5
VT 71 L
0,63 4,0
VT 80 S
0,75 3,8
VT 80 L
1,1 5,1
VT 90 S
1,5 10,1
VT 90 L
2,2 14,8
VT 90 P 3
20
VT 90 X 4
25 920
VT100A 4
25
VT 100 S 6
38
VT 100 M
7,5 46
VT 100 L
8,5 54
VT 100 P
10 60
VT 132 S
11 72
VT 132 M
17 110
VT 132 L
22 143
VT 132 P
28 176
