上海航欧销售ELSI传感器 ELSI热电偶 ELSI热电阻 ELSI温度探头 ELSI温度探针 ELSI温度传感器
F1.S80-P00-B0250-S00
ZRP7F20-J00
A2.D60-P11-B0180-S00-059 180mm, 1/4,
F1.S80-P60-B0350-S00
JUMO
产品型号 ACTR200-42L-S automation direct
产品型号 ST5484E-152-432-00 METRIX
产品型号 2641050LD11A1G SETRA
产品型号 2641500LD11A1G SETRA
产品型号 264125CLD11A1G SETRA
产品型号 2641250LD11A1E SETRA
产品型号 TGM80-75-12L TGM60-50-10L NEC
产品型号 M100-XA4 MULTITEK
产品型号 MCOEAQ,IN: 0-1,5A OUT: 0-30mA Aux.Supply 220Vdc FRER
产品型号 MCOWT,IN: 2400/1A 220000/110V Out: +/- 12,5mA = +/-1250MW Aux.Supply 220Vdc FRER
产品型号 MCOWT,IN: 1200/1A 132000/110V Out: +/- 12,5mA = +/-375MW Aux.Supply 220Vdc FRER
产品型号 MCORT,IN: 2400/1A 220000/110V Out: +/- 12,5mA = +/-1250MVAR Aux.Supply 220Vdc FRER
产品型号 MCORT,IN: 1200/1A 132000/110V Out: +/- 12,5mA = +/-375MVAR Aux.Supply 220Vdc FRER
产品型号 MCOWT,IN: 1600/1A, 132000/110V OUT: +/-12,5mA = +/- 500MVAR Aux.Supply 110Vdc FRER
产品型号 A96MMA,96x96 IN: +/- 12,5mA Scale +/- 500MVAR Class 1 FRER
产品型号 MCORT,IN: 1600/1A, 132000/110V OUT: +/-12,5mA = +/- 500MVAR Aux.Supply 110Vdc FRER
产品型号 VDCT050-42-24 automation direct
产品型号 M2VS-AA-R/UL M-SYSTEM
产品型号 W2VS-AAA-R/K/N M-SYSTEM
产品型号 CS Transmitter (包含EL-30264) WESTLOCK
产品型号 MCOWT,Input:1200/1A,132kV/110V,Output:-10~10mA,Range: +/-375MW,Aux.Supply:110V DC FRER
产品型号 MCORT,Input:1200/1A,132kV/110V Output:-10~10mA,Range: +/-375MVAR Aux.Supply:110V DC FRER
产品型号 MCOWT,Input:200/1A,132kV/110V Output:-+/10mA = +/-60MW,Aux.Supply:110VDC FRER
产品型号 MCORT,Input:200/1A,132kV/110V Output:+/-10mA = +/- 60MVAR,Aux.Supply:110V DC FRER
产品型号 MCOFP,IN: 0-165V Out: 4-20mA = 45-55Hz Aux.Supply 110Vdc FRER
产品型号 MCOEAQ,IN: 0-1,5A OUT: 0-20mA Aux.Supply 110Vdc FRER
产品型号 MCOEVQ, Input:0~230V(AC)(50% overload) Output:0~20mA(50% overload) , Aux.Supply:220V DC,(0~230V AC) FRER
产品型号 MCORT, Suitable for:3 phase,4 wire,unbalanced load ,Input:3000/1A,500kV/110V (25% overload),Output:+/-10mA , Range: +/-3250MVAR,Aux.Supply:220VDC FRER
产品型号 MCOWT, Suitable for:3 phase,4 wire,unbalanced load ,Input:3000/1A,500kV/110V, (25% overload),Output: +/-10mA, Range: +/-3250MW, Aux.Supply:220V DC FRER
产品型号 MCOWT,IN: 2400/1A 220000/110V, Out: +/-
