  • brusatori马达VT 80 S 0,75 3,8
  • 发布时间:2021/10/23 7:43:53   修改时间:2021/10/23 7:43:53 浏览次数:460
  •  2016brusatori工厂上海欧航中国区销售
    brusatori电机、brusatori马达、brusatori泵、brusatori配件
     上海航欧销售brusatori电机,brusatori马达
     brusatori电机,brusatori马达brusatoribrusatori配件
     2016
     主要型号:BR120,553
     BR140,871
     BR161,193
     BR221,160
     BR241,985
     BR262,415
     BR28343
     BR51221
     BR52442
     BR535,467
     BR546,993
     BR558,224
     BR569,358
     BR5710,482
     BR5811,506
     BR715,8228,1295
     BR72117515,448
     BR7315,32821,400
     BR7419,58127,353
     BR7522,53531,507
     BR76269236,464
     BR7730524225
     BR78341647,690
     BR82306248.026
     BR8457.14385.309
     BR8680.436115.612
     BR88105.754147.938
     BR9292.572120.787
     BR94179.369236.603
     BR96255.992338.251
     BR98332.914442.181
     Brushlessmotors-BRseries-EXPORT
     Validfrom01/01/2015to31/12/2015
     Prezzo
    FEEDBACK
    2 POLES RESOLVER Include
    2 POLES RESOLVER Included in the price above
    Incremental encoder EF36K6-1024-only for BR1 / BR2 0
    Incremental encoder 1024 ppr 0
    Incremental encoder 2048 ppr 0
    Incremental encoder 4096 ppr 0
    Incremental encoder ERN 1323 4096 ppr 36
    SinCos encoder Heidenhain ERN 1385 00
    EnDat encoder Heidenhain EQN 1325 25
    CONNECTORS
    Flying power connector for BR1 / BR2 3
    Flying signal connector for BR1 / BR2 3
    Flying power connector per BR3 / BR5 / BR7 5
    Flying signal connector per BR3 / BR5 / BR7 / BR8 / BR9 0
    Strip Phoenix clamps 5
    BRAKES
    Holding brake BR1 00
    Holding brake BR2 27
    Holding brake BR5 7
    Holding brake BR7 07
    Holding brake BR8 60
    Holding brake BR92/BR94 57
    Holding brake BR96/BR98 22
    FEET MOUNT
    Feet for BR5 5
    Feet for BR7 5
    Feet for BR8 1
    Feet for BR9 4
    PROTECTION DEGREE
    IP65 protection 0
    OBJ INSULATION SYSTEM
    BR5 10%
    BR7 8%
    BR8 5%
    BR9 4%
    SPECIAL SHAFT (After technical approval)
    Special shaft for BR5 1
    Special shaft for BR7 1
    Special shaft for BR8 15
    Special shaft for BR9 15
    VL 132 S 16 KW 95
    VL 132 M 21 KW 05
    VL 132 L 24 KW 18
    VL 132 P 30 KW 35
    VL 132 X 33 KW 30
    VL 160 S 40 KW 30
    VL 160 M 45 KW 02
    VL 160 L 49 KW 12
    VL 160 P 52 KW .012
    VL 180 S 64 KW 40
    VL 180 M 80 KW 80
    VL 180 L 88 KW 45
    VL 225 S 93 KW 80
    VL 225 M 130 KW 20
    VL 225 L 184 KW 10
    VL 280 S 270 KW 550
    VL 280 M 264 KW 645
    VL 280 L 342 KW 970VL 132 S 23 KW 94
    VL 132 M 31 KW 02
    VL 132 L 34 KW 16
    VL 132 P 39 KW 35
    VL 132 X 42 KW 75
    VL 160 S 63 KW 80
    VL 160 M 71 KW 26
    VL 160 L 82 KW 72
    VL 160 P 88 KW .072
    VL 180 S 100 KW 32
    VL 180 M 124 KW 76
    VL 180 L 138 KW 50
    VL 225 S 144 KW 30
    VL 225 M 190 KW .065
    VL 225 L 280 KW .056
    VL 280 S 407 KW 585
    VL 280 M 401 KW 700
    VL 280 L 524 KW 900VL132 VL160 VL180 VL225 VL280
    -- 16 65 12 --
    Flange
    Mounting B3/B5 5 5 45 70
    Bearings
    VL 132 VL 160 VL180 VL225 VL280
    Ball bearing Std Std Std Std
    Insulated bearing -- 60 40 40 .074
    Brake (Motor IP54)
    K7 KTD K9 K9D K9D NIA63 NIA400
    VL 132 65 20
    VL 160 25 090
    VL 180 420
    VL 225 700
    VL 280
    Brake (Motor IP23)
    VL 132 08 60
    VL 160 056 260
    VL 180 415
    VL 225 700
    VL 280
    Feedback
    VFS60 - Incremental programmable encoder 15
    VT 71 M 0,37 2,5
    VT 71 L 0,63 4,0
    VT 80 S 0,75 3,8
    VT 80 L 1,1 5,1
    VT 90 S 1,5 10,1
    VT 90 L 2,2 14,8
    VT 90 P 3 20
    VT 90 X 4 25 920
    VT100A 4 25
    VT 100 S 6 38
    VT 100 M 7,5 46
    VT 100 L 8,5 54
    VT 100 P 10 60
    VT 132 S 11 72
    VT 132 M 17 110
    VT 132 L 22 143
    VT 132 P 28 176上海航欧机电设备有限公司成立于2006年,从事进口机电设备、仪器仪表等备品备件的销售,是经营世界各地进口设备机电配件的企业。上海航欧公司与众多品牌电子元件供应商建立有良好的合作关系,在欧美、日本等地形成了稳定的供应网络,良好的供应商关系和多年的行业经验,使我们在价格及货期上有优势。经销产品供应的行业涉及冶金、钢铁、石化、能源、航天、集装箱码头、汽车、水利、造纸、电厂、纺织、注塑、橡胶、食品包装等。我们热忱地希望尽我们的努力,力争优惠的产品价格,供货周期以及服务质量,能够为您解决进口备件方面的问题。进口产品主要有:传感器,测速电机,接近开关,电子尺,编码器,控制器、分析仪,光纤,光栅,插装阀,电缆,拖链,分配器,马达,减速机,继电器、缓冲器和进口五金等
    产品型号         GB0350PP6MNN                        Milton Roy
    产品型号         EHN-B31VC4R          EHN-B31VCMR       IWAKI
    产品型号         GM0050PR1MNN    SRPM063                  Milton Roy
    产品型号         SRPM045                   Milton Roy
    产品型号         502.05.40                            Dopag
    产品型号         401.02.30         22001856         401.00.24         Dopag
    产品型号         415.01.73                  450.10.06         Dopag
    产品型号         418.01.00                            Dopag
    产品型号         415.12.21                            Dopag
    产品型号         400.02.64                            Dopag
    产品型号         415.01.75                            Dopag
    产品型号         418.10.00                            Dopag
    产品型号         394C06                       PCB
    产品型号         BZ142-3 DC24V                          THEBEN
    产品型号         6045-20                      PRECISION
    产品型号         TC90 10 FUNZ                    CDC
    产品型号         119-02-M-1-15M0-E                           CDC
    产品型号         TU93                           CDC
    产品型号         54.022                        KUHNKE
    产品型号         HP515A5120V/50HZ,10SEC                           EAGLE SIGNAL
    产品型号         TB822E6MFT110VAC2CO                           ELTIME
    产品型号         732-0014                    TRUMETER
    产品型号         Timer NASmini16     87414720                   NETTER
    产品型号         Timer NASmini8       87414700                   NETTER
    产品型号         3602-192TG                        TRUMETER
    产品型号         0891203 115VAC 0.6VA                     HENGSTLER
    产品型号         0891331                     HENGSTLER
    产品型号         NKS           KPS   MUTOH
    产品型号         P2-4904 115VAC 4figure panelmount                        REDINGTON
    产品型号         0732002                     HENGSTLER
    产品型号         0891211                     HENGSTLER
    产品型号         9100                            TRUMETER
    产品型号         0866165                     HENGSTLER
    产品型号         KPS                     MUTOH
    产品型号         S-125-V                       MUTOH
    产品型号         CE4DMID01                       IME
    产品型号         7110DIN           7111         TRUMETER
    产品型号         1-4635                        TRUMETER
    产品型号         7110                   7110 DIN TRUMETER
    产品型号         3602-021613-611A                    TRUMETER
    产品型号         0732031                     HENGSTLER
    产品型号         LGB00000                  PAXI0020+PAXCDS20+PAXCDC10    REDLION
    产品型号         3602-132TG                        TRUMETER
    产品型号         OP3-B-60-DX-F14-R                    FIAMA
    产品型号         DA09S-9976 -02-10-1-I-20-MCM-A-M-GD-OZP-OD-ORP                           SIKO
    产品型号         3602-017237 TTL                        TRUMETER
    产品型号         C-100-V                      MUTOH
    产品型号         CP 2 1226                            KOHLER
    产品型号         1-4635(配套弹簧)                            TRUMETER
    产品型号         red (#1 1 pen Universal用于242E recorder-0-20000PSI                           BARTON
    产品型号         5124329D                           GRAPHIC
    产品型号         383 965-02                        Heidenhain
    产品型号         12" 100pcs/bag 适用于242E recorder-0-20000PSI                         BARTON
    产品型号         CWD4850P                         CRYDOM
    产品型号         D2450 240V 50A                         CRYDOM
    产品型号         CS AR-04V024                    PIZZATO
    产品型号         HD4875                      CRYDOM
    产品型号         RF381800 13-18 AMP BF09A-BF38A                           LOVATO
    产品型号         462121H5U                        ELOBAU
    产品型号         55.34.9024.0040                        FINDER
    产品型号         52000                          MURR
  • 姜小姐 在2024/7/23 10:50:00留言
  • 详细留言:4*102+2*1,0+2*0,75订货号S950-16110
  • 陈长 在2024/7/19 15:13:00留言
  • 详细留言:SC1DD4015,SC1DD4030 SC1DD4050 各100个价格及货期,谢谢
  • 陈小洁 在2023/4/11 10:23:00留言
  • 详细留言:SCTSF-SS-100-P1/1-PCW
  • 薛康 在2023/3/29 17:13:00留言
  • 详细留言:CAMCO-M902RDM4H32-330 凸轮分割器 价格和货期,烦请提供相关外形尺寸图,以便做方案设计
  • Emma Fan 在2023/3/8 14:47:00留言
  • 详细留言:dayton电机1LPW5 1台
