  • Waddington开关PSPCB10000
  • 发布时间:2022/8/17 11:05:46   修改时间:2022/8/17 11:05:46 浏览次数:658
  • 2016年Waddington工厂上海航欧中国区销售
    上海航欧销售Waddington变速循环控制单元Waddington传感器Waddington超声波传感器Waddington开关 Waddington电源,Waddington控制器,Waddington动力控制
     主要型号:Waddington开关PSPCB10000
     PSPCB10000-BIN
     PSENC10000
     PSENC10031
     PSENC10032
     PSENC10009
     PSENC10010
     PSENC10000-NE
     PSENC10001
     PSENC10021
     PSENC10035
     PSENC50002
     PCDIO10003
     PCDIO10008
     PCDIO10000
     PCDIO10008
     PCDIO10003
     PCDIO10000
     STTOPLIMIT1
     STTOPLIMIT2
     STBOTTOMLIMIT1
     STBOTTOMLIMIT2
     ST2NDTOPLIMIT
     ST2NDBOTTOMLIMI
     PSCBL70012
     PSCBL70006
     PSCBL70008
     PSCBL70013
     PSCBL70014
     PSCBL70019
     PSCBL70015
     WESTAMRSH2R1
     WESTAMRSH2R2
     WESTAMRSH2R2SST
     WESTAMRSH3
     WESTAMRSH2R1H
     WESTAMRSH2R2H
     WESTAMRSH2FG
     WESTAMRSH2R1H
     WESTAMRSH2R2HFG
     WESTASSH1
     WESTASSH2
     STHEADsonatrolheadoptionsExtrasensors
     WESTAMRSH2R1mrsh-2/r15in-20ftsonarsensor3800
     WESTAMRSH2R2mrsh-2/r218in-20ftsonarsenso3800
     WESTAMRSH2R2SSTmrsh-2/r218in-20ftsstransdu5500
     WESTAMRSH3sonatrolsensorwithdual7700
     WESTAMRSH2R1Hr1sensorw/hornN8800
     WESTAMRSH2R2Hr2sensorw/hornN8800
     WESTAMRSH2FGmrsh-2fgsensorr2fixedgain0000
     WESTAMRSH2R2HFGr2sensorw/hornandfixedgainN2000
     WESTASSSH1 r-1 stainless steel sensor  7500
     WESTASSSH2 r-2 stainless steel sensor  7500
     STWESTA30FT st6z mods for 30 ft range  Range Mods
     WESTA30FT st6z mods for 30 ft range  000
     STWESTAAOAB air output a/b option
     WESTAAOAB air output a / b selec switch  $ -
     STWESTAAUTO/MAN auto manual out put option
     WESTAAUTO/MAN auto/manual selector switch  $ -
     STWESTAF/V1 freq to voltage option
     WEEZAFV1 f/v-1 frequency to voltage oe Y $ -
     STWESTAGUIDE001 sensor guide adjust able width  call
     WESTASTANDWH1 stand-wh sensor stand w/wheels N 3000
     STWESTAMTRSEL dc motor sel a/b contactor
     WESTAMTRSEL dc motor sel a/b contactor  5000
     STWESTAUTF1 upper time filter option
     WESTAUTF1 utf-1 upper time filter option  $ -
     STWEST/F1 voltage to frequecny option
     PSMDL04 v/f-1 voltage to frequency  $ -
     WESTAQCON Sensor Head quick connector  $ -
     STWESTAMUX2 option analog multiplier
     WESTAMUX2 mux-2 analog multiplier option  8900
     STWESTAHVAO1 option 0-90v dc output
     WESTAHVAO1 hvao-1 0-90vdc output option  2500
     STWESTAJOG option jog option
     WESTAJOG jog pushbutton option  $ -
     STWESTALFO1 option ac line filter
     WESTALFO1 lfo-1 ac line filter option  500
     STWESTATAP1 option percent taper option
     WESTATAP1 tap-1 percent taper option  1800
     STWESTATW1 option limit thumbwheel setpoi
     WESTATW1 thumbwheel set point pot  5000
     STWESTARP1 option remote distance pot
     WESTARP1 rp-1 10 turn remote distance  000
     STWESTARP2 option remote gain pot
     WESTARP2 rp-2 ten turn remote gain  000
     STWESTARP3 option remote speed on output
     WESTARP3 option remote speed on output  000
     STWESTAPT1 option payoff/takeup switch
     WESTAPT1 payout take up switch option  500
     STWESTAFR1 option forward reverse switch
     WESTAFR1 fr-1 forward-reverse switch  500
     STWESTAMAO20 option 4-20 ma output  current loop optput
     WESTAMAO20 mao-20 4-20ma output option  6600
     STWESTAMAO10 option 0-10 ma output
     WESTAMAO10 mao-10 0-10ma output option  6600
     STWESTABOB1 option 12 bit binary output  12 bit binary output
     WESTABOB1 bob-1 12bit binary output  5000
     STWESTASY2M option sy2 sequencer(master op  Sequencer for 2 units operating close together
     WESTASY2M sy2-m sy-2 sequencer master  5000 master
     STWESTASYS option sle option
     WESTASYS sy-s sle option  000 sle
     STWESTASY8 option sy8 sequencer
     WESTASY8 sy-8 8 unit sequencing option  6000 8 CH sequencer for up to 8 units close together
     STWESTASTAND1 option sensorhead stand
     WESTASTAND1A stand-1 sensor head stand N 0900 Sensor Stands
     WESTASTAND10 stand with spool guide N $ -
     WESTASTAND1B sensor head stand with guides N $ -
     STWESTASTANDWH1 stand-wh sensor stand w/wheels
     WESTASTANDWH1 stand-wh sensor stand w/wheels N 8200
     STWESTARAAC1 cable adapter rapid air raac1  Adapter Cables for other OEM equipment
     WESTARAAC1 raac-1 5 pin rapid adapter  000
     STWESTARAAC2 option 15 pin rapidair cable
     WESTARAAC2 raac-2 V2 rapid air adapter  500
     STWESTARAAC2J option 15 pin rapidair cable
     WESTARAAC2J raac-2j rapid air adapter  0000
     STWESTAGOODMAN1 option cable to goodman cutter
     WESTAGOODMAN1 goodman cutter adapter 15 ft  000
     STWESTARAAC3 option d shell rapidair connec
     WESTARAAC3 rapid air d-shell adapter  500
     STWESTADIV2 option analog divider
     WESTADIV2 div-2 analog divider option  0000
     STWESTABSO1 option base speed option
     WESTABSO1 bso-1 base speed option  7500
     STWESTAAOM1 option anolog meter  output meters
     WESTAAOM2 analog meter 0-90 vdc  $ -
     WESTAAOM1 aom-1 analog output meter+-15  0000
     STWESTADMS1 option digital display
     WESTADMS1 dms-1 digital display  9900
     STWESTAEAO1 option extra analog output  Extra analog outputs
     WESTAEAO1 eoa-1 normal extra analog  5000
     STWESTAEAON1 option extra analog output inv
     WESTAEAON1 eaon-1 inverted extra analog  5000
     STWESTADUAL option relay for dual sensor o
     WESTADUAL relay option for dual heads  6500 Relay for 2nd sensor switchable
     STWESTATOGGLE option on off toggle switch
     WESTATOGGLE on/off toggle switch option  500 on off power switch
     STWESTASUM3 option line speed summing
     WESTASUM3 sum-3 3input summing amplifier  7600 Summing input
     STWESTATC6 option tension control(auto/ma
     WESTATC6 tc-6 tension control option  0000
     STWESTADF1 option dust filter option  Dust filter for sensor
     WESTADF1 df-1 dust filter for  500
     STWESTAPID2 option pid output
     WESTAPID2 pid2 output option  6500 PID Output
     STWESTAONOFF two setpoint on off control
     WESTAONOFF 2-set point on/off relay  500 dual setpoint On/Off relay
    WEPTAONOFFNS
    WEPTAPT1LSA
    WEPTAPT1-1
    PTTOPLIMIT
    WEPTATL1
    PTBOTTOMLIMIT
    WEPTABL1
    PTSTAND
    WEPTASTAND
    PTWESTAEXTBASE
    WESTAEXTBASE
    STWESTAMAO20
    WESTAMAO20
    STWESTAMAO10
    WESTAMAO10
    STWESTARAAC1
    WESTARAAC1
    STWESTARAAC2
    WESTARAAC2
    STWESTARAAC2J
    WESTARAAC2J
    STWESTARAAC3
    WESTARAAC3
    STWESTASUM3
    WESTASUM3
    PSOSDA10003
    PSENC10032-PT
    PSDRV10001-PT
    PSDRV10002-PT
    PSSPR10000
    PSPTA10006
    PSOPR10001
    PTTOPLIMIT
    WEPTATL1
    PTBOTTOMLIMIT
    WEPTABL1
    PTSTAND
    WEPTASTAND
    STWESTAF/V1
    WEEZAFV1
    PTWESTAEXTBASE
    WESTAEXTBASE
    STWESTAMAO20
    WESTAMAO20
    STWESTAMAO10
    WESTAMAO10
    STWESTARAAC1
    WESTARAAC1
    STWESTARAAC2
    WESTARAAC2
    STWESTARAAC2J
    WESTARAAC2J
    STWESTARAAC3
    WESTARAAC3
    STWESTAAOM1
    WESTAAOM2
    WESTAAOM1
    STWESTASUM3
    WESTASUM3
    1303157 现货查询
    1303864 现货查询
    1303872 现货查询
    1303880 现货查询
    1303899 现货查询
    1303902 现货查询
    1303910 现货查询
    1303929 现货查询
    1303937 现货查询
    1303PGT-1A-2.5B-T2 0-70bar 现货查询
    13051-200/5A  现货查询
    13071 02 0/4 现货查询
    1307D 13070310 现货查询
    130B-111JJ 现货查询
    130B-291JJ  现货查询
    130B-614JA 现货查询
    130B1235 现货查询
    131603 5A,G1/4 现货查询
    13180V 现货查询
    1319.50.370.01 现货查询
    132 现货查询
    132034 现货查询
    1321.63.100.01 现货查询
             14240148/PSD-4      13233394/PSD-30 现货查询
    1324075520 现货查询
    132748 现货查询
    132S-02 现货查询
    132SB2B5 现货查询
    132kW 4P 380V B3 50Hz 现货查询
    1330-2-PM20 现货查询
    13302 现货查询
    1332-M-212-MS 现货查询
    1332-M-212-MZ 现货查询
    1341166 现货查询
    1341173 现货查询
    134376 现货查询
    134385 现货查询
    134386 现货查询
    1344A.28 现货查询
    134593 现货查询
    1348797 Indicator lamp 24 VAC DC 现货查询
    134ADS 现货查询
    135629 ZHB 180X60 900W 110V FA A=1500 1908871 001 01" 现货查询
    13567 现货查询
    135903 现货查询
    135905 现货查询
    136-PG-A101 现货查询
    136211 现货查询
    136228 现货查询
    136259 现货查询
    136455 L=2M,P=195W G1/4 现货查询
    1364789 STR-660-100-CW-FL-L01-60-S-TX 现货查询
    137G 现货查询
    137G-2590 现货查询
    137G-2590-50C 现货查询
    1381 0.5-11BAR 现货查询
    1381P 1-20bar 现货查询
    12C20230071381R 0.7-14bar  现货查询
    1382 Range: 0.07 to 1 bar 现货查询
    13AA 132MC-2 IMB5 现货查询
             S 18/10     13N0717 80054 现货查询
    13mm*0.15mm 现货查询
    13mm*0.20mm 现货查询
    14-511-100B20 现货查询
    14-7-3745 现货查询
    14.44.100 现货查询
    14.44.130 现货查询
    14.44.150 现货查询
    14.60.170 现货查询
    700037114/940.022.A/φ15/φ15 现货查询
    1400-6950 现货查询
    14000500 现货查询
    14001020  现货查询
    140064 现货查询
    14080207 现货查询
    14087600 现货查询
             FS-EB-4N-400SLPM-R-X5A-GAS        140993177 现货查询
    140H-8 TC100BB950-AB-X 现货查询
    141045 现货查询
    141ST-120R  现货查询
    142 现货查询
    1421 SRK E4 现货查询
    14232113 现货查询
    142611FH 12CSA200  现货查询
                    1427SRKKE5 现货查询
    142840JB 4CB200 现货查询
    142DRF6AA 现货查询
    142DRV6AA 现货查询
    142DRX6AA 现货查询
    143 012 010 0.37KW 140 现货查询
    143-011-131 现货查询
  • 姜小姐 在2024/7/23 10:50:00留言
  • 详细留言:4*102+2*1,0+2*0,75订货号S950-16110
  • 陈长 在2024/7/19 15:13:00留言
  • 详细留言:SC1DD4015,SC1DD4030 SC1DD4050 各100个价格及货期,谢谢
  • 陈小洁 在2023/4/11 10:23:00留言
  • 详细留言:SCTSF-SS-100-P1/1-PCW
  • 薛康 在2023/3/29 17:13:00留言
  • 详细留言:CAMCO-M902RDM4H32-330 凸轮分割器 价格和货期,烦请提供相关外形尺寸图,以便做方案设计
  • Emma Fan 在2023/3/8 14:47:00留言
  • 详细留言:dayton电机1LPW5 1台
