上海航欧销售Eltrotec光电传感器、 Eltrotec工业内窥镜、Eltrotec照明、Eltrotec颜色识别传感器、Eltrotec色标传感器、Eltrotec激光测距传感器、 Eltrotec光纤
ELTROTEC
FES-M-16 ART-NR:10281302
14/270 24VDC+-25% VA/M 3.0
FAD-E-C2.0-2,5-S-22°
Sender1200 mm Receiver2400mm
ELT.CLS-K-50 ANALOG
ELT.FADT-A3.0-3.0-1500-67 OT-
TICA L=1500mm 67° NO:10810864
CLS-K63
Eltrotec色标传感器DCF966 PF-DC101 8M电缆传感器IFA-10/022 CLS-K-65;RLS-M-50/OPTO1A;光纤FAD-P-C1.0-1.0-600-68;FV-FT-D61(91343948);AFV-C0946S(9.133.3329);021.275;0810259;光纤开关CLSK31 3843640106;颜色识别传感器LC2004;色标传感器DCF 966S;放大模块CLS-K-63;光纤放大器9.062.4040 IFA-10/022;导线WRB11105;电器元件CLS-K50;配件FES-M-11-3;传感器FAR-P=A3.0-3;LRD-6110、
ELTRONIC
ESKBI 60
CLS-K-65
FV-FT-D61(91343948)
LC2004
DCF 966S 色标传感器
CLS-K-63
021.275
081.0300
021.324
081.0310
IFA-10/022
0810259
RLS-M-50/OPTO1A
WRB11105
光导线
CLS-K-50
FES-M-11-3
FAR-P=A3.0-3,0-1200-67度
Art No:10810321
LRD-6110
色标传感器
FAR-T-Q2-10*0.3-2200(
光纤长22mm) 传感器
CLS-K-10 转换器
和ELTROTEC-0021配套用
WLCS-TCL-255
FAR-P-D3 0-2. 5-120
LDS85/10 2.5KHZ RS422
LDS85/20 2.5KHZ RS422
0810311
XU AFP 989 SP 光纤传感器
021.103
FEL-EL-10
6916.011.393
FAR-P-D 3.0-2.5
FOT 150
EB使用的冷光源
FOT 20
FOT 100
5-600-68
0-600-68
感应器
FAR-M-F1-D-1
1FA-10/022
强光源FOT150上的光电纤维
WLCS-LD800
PS4-KT200/3
FAR-M-A1.1-1.5-600-68°
FAR-M-A1.1-1.5-1200-68°
FAD-M-M2.0-1.0-600-68°
FAD-M-M2.0-1.0-1200-68°
FAR-M-A11-1.5-1200-68
FAD-M-M20-1.0-1200-68
CLS-K-61
CLS-K-31
FAR-P-A1.0-1.5-1200-67°
FAR-P-A2.0-2.5-1200-67°
LAM-K-200-11071112
LAM-200-K-10812226
LAM-200-K-11251112
PS1LC0965S
LDS100/500 激光测距传感器
CLS-K-63/100
EIPH2-016RK03-10+EIPH2-008RK33
-10
CLS-K-63,VAL0158388 放大器
EIPH2-004-RK03
EIPH2-008RK03-10 40MPA 4200
高压齿轮泵
FAR-T-Q2-10*0.3-2400-67°
传感器
LBS-M-34 25*2 90度
10661699
FES-M-110
FAD-E-C2.0-2.5-S-22C
订货号:10813901
订货号:10813902
PS 1L CO 965S 10/30VDC
FASOT RLS-B-50,
FAR-P-D3 0-2 5-1200S
FAR-M-M4.0-3.5-1200-68°
LDS72-10 位移传感器
1-型号:FA 2-功能模式:D
3-保护模式:E
FAD-E-C2.0-2.5-1200-22
FAD-E-C2.0-2.5-2400-22
CLS-K-63配套光纤System FASOP
CLS-K-65配套光纤System FASOP
FAD-M-Q5-38X0,15-1200-67°
FAR-M-M1.1-0.6-1200S
08710267
021115
LT1 15KHZ
RS32,2M,4PIN
10810267
LDS100/900,(10652073)
