2013年 Seametrics工厂上海航欧中国区销售
上海航欧销售Seametrics流量计Seametrics电磁流量计Seametrics流量计探头Seametrics传感器Seametrics变送器Seametrics指示器Seametrics频率计Seametrics接头Seametrics探头,Seametrics传感器Seametrics流量计
Seametrics公司成立于1990年,一直致力于高效流量和控制类产品的研发和生产。
FT415WBatteryPoweredPulseOutput,WallMount96
Note:UseofHingedDisplayCoverisrecommendedforalloutdoorapplications.
FT420W12-24Vdc,PulseOutput&4-20mAOutputs,WallMount70
FT420P12-24Vdc,PulseOutput&4-20mAOutputs,PanelMount70
FT420W-2712-24Vdc,110VacDualPowerSupply,HardWired,WallMount70
Mount70
OptionCode(s)Description
06LMIPump4-PinConnector0
106Roytronics?Series-APump5PinConnector0
AO55Parts&Accessories
Model#Description
100471AO55ReplacementModule65
100414Screw/WasherKit,Upperhousing(Qty4)1
100364CordGrip1/4"I.D.2
101850CordGrip,1/2"NPT8
2014IndustrialListV2Page8January01,2014
Rev.050114
PC-SeriesPowerConverters
Model#Description
PC3110-115Vac,24Vdc,Unregulated6
Model#Description
EX810BFixedDepthInsertionMagmeter,Brass,1"-3"90
EX810PFixedDepthInsertionMagmeter,PVC,1"-3"98
EX810SFixedDepthInsertionMagmeter,316SS,1"-3"21
EX820BFixedDepthInsertionMagmeter,Brass,4"-10"19
EX820PFixedDepthInsertionMagmeter,PVC,4"-10"19
EX820SFixedDepthInsertionMagmeter,316SS,4"-10"97
EX830BFixedDepthInsertionMagmeter,Brass,12"87
EX830PFixedDepthInsertionMagmeter,PVC,12"80
EX830SFixedDepthInsertionMagmeter,316SS,12"83
15ReverseFlow49
40Immersible0
50LowPowerNC
125Viton?O-Ring6
EX801SeriesFixedDepthInsertionMagmeter(FT420MeterMount)
Model#Description
EX811BFixedDepthInsertionMagmeter,Brass,1"-3",FT420160
EX811PFixedDepthInsertionMagmeter,PVC,1"-3",FT420068
EX811SFixedDepthInsertionMagmeter,316SS,1"-3",FT420291
EX821BFixedDepthInsertionMagmeter,Brass,4"-10",FT420189
EX821PFixedDepthInsertionMagmeter,PVC,4"-10",FT420089
EX821SFixedDepthInsertionMagmeter,316SS,4"-10",FT420367
EX831BFixedDepthInsertionMagmeter,Brass,12",FT420257
EX831PFixedDepthInsertionMagmeter,PVC,12",FT420150
EX831SFixedDepthInsertionMagmeter,316SS,12",FT420453
Model#Description
EX812BFixedDepthInsertionMagmeter,Brass,1"-3",AO55060
EX812PFixedDepthInsertionMagmeter,PVC,1"-3",AO5568
EX812SFixedDepthInsertionMagmeter,316SS,1"-3",AO55191
EX822BFixedDepthInsertionMagmeter,Brass,4"-10",AO55089
EX822PFixedDepthInsertionMagmeter,PVC,4"-10",AO5589
EX822SFixedDepthInsertionMagmeter,316SS,4"-10",AO55267
EX832BFixedDepthInsertionMagmeter,Brass,12",AO55157
EX832PFixedDepthInsertionMagmeter,PVC,12",AO55050
EX832SFixedDepthInsertionMagmeter,316SS,12",AO55353
15ReverseFlow49
50LowPowerNC
125Viton?O-Ring6
2014IndustrialListV2Page13January01,2014
Rev.050114
EX806SeriesFixedDepthInsertionMagmeter(DL76MeterMount)
Model#Description
EX816B Fixed Depth Insertion Magmeter,
Brass, 1"-3", DL76 045
EX816P Fixed Depth Insertion Magmeter,
PVC, 1"-3", DL76 53
EX816S Fixed Depth Insertion Magmeter, 316
SS, 1"-3", DL76 176
EX826B Fixed Depth Insertion Magmeter,
Brass, 4"-10", DL76 074
EX826P Fixed Depth Insertion Magmeter,
PVC, 4"-10", DL76 74
EX826S Fixed Depth Insertion Magmeter, 316
SS, 4"-10", DL76 252
EX836B Fixed Depth Insertion Magmeter,
Brass, 12", DL76 142
EX836P Fixed Depth Insertion Magmeter,
PVC, 12", DL76 035
EX836S Fixed Depth Insertion Magmeter, 316
SS, 12", DL76 338
Option Code(s) Description
15 Reverse Flow 49
32 Tamper-Evident Kit, Wire, Seal 1
50 Low Power NC
125 Viton? O-Ring 6
EX808 Series Fixed Depth Insertion
Magmeter (PD10 Meter Mount)
Model # Description
EX818B Fixed Depth Insertion Magmeter,
Brass, 1"-3", PD10 48
EX818P Fixed Depth Insertion Magmeter,
PVC, 1"-3", PD10 56
EX818S Fixed Depth Insertion Magmeter, 316
SS, 1"-3", PD10 79
EX828B Fixed Depth Insertion Magmeter,
Brass, 4"-10", PD10 77
EX828P Fixed Depth Insertion Magmeter,
PVC, 4"-10", PD10 77
EX828S Fixed Depth Insertion Magmeter, 316
SS, 4"-10", PD10 055
EX838B Fixed Depth Insertion Magmeter,
Brass, 12", PD10 45
EX838P Fixed Depth Insertion Magmeter,
PVC, 12", PD10 38
EX838S Fixed Depth Insertion Magmeter, 316
SS, 12", PD10 141
EX800 Series Tee Fittings
Model # Description
Bronze
EF81T-B-100 Tee Fitting, Bronze, Threaded,
1", EX 44
EF81T-B-150 Tee Fitting, Bronze, Threaded,
1-1/2", EX 59
EF81T-B-200 Tee Fitting, Bronze, Threaded,
2", EX 79
EF81T-B-300 Tee Fitting, Bronze, Threaded,
3", EX 44
EF81T-B-400 Tee Fitting, Bronze, Threaded,
4", EX 76
EF81TC-B-100 Tee Fitting, Bronze, Sweat,
1", EX 44
EF81TC-B-150 Tee Fitting, Bronze, Sweat,
1-1/2", EX 59
EF81TC-B-200 Tee Fitting, Bronze, Sweat,
2", EX 79
EF81TC-B-300 Tee Fitting, Bronze, Sweat,
3", EX 44
EF81TC-B-400 Tee Fitting, Bronze, Sweat,
4", EX 76
PVC
EF81T-P-100 Tee Fitting, PVC, 1", EX
24
EF81T-P-150 Tee Fitting, PVC, 1-1/2",
EX 28
EF81T-P-200 Tee Fitting, PVC, 2", EX
35
EF81T-P-200-18 Tee Fitting, PVC, Flanged
Ends, 2",EX 45
Carbon Steel
EF81T-C-100 Tee Fitting, Carbon Steel,
1", EX 79
EF81T-C-150 Tee Fitting, Carbon Steel,
1-1/2", EX 20
EF81T-C-200 Tee Fitting, Carbon Steel,
2", EX 61
EF81T-C-200-34 Tee Fitting, Carbon Steel,
Flanged Ends, 2", EX 41
Stainless Steel
EF81T-S-100 Tee Fitting, 304 SS,
1",EX 57
EF81T-S-150 Tee Fitting, 304 SS,
1-1/2", EX 67
EF81T-S-200 Tee Fitting, 304 SS, 2",
EX 77
EF81T-S-100-14 Tee Fitting, 316 SS,
1",EX 18
EF81T-S-150-14 Tee Fitting, 316 SS ,
1-1/2", EX 38
EF81T-S-200-14 Tee Fitting, 316 SS,
2", EX 63
EF81T-S-200-20 Tee Fitting, 304 SS,
Flanged Ends, 2", EX 17
EF81T-S-200-14-20 Tee Fitting, 316 SS,
Flanged Ends, 2", EX 003
2014 Industrial List V2 Page 15
January 01, 2014
Rev. 050114
EX800 Series Saddle Fittings
Model # Description
Ductile Iron
EF82S-F-300 Saddle, Iron, 3", EX 72
EF82S-F-400 Saddle, Iron, 4", EX 06
EF82S-F-600 Saddle, Iron, 6", EX 61
EF82S-F-800 Saddle, Iron, 8", EX 95
EF82S-F-1000 Saddle, Iron, 10", EX 67
EF82S-F-1200 Saddle, Iron, 12", EX 55
PVC
EF82S-P-300 Saddle, PVC, 3", EX 15
EF82S-P-400 Saddle, PVC, 4", EX 31
EF82S-P-600 Saddle, PVC, 6", EX 51
EF82S-P-800 Saddle, PVC, 8", EX 79
Note: PVC saddles supplied with Buna-O
O-rings only.
For Chemical service, O-ring must be
removed and saddle glued to pipe with PVC cement.
See Instructions for more detail.
EF82S-P-300-16 Saddle, PVC, 3", w/
16" Pipe Stub, EX 84
EF82S-P-400-16 Saddle, PVC, 4", w/
16" Pipe Stub, EX 05
EF82S-P-600-16 Saddle, PVC, 6", w/
16" Pipe Stub, EX 30
EF82S-P-800-16 Saddle, PVC, 8", w/
16" Pipe Stub, EX 63
EF82W-B-300 Weldolet, Brass, 3", EX
40
EF82W-B-400 Weldolet, Brass, 4", EX
40
EF82W-B-600 Weldolet, Brass, 6", EX
40
EF82W-B-800 Weldolet, Brass, 8", EX
40
EF82W-B-1000 Weldolet, Brass, 10", EX
40
EF82W-B-1200 Weldolet, Brass, 12", EX
40
Carbon Steel
EF82W-C-300 Weldolet, Carbon Steel,
3", EX 18
EF82W-C-400 Weldolet, Carbon Steel,
4", EX 18
EF82W-C-600 Weldolet, Carbon Steel,
6", EX 18
EF82W-C-800 Weldolet, Carbon Steel,
8", EX 18
EF82W-C-1000 Weldolet, Carbon Steel,
10", EX 18
EF82W-C-1200 Weldolet, Carbon Steel,
12", EX 18
Stainless Steel
EF82W-S-300 Weldolet, 316 SS, 3", EX
06
EF82W-S-400 Weldolet, 316 SS, 4", EX
06
EF82W-S-600 Weldolet, 316 SS, 6", EX
06
EF82W-S-800 Weldolet, 316 SS, 8", EX
06
EF82W-S-1000 Weldolet, 316 SS, 10",
EX 06
72 12" Extension (210/250 Series
Only) 02
EX150/250 Hot-Tap Adjustable Depth
Insertion Magmeter (Sensor Only)
Model # Description
EX150B Hot Tap Adj Depth Insertion
Magmeter, Brass, 3-10" 331
EX150S Hot Tap Adj Depth Insertion
Magmeter, 316 SS, 3-10" 576
EX250B Hot Tap Adj Depth Insertion
Magmeter, Brass, 10-48" 593
Model # Description
MF101F-300-150 Saddle, Iron, NPT Thread,
3" X 1-1/2" 36
MF101F-400-150 Saddle, Iron, NPT Thread,
4" X 1-1/2" 44
MF101F-600-150 Saddle, Iron, NPT Thread,
6" X 1-1/2" 48
MF101F-800-150 Saddle, Iron, NPT Thread,
8" X 1-1/2" 78
MF101F-1000-150 Saddle, Iron, NPT Thread,
10" X 1-1/2" 58
MF101F-1200-150 Saddle, Iron, NPT Thread,
12" X 1-1/2" 20
MF101F-1400-150 Saddle, Iron, NPT Thread,
14" X 1-1/2" 90
MF101F-1600-150 Saddle, Iron, NPT Thread,
16" X 1-1/2" 55
MF101F-1800-150 Saddle, Iron, NPT Thread,
18" X 1-1/2" 29
MF101F-2000-150 Saddle, Iron, NPT Thread,
20" X 1-1/2" 02
MF101F-2200-150 Saddle, Iron, NPT Thread,
22" X 1-1/2" 50
MF101F-2400-150 Saddle, Iron, NPT Thread,
24" X 1-1/2" 95
MF101B-300-150 Saddle, Bronze, NPT Thread,
3" X 1-1/2" 93
MF101B-400-150 Saddle, Bronze, NPT Thread
4" X 1-1/2" 24
EX150/250 Series Saddle Fittings
Model # Description
MF101F-300-200 Saddle, Iron, NPT Thread,
3" X 2" 36
MF101F-400-200 Saddle, Iron, NPT Thread,
4" X 2" 44
MF101F-600-200 Saddle, Iron, NPT Thread,
6" X 2" 48
MF101F-800-200 Saddle, Iron, NPT Thread,
8" X 2" 78
MF101F-1000-200 Saddle, Iron, NPT Thread,
10" X 2" 58
MF101F-1200-200 Saddle, Iron, NPT Thread,
12" X 2" 20
MF101F-1400-200 Saddle, Iron, NPT Thread,
14" X 2" 90
MF101F-1600-200 Saddle, Iron, NPT Thread,
16" X 2" 55
MF101F-1800-200 Saddle, Iron, NPT Thread,
18" X 2" 29
MF101F-2000-200 Saddle, Iron, NPT Thread,
20" X 2" 02
MF101F-2200-200 Saddle, Iron, NPT Thread,
22" X 2" 50
MF101F-2400-200 Saddle, Iron, NPT Thread,
24" X 2" 95
MF101B-300-200 Saddle, Bronze, NPT Thread,
3" X 2" 93
MF101B-400-200 Saddle, Bronze, NPT Thread,
4" X 2" 24
Model # Description
TX810B Fixed Depth Insertion Turbine
Meter, Brass, 1-1/2"-3" 93
TX810P Fixed Depth Insertion Turbine
Meter, PVC, 1-1/2"-3" 96
TX810S Fixed Depth Insertion Turbine
Meter, 316 SS, 1-1/2"-3" 23
TX810S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 1-1/2"-3" 98
TX820B Fixed Depth Insertion Turbine
Meter, Brass, 4"-8" 23
TX820P Fixed Depth Insertion Turbine
Meter, PVC, 4"-8" 17
TX820S Fixed Depth Insertion Turbine
Meter, 316 SS, 4"-8" 01
TX820S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 4"-8" 76
Model # Description
TX811B Fixed Depth Insertion Turbine
Meter, Brass, 1-1/2"-3", FT420 163
TX811P Fixed Depth Insertion Turbine
Meter, PVC, 1-1/2"-3", FT420 066
TX811S Fixed Depth Insertion Turbine
Meter, 316 SS, 1-1/2"-3", FT420 293
TX811S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 1-1/2"-3", FT420 368
TX821B Fixed Depth Insertion Turbine
Meter, Brass, 4"-8", FT420 193
TX821P Fixed Depth Insertion Turbine
Meter, PVC, 4"-8", FT420 087
TX821S Fixed Depth Insertion Turbine
Meter, 316 SS, 4"-8", FT420 371
TX821S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 4"-8", FT420 446
TX812B Fixed Depth Insertion Turbine
Meter, Brass, 1-1/2"-3", AO55 063
TX812P Fixed Depth Insertion Turbine
Meter, PVC, 1-1/2"-3", AO55 66
TX812S Fixed Depth Insertion Turbine
Meter, 316 SS, 1-1/2"-3", AO55 193
TX812S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 1-1/2"-3", AO55 268
TX822B Fixed Depth Insertion Turbine
Meter, Brass, 4"-8", AO55 093
TX822P Fixed Depth Insertion Turbine
Meter, PVC, 4"-8", AO55 87
TX822S Fixed Depth Insertion Turbine
Meter, 316 SS, 4"-8", AO55 271
TX822S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 4"-8", AO55 346
06 LMI Pump 4-Pin Connector 0
60 Viton? O-Ring 6
106 Roytronics? Series-A Pump 5-Pin
Connector 0
Note: If the -HP option is ordered, a
Carbon or Stainless fitting must also be ordered.
HP units are not interchangable with
standard units.
TX804 Series Fixed Depth Insertion Turbine
Meter (FT415 Meter Mount)
Model # Description
TX814B Fixed Depth Insertion Turbine
Meter, Brass, 1-1/2"-3", FT415 189
TX814P Fixed Depth Insertion Turbine
Meter, PVC, 1-1/2"-3", FT415 092
TX814S Fixed Depth Insertion Turbine
Meter, 316 SS, 1-1/2"-3", FT415 319
TX814S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 1-1/2"-3", FT415 394
TX824B Fixed Depth Insertion Turbine
Meter, Brass, 4"-8", FT415 219
TX824P Fixed Depth Insertion Turbine
Meter, PVC, 4"-8", FT415 113
TX824S Fixed Depth Insertion Turbine
Meter, 316 SS, 4"-8", FT415 397
TX824S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 4"-8", FT415 472
60 Viton? O-Ring 6
64 Non-Resettable Total 7
126 Hinged Display Cover 3
standard units.
2014 Industrial List V2 Page 29 January
01, 2014
Rev. 050114
TX806 Series Fixed Depth Insertion Turbine
Meter (DL76 Meter Mount)
Model # Description
TX816B Fixed Depth Insertion Turbine
Meter, Brass, 1-1/2"-3", DL76 048
TX816P Fixed Depth Insertion Turbine
Meter, PVC, 1-1/2"-3", DL76 51
TX816S Fixed Depth Insertion Turbine
Meter, 316 SS, 1-1/2"-3", DL76 178
TX816S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 1-1/2"-3", DL76 253
TX826B Fixed Depth Insertion Turbine
Meter, Brass, 4"-8", DL76 078
TX826P Fixed Depth Insertion Turbine
Meter, PVC, 4"-8", DL76 72
TX826S Fixed Depth Insertion Turbine
Meter, 316 SS, 4"-8", DL76 256
TX826S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 4"-8", DL76 331
60 Viton? O-Ring 6
standard units.
TX808 Series Fixed Depth Insertion Turbine
Meter (PD10 Meter Mount)
Model # Description
TX818B Fixed Depth Insertion Turbine
Meter, Brass, 1-1/2"-3", PD10 51
TX818P Fixed Depth Insertion Turbine
Meter, PVC, 1-1/2"-3", PD10 54
TX818S Fixed Depth Insertion Turbine
Meter, 316 SS, 1-1/2"-3", PD10 81
TX818S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 1-1/2"-3", PD10 056
TX828B Fixed Depth Insertion Turbine
Meter, Brass, 4"-8", PD10 81
TX828P Fixed Depth Insertion Turbine
Meter, PVC, 4"-8", PD10 75
TX828S Fixed Depth Insertion Turbine
Meter, 316 SS, 4"-8", PD10 059
TX828S-HP Fixed Depth Insertion Turbine
Meter, 316 SS, Hi Pres, 4"-8", PD10 134
37 10 Ft. Cable for LMI Connector 2
60 Viton? O-Ring 6
Connector 0
standard units.
2014 Industrial List V2 Page 30
January 01, 2014
Rev. 050114
TX800 Series Tee Fittings
Model # Description
Bronze
TF81T-B-150 Tee Fitting, Bronze, Threaded,
1-1/2", TX 59
TF81T-B-200 Tee Fitting, Bronze, Threaded,
2", TX 79
TF81T-B-300 Tee Fitting, Bronze, Threaded,
3", TX 44
TF81T-B-400 Tee Fitting, Bronze, Threaded,
4", TX 76
TF81TC-B-150 Tee Fitting, Bronze, Sweat,
1-1/2", TX 59
TF81TC-B-200 Tee Fitting, Bronze, Sweat,
2", TX 79
TF81TC-B-300 Tee Fitting, Bronze, Sweat,
3", TX 44
TF81TC-B-400 Tee Fitting, Bronze, Sweat,
4", TX 76
PVC
TF81T-P-150 Tee Fitting, PVC, 1-1/2",
TX 28
TF81T-P-200 Tee Fitting, PVC, 2", TX
35
Carbon Steel
TF81T-C-150 Tee Fitting, Carbon Steel,
1-1/2", TX 20
TF81T-C-200 Tee Fitting, Carbon Steel,
2", TX 61
TF81T-C-150-HP Tee Fitting, Carbon Steel,
Hi Pres, 1-1/2", TX 35
TF81T-C-200-HP Tee Fitting, Carbon Steel,
Hi Pres, 2", TX 76
Stainless Steel
TF81T-S-150 Tee Fitting, 304 SS,
1-1/2", TX 67
TF81T-S-200 Tee Fitting, 304 SS, 2",
TX 77
TF81T-S-150-14 Tee Fitting, 316 SS,
1-1/2", TX 38
TF81T-S-200-14 Tee Fitting, 316 SS,
2", TX 63
TF81T-S-150-HP Tee Fitting, 304 SS, Hi
Pres, 1-1/2", TX 82
TF81T-S-200-HP Tee Fitting, 304 SS, Hi
Pres, 2", TX 92
TF81T-S-150-14-HP Tee Fitting, 316 SS, Hi
Pres, 1-1/2", TX 53
TF81T-S-200-14-HP Tee Fitting, 316 SS, Hi
Pres, 2", TX 78
2014 Industrial List V2 Page 31
January 01, 2014
Rev. 050114
TX800 Series Saddle Fittings
Model # Description
Bronze
MF82S-B-300 Saddle, Bronze, 3" 74
MF82S-B-400 Saddle, Bronze, 4" 15
PVC
MF82S-P-300 Saddle, PVC, 3" 15
MF82S-P-400 Saddle, PVC, 4" 31
MF82S-P-600 Saddle, PVC, 6" 51
MF82S-P-800 Saddle, PVC, 8" 79
O-rings only.
MF82S-P-300-16 Saddle, PVC, 3", w/
16" Pipe Stub 84
MF82S-P-400-16 Saddle, PVC, 4", w/
16" Pipe Stub 05
MF82S-P-600-16 Saddle, PVC, 6", w/
16" Pipe Stub 30
MF82S-P-800-16 Saddle, PVC, 8", w/
16" Pipe Stub 63
PVC saddles ordered with -16 option will
be calibrated for K-Factor before shipping.
Ductile Iron
MF82S-F-300 Saddle, Iron, 3" 72
MF82S-F-400 Saddle, Iron, 4" 06
MF82S-F-600 Saddle, Iron, 6" 61
MF82S-F-800 Saddle, Iron, 8" 95
2014 Industrial List V2 Page 32
January 01, 2014
Rev. 050114
TX800 Series Weld/Braze Fittings
Model # Description
Brass
MF82W-B-300 Weldolet, Brass, 3" 40
MF82W-B-400 Weldolet, Brass, 4" 40
MF82W-B-600 Weldolet, Brass, 6" 40
MF82W-B-800 Weldolet, Brass, 8" 40
Carbon Steel
MF82W-C-300 Weldolet, Carbon Steel,
3" 18
MF82W-C-400 Weldolet, Carbon Steel,
4" 18
MF82W-C-600 Weldolet, Carbon Steel,
6" 18
MF82W-C-800 Weldolet, Carbon Steel,
8" 18
MF82W-C-300-HP Weldolet, Carbon Steel, Hi
Pres, 3" 33
MF82W-C-400-HP Weldolet, Carbon Steel, Hi
Pres, 4" 33
MF82W-C-600-HP Weldolet, Carbon Steel, Hi
Pres, 6" 33
MF82W-C-800-HP Weldolet, Carbon Steel, Hi
Pres, 8" 33
Stainless Steel
MF82W-S-300 Weldolet, 316 SS, 3" 06
MF82W-S-400 Weldolet, 316 SS, 4" 06
MF82W-S-600 Weldolet, 316 SS, 6" 06
MF82W-S-800 Weldolet, 316 SS, 8" 06
MF82W-S-300-HP Weldolet, 316 SS, Hi Pres,
3" 21
MF82W-S-400-HP Weldolet, 316 SS, Hi Pres,
4" 21
TX150S Hot Tap Adj Depth Insertion Turbine
Meter, 316 SS, 3"-12" 577
TX152/252 Hot-Tap Adjustable Depth
Insertion Turbine Meter (AO55 Meter Mount)
Model # Description
TX152B Hot Tap Adj Depth Insertion Turbine
Meter, Brass, 3"-12", AO55 695
TX152S Hot Tap Adj Depth Insertion Turbine
Meter, 316 SS, 3"-12", AO55 947
TX252B Hot Tap Adj Depth Insertion Turbine
Meter, Brass, 12"- 40", AO55 956
TX114B Adj Depth Insertion Turbine Meter,
Brass, 3"-12", FT415 583
TX114S Adj Depth Insertion Turbine Meter,
316 SS, 3"-12", FT415 866
TX214B Adj Depth Insertion Turbine Meter,
Brass, 12"- 40", FT415 763
TX214S Adj Depth Insertion Turbine Meter,
316 SS, 12"- 40", FT415 988
02 Adapter Fitting, 2" NPT Threads,
Brass 6
SS 6
03 Bi-Directional 13
23 Adapter, 1-1/2" BSP Thread
Tapered, Brass 3
24 Adapter, 1-1/2" BSP Thread
Tapered, SS 7
35 Old Style Adapter, 1-1/2" NPT
Thread 03
3" X 1-1/2" 36
4" X 1-1/2" 44
6" X 1-1/2" 48
8" X 1-1/2" 78
10" X 1-1/2" 58
12" X 1-1/2" 20
14" X 1-1/2" 90
16" X 1-1/2" 55
18" X 1-1/2" 29
20" X 1-1/2" 02
22" X 1-1/2" 50
24" X 1-1/2" 95
3" X 1-1/2" 93
4" X 1-1/2" 24
TX150/250 Saddle Fittings
Model # Description
3" X 2" 36
4" X 2" 44
6" X 2" 48
8" X 2" 78
10" X 2" 58
12" X 2" 20
14" X 2" 90
16" X 2" 55
Model # Description
IP811B Fixed Depth Insertion Paddlewheel
Meter, Brass, 1/2"-3", FT420 42
IP811S Fixed Depth Insertion Paddlewheel
Meter, 316 SS, 1/2"-3", FT420 70
IP811P Fixed Depth Insertion Paddlewheel
Meter, PVC, 1/2"-3", FT420 73
IP811Y Fixed Depth Insertion Paddlewheel
Meter, Polypro, 1/2"-3", FT420 84
IP811S-HP Fixed Depth Insertion
Paddlewheel Meter, 316 SS, Hi Pres,1/2"-3",FT420 063
IP821B Fixed Depth Insertion Paddlewheel
Meter, Brass, 4"-8", FT420 68
IP821S Fixed Depth Insertion Paddlewheel
Meter, 316 SS, 4"-8", FT420 88
IP821P Fixed Depth Insertion Paddlewheel
Meter, PVC, 4"-8", FT420 90
IP821Y Fixed Depth Insertion Paddlewheel
Meter, Polypro, 4"-8", FT420 03
IP821S-HP Fixed Depth Insertion
Paddlewheel Meter, 316 SS, Hi Pres, 4"-8", FT420 063
Bronze
MF81TC-B-050 Tee Fitting, Bronze, Sweat,
1/2", IP 24
MF81TC-B-075 Tee Fitting, Bronze, Sweat,
3/4", IP 34
MF81TC-B-100 Tee Fitting, Bronze, Sweat,
1", IP 44
MF81TC-B-150 Tee Fitting, Bronze, Sweat,
1-1/2", IP 59
MF81TC-B-200 Tee Fitting, Bronze, Sweat,
2", IP 79
MF81TC-B-300 Tee Fitting, Bronze, Sweat,
3", IP 44
MF81TC-B-400 Tee Fitting, Bronze, Sweat,
4, IP 76
MF81T-B-050 Tee Fitting, Bronze,
1/2", Threaded, IP 24
MF81T-B-075 Tee Fitting, Bronze,
3/4", Threaded, IP 34
MF81T-B-100 Tee Fitting, Bronze, 1",
Threaded, IP 44
MF81T-B-150 Tee Fitting, Bronze,
1-1/2", Threaded, IP 59
MF81T-B-200 Tee Fitting, Bronze, 2",
Threaded, IP 79
MF81T-B-300 Tee Fitting, Bronze, 3",
Threaded, IP 44
MF81T-B-400 Tee Fitting, Bronze, 4",
Threaded, IP 76
PVC
MF81T-P-050 Tee Fitting, PVC, 1/2",
IP 04
MF81T-P-075 Tee Fitting, PVC, 3/4",
IP 14
MF81T-P-100 Tee Fitting, PVC, 1", IP
24
MF81T-P-150 Tee Fitting, PVC, 1-1/2",
IP 28
MF81T-P-200 Tee Fitting, PVC, 2", IP
35
MF81T-P-200-18 Tee Fitting, PVC, Flanged
Ends, 2", IP 45
Carbon Steel
MF81T-C-050 Tee Fitting, Carbon Steel,
1/2", IP 51
MF81T-C-075 Tee Fitting, Carbon Steel,
3/4", IP 51
MF81T-C-100 Tee Fitting, Carbon Steel,
1", IP 79
MF81T-C-150 Tee Fitting, Carbon Steel,
1-1/2", IP 20
MF81T-C-200 Tee Fitting, Carbon Steel,
2", IP 61
MF81T-C-200-34 Tee Fitting, Carbon Steel,
Flanged Ends, 2", IP 41
MF81T-C-050-HP Tee Fitting, Carbon Steel,
Hi Pres, 1/2", IP 66
MF81T-C-075-HP Tee Fitting, Carbon Steel,
Hi Pres, 3/4", IP 66
MF81T-C-100-HP Tee Fitting, Carbon Steel,
Hi Pres, 1", IP 94
MF81T-C-150-HP Tee Fitting, Carbon Steel,
Hi Pres, 1-1/2", IP 35
MF81T-C-200-HP Tee Fitting, Carbon Steel,
Hi Pres, 2", IP 76
MF81T-C-200-34-HP Tee Fitting, Carbon
Steel, Flanged Ends, Hi Pres, 2", IP 56
2014 Industrial List V2 Page 49
January 01, 2014
Rev. 050114
IP800 Series Tee Fittings
Model # Description
Stainless Steel
MF81T-S-050 Tee Fitting, 304 SS, 1/2",
IP 16
MF81T-S-075 Tee Fitting, 304 SS,
3/4", IP 16
MF81T-S-100 Tee Fitting, 304 SS, 1",
IP 57
MF81T-S-150 Tee Fitting, 304 SS,
1-1/2", IP 67
MF81T-S-200 Tee Fitting, 304 SS, 2",
IP 77
MF81T-S-050-14 Tee Fitting, 316 SS,
1/2", IP 52
MF81T-S-075-14 Tee Fitting, 316 SS,
3/4", IP 62
MF81T-S-100-14 Tee Fitting, 316 SS,
1", IP 18
MF81T-S-150-14 Tee Fitting, 316 SS,
1-1/2", IP 38
MF81T-S-200-14 Tee Fitting, 316 SS,
2", IP 63
MF81T-S-050-HP Tee Fitting, 304 SS, Hi
Pres, 1/2", IP 67
MF81T-S-075-HP Tee Fitting, 304 SS, Hi
Pres, 3/4", IP 77
MF81T-S-100-HP Tee Fitting, 304 SS, Hi
Pres, 1", IP 33
MF81T-S-150-HP Tee Fitting, 304 SS, Hi
Pres, 1-1/2", IP 53
MF81T-S-200-HP Tee Fitting, 304 SS, Hi
Pres, 2", IP 78
MF81T-S-050-14-HP Tee Fitting, 316 SS, Hi
Pres, 1/2", IP 67
MF81T-S-075-14-HP Tee Fitting, 316 SS, Hi
Pres, 3/4", IP 77
MF81T-S-100-14-HP Tee Fitting, 316 SS, Hi
Pres, 1", IP 33
MF81T-S-150-14-HP Tee Fitting, 316 SS, Hi
Pres, 1-1/2", IP 53
MF81T-S-200-14-HP Tee Fitting, 316 SS, Hi
Pres, 2", IP 78
MF81T-S-200-20 Tee Fitting, 304 SS,
2", Flanged Ends, IP 17
MF81T-S-200-20-HP Tee Fitting, 304
SS,Flanged Ends, Hi Pres, 2", IP 32
MF81T-S-200-14-20-HP Tee Fitting, 316 SS,
Flanged Ends, Hi Pres, 2", IP 118
IP800 Series Saddle Fittings
Model # Description
Ductile Iron
Bronze
PVC
Note: PVC saddles supplied with Buna-N
O-rings only.
16" Pipe Stub 84
16" Pipe Stub 05
16" Pipe Stub 30
16" Pipe Stub 63
2014 Industrial List V2 Page 50
January 01, 2014
Rev. 050114
IP800 Series Weld/Braze Fittings
Model # Description
Brass
Carbon Steel
3" 18
4" 18
6" 18
8" 18
Pres, 3" 33
Pres, 4" 33
Pres, 6" 33
Pres, 8" 33
Stainless Steel
IP114B Adj Depth Insertion Paddlewheel
Meter, Brass, 3"-12", FT415 94
IP114P Adj Depth Insertion Paddlewheel
Meter, PVC, 3"-12", FT415 99
IP114S Adj Depth Insertion Paddlewheel
Meter, 316 SS, 3"-12", FT415 121
IP214B Adj Depth Insertion Paddlewheel
Meter, Brass, 12"- 40", FT415 081
IP214P Adj Depth Insertion Paddlewheel
Meter, PVC, 12"- 40", FT415 59
IP214S Adj Depth Insertion Paddlewheel
Meter, 316 SS, 12"- 40", FT415 154
Model # Description
IP154B Hot Tap Adj Depth Insertion
Paddlewheel Meter, Brass, 3"-12", FT415 301
Model # Description
IP116B Adj Depth Insertion Paddlewheel
Meter, Brass, 3"-12", DL76 53
IP116P Adj Depth Insertion Paddlewheel
Meter, PVC, 3"-12", DL76 58
IP116S Adj Depth Insertion Paddlewheel
Meter, 316 SS, 3"-12", DL76 80
IP216B Adj Depth Insertion Paddlewheel
Meter, Brass, 12"- 40", DL76 40
IP156/256 Hot-Tap Adjustable Depth
Insertion Paddlewheel Meter (DL76 Meter Mount)
Model # Description
IP156B Hot Tap Adj Depth Insertion
Paddlewheel Meter, Brass, 3"-12", DL76 160
IP156P Hot Tap Adj Depth Insertion
Paddlewheel Meter, PVC, 3"-12", DL76 103
IP156S Hot Tap Adj Depth Insertion
Paddlewheel Meter, 316 SS, 3"-12", DL76 290
IP256B Hot Tap Adj Depth Insertion
Paddlewheel Meter, Brass, 12"- 40", DL76 211
IP256P Hot Tap Adj Depth Insertion
Paddlewheel Meter, PVC, 12"- 40", DL76 178
IP256S Hot Tap Adj Depth Insertion
Paddlewheel Meter, 316 SS, 12"- 40", DL76 320
01 Rotor w/ Ceramic Shaft, PVDF, Kynar? 9
Model # Description
IP158B Hot Tap Adj Depth Insertion
Paddlewheel Meter, Brass, 3"-12", PD10 63
IP158P Hot Tap Adj Depth Insertion
Paddlewheel Meter, PVC, 3"-12", PD10 06
IP158S Hot Tap Adj Depth Insertion
Paddlewheel Meter, 316 SS, 3"-12", PD10 093
IP258B Hot Tap Adj Depth Insertion
Paddlewheel Meter, Brass, 12"- 40", PD10 014
IP258P Hot Tap Adj Depth Insertion
Paddlewheel Meter, PVC, 12"- 40", PD10 81
IP258S Hot Tap Adj Depth Insertion Paddlewheel
Meter, 316 SS, 12"- 40", PD10 123
Model # Description
3" X 1-1/2" 36
4" X 1-1/2" 44
6" X 1-1/2" 48
8" X 1-1/2" 78
10" X 1-1/2" 58
12" X 1-1/2" 20
14" X 1-1/2" 90
16" X 1-1/2" 55
18" X 1-1/2" 29
20" X 1-1/2" 02
22" X 1-1/2" 50
24" X 1-1/2" 95
3" X 1-1/2" 93
4" X 1-1/2" 24
Saddle Fittings For IP150/250
Model # Description
3" X 2" 36
4" X 2" 44
6" X 2" 48
8" X 2" 78
10" X 2" 58
12" X 2" 20
14" X 2" 90
16" X 2" 55
18" X 2" 29
20" X 2" 02
22" X 2" 50
24" X 2" 95
3" X 2" 93
Model # Description
WTC100-200 In-Line Turbine Meter, Carbon
Steel, 2" Sensor Only 035
WTC101-200 In-Line Turbine Meter, Carbon
Steel, 2", FT420 505
WTC102-200 In-Line Turbine Meter, Carbon
Steel, 2", AO55 405
WTC104-200 In-Line Turbine Meter, Carbon
Steel, 2", FT415 531
34 2" Body 80
WTC100-300 In-Line Turbine Meter, Carbon
Steel, 3" Sensor Only 299
WTC101-300 In-Line Turbine Meter, Carbon
Steel, 3", FT420 769
WTC102-300 In-Line Turbine Meter, Carbon
Steel, 3", AO55 669
WTC104-300 In-Line Turbine Meter, Carbon
Steel, 3", FT415 795
WTC100-400 In-Line Turbine Meter, Carbon
Steel, 4" Sensor Only 583
WTC101-400 In-Line Turbine Meter, Carbon
Steel, 4", FT420 053
WTC102-400 In-Line Turbine Meter, Carbon
Steel, 4", AO55 953
WTP100-200 In-Line Turbine Meter, PVC,
2" Sensor Only 02
WTP101-200 In-Line Turbine Meter, PVC,
2", FT420 272
WTP102-200 In-Line Turbine Meter, PVC,
2", AO55 172
WTP104-200 In-Line Turbine Meter, PVC,
2", FT415 298
Model # Description
WTS100-200 In-Line Turbine Meter, 304 SS,
2" 655
WTS101-200 In-Line Turbine Meter, 304 SS,
2", FT420 125
WTS102-200 In-Line Turbine Meter, 304 SS,
2", AO55 025
WTS104-200 In-Line Turbine Meter, 304 SS,
2", FT415 151
14 All 316 SS 28
20 Flanged Ends 40
WTS100-300 In-Line Turbine Meter, 304 SS,
3" 250
WTS101-300 In-Line Turbine Meter, 304 SS,
3", FT420 720
WTS102-300 In-Line Turbine Meter, 304 SS,
3", AO55 620
WTS104-300 In-Line Turbine Meter, 304 SS,
3", FT415 746
14 All 316 SS 54
WTS100-400 In-Line Turbine Meter, 304 SS,
4" 670
WTS101-400 In-Line Turbine Meter, 304 SS,
4", FT420 140
WTS102-400 In-Line Turbine Meter, 304 SS,
4", AO55 040
WTS104-400 In-Line Turbine Meter, 304 SS,
4", FT415 166
14 All 316 SS 014
WTS100-600 In-Line Turbine Meter, 304 SS,
6" 634
WTS101-600 In-Line Turbine Meter, 304 SS,
6", FT420 104
WTS102-600 In-Line Turbine Meter, 304 SS,
6", AO55 004
WTS104-600 In-Line Turbine Meter, 304 SS,
6", FT415 130
WMP101-200 Plastic Bodied In-Line
Magmeter, DC Powered, 2" 35
WMP101-300 Plastic Bodied In-Line
Magmeter, DC Powered, 3" 128
WMP104-100 Plastic Bodied In-Line
Magmeter, Battery Powered, 1" 65
WMP104-200 Plastic Bodied In-Line
Magmeter, Battery Powered, 2" 36
WMP104-300 Plastic Bodied In-Line
Magmeter, Battery Powered, 3" 96
WMX101-400 Flanged In-Line Magmeter, 2 AA
Backup Batteries, 4" 962
WMX101-600 Flanged In-Line Magmeter, 2 AA
Backup Batteries, 6" 113
WMX101-800 Flanged In-Line Magmeter, 2 AA
Backup Batteries, 8" 345
WMX101-1000 Flanged In-Line Magmeter, 2 AA
Backup Batteries, 10" 699
WMX101-1200 Flanged In-Line Magmeter, 2 AA
Backup Batteries, 12" 900
WMX104-400 Flanged In-Line Magmeter, 2 DD
Cell Batteries, 4" 862
WMX104-600 Flanged In-Line Magmeter, 2 DD
Cell Batteries, 6" 013
WMX104-800 Flanged In-Line Magmeter, 2 DD
Cell Batteries, 8" 245
WMX104-1000 Flanged In-Line Magmeter, 2 DD
Cell Batteries, 10" 599
WMX104-1200 Flanged In-Line Magmeter, 2 DD
Cell Batteries, 12" 800
Model # Description
AG2000-168-300 Flanged In-Line Magmeter, 2
AA Backup Batteries, IP68 3" 137
AG2000-168-400 Flanged In-Line Magmeter, 2
AA Backup Batteries, IP68, 4" 378
AG2000-168-600 Flanged In-Line Magmeter, 2
AA Backup Batteries, IP68, 6" 630
AG2000-168-800 Flanged In-Line Magmeter, 2
AA Backup Batteries, IP68, 8" 858
AG2000-168-1000 Flanged In-Line Magmeter,
2 AA Backup Batteries, IP68, 10" 238
DD Cell Batteries, IP68 3" 961
Rate/Total unit Selection)
Ordering Example WMX101-168 NO
CABLE:
WMX101-400-168-GPM/CFT
Ordering Example WMX101-168 W/CABLE:
WMX101-400-168-GPM/CFT-PxX
2014 Industrial List V2 Page 73
January 01, 2014
MJ Bronze Body Pulse Meters (COLD for
temperature 105°F and below)
Model # Description
MJE-075 Cold-Water, Solid-state Pickup,
3/4" 65
MJE-100 Cold-Water, Solid-state Pickup,
1" 31
MJE-150 Cold-Water, Solid-state Pickup,
1-1/2" 24
MJE-200 Cold-Water, Solid-state Pickup,
2" 32
MJR-075 Cold-Water, Reed Switch (Dry
Contact), 3/4" 41
MJR-100 Cold-Water, Reed Switch (Dry
Contact), 1" 08
MJR-150 Cold-Water, Reed Switch (Dry
Contact), 1-1/2" 77
MJR-200 Cold-Water, Reed Switch (Dry
Contact), 2" 09
MJT-075 Cold Water, Mechanical Register
Only, 3/4" 05
MJT-100 Cold Water, Mechanical Register
Only, 1" 71
MJT-150 Cold Water, Mechanical Register
Only, 1-1/2" 43
MJT-200 Cold Water, Mechanical Register
Only, 2" 70
Note: s reflect standard pulse rates
expressed in gallons.
There is an additional charge of 0 if you
need indication in Cubic Feet or Cubic Meters.
Available pulse rates are 20, 10, 4, 2, 1
Pulses/Gallon, and 1, 5, 10, 50, 100 Gallons/Pulse.
Specify MJR/MJE pulse rate at time of
order.
Consult Spec sheet for corresponding meter
sizes, and CF and CM pulse rates.
07 Seametrics Control Connector 0
106 Roytronics? Series-A Pump 5 Pin
Connector 0
Note: Options not available with MJT
MJH Bronze Body Pulse Meters (HOT for
temperatures 194°F and below)
Model # Description
MJHE-075 Hot-Water, Solid-state Pickup,
3/4" 27
MJHE-100 Hot-Water, Solid-state Pickup,
1" 17
MJHE-150 Hot-Water, Solid-state Pickup,
1-1/2" 53
MJHE-200 Hot-Water, Solid-state Pickup,
2" 20
MJHR-075 Hot-Water, Reed Switch (Dry
Contact), 3/4" 15
MJHR-100 Hot-Water, Reed Switch (Dry
Contact), 1" 00
MJHR-150 Hot-Water, Reed Switch (Dry
Contact), 1-1/2" 18
MJHR-200 Hot-Water, Reed Switch (Dry
Contact), 2" 77
MJHT-075 Hot-Water, Mechanical Register
Only, 3/4" 45
MJHT-100 Hot-Water, Mechanical Register
Only, 1" 35
MJHT-150 Hot-Water, Mechanical Register
Only, 1-1/2" 55
MJHT-200 Hot-Water, Mechanical Register
Only, 2" 24
Model # Description
MJNE-075 Cold-Water, Solid-state Pickup,
3/4" NSF 82
MJNE-100 Cold-Water, Solid-state Pickup,
1" NSF 84
MJNE-150 Cold-Water, Solid-state Pickup,
1-1/2" NSF 43
MJNE-200 Cold-Water, Solid-state Pickup,
2" NSF 86
MJNR-075 Cold Water Reed Switch Dry
Contact, 3/4" NSF 54
MJNR-100 Cold Water Reed Switch Dry
Contact, 1" NSF 55
MJNR-150 Cold Water Reed Switch Dry
Contact, 1-1/2" NSF 80
MJNR-200 Cold Water Reed Switch Dry
Contact, 2" NSF 53
MJNT-075 Cold-Water Mechanical Register
Only, 3/4" NSF 16
MJNT-100 Cold-Water Mechanical Register
Only, 1" NSF 10
MJNT-150 Cold-Water Mechanical Register
Only, 1-1/2" NSF 51
103318 Screw Kit, 1/4-20 x 0.625", SH,
SS 2
100264 O-Ring, EPDM, Black 4
100973 O-Ring, Viton? Teflon Coated 3
100556 Rotor Repair Kit, Kynar? Silicone
Carbide, 6 Magnet 85
2014 Industrial List V2 Page 86
January 01, 2014
Rev. 050114
SPT Single Jet Low Flow Meters
Model # Description
SPT-038 Single Jet Low Flow, PTFE, PTFE
Cover, 3/8" 20
SPT-038-70 Single Jet Low Flow, PTFE, PTFE
Cover, SAE Ports, 3/8" 79
SPT-038-117 Single Jet Low Flow, PTFE,
PTFE Cover, BSP Threads, 3/8" 74
SPT-050 Single Jet Low Flow, PTFE, PTFE
Cover, 1/2" 20
SPT-050-70 Single Jet Low Flow, PTFE, PTFE
Cover, SAE Ports, 1/2" 79
SPT-050-117 Single Jet Low Flow, PTFE,
PTFE Cover, BSP Threads, 1/2" 74
SPX Single Jet Low Flow Meters
Model # Description
SPX-038 Single Jet Low Flow, Acrylic
Cover, Polypro, 3/8" 95
SPX-038-70 Single Jet Low Flow, Acrylic
Cover, SAE Ports, Polypro, 3/8" 54
SPX-038-116 Single Jet Low Flow, Acrylic
Cover, BSP Threads, Polypro, 3/8" 49
SPX-050 Single Jet Low Flow, Acrylic
Cover, Polypro, 1/2" 95
SPX-050-70 Single Jet Low Flow, Acrylic
Cover, SAE Ports, Polypro, 1/2" 54
SPX-050-116 Single Jet Low Flow, Acrylic
Cover, BSP Threads, Polypro, 1/2" 49
SPX-075 Single Jet Low Flow, Acrylic
Cover, Polypro, 3/4" 95
SPX-075-70 Single Jet Low Flow, Acrylic
Cover, SAE Ports, Polypro, 3/4" 54
SPX-075-116 Single Jet Low Flow, Acrylic
Cover, BSP Threads, Polypro, 3/4" 49
SPX-100 Single Jet Low Flow, Acrylic
Cover, Polypro, 1" 95
SPX-100-70 Single Jet Low Flow, Acrylic
Cover, SAE Ports, Polypro, 1" 54
SPX-100-116 Single Jet Low Flow, Acrylic
Cover, BSP Threads, Polypro, 1" 49
PE102-038
101422 Cable, PE Output, 8 Pin, 6 Meter,
Shield 3
103254 PE102-038 PVDF Adapter Kit,
1/4" MNPT, EPDM O-Ring (101688 & 101684) 26
103255 PE102-038 PVDF Adapter Kit,
1/4" MNPT Viton? O-Ring (101688 & 101685) 34
103256 PE102-038 PP Adapter Kit, 1/4"
MNPT EPDM O-Ring (103014 & 101684) 4
103257 PE102-038 PP Adapter Kit, 1/4"
MNPT Viton? O-Ring (103014 & 101685) 2
103258 PE102-038 PVDF Adapter Kit,
3/8" MNPT EPDM O-Ring (101672 & 101684) 26
103259 PE102-038 PVDF Adapter Kit,
3/8" MNPT Viton? O-Ring (101672 & 101685) 34
103260 PE102-038 PP Adapter Kit, 3/8"
MNPT EPDM O-Ring (103013 & 101684) 4
103261 PE102-038 PP Adapter Kit, 3/8"
MNPT Viton? O-Ring (103013 & 101685) 2
103262 PE102-038 PVDF Adapter Kit,
1/2" MNPT EPDM O-Ring (101940 & 101684) 4
103263 PE102-038 PVDF Adapter Kit,
1/2" MNPT Viton? O-Ring (101940 & 101685) 2
103264 PE102-038 PVDF Adapter Kit,
1/2" FNPT EPDM O-Ring (102180 & 101684) 26
103265 PE102-038 PVDF Adapter Kit,
1/2" FNPT Viton? O-Ring (102180 & 101685) 34
103266 PE102-038 PP Adapter Kit, 1/2"
FNPT EPDM O-Ring (103011 & 101684) 4
103267 PE102-038 PP Adapter Kit, 1/2"
FNPT Viton? O-Ring (103011 & 101685) 2
101689 Nut, Flaretek, 0.375" (2
Required) 8
101690 Tool, Flaretek 0.375" 94
103320 O-Ring Kit, EPDM, 70-Duro, 2-205 8
103321 O-Ring Kit, Viton, Brown, 75-Duro,
2-205 6
PE102-075
Shield 3
103270 PE102-075 PVDF Adapter Kit,
1/2" MNPT EPDM O-Ring (101396 & 100996) 26
103271 PE102-075 PVDF Adapter Kit,
1/2" MNPT Viton? O-Ring (101396 & 101290) 34
103272 PE102-075 PP Adapter Kit, 1/2"
MNPT EPDM O-Ring (103016 & 100996) 4
103273 PE102-075 PP Adapter Kit, 1/2"
MNPT Viton? O-Ring (103016 & 101290) 2
103274 PE102-075 PVDF Adapter Kit,
1/2" FNPT EPDM O-Ring (102181 & 100996) 26
103275 PE102-075 PVDF Adapter Kit,
1/2" FNPT Viton? O-Ring (102181 &101290) 34
103276 PE102-075 PP Adapter Kit, 1/2"
FNPT EPDM O-Ring (103012 &100996) 4
103277 PE102-075 PP Adapter Kit, 1/2"
FNPT Viton? O-Ring (103012 & 101290) 2
103278 PE102-075 PVDF Adapter Kit,
3/4" MNPT EPDM O-Ring (101252 & 100996) 26
103279 PE102-075 PVDF Adapter Kit,
3/4" MNPT Viton? O-Ring (101252 & 101290) 34
103280 PE102-075 PP Adapter Kit, 3/4"
MNPT EPDM O-Ring (103015 & 100996)) 4
103281 PE102-075 PP Adapter Kit, 3/4"
MNPT Viton? O-Ring (103015 & 101290) 2
101284 Nut, Flaretek , 3/4" (2
Required) 8
101370 Register, MJH CF, 1-1/2" 80
101371 Register, MJH CF, 2" 80
101372 Register, MJH, GAL, 3/4" 79
101373 Register, MJH, GAL, 1" 79
101374 Register, MJH, GAL, 1-1/2" 80
101375 Register, MJH, GAL, 2" 80
101379 Strainer, Internal, MJH, 3/4"
79
101380 Strainer, Internal, MJH, 1" 79
101381 Strainer, Internal, MJH,
1-1/2" and 2" 80
101382 Strainer, Tubular, MJH, 3/4"
79
101383 Strainer, Tubular, MJH, 1" 79
2014 Industrial List V2 Page 99
January 01, 2014
Rev. 050114
101384 Strainer, Tubular, MJH, 1-1/2"
80
101385 Strainer, Tubular, MJH, 2" 80
101442 Insert Assy, WTC, 3"-8"
67
101443 Flange, Blanking, Carbon Steel,
3"-8" 67
101446 Insert Assy, WTC/WTS 2" 67
101492 Cordset, 5 Pin, 6 Meter,
Power/Output Cable for WMP101 70
101516 Lid & Hinge Pin Assy, WJ Series
76
101594 Replacement Batteries, WMP, 2
C-Cell (WMP104 only) 70
101621 Equalization Cable, AG/WMX-400 74
101622 Equalization Cable, AG/WMX-600/800
74
101623 Equalization Cable,
AG/WMX-1000/1200 74
101850 Cord Grip, 1/2" NPT 7, 8, 18,
25, 34, 42, 43, 52, 60, 61,
67 101862 Rotor Assy, Kynar? w/ Carbide
Shaft, TX 34, 42, 43, 67
101868 Housing, Rotor, Brass, TX 42, 43
101869 Housing, Rotor, 316 SS, TX 42, 43
101912 Rotor Repair Kit, TX, Kynar?,
Carbide Shaft (Rotor, Bearings, Shaft) 34, 43, 67
101949 Hinged Display Cover 70, 74
102073 Kit, 3" WMP FNPT Flange Clamps
70
102157 Grounding Ring, AG/WMX-300 74
102203 Kit, 2", WMP BSP Flange Clamps
(Male Thread) 70
102204 Kit, 3", WMP BSP Flange Clamps
(Male Thread) 70
102228 O-Ring, Buna-N, 70-Duro, MJ,
1-1/2" and 2" 78, 79, 82, 83
101684)
89
101685)
89
101684)
89
101685)
89
101684)
89
101685)
89
101684)
89
101685)
89
101684)
89
101685)
89
101684)
89
100996)
89
101290)
89
100996)
89
101290)
89
100996)
89
&101290)
89
&100996)
89
101290)
89
100996)
89
103308 Kit, Capscrew 10-32 x 2",
Socket Head, SS 87
103309 Kit, 1/4-20 x 1" M/S, SS, WT
67
103310 Kit, Nut 10-32 Hex, SS 87
103311 Kit, Gasket Coupling Fiber,
0.625" 86
103312 Kit, Shaft Assembly, Ceramic, WT/TX
34, 42, 43, 67
103313 Bearing Assembly Kit, SPX/SPT/SES
86, 87
103315 Bearing Assembly Kit, IP/TX, Kynar
103316 Gasket Kit, Coupling, Fiber, SEB,
3/4" 86
103317 Shaft Assy Kit, Carbide, WT 3"
to 8" 67
SH, SS 86
103324 Strain Relief Kit, .069" to
.25" Cable 7
103325 Coupling Assy, Brass, SEB-050 86
2014 Industrial List V2 Page 100
January 01, 2014
Rev. 050114
103326 Coupling Assy, Brass, SEB-075 86
DC100 Field-Installed Power/Output Cable,
30M (100 ft) 74
DC30 Field-Installed Power/Output Cable,
6m (20 ft) 74
DC30S Field-Installed Power/Output Cable,
6m (20 ft) 74
DC35 Field-Installed Power/Output Cable,
15m (50 ft) 74
DC35S Field-Installed Power/Output Cable,
15m (50 ft) 74
1", EX 15
1-1/2", EX 15
2", EX 15
3", EX 15
4", EX 15
1", EX 15
1-1/2", EX 15
2", EX 15
Flanged Ends, 2", EX 15
1", EX 15
1-1/2", EX 15
2", EX 15
3", EX 15
4", EX 15
15
EX 15
15
Ends, 2",EX 15
1",EX 15
1",EX 15
1-1/2", EX 15
1-1/2", EX 15
EX 15
2", EX 15
EF82S-B-300 Saddle, Bronze, 3", EX 16
EF82S-B-400 Saddle, Bronze, 4", EX 16
EF82S-F-1000 Saddle, Iron, 10", EX 16
EF82S-F-1200 Saddle, Iron, 12", EX 16
EF82S-F-300 Saddle, Iron, 3", EX 16
EF82S-F-400 Saddle, Iron, 4", EX 16
EF82S-F-600 Saddle, Iron, 6", EX 16
EF82S-F-800 Saddle, Iron, 8", EX 16
EF82S-P-300 Saddle, PVC, 3", EX 16
16" Pipe Stub, EX 16
EF82S-P-400 Saddle, PVC, 4", EX 16
EF82S-P-600 Saddle, PVC, 6", EX 16
EF82S-P-800 Saddle, PVC, 8", EX 16
17
17
17
17
17
17
10", EX 17
2014 Industrial List V2 Page 101
January 01, 2014
Rev. 050114
12", EX 17
3", EX 17
4", EX 17
6", EX 17
8", EX 17
EX 17
EF82W-S-1200 Weldolet, 316 SS, 12",
EX 17
17
17
17
17
3" X 1-1/2" 24, 41, 59
3" X 2" 24, 41, 59
4" X 1-1/2" 24, 41, 59
4" X 2" 24, 41, 59
10" X 1-1/2" 24, 41, 59
10" X 2" 24, 41, 59
12" X 1-1/2" 24, 41, 59
12" X 2" 24, 41, 59
14" X 1-1/2" 24, 41, 59
14" X 2" 24, 41, 59
16" X 1-1/2" 24, 41, 59
16" X 2" 24, 41, 59
18" X 1-1/2" 24, 41, 59
18" X 2" 24, 41, 59
20" X 1-1/2" 24, 41, 59
20" X 2" 24, 41, 59
22" X 1-1/2" 24, 41, 59
22" X 2" 24, 41, 59
24" X 1-1/2" 24, 41, 59
24" X 2" 24, 41, 59
3" X 2" 24, 41, 59
4" X 2" 24, 41, 59
6" X 2" 24, 41, 59
8" X 2" 24, 41, 59
1/2", Threaded, IP 49
3/4", Threaded, IP 49
Threaded, IP 49
1-1/2", Threaded, IP 49
Threaded, IP 49
Threaded, IP 49
Threaded, IP 49
1/2", IP 49
Hi Pres, 1/2", IP 49
3/4", IP 49
Hi Pres, 3/4", IP 49
1", IP 49
Hi Pres, 1", IP 49
1-1/2", IP 49
Hi Pres, 1-1/2", IP 49
2014 Industrial List V2 Page 102
January 01, 2014
Rev. 050114
2", IP 49
Flanged Ends, 2", IP 49
Hi Pres, 2", IP 49
1/2", IP 49
3/4", IP 49
1", IP 49
1-1/2", IP 49
2", IP 49
3", IP 49
4, IP 49
IP 49
IP 49
49
IP 49
49
Ends, 2", IP 49
1/2", IP 50
1/2", IP 50
Pres, 1/2", IP 50
Pres, 1/2", IP 50
3/4", IP 50
3/4", IP 50
Pres, 3/4", IP 50
Pres, 3/4", IP 50
IP 50
1", IP 50
Pres, 1", IP 50
Pres, 1", IP 50
1-1/2", IP 50
1-1/2", IP 50
Pres, 1-1/2", IP 50
Pres, 1-1/2", IP 50
IP 50
2", IP 50
Pres, 2", IP 50
2", Flanged Ends, IP 50
Pres, 2", IP 50
MF82S-B-300 Saddle, Bronze, 3" 32, 50
MF82S-B-400 Saddle, Bronze, 4" 32, 50
MF82S-F-300 Saddle, Iron, 3" 32, 50
MF82S-F-400 Saddle, Iron, 4" 32, 50
MF82S-F-600 Saddle, Iron, 6" 32, 50
MF82S-F-800 Saddle, Iron, 8" 32, 50
MF82S-P-300 Saddle, PVC, 3" 32, 50
16" Pipe Stub 32, 50
MF82S-P-400 Saddle, PVC, 4" 32, 50
MF82S-P-600 Saddle, PVC, 6" 32, 50
MF82S-P-800 Saddle, PVC, 8" 32, 50
MF82W-B-300 Weldolet, Brass, 3" 33,
51
MF82W-B-400 Weldolet, Brass, 4" 33,
51
MF82W-B-600 Weldolet, Brass, 6" 33,
51
2014 Industrial List V2 Page 103
January 01, 2014
Rev. 050114
MF82W-B-800 Weldolet, Brass, 8" 33,
51
3" 33, 51
Pres, 3" 33, 51
4" 33, 51
Pres, 4" 33, 51
6" 33, 51
Pres, 6" 33, 51
8" 33, 51
Pres, 8" 33, 51
MF82W-S-300 Weldolet, 316 SS, 3" 33,
51
3" 33, 51
MF82W-S-400 Weldolet, 316 SS, 4" 33,
51
4" 33, 51
MF82W-S-600 Weldolet, 316 SS, 6" 33,
51
MF82W-S-600-HP Weldolet, 316 SS, Hi Pres,
6" 33, 51
MF82W-S-800 Weldolet, 316 SS, 8" 33,
51
MF82W-S-800-HP Weldolet, 316 SS, Hi Pres,
8" 33, 51
1-1/2", TX 31
2", TX 31
3", TX 31
4", TX 31
1-1/2", TX 31
Hi Pres, 1-1/2", TX 31
2", TX 31
Hi Pres, 2", TX 31
1-1/2", TX 31
2", TX 31
3", TX 31
4", TX 31
TX 31
31
1-1/2", TX 31
1-1/2", TX 31
Pres, 1-1/2", TX 31
Pres, 1-1/2", TX 31
TX 31
2", TX 31
Pres, 2", TX 31![](http://www.cechina.cn/UpLoad/CompanyFile/2022/9/12/264faf95-9649-43e1-b43e-40e8fadc404c.jpg)
Pres, 2", TX 31
