上海航欧销上海航欧销售SENECA传感器SENECA电流传感器、SENECA开关SENECA编码器SENECA信号隔离器、SENECA适配器SENECA I/ O模块、SENECA通信通讯模块、SENECA面板显示仪
A-169DV12 A-169DV14 A-169YAGI A-DIN-T201
A-DIR-10-869 A-DIR-6-869 A-GPS A-GSM A-GSM-DIR-5M A-GSM-OMNIDIR
A-GSM-OMNIDIR-10 A-GSM-QUAD ANT-LINK1-MG A-STIL A-STIL-D B BATT-S C
CE-RJ45-RJ45-C CE-RJ45-RJ45-R CS-DB9F-CFV10 CS-DB9F-CLAMP CS-DB9F-DB25M
CS-DB9F-DB9F CS-DB9F-TIP CS-DB9F-TIP-V CS-DB9M-DB9F CS-DB9M-DB9M
CS-DB9M-MEF-1012 CS-DB9M-MEF-PH CS-DB9M-TIP CS-DB9M-TIP-V CS-JACK-DB9F
CS-JACK-JACK CS-RJ10-AMP CS-RJ10-DB25M-1 CS-RJ10-DB25M-2 CS-RJ10-DB9F
CS-RJ10-DB9M CS-RJ10-TIP CS-TPW-TIP CS-TPW-TPW CU-A-MICROB CU-A-MINIB-1
CU-A-MINIB-2 CU-A-MICRO-OTG D DL169-RS232 DL169-RS232-Y DL-COUNT DL-MA DL-MV
DL-V DOC-CENE-1510-0-ITA DOC-CFS-1603-IE SENECA适配器DOC-CLIS-1507-0-ITA
DOC-CSIN-1603-0-ITA DOC-PCAT-1511-0-ENG DOC-PCAT-1511-0-DEU DOC-PCAT-1602-0-SPA
DOC-POVE-1410-0-SPA DOC-POVE-1411-0-ENG DOC-POVE-1411-0-RUS DOC-POVE-1411-0-TED
DOC-PCAT-1511-0-DEU DR-2 DR-4 DR-8 DR-16 DR-32 DR-64 DR-2-PLUS DR-4-PLUS
DR-8-PLUS DR-16-PLUS DR-32-PLUS DR-64-PLUS E EASY RELAY EASY-USB F FD01
FH190-24 FLEX-DIN K K107A K107B K107USB K109LV K109PT K109PT1000 K109PT-HPC
K109S K109TC K109UI K111 K111-C K112 K120RTD K120RTD-C K121 K121-C K400CL
K400CL-10 K-BUS K-SUPPLY KIT-USB L M MSD MY-0 MY-PT-150-3 MY-PT-250-2
MY-PT-150-3R MY-PT-KIT MY-TC-250-3 MY-TC-250-1.5 MY-TC-AC MY-TC-KIT MY-UT
MY2B-0-0-M-B MY2B-0-0-M-G MY2-KITIP66 MY2B-R-0-M-B MY2B-R-0-M-G MY2B-0-0-M-B-4X
MY2B-0-0-M-G-4X MY2B-R-0-M-B-4X MY2B-R-0-M-G-4X MY2G-0-0-M-B MY2G-0-0-M-G
MY2G-R-0-M-B MY2G-R-0-M-G MY2G-0-0-M-B-4X MY2G-0-0-M-G-4X MY2G-R-0-M-B-4X
MY2G-R-0-M-G-4X MY2S-0-0-M-B MY2S-0-0-M-G MY2S-R-0-M-B MY2S-R-0-M-G
MY2S-0-0-M-B-4X MY2S-0-0-M-G-4X MY2S-R-0-M-B-4X MY2S-R-0-M-G-4X O OPC-SERVER
OPC-SERVER-IO-1 OPC-SERVER-IO-2 OPC-SERVER-IO-3 OPC-SERVER-MB-1 OPC-SERVER-MB-2
OPC-SERVER-MB-3 P POZZ-100 POZZ-150 POZZ-200 POZZ-250 POZZ-300 POZZ-50
PT-150-3-M12 PT-250-2-M12 PT-150-3R-M12 PT100-100 PT100-100-MA PT100-150
PT100-150-MA PT100-200 PT100-200-MA PT100-250 PT100-250-MA PT100-300
PT100-300-MA PT100-50 PT100-50-MA PT100-A PT100-A-MA PT100-SOLAR PT100-SOLAR-MA
R RC-V250-100 RC-V400-050 RC-V400-100 RC-V500-100 RC150-025-100-3M
RC150-040-100-3M RC150-060-100-3M RM169-169DV12 RM169-169YAGI RM169-169DV14
RM169 RTURADIO-169 RTURADIO-169DV14 RTURADIO-169DV12 RTURADIO-169YAGI S
S100S-1-ST S100S-3-ST S102-1-ST S104-1-ST S105CS1-B S105CS1-C S105TCS-1
S105TCS-2 S105TCS-3 S107P S107MBU S107USB S108 S109PT-1-ST S109REG-1-ST
S109REG-1-X7 S109S-1-ST S111-1-ST S112A-1-ST S112D-1-ST S112M-1-ST S112M-23-ST
S113S-1-ST S113T-1-ST S117P1 S170-1-ST S190-1-ST S2000-1-ST S2000-23-ST
S200-1-ST S200D-1-ST S200G S200REG-16 S200REG-24 S201D-1-ST S201DP-1-ST
S203RC-D S203T S203TA S203TA-D S20ADP S20ADP-CM S20ADP-CM-S S20ADP-IP65
S20N1-1-ST S20N1-23-ST S20N1EX-1-ST S20N1EX-23-ST S20N1IP65-1-ST
S20N1IP65-23-ST S20N1-KIT-1-ST S20N1-KIT-23-ST S21N1-1-ST S21N1-23-ST
S21N1EX-1-ST S21N1EX-23-ST S21N1IP65-1-ST S21N1IP65-23-ST S232-FO-MONO-SL
S232-FO-MONO-DL S232-FO-MULTI-SL S232-FO-MULTI-DL S301-1-R S301-1-R-AOC-S
S301-1-R-AR-S S301-23-R S301-23-R-AOC-S S301-23-R-AR-S S301B-1-R
S301B-1-R-AOC-S S301B-1-R-AR-S S301B-23-R S301B-23-R-AOC-S S301B-23-R-AR-S
S311A-11-H S311A-11-H-O S311A-11-L S311A-11-L-O S311A-4-H S311A-4-H-O S311A-4-L
S311A-4-L-O S311A-6-H S311A-6-H-O S311A-6-L S311A-6-L-O S311A-8-H S311A-8-H-O
S311A-8-L S311A-8-L-O S311AK-4-L S311AK-4-L-IP66 S311AK-4-L-IP66D S311D-11-H
S311D-11-H-O S311D-11-L S311D-11-L-O S311D-4-H S311D-4-H-O S311D-4-L
S311D-4-L-O S311D-6-H S311D-6-H-O S311D-6-L S311D-6-L-O S311D-8-H S311D-8-H-O
S311D-8-L S311D-8-L-O S311OPZ S311-T S312A-4-H-4R S312A-4-L-4R S315 S315-IP66
S315-IP66D S320A-1-ST S320A-1-ST-R S320A-23-ST S320A-23-ST-R S400CL S400HV
S400LV S400HV-2 S400HV-2-RIC-SL S400HV-2-RIC-SN S400LV-1 S400LV-1-RIC-SL
S400CL-1 S400CL-1-15 S400CL-1-P5 S400NET S400NET-RIC-SL S400ETH-DSK S401-L
S485-FO-MONO-DL S485-FO-MULTI-DL S485-FO-MONO-SL S485-FO-MULTI-SL S50-1-ST
S50-3-ST S500-MOD S500-MBU S500-ETH S501-32-0 S501-32-MBU-MID S502-80-MID
S502-80-R S504C-6-MOD-MID S504C-6-MBU-MID S504C-6-ETH-MID S504C-80-MOD-MID
S504C-80-MBU-MID S504C-80-ETH-MID S534-6-MID S534-80-MID S604B-6-MOD
S604B-6-ETH S604B-80-MOD S604B-80-ETH S604E-6-MOD S604E-6-ETH S604E-80-ETH
S604E-ROG-MOD-30 S604E-ROG-MOD-45 S604E-ROG-MOD-70 S604E-ROG-ETH-30
S604E-ROG-ETH-45 S604E-ROG-ETH-70 S6001-PC S6001-RTU S6001-RTU-E S711B6MOD
S711E6MOD S711E6ETH S711EROGETH45 S-DIN SCAN-FO-MONO-SL SCAN-FO-MONO-DL
SCAN-FO-MULTI-SL SCAN-FO-MULTI-DL SETH-FO-MONO-SL SETH-FO-MONO-DL
SETH-FO-MULTI-SL SETH-FO-MULTI-DL SG-EQ4 SG-EQ4-BOXPG7 SOFT-EDUC SOFT-OTLM
S-TOOL STRATON-D-USB STRATON-IDE256 STRATON-IDE512 STRATON-IDEUN STRATON-IEC-E1
STRATON-IEC-E2 STRATON-IEC-E3 STRATON-IEC-E4 STRATON-IEC-E5 STRATON-IEC-EF T
T120 T120-C T121 T121-C T201 T201DC T201DC100 T201DCH T201DCH100 T201DCH300
T201DCH50-LP T201DCH100-LP T201DCH300-LP TA100 TA15 TA25 TCK-250-3-M12 TCK-250-1.5-M12
TCK-W-1000-M12 TCK-AC-M12 TEST-4-PK TEST-4-R TEST-4-T TEST-4 U USB-SW-KEY
UT-M12 V VISUAL1 VISUAL2 VISUAL3 VISUAL4 VPN BOX Z Z102 Z104 Z107 Z109PT2-1
Z109REG Z109REG-BP Z109REG2-1 Z109REG2-H Z109S Z109S-DI Z109TC2-1 Z109UI2-1
Z-10-D-IN Z-10-D-OUT Z110D Z110S Z111 Z112A Z112D Z113-1 Z113D Z113S Z113T
Z170REG-1 Z190 Z201 Z201-H Z202 Z202-H Z202-LP Z203-1 Z204-1 Z-4DI-2AI-2DO
Z-3AO Z-4AI Z-4AI-D Z-4RTD2 Z-4TC Z-4TC-D Z-8AI Z-8R-10A Z-8TC Z-AIR
ZC-16DI-8DO ZC-24DI ZC-24DO ZC-3AO ZC-4RTD ZC-8AI ZC-8TC Z-CALC ZC-SG Z-DAQ-PID
Z-D-IN Z-D-IO Z-D-OUT ZE-2AI ZE-4DI-2AI-2DO Z-FLOWCOMPUTER Z-GPRS3 Z-KEY-0
Z-LINK1-NM Z-LOGGER3 Z-MINIRTU Z-MODEM Z-MODEM-3G Z-PASS1-0 Z-PASS2-A Z-PASS2-B
Z-PASS2-S-A Z-PASS2-S-B Z-PASS2-S-A-E Z-PASS2-S-B-E Z-PC-DIN1-35 Z-PC-DIN2-17.5
Z-PC-DIN4-35 Z-PC-DIN8-17.5 Z-PC-DINAL1-35 Z-PC-DINAL2-17.5 Z-PC-DINAL2-52.5
Z-POWER-115-15VA Z-POWER-230-15VA Z-POWER-230-25VA Z-SG Z-SUPPLY Z-TWS11
Z-TWS4-L-0 Z-TWS4-L-K Z-TWS4-S-0 Z-TWS4-S-K Z-TWS4-E-0 Z-TWS4-E-K Z-TWS5 上海航欧机电设备有限公司成立于2006年,专业从事进口机电设备、仪器仪表等备品备件的销售,是经营世界各地进口设备机电配件的企业。上海航欧公司与众多品牌电子元件供应商建立有良好的合作关系,在欧美、日本等地形成了稳定的供应网络,良好的供应商关系和多年的行业经验,使我们在价格及货期上有优势。经销产品供应的行业涉及冶金、钢铁、石化、能源、航天、集装箱码头、汽车、水利、造纸、电厂、纺织、注塑、橡胶、食品包装等。我们热忱地希望尽我们的努力,力争优惠的产品价格,供货周期以及服务质量,能够为您解决进口备件方面的问题。进口产品主要有:传感器,测速电机,接近开关,电子尺,编码器,控制器、分析仪,光纤,光栅,插装阀,电缆,拖链,分配器,马达,减速机,继电器、缓冲器和进口五金等
02041-108015 现货查询
02041-216015 现货查询
020AA 现货查询
020E01 现货查询
020E10 现货查询
020G 现货查询
020GE20 现货查询
020LMV 现货查询
020SCBD 现货查询
020SM 现货查询
021045 现货查询
0212101-0000-05 现货查询
02150-10 现货查询
02150-20
现货查询
021901159 现货查询
021901160 现货查询
021901161 现货查询
021901162 现货查询
0230-06984 0220-61927-261 60/1 现货查询
0223RF JG/#65211 现货查询
023-LW180-038 现货查询
024-34980-203 024-34980-003 现货查询
5508223024-34980-201 现货查询
0240
D 010 ON 0240 D 010 BN4HC 现货查询
02409022S31 现货查询
0241 现货查询
024298 现货查询
024299 现货查询
863999024G00098-001 现货查询
025-30440-000 NEW NO.025-47672-000 现货查询
025-38177-000 现货查询
12V0258104002 现货查询
025AA 现货查询
025ACS 现货查询
440497026Z41943-000 现货查询
027-22071-0
现货查询
02ZAG110035PD 现货查询
02ZCG25N438D 现货查询
03.06.953 现货查询
03.11.086 现货查询
03001-08 现货查询
03001-205 现货查询
0301500003 现货查询
0301500004 现货查询
0301-41654-10301A 0......10bar 现货查询
03031-10 现货查询
03073-08 现货查询
03073-10 现货查询
03089-001105 现货查询
03089-3410 现货查询
03089-5206 现货查询
03089-5308 现货查询
03090-4308
现货查询
03092-1308 现货查询
03092-4206 现货查询
030F1AU 现货查询
030FA 现货查询
030FAP 现货查询
030FCP 现货查询
030RFFNFA 现货查询
0310-4005-0408 现货查询
03120-16 现货查询
03153-20020 现货查询
03155-20 现货查询
03182-010 现货查询
03182-012 现货查询
031SA4414000061 现货查询
03230017 GT44 现货查询
0324000ZHB14 现货查询
0330
D 020 ON 0330 D 020 BN4HC 现货查询
1253086 0330D003BH4HC0330D003ON 现货查询
0330D010BH4HC 0330D010BH3HC 现货查询
0330D025W/HC 现货查询
0330R0200N 0330R020BN4HC 现货查询
034PNX0120-XX-5808X 现货查询
035-071-01 现货查询
04-1010-55 现货查询
04-1060-51 现货查询
04.02727.0009 现货查询
040AA 现货查询
040AO 现货查询
040C0909-7P1C 现货查询
040C0920-7EP5L 现货查询
040C0926-7EP4 现货查询
0417-094
8131-PL2-B 现货查询
042-17-01 现货查询
0497621 现货查询
0499-002 现货查询
05.06.159 现货查询
05.43.705
现货查询
05.44.412 现货查询![](http://www.cechina.cn/UpLoad/CompanyFile/2022/9/12/df6711ba-a96e-4806-96d5-96c88f6c8024.jpg)
