上海航欧ARIS电机ARIS调节阀ARIS变送器ARIS调节器ARIS蝶阀ARIS执行机构ARIS显示屏ARIS开关ARIS执行器ARIS液压伺服缸ARIS伺服器ARIS伺服电动机![](http://www.cechina.cn/UpLoad/CompanyFile/2022/10/22/bf0179e6-6ed7-4eb2-8b56-754f6d8ed248.jpg)
ARIS
PD35
ARIS
PE55-06
ARIS
BE41-21003
ARIS
ACTUATINGDRIVE|K3006230V\50HZ,IP54 0429-4002-01003
ARIS
EF06-1
ARIS
K3006/1242-84873-01001
ARIS
FNr.1420-6259-01010;Typ:EF 1 MA333312
ARIS
PE40-08
ARIS Antriebe und Steuerungen GmbH PE30-08
aris
FNr: 0736-67622-01002
aris
6443LI 230V 50/60HZ 18VA 375/450RPM 92MA 0.56??F Nr.000429
ARIS
N5 RD-S/DN 250d 230V 50??60??HZ FNr??0620-62724-01001
Aris
PMR2 0700002 NR:0216-52001-001
ARIS
0542-61428-02010 N-B1-E
Aris
K3006 FNR.1137-5461-01059
ARIS
FNr:1142-5481-02040
ARIS
FNr:1219-83411-01003
Aris
K3012,Stroke -- 300mm;actuating force --- 1200N;voltage ---
230V/50Hz;actuating speed --- 1.7(2) sec;
ARIS
PD35 90 degrees, bushings for the plum-shaped CH.22, counterclockwise
81020/06
ARIS
PE55-06 S4, 90 degrees, bushings for the plum-shaped CH.27,
counterclockwise 81928/03
ARIS
N 5 1209-82710-01003 30 s / 90??+ PMR 3
ARIS
Typ:NL-90/120 FNr:1209-82710-02017 230V 50/60Hz 18VA 120Nm 90?? IP65
ARIS
FNr:0908-4966-01008 Typ:EF1
ARIS
NL-90/120
ARIS
Aris
Type: K3012 1,7/1200 2ZW RP19; Rated power: 0,031 kw; Nominal voltage:
220,000 V; Nominal voltage: 230,000 V; Nominal frequency: 60,000 hz; Nominal
frequency: 50,000 hz; Degree of protection: IP54; Stroke: 300,000
ARIS
TYP.N5 FNr.1117-79726-01002
Aris
1206-S2453-02002 N5L SNR107504
ARIS
0906-71866-01002??N6S DN1120d
aris
PE60-08 0087.00033
aris
0301-54088-01006
ARIS
TYPE:N5 230V 50HZ 18VA 110Nm 90' 50S IP54
Aris
Nr.1012-5165-02067
ARIS
WRK 3012 Nr.9425-16842-01011 220V 50HZ 17VA 1200N 200S/300MM
ARIS
NL-90/120
ARIS
EV61-521MJ1
ARIS
K 3012 1126-79613-01002
ARIS
K 3012 1126-79612-01002
ARIS
N5 RD-S/DN250d /0620-62724-01001/:230v 50(60)HZ
ARIS
N1-RD-S/DN125d/1108-78827-02036
ARIS
N4 230v 50HZ 30Nm 35VA 6U 4??2(3??5)S/90??FNr??0816-69661-01002
ARIS
type K3012 1,7/1200 2ZW; regulating distance: 300 mm;actuating force:
1200 N; actuating time: 176 s; nominal ,voltage: 230 V AC, 50Hz; nominal power:
31 W; protection ,class: IP 54; limit switches: 2 (standard), 2 (additio
ARIS
BE41-210003
ARIS
N5 1209-82710-0100330 S/90+PMR3
Aris
FNr:1136-5463-01001 TYP:K1512
Aris
FNr.1112-5375-04014 TPY:K3012
Aris
FNr.1026-5230-01040 TPY:K3006
ARIS
1217-83288-01001
ARIS
1217-83288-01002
ARIS
FNr.0906-71866-01003 TYP.N68 DN1120d
ARIS
FNr.0751-4710-02034 Typ.K 3006
Aris
K-A 3025
30-08
aris
typ nk3015 dn150d,FNr:1118-79608-02001
Aris
PE20-08
ARIS
0338-55766-01005 TYP:N3
ARIS
RD-S DN125+N1 JN0 O-BDNR 2139147;TLNR 148048 257270/#16
Aris
EV61-521MJ1
Aris
K3012 1012-5165-02062
Aris
Aris
see picture
Aris
K3012, 1029-5247-02029
Aris
K3006, 1013-75710-02003
Aris
FNr: 1235-84300-02061 TYP: NK3015 230V 50(60)Hz 7VA 15Nm
Aris
Nr.1442-90991-01001
Aris
PMR3(FNR:1219-83411-0100)
Aris
6444LI 230V 375/450rpm
Aris
Aris
Aris
ARIS
FNr:0633-64053-01001 Typ:N3 230V 50(60)Hz 18VA 30Nm 90?? 30(25)s IP65
A.121.879.6234
ARIS Antriebe und Steuerungen GmbH 0633-S4053-01001
ArIS
NL3040 (including limit switches, PMR2-LC, electric heating)
ARIS Antriebe und Steuerungen GmbH FNr:1012-5165-02067;Typ:K 3012
ARIS
0203-51259-01003 K3012
ARIS
NL-90/100
ARIS
KA3050
ARIS
K3012
ARIS Antriebe und Steuerungen GmbH 0850-71942-01001;6443LI 230V 50 (60)HZ
18VA
ARIS
K1506 40NM 23OV 50(60HZ)
ARIS
HK40.1 ?A:20mm--?B:20mm
ARIS
HK60.5 ?A:12mm--?B:12mm
Aris
K3012 1,7/1200 2ZW ARIS art.-no. 0100.03217
ARIS Antriebe und Steuerungen GmbH /motor
6443LI/230V/50(60)Hz/18VA/375rpm/78MA/0.56uF
Aris 6444LI 230V 375/450rpm
Aris
WAN 3 Nr.9914-43637-01002
Aris
CL-L 140-70
Aris
WAK 3012 N; Nr.2473672
Aris
WAK 3012N NR:2473672
Aris
FNr: 0836-71033-01002 230V 50 (60) Hz, 30Nm 35VA 6U 4,2 (3,50 s/90??,
Ip65 UTO/+60 ??C PMR3
Aris
Aris
PD25HT MAX10BAR 8BAR 90NM
ARIS
0523-4198-02046 K3012
ARIS
0615-4394-01008
ARIS
SM6585-4 1-2UF
ARIS
KA3050
ARIS
K3012??
ARIS
NL-90/100
Aris
0080.10013 6444LI 230V 375/450RPM
Aris
Nano M 40-60 Nr.VA03.00002
Aris
VA02.L0001
Aris
117.00501
Aris
CL 12-17 300(replace K3012)+0117.00501
Aris
VA02.L0005
VARISCO
117.00588
VARISCO
JE1-110 G10 ET20
Aris
117.00501
Aris
117.00652
VARISCO
VA02.L0001
Aris
CL12-17 300 Nr:VA02.L1001(Replace K3012)
Aris
06-17 300(0429-4002-01003)
Aris
VA02.L0001
Aris
117.00501
Aris
VA02.L0005
VARISCO
117.00652
Aris
117.00588
Aris
Artikel-Nr.0045.00011
Aris
Artikel-Nr.0016.X9014
Aris
Artikel-Nr.1110.00115
VARISCO
14440012
Aris
10014358
Aris
10008895
Aris
10009010
Aris
999990.999.00000(1:1 ersetzt K 3012 1305-5758-01018)
Aris
06-17-300 230V 50Hz
Aris
10007593
Aris
10005371
Aris
10016934
Aris
10014358
Aris
10009010
Aris
10008895
Aris 14440012
Aris
117.00652
Aris
VA02.L0005
Aris
117.00501
Aris
Linearis TE 12-17 300 ARIS Klappenversteller
Aris
I-ACT-Regler, eingebaut
Aris
Aris
Aris
Linearis N+ 12-17 300 (replacement K3012 1012-5165-02062)
Aris
1672.82004
Aris
1672.82003
Aris
VA07.L0001
Aris
117.00501
Aris
117.00652
Aris
VA02.L0005
Aris
1110.00200 Endschaltersatz BE41
Aris
EV61-521MJ1
Aris
000988.024.60153; Stellantrieb Typ EF 1
Aris
8047GG+GG514+TYP.1A
Aris
8047GG+GG514+TYP.1A
Aris
Typ:WAN V71-R1;FNr:0115-49153-04001
Aris
Typ:WAN V71-R1;FNr:0115-49153-03003
Aris
K 3012 Nr.0243-03671-01016
Aris
N6S DN1120d 0906-71866-01002
Aris
Nr 9843-42249-01006 typ WAK 3012
Aris
|ADJUSTING DRIVE|TYPE WAK 3012; VOLTAGE: 220V; 09346.401.011006.000
Aris
K3012 H300,Nr.1505-91626-04001
Aris
CL-M60-25
Aris
FNr??1302-5756-01023
Aris
K3006
Aris
ype: CL-S 30-30 30Nm 30s/90?230V 50(60)Hz 11VA 48mA UT-15/+60??
ED-S1-100%Pa?f. MP21 FNr:1538-93225-01001
Aris
Type:N3230V 50(60)Hz18VA 30Nm90?30(25)SIP54 UT-15/+60??
FNr:1342-88096-01001
Aris
Typ:K 1512,FNr:0936-73991-01001,pls see the pic
Aris
CL-S?40-120 FNr:1136-81073-01001??Typ:N3??230V 50(60)Hz 7VA 40Nm 90??
120(100)s IP65 UT-15/+60??
Aris
CL-M60-25
Aris
SN:038895 SW-REV PMR3_06
Aris
CL-M 100-25
Aris
117.00501
Aris
CL-L160-17
Aris
1110.00003
Aris
1110.00309
Aris
1110.0031
Aris
40.02291
Aris
1110.00309
Aris
1110.00003
Aris
1110.0031
Aris
1145-78525-01001 NL-3040
Aris
FNr??0851-4915-01003 typ??K 3006
Aris
PE30-08
Aris
Aris
0016.02076+1110.00107+0045.00011
Aris
FNr:1445-91087-01016 Typ??LINEARIS 06-17 300 23V 50(60) HZ 18VA 1.7(2)
mm 600N H300 IP65 UT-15/+60?? 2ZW, PMR-CL
Aris
Typ??K 3012 1142-5481-02045
Aris
Typ??K 3006
Aris
PE60-08
Aris
FNr:0827-70285-01004 Typ:N1 230V 50(60)Hz 7VA 30Nm 90?? 120??100??s IP54
UT-15/+60??
Aris
06-17-300 230V 50Hz
Aris
1209-82710-01003 TYP??N5
Aris
Aris
Aris
Aris
CL-L 140-70 140Nm 220v/50HZ,4-20mA
Aris
CL12-17 300??Nr??VA02.L1001??Replace K3012??
Aris
Aris
NL-3040
Aris
NL-3040
Aris
FNr:1219-83411-01009TYP: K 3012
Aris
PMR3 (FNR:1219-83411-0100)
Aris
K3006 4-20MA 600N FNr??1307-85809-01039
Aris
EV61-521MB1
Aris
K3006??Nr0914-72779-01009
ARIS
Nr.1442-90991-01001 Typ??LINEARIS12-17 300
aris
1102-78517-03002
ARIS Antriebe und Steuerungen GmbH TYP:WAK 3012 N ,Nr:9310-12551-01004
ARIS
EF06
ARIS
K3012
ARIS
K3006
ARIS
K1512
ARIS
K3006 NR.1145-81511-01006
ARIS
PMR3(FNR:1219-83411-01008)
ARIS Antriebe und Steuerungen GmbH FNr:1219-83411-01009 TYP: K 3012
ARIS
K3012 Nr??1107-78855-01001 IP54 50/60HZ
ARIS
1010-75416-01002
ARIS
K3012.ED-S3-50%,~230V.50HZ.31VA.1200N.H300.1.7(2)mm/S
ARIS
WAN 1 Nr??2214859
ARIS
1141-81317-01003
ARIS
Type:K3012 1,7/1200 2ZW RP19 1029-5247-02016
ARIS
K3006 1316-5830-01002
ARIS Antriebe und Steuerungen 0016x9014+1110.0 0107+0045.0011
ARIS
FNr:1219-83411-01008 TYP:K3012
ARIS
K3006??Nr.0914-72779-01009 230v 50??60??HZ 180VA 600N
Aris
K3006 FNR:1048-5310-01033
ARIS
"type WAK 3012; stroke: 300 mm; actuating force: 11200 N上海航欧机电设备有限公司成立于2006年,从事进口机电设备、仪器仪表等备品备件的销售,是经营世界各地进口设备机电配件的企业。上海航欧公司与众多品牌电子元件供应商建立有良好的合作关系,在欧美、日本等地形成了稳定的供应网络,良好的供应商关系和多年的行业经验,使我们在价格及货期上有优势。经销产品供应的行业涉及冶金、钢铁、石化、能源、航天、集装箱码头、汽车、水利、造纸、电厂、纺织、注塑、橡胶、食品包装等。我们热忱地希望尽我们的努力,力争优惠的产品价格,供货周期以及服务质量,能够为您解决进口备件方面的问题。进口产品主要有:传感器,测速电机,接近开关,电子尺,编码器,控制器、分析仪,光纤,光栅,插装阀,电缆,拖链,分配器,马达,减速机,继电器、缓冲器和进口五金等
产品型号 3SKG160L-2T-1E3 18.5kw
Tamel
产品型号 3SG160M-2A-1E3 11.0kw Tamel
产品型号 3GAA132004-BDB ABB
产品型号 BS02-72H/D05LA4-TOF/SP BAUER
产品型号 MA45-4T CIE
产品型号 AIS71B4 STM
产品型号 MT80L2-OML A3433132220 CEG
产品型号 BG40-11/D09LA4-TF BG40-11/DHE09XA4-TF BAUER
产品型号 3CWAR91L4BR20 Watt dirve
产品型号 7WAR 161L4 THTF+
HF130A161L4 3CWAR 161L4+ HG 130A
161L4 Watt dirve
产品型号 W 63 U 7 P80 B14 B8+BE
80B 4 230/400-50 IP55 CLF B14 CCC BONFIGLIOLI
产品型号 8856506705 +88842 02024 DUNKERMOTOREN
产品型号 1ATK 90S4 1.1KW+OMF112
P C55 1/223.5 ELVEM
产品型号 1ATK 90S4
1.1KW+OMF112P SIN C55 1/223.5 ELVEM
产品型号 DR62.1x30-2
88139.03051+PLG52 8885101762 DUNKERMOTOREN
产品型号 3SKG90L-2PCT-IE3 Tamel
产品型号 460 SYMCOM
产品型号 FBBRC040-195 WATT
产品型号 M205-2000+ VOGEL
产品型号 ABF63/4B-7Q 2019C-02 ATB
产品型号 UVN-1A-0A4-07A-Q14-6063B UVN-1A-0A4-07A-Q14-6063E NACHI
产品型号 BFK458-14E 00720759 INTORQ
产品型号 00396215 INTORQ
产品型号 CNVXS-6120G-87/G/90/C160
0.94KW RELEX
产品型号 90-P4-1,5-B5 +
MF200/116 + KUZ-28-20/24 ZIMM
产品型号 SZ283 B&C
产品型号 Z944K109 HEGWEIN
产品型号 577V782-S7 Van London
产品型号 PY-ASI SARTORIUS
产品型号 Knife Electrode 110mm
(210) AQUA-BOY
产品型号 132748 RDSON
产品型号 CIR-3037-240 CHROMALOX
产品型号 CPV10-GE-MP-6 18254 FESTO
产品型号 DF E-lectrolyte Blue DELTA-F
产品型号 RL-02501 MTE
产品型号 RL-16002 MTE
产品型号 CRX0040BE HAMMOND
产品型号 RL-05502 MTE
产品型号 276993160 B0701061 BLOCK
产品型号 276996170 B0701091 BLOCK
产品型号 NKD
25/1.17400V/25A/1.17mH LR3
40-4/25 BLOCK
产品型号 output choke sk c01-460/17-c 276996017 BLOCK
c01-460/9-c 276996009 BLOCK
产品型号 INPUT CHOKE SK
CI1-480/40-C 3U176/41/F 276993040 BLOCK
产品型号 OUTPUT CHOKE SK
CO1-460/33-C 3U190/51/F1 276996033 BLOCK
产品型号 OD/15051747/411612802/OD1505173DS000 OD150517D000000 EDI
产品型号 AS-P 400V 50HZ DEUFRA
产品型号 KDF-SB 2P*0.5SQ KURAMO
产品型号 KVC-36SB 5P*0.2SQ KURAMO
产品型号 KDF-SB 2P*0.2SQ KURAMO
产品型号 VCTF23NXX 2C*0.5SQ KURAMO
产品型号 VCTF23NXX 3C*0.5SQ KURAMO
产品型号 VCTF23NXX 20C*0.5SQ KURAMO
产品型号 VCTF23NXX 3C﹡0.5SQ KURAMO
产品型号 FANC-110SBH 3C*0.5SQ KURAMO
产品型号 KDF-SB 1P*0.5SQ KURAMO
产品型号 VCT531BX 3C*0.75SQ KURAMO
产品型号 VCT531BX 20C*0.75SQ KURAMO
产品型号 VCT531BX 6C*2SQ KURAMO
产品型号 KVC-36 6C*0.2SQ KURAMO
产品型号 VCT531BX 7C*2SQ KURAMO
产品型号 VCT531BXS 20C*0.75SQ KURAMO
产品型号 FANC-110SBH KURAMO
产品型号 804000W03M020W BRAD HARRISON
产品型号 804001A15M040 WOODHEAD
产品型号 M12-C1012 JOKAB SAFETY
产品型号 KB4-2m 499400 Z-LASER
产品型号 ST-02G-3A-U2X ST-02G-4A-U2X METO-FER
产品型号 M12-C61 20-056-00 JOKAB
SAFETY
产品型号 cable (00477) SBS TECHLOGIES
产品型号 AO-0531-D-050 B&K
产品型号 MDCP-4FPX-10M 电缆直径在7.5mm至11.9mm之间 订货号5012804 MENCOM
产品型号 9688 Belden
产品型号 CL-AT-S-20-SF(for gycat) SANTEST
产品型号 215235P-48 AUTAC
产品型号 CD08-0C-050-C1 automation direct
产品型号 CL-SE-S-15-SF SANTEST
产品型号 0029614/7×1.0mm2 Lapp kabel
产品型号 C-MINF10-10X1,OPU06,0-MA 102518 EUCHNER
产品型号 QBT-C-6 PROPORTION-AIR
产品型号 CL-RP-S-5-SF(5M) SANTEST
产品型号 MDC-4FP-5M-R CABLE
MICRO 5M 4 PIN F/90 FLY MENCOM
产品型号 CL-AT-S-10-SF(for gycat) SANTEST
产品型号 QCI-C-D15P-T14S-15 QUICKSILVER
产品型号 59-546-12 FIREYE
产品型号 VK-D/F-ST-A 5m 2105-00005-0600 VESTER ELEKTRONIK
产品型号 CA0021360 ARbiter
产品型号 CABLE 2.5M CV13 TOOL 6159176010 Desoutter
产品型号 RKWUE 19-242/5M LUMBERG
产品型号 115030K13M060 WOODHEAD
产品型号 ECF10ESFP 2MT 21E014540 EUROGI
产品型号 AMP-T6 TransducerTechniques
产品型号 CD12M-0B-050-C1 automation direct
产品型号 3S-S-0144-200 NSD
产品型号 KDF 6C*0.5SQ KURAMO
产品型号 1761-CBL-AS03 AB
产品型号 VCTF23NXX 10C*0.5SQ KURAMO
产品型号 VCTF23NXX 4C﹡0.5SQ KURAMO
产品型号 VCTF23NXX 30C*0.5SQ KURAMO
产品型号 VCTF23NXX 40C*0.75SQ KURAMO
产品型号 CL-RS-R-30-SF SANTEST
产品型号 CL-RS-S-10-SF SANTEST
产品型号 CL-RS-S-5-SF SANTEST
产品型号 OPT-TEDS-RP TransducerTechniques
产品型号 OPT-TEDS TransducerTechniques
产品型号 CL-I3-(Gr3)-2-FF SANTEST
产品型号 VCT222 2C*1.25SQ KURAMO
产品型号 MDE45P-4MP-RJ45-10M MENCOM
产品型号 MTN/CA137-1185(5米线缆) Monitran
产品型号 CL-AT-S-5-SF SANTEST
产品型号 CL-A4-S-5-SF SANTEST
产品型号 111421 LUTZE
产品型号 CL-RS-R-35-SF SANTEST
产品型号 CL-RP-S-10-SFC SANTEST
产品型号 WDX19-80-0402-3 FORD
产品型号 CL-I3-(Gr2)-5-FF SANTEST
产品型号 RKMV4-225/5m SENSOPART
产品型号 5m cable with plug(3P)
SKY
产品型号 CD12M-0B-050C-C1 automation direct
产品型号 7000-18021-2160 MURR
产品型号 ZL-D24-CBL40-X automation direct
产品型号 ZL-D24-CBL40-1X automation direct
产品型号 Z174.003 IVO
产品型号 MTN/CA284 Monitran
产品型号 KVC36 5P*0.3SQ黑 KURAMO
产品型号 CD12M-OB-070-A1 automation direct
产品型号 EHN900024U-0010 Black box
产品型号 00.F5.0C0-0010 KEB
产品型号 A6BCDCN-5M ASAHI KEIKI
产品型号 SC11-5 automation direct
产品型号 SC18-5 automation direct
产品型号 EVNDVI02-0010 Black box
产品型号 EVNSL60BL-0020 Black box
产品型号 VK500421 IPF
产品型号 EVNPS06-0003-MM Black box
产品型号 X-VGA-TP-TX Black box
产品型号 EHN900024U-0006 Black box
产品型号 EVNPS06-0025-MM Black box
产品型号 ML4C4WC120F COOPER
产品型号 CA0021330 ARbiter
产品型号 CA-FC10-SH-MIC6-33 US DIGITAL
产品型号 CA-FC10-SH-FC10-33 US DIGITAL
产品型号 LIFE-LINE 46150
4*1.5平 46150 KABELSCHLEPP
产品型号 AO-0250-D-030 B&K
产品型号 MTN/CA137-1185(30米线缆) Monitran
产品型号 CA0021302 ARbiter
产品型号 MTN/CA137-1185(25米线缆) Monitran
产品型号 CS-A1-02-G-05 DATASENSOR
产品型号 CS-A1-03-G-05 DATASENSOR
产品型号 CAQC GIMATIC
产品型号 0610001-06 FIMP-XL-8xST/ST-D EKS
产品型号 Measuring Cable (200)
and Holder (204) AQUA-BOY
产品型号 A0B0912A H6 GRANZOW
产品型号 007 SEAMETRICS
产品型号 266303 CAPRI
产品型号 62GB-16F14-19SN AMPHEL
产品型号 410970 CAPRI
产品型号 680637 CAPRI
产品型号 1.209.1601.14 HUMMEL
产品型号 1.533.2101.14 HUMMEL
产品型号 BH12M SS 3/4 SUBCONN
产品型号 K4P10M-S-M8 WayCon
产品型号 EXEL4 1S38T C080 DELACHAUX
产品型号 RKWT 3U-664/20 F LUMBERG
产品型号 DLSC-F Φ60.5mm SUBCONN
产品型号 DLSC-M Φ60.5mm SUBCONN
产品型号 V1-G-20M-PUR-ABG-V1-W P+F
