Dwyer流量传感器,Dwyer流量计,Dwyer开关,Dwyer变送器,Dwyer风速计,Dwyer温度传感器
Dwyer公司建立与1931年,在1955年时把制造总部从伊利诺斯州的芝加哥迁移到印第安纳州的密歇根市并建立起新的制造工厂和辅助设施.
![](http://www.cechina.cn/UpLoad/CompanyFile/2022/11/7/e9c24e3d-a24b-4e41-9b43-7336d0c56f83.jpg)
Dwyer Magnehelic2000-1.5KPA
Dwyer ATH411-0-N
Dwyer持式数字压力计475-000-FM
Dwyer差压计2000-500PA
Dwyer差压变送器605-2
Dwyer TFS100L1GA4A8X,0-150cm/s;-20~70℃;1.0MPA
Dwyer 1638-0
Dwyer OEM2601G-74
Dwyer SFI-100-MP-3/4
Dwyer压力变送器679-64-20mA、0-1250Pa
Dwyer UFB-2230.1~10m/s±0.5%
Dwyer RMB-55SSV-40
Dwyer RMB-53SSV-20
Dwyer RMB-53SSV-10
Dwyer RANGE:0-500mmH2OMODEL:MP-020
Dwyer压力开关SA1111E-S5-K2
Dwyer压力开关1910-1;Range0.40-1.6"w.c.
Dwyer 2002D(0-500Pa1/8"NPT)
Dwyer 2000-3KPA(0-3000Pa1/8"NPT)
Dwyer Model:MP-020Range:0-20inw.c.
Dwyer MS-131
Dwyer Type:2002D
Dwyer Type:2000-3KPA
Dwyer RMB-55-SSV
Dwyer RMB-54-SSV
Dwyer RMB-53-SSV
Dwyer压力开关1910-20
Dwyer压力控制单元1950-10-2F
Dwyer压力控制单元1950-1-2F
Dwyer 477-7
Dwyer ADPS-03-2-N0.2-2.0WC(50-500pa)
Dwyer SGY-D11022N
Dwyer 477-7-FM
Dwyer DESPATCHFR0-35GPM
Dwyer VFB-55-BV
Dwyer DH-008
Dwyer AT11910-0-AB2X
Dwyer 2-5020-NPTN340MIMIHELICⅡGAGE0~20INCHIESW.C.
Dwyer差压开关Type:1950-0-2F
Dwyer VFA-6-SSV
Dwyer PHOTOHELIC3000(2-300mm.H2O)
Dwyer DWYERINSTRUMENTSINCMICHIGANCITYIN46360,USACAT..1910-00PRESSURERATINGMAXPRESSUDwyer 628-18-CH-P1-E1-S1-LED0-3000PSI压力变送器
Dwyer 1910-10压力开关
Dwyer model607-8
Dwyer 160159173526-00T23V
Dwyer 013504RWB-54D-SSVT20V流量计
Dwyer DM-2003-LCD压力变送器
Dwyer 1626-20-wp
Dwyer T33S-S70662401(1635-1-MIL)
Dwyer RMA-16-SSV(1000-10000CC/MIN)流量计
Dwyer ADPS-03-2-N
Dwyer RHP-2W44
Dwyer RHP-2F11
Dwyer V6EPB-B-S-LF
Dwyer V6EPB-B-S-L-3-B
Dwyer Type: A3000 Range. 0
to 300 mm H2O
Dwyer FC01-U1R2C1 PUF-1002
Dwyer VFA-3-SSV-VIT
Dwyer VFA-3-VITDwyer 压力变送器 628-18-CH-P1-E1-S1-LED
0-3000PSI
Dwyer 压力开关 1910-10
Dwyer model 607-8
Dwyer 160159
173526-00 T23V
Dwyer 流量计 013504 RWB-54D-SSV
T20V
Dwyer 压力变送器 DM-2003-LCD
Dwyer 1626-20-wp
Dwyer 流量计 RMA-16-SSV(1000-10000CC/MIN)
Dwyer ADPS-03-2-N
Dwyer RHP-2W44
Dwyer RHP-2F11
Dwyer V6EPB-B-S-LF
Dwyer Type:
A3000 Range. 0 to 300 mm H2O
Dwyer FC01-U1R2C1
PUF-1002
Dwyer VFA-3-SSV-VIT
Dwyer VFA-3-VIT
Dwyer VFA-6-SSV
Dwyer DWYER
INSTRUMENTS INC MICHIGAN CITY IN46360,USA CAT..1910-00 PRESSURE RATING MAX PRESSURE 45 IN .W.C SURGE PRESSURE 10 PSI
UNITS WITH CONDUIT ENCLOSURE AND COVER MEET TYPE 1SPECS DIAPHRAGM WERTICAL
ELECT RATING 15A 125,250,480VAC,1/8HP 125VAC1/4HP250VAC附图
Dwyer 1"
V6EPB-B-S-3-B
Dwyer 1/2"
V6EPB-B-S-LF
Dwyer 差压开关 1950-5-2F
Dwyer AQTI-VP1
Dwyer HM3531DLK300
Dwyer SSM-04
Dwyer Typ:
V6EPB-B-S-2-B
Dwyer fch31pdd03x
Dwyer 2000-3KPA
Dwyer V6EPB BS2B
Dwyer MP-002
Dwyer 2636200
Dwyer 7112-GC100
Dwyer 7112-GC010
Dwyer 7112-G200
Dwyer 8904
Dwyer 2000-1.5KPA
Dwyer MS311/0-500pa
Dwyer MS311/0-250pa上海航欧机电设备有限公司成立于2006年,从事进口机电设备、仪器仪表等备品备件的销售,是经营世界各地进口设备机电配件的企业。上海航欧公司与众多品牌电子元件供应商建立有良好的合作关系,在欧美、日本等地形成了稳定的供应网络,良好的供应商关系和多年的行业经验,使我们在价格及货期上有优势。经销产品供应的行业涉及冶金、钢铁、石化、能源、航天、集装箱码头、汽车、水利、造纸、电厂、纺织、注塑、橡胶、食品包装等。我们热忱地希望尽我们的努力,力争优惠的产品价格,供货周期以及服务质量,能够为您解决进口备件方面的问题。进口产品主要有:传感器,测速电机,接近开关,电子尺,编码器,控制器、分析仪,光纤,光栅,插装阀,电缆,拖链,分配器,马达,减速机,继电器、缓冲器和进口五金等
产品型号 NESB100AE21(180.220.220/100.110)
nume
产品型号 B500-0219-5 MICRON
产品型号 EUR0401 TRANSFOS MARY
产品型号 STU 63/2×115 BLOCK
产品型号 Q002FEKF HAMMOND
产品型号 USTE 630/2x115 BLOCK
产品型号 NESB750AEX nume
产品型号 TB-54524 ACME
产品型号 CT159NN 11257 ETI
产品型号 B0604056 BLOCK
产品型号 TAM6442-5AT10-0FA0 MDEXX
产品型号 EP 1500 010 017 0004 ROLLER
FISCHER
产品型号 T15666 Securelec-socem
产品型号 T253060 ACME
产品型号 27689 ELETTROMECCANICA
ORT
产品型号 STU1000/2*115 1000VA BLOCK
产品型号 STU1600/2*115 1600VA BLOCK
产品型号 dm093kdc 480 DELTA
Primary Volts, 380Y Secondary Volts HAMMOND
产品型号 VC 5.0/2/15 BLOCK
产品型号 EP 2500 010 019 0002 ROLLER
FISCHER
产品型号 STEU 250/23 BLOCK
产品型号 T-2-52705-1 ACME
产品型号 T-2-52707-1 ACME
产品型号 T253064 ACME
产品型号 PH50MQMJ HAMMOND
产品型号 ES 33350.806 DONGAN
产品型号 ST 500/23/23 BLOCK
产品型号 COD
PSPMKS20000350004 TECCABLAGGI
产品型号 7121.3802.005 ICE
产品型号 STU 250/2x115 BLOCK
产品型号 PP-1 15/1A 2VA CL1 4-083-000626 ratel
产品型号 ZB1/20-65 BLE-ELECTRONIK
产品型号 859982 20VA SEDLBAUER
产品型号 ST630/4/23 BLOCK
产品型号 50-0500-053 DONGAN
产品型号 859717 SEDLBAUER
产品型号 TF-2-79304-S ACME
产品型号 EN61558/SETGK现在的型号是Typ
02048 Rist
产品型号 168C HAMMOND
产品型号 MO100H MARCUS
产品型号 T-2-53616-1S ACME
产品型号 AF 800 T10 HEGWEIN
产品型号 ES-10230.376 DONGAN
产品型号 CS3000H1F-C1A/50/CE REX
产品型号 FGSE 145-117.001 145-117.010 FREI
产品型号 ES-10170.843 DONGAN
产品型号 ES-10210.843 DONGAN
产品型号 ES-10230.843 DONGAN
产品型号 NSC-30H6-0834 DONGAN
产品型号 EN 120 040 019 0014 ROLLER FISCHER
产品型号 T253062 ACME
产品型号 SP1500KHP HAMMOND
产品型号 006074 CUOGHI ROLANDO
产品型号 NESB1000AEX 输入380V,输出220V nume
产品型号 TAPR 2C 10000A/250mA MISURE
产品型号 PE 2000VA Trafomic
产品型号 STV 0.13 EMB
产品型号 ST500-23-23 BLOCK
产品型号 F10-LA2XL-1 DONGAN
产品型号 STU 63/24 BLOCK
产品型号 ETTK630 BLOCK
产品型号 USTE 1600/2x115 BLOCK
产品型号 86351 MURR
产品型号 F10-LA2 DONGAN
产品型号 B050-2061-GA MICRON
产品型号 TTV0201K0JCO FRER
产品型号 CS1000F-C2/50 REX POWER MAGNETICS
产品型号 MAC017XXXG42 FRER
产品型号 CTA700-L01 POWERVOLT
产品型号 MF8-8,9-6,5-TMUeRF-M8Pr-1G EXPERT
产品型号 MO1KK MARCUS
产品型号 TL-96/60 TL-120/42 KMOAS
产品型号 A030-8MA DONGAN
产品型号 MEST1B00500 Bi-mec
产品型号 ABL6TS40U 输入220v400VA1.6A SCHNEIDER
产品型号 ES-10250.843 DONGAN
产品型号 NESB500AE21 nume
产品型号 TTV006100VCO 100:
V3/100 V,3VA, CLASS 1 FRER
产品型号 V380-390-400-410-420/230V
4000VA TRASFOTEC
2000VA TRASFOTEC
产品型号 TTV006 110:R3/110V 3Va
class 1 FRER
产品型号 TRK2-35 COFI
产品型号 TSRL92109219 FSM
产品型号 TSRL92109225 FSM
产品型号 793-503 WAGO
产品型号 209-666 WAGO
产品型号 JM71B 4 B14 Seipee
产品型号 A20SW-01UDY30 ANYWIRE
产品型号 DNCI-40-460-P-A 575844 FESTO
产品型号 AQ96M input:DC 0-90mV Scale:0-6KA, 96*96mm IME
产品型号 PTX510-1519 PTX5072-TC-A2-CB-HO-PA 350bar DRUCK
产品型号 18/30R3/500-MSC 979-08066 SENSOPART
产品型号 BO 600.1 VERIBOR
产品型号 SLG-30-L12/3000S-5000S 152-10550 SCHLUETER
产品型号 GB 170-325 Omni Finishing
产品型号 DPP03 010N20R TOSOKU
产品型号 RS400P3-3-6BP3016R TOSOKU
产品型号 V6-450 FREUDENBERG
产品型号 402-881.245 JENA
产品型号 R-1 DN100 13130700-00 STENFLEX
产品型号 GR-SAE DN50 PN16
length:130mm STENFLEX
产品型号 A-2 DN200 PN 16 1.4541 STENFLEX
产品型号 A-2 DN200 PN10 1.4571 STENFLEX
产品型号 R0065RA16U (ERV-R
65.16) ELAFLEX
产品型号 MEMG2S342243015/C END-ARMATUREN
产品型号 27894(DSA1-S12W-1M1A配套的接头) VOGEL
产品型号 DOS3+N1115+44445 CONSILIUM
产品型号 M2.5 1904-41 61-287 ELMA
产品型号 SSV6(VA) LINCOLN
产品型号 3899 04 19 PARKER
产品型号 DN500mm PN1 250mm 19.9.03501.0005 Frenzelit
产品型号 DN500mm PN1 930mm 19.9.03501.0002 Frenzelit
产品型号 DN400mm PN1 920mm 19.9.03501.0001 Frenzelit
产品型号 6A77C
BORE:80mm/bore:80mm keyway A049656 ZERO-MAX
产品型号 MR 14.0 G.O. IX B50 10201I011401106 MAILLON RAPIDE
产品型号 06240-308 relem
产品型号 SG 5481 SEQ 60434F4F MATHESON
产品型号 22590.0712 HALDER
产品型号 P 65 SS 2.2kW PERFECTA
产品型号 SS100 Chemyx
产品型号 SS402 220V 0.4A SS402B SLO-SYN
产品型号 H32NCHA-LNN-NS-00 PACIFIC SCIENTIFIC
产品型号 KMT063F07 DANAHER
产品型号 TS3653N94E5 Index Stepper Motor TAMAGAWA
产品型号 MDI1FRD34C7-EQ-N IMS
产品型号 SDT1103-150-120 ST423-U88-XTS-M04-C3E8 TOTAL
产品型号 M-1410-0.75S IMS
产品型号 HN200 3451 0640 AXR08 MAE
产品型号 M-2218-2.4S IMS
产品型号 SHS 56/200-K744-4322W MicroStep
产品型号 SLA2221 210 4AX00 SHS
产品型号 ST4118L1804-B Natec
产品型号 X-MIND B6 RTA PAVIA
产品型号 ESH3 00/D16 SHS
产品型号 SLM34516408AX00 SHS
产品型号 MS-2H090M QZ-2H606A MicroStep
产品型号 D75/9 Mclennan 006MSD00034 SmartDrive
产品型号 ES3-00 SHS
产品型号 SFBP2-G3700-01 SeaFlo
产品型号 ACTUATOR-P-G 059226 EUCHNER
产品型号 SP-4890A-6 ALKON
产品型号 S90JAM-XI-12R1G ALTHERIS
产品型号 DXTBS-21SE1 TODENSHA
产品型号 DXCBS-81SD1 TODENSHA
产品型号 UXTBS-SCSN52/SCSN52 TODENSHA
产品型号 PF580C233029 TER
产品型号 VCS2E-101.6110 J.R.Merritt Controls
产品型号 PF580C233028 TER
产品型号 829-151.21K0+point
milieu MEGATRON
产品型号 PF580L066002 TER
产品型号 851 - 211.11 MEGATRON
产品型号 PCL401-04-HK27-101 PARKER
产品型号 077M4T4TY88 GE
JOYSTICK OPERATOR CEMA
产品型号 KCB2D2D2D2D0000DV0W EUCHNER
产品型号 077SXN22 CEMA
产品型号 KCB2D2D2D2D0000W 022205 EUCHNER
产品型号 PGD1000F00 CAREL
产品型号 6037665 HERKULES
产品型号 00.F5.060-2000 KEB
产品型号 VCS09611KKVRH240.240 S+B
产品型号 CA10B D-Y567*01E CA10B D-Y567*01 E K&N
产品型号 SMON5ER24 S+B
产品型号 MO S+B
产品型号 3100系列 PERMCO
产品型号 APG 1 SEON/1 G 1"
1804 VSE
产品型号 2BH1002-0AB22 ELMO
产品型号 4429449 MAHR
