MTE滤波器、MTE驱动器、MTE电抗器、MTE互感器、MTE电容器、MTE滤波电容、MTE继电器、MTE感应器、MTE侦测器、MTE无源滤波器MTE
上海航欧销售MTE滤波器、MTE驱动器、MTE电抗器、MTE互感器、MTE电容器、MTE滤波电容、MTE继电器、MTE感应器、MTE侦测器、MTE无源滤波器MTE
型号:M5P0006A,M5P0008A,M5P0011A,M5P0014A,M5P0021A
,M5P0027A,M5P0034A,M5P0044A,M5P0052A,M5P0066A,M5P0083A,M5P0103A,M5P0128A,
M5P0165A,M5P0208A,M5P0240A,M5GB0006A,M5GB0008A,M5GB0011A,M5GB0014A,M5GC0021A,
M5GC0027A,M5GC0034A,M5GC0044A,M5GC0052A,M5GD0066A,M5GD0083A,M5GD0103A,M5GD0128A,
M5GD0165A,M5GD0208A,M5GD0240A,M5WB0006A,M5WB0008A,M5WB0011A,M5WB0014A,M5WC0021A,
M5WC0027A,M5WC0034A,M5WC0044A,M5WC0052A,M5WD0066A,M5WD0083A,M5WD0103A,M5WD0128A,
M5WD0165A,M5WD0208A,M5WD0240A,M5NB0006A,M5NB0008A,M5NB0011A,M5NB0014A,M5NB0021A,
M5ND0027A,M5ND0034A,M5ND0044A,M5ND0052A,M5ND0066A,M5ND0083A,M5ND0103A,M5ND0128A,
M5NE0165A,M5NE0208A,M5NE0240A,M5P0006C,M5P0008C,M5P0011C,M5P0014C,M5P0021C,
M5P0027C,M5P0034C,M5P0044C,M5P0052C,M5P0066C,M5P0083C,M5P0103C,M5P0128C,M5P0165C
,M5P0208C,M5P0240C,M5P0320C,M5P0403C,M5P0482C,M5P0636C,M5P0786C,M5GB0006C,
M5GB0008C,M5GB0011C,M5GB0014C,M5GC0021C,M5GC0027C,M5GC0034C,M5GC0044C,M5GC0052C,
M5GD0066C,M5GD0083C,M5GD0103C,M5GD0128C,M5GD0165C,M5GD0208C,M5GD0240C,M5GE0320C,
M5GE0403C,M5GE0482C,M5GF0636C,M5GF0786C,M5WB0006C,M5WB0008C,M5WB0011C,M5WB0014C,
M5WC0021C,M5WC0027C,M5WC0034C,M5WC0044C,M5WC0052C,M5WD0066C,M5WD0083C,M5WD0103C,
M5WD0128C,M5WD0165C,M5WD0208C,M5WD0240C,M5WE0320C,M5WE0403C,M5WE0482C,M5WF0636C,
M5WF0786C,M5NB0006C,M5NB0008C,M5NB0011C,M5NB0014C,M5NB0021C,M5ND0027C
,M5ND0034C,
M5ND0044C,M5ND0052C,M5ND0066C,M5ND0083C,M5ND0103C,M5ND0128C,M5NE0165C,M5NE0208C,
M5NE0240C,M5NF0320C,M5NF0403C,M5NF0482C,M5P0006D,M5P0008D,M5P0011D,M5P0014D,
M5P0021D,M5P0027D,M5P0034D,M5P0044D,M5P0052D,M5P0066D,M5P0083D,M5P0103D,M5P0128D
1, RLA110002, RLA140001,
RLA140002, RLA180001, RLA180002, RLA210001,
RLA210002, RLC00401,RLC00402, RLC00801,
RLC00802, RLC01201, RLC01202, RLC01801, RLC01802,
RLC02501, RLC02502, RLC03501, RLC03502,
RLC04501, RLC04502, RLC05501, RLC05502, RLC08001,
RLC08002, RLC10001, RLC10002, RLC13001,
RLC13002, RLC16001, RLC16002, RLC20001,V20002,
RLC25001, RLC25002, RLC32001, RLC32002,
RLC40001, RLC40002, RLC50001, RLC50002, RLC60001,
RLC60002, RLC75001, RLC75002, RLC85001,
RLC85002, RLC100001, RLC100002, RLC110001,
RLC110002, RLC140001, RLC140002, RLC180001,
RLC180002, RLC210001, RLC210002,RLG00202,
RLG00402, RLG00403, RLG00802, RLG00803,
RLG01202, RLG001203,RLG01802, RLG001803,
RLG02502, RLG02503, RLG03502, RLG03503,
RLG04502, RLG04503, RLG05502, RLG05503, RLG08002,
RLG08003, RLG10002, RLG10003, RLG13002,
RLG13003, RLG16002, RLG16003, RLG20002, RLG20003,
RLG25002, RLG25003, RLG32002, RLG32003,
RLG40002, RLG40003,RLG50002, RLG50002, RLG60002,
RLG60002, RLG75002,
RLG75003,RLG90002,RLG90003,RLJ00202, RLJ00402, RLJ00403, RLJ00802,
RLJ00803, RLJ01202, RLJ001203, RLJ01802,
RLJ01803, RLJ02502, RLJ02503, RLJ03502,
RLJ03503, RLJ04501, RLJ04502, RLJ04503,
RLJ05502, RLJ05503, RLJ08002, RLJ08003, RLJ10002,
RLJ10003, RLJ13001, RLJ13002,
RLJ13003,RLJ16002, RLJ16003, RLJ20002, RLJ20003, RLJ25002,
RLJ25003, RLJ32002, RLJ32003, RLJ40002,
RLJ40003, RLJ50002, RLJ50002, RLJ60002, RLJ60002,
RLJ75002, RLJ75003,RLJ00404,RLJ00804,RLE00201,
RLE00202, RLE00404, RLE00403, RLE00803,
RLE00804, RLE01203, RLE1202, RLE01803,
RLE01802, RLE02502, RLE03502, RLE04502, RLE08002,
RLE10002, RLE10003, RLE16003, RLE20003, RLE25003,
RLE32003, RLE 40002,RLE40003, RLE50002,
RLE50003, RLE60003, RLE75003, RLE125003,
RLE110003, RLE140003
美国上海航欧销售MTE dV/dT滤波器等其他
美国上海航欧销售MTE的dV/dT滤波器等其他是设计用于保护电机的滤波器等其他,由于变频器与电机之间运行电缆过长会
引起对电机产生毁灭性影响峰值电压。电缆的长度取决于用在变频器中的电力半导体的开关次数和电
机的大小,如果电缆短到2.5米则会导致电机承受的峰值电压超过电机绝缘系统的额定值。然而,如果
电缆太长则问题更大,在这种情况下就需要用美国上海航欧销售MTEdV/dT滤波器等其他来保护电机不受峰值电压的
毁灭性影响。
美国上海航欧销售MTE的dV/dT滤波器等其他在远离电机300米处仍然能保证满足电机的大峰值电压规格(母线电压
的150%)。它的额定值为大达每毫秒200V的dV/dT值。但在一些特别的应用中,电缆长度达到900米
时,这种滤波器等其他仍能提供卓越的性能。这种dV/dT滤波器等其他具有3%的接入阻抗,这个接入阻抗是肯定不会
因为滤波器等其他出来的额外压降影响到电机扭矩的。美国上海航欧销售MTE的dV/dT滤波器等其他是一个无源的四序装置
,它可以通过减弱电压升高率和使得出现在电机终端上的峰值电压小化来降低电机电缆传输线路的
影响。dV/dT滤波器等其他是设计用在有变频器工作且开关频率在900Hz和8KHz之间的电机保护上的。
美国上海航欧销售MTEdV/dT滤波器等其他可以允许100%RMS的连续额定电流,而允许的间歇的电流是150%为1分钟和
200%达10秒。MTE可以提供面板安装开放式滤波器等其他或带标准的NEMA1,NEMA2,和NEMA3R式外壳,其工作
的环境温度面板式安装为50°C,带外壳式的为40°C。
美国上海航欧销售MTE典型的应用包括潜水泵,HVAC设备和过程自动化生产线。额定功率100HP及以下的电机和
标准的NEMA B电机(MG1的部分30)由于高电压的冲击易被损坏,而使用美国上海航欧销售MTEdV/dT滤波器等其他将
得到明显的好处。
美国上海航欧销售MTE代表型号:DVAP00003, DVAP0004, DVAP0007, DVAP0009, DVAP0012, DVAP0017,
DVAP0022, DVAP0027, DVAP0035, DVAP0045,
DVAP0065, DVAP0080, DVAP0110, DVAP0130, DVAP0160,
DVAP0200, DVAP0250, DVAP0305, DVAP0365,
DVAP0415, DVAP0515, DVAP0600, DVAGA0003,
DVAGA0004, DVAGA0007, DVAGA0009, DVAGA0012,
DVAGA0017, DVAGA0022, DVAGB0027, DVAGB0035,
DVAGB0045, DVAGB0065, DVAGB0080, DVAGB0110,
DVAGC0130, DVAGC0160, DVAGC0200, DVAGC0250,
DVAGD0305, DVAGD0365, DVAGD0415, DVAGD0515,
DVAGD0600,DVAWA0003, DVAWA0004, DVAWA0007,
DVAWA0009, DVAWA0012, DVAWA0017, DVAWA0022,
DVAWB0027, DVAWB0035, DVAWB0045, DVAWB0065,
DVAWB0080, DVAWB0110, DVAWC0130, DVAWC0160,
DVAWC0200, DVAWC0250, DVAWD0305, DVAWD0365,
DVAWD0415, DVAWD0515, DVAWD0600,
美国上海航欧销售MTE正弦波滤波器等其他
新的美国上海航欧销售MTE的A系列正弦波滤波器等其他是在PWM变频器驱动下,其开关频率范围在2 – 8kHz之间仍
提供正弦波输出电压。 在变频器驱动应用中,这种滤波器等其他可以消除电机绝缘失效问题并通过消除与变
频器输出波形相关的高dV/dT来减少电磁, 改善电机的性能和寿命。在其他能源应用下,比如风力
发电机,逆变器将电力通过升压变压器还原到实用的配电系统,这种滤波器等其他可以符合 IEEE-519的要求
并允许使用标准变压器。满载并在60Hz时给变压器输入的谐波电压畸变大值是5%的话,那么满载时
给电机输入的谐波电压畸变一般就是5%。
美国上海航欧销售MTE正弦波滤波器等其他可用在440-480 VAC和550-600VAC的电压范围及1.5 - 700HP的电机功率范
围。可以开放式安装在面板上,也可以安装在NEMA1,2和3R的外壳中。
美国上海航欧销售MTE典型的应用场合包括: 潜水泵,低压驱动 给中压电机供电,HVAC设备,风力发电机,
以及电机和变频器之间的距离高达到15000英尺的地方。正弦波滤波器等其他允许承受100%RMS的连续定额电
流,而允许承受的间歇的电流是150%为1分钟。
美国上海航欧销售MTE代表型号:SWAP0003A, SWAP0005A, SWAP0007A, SWAP0009A, SWAP0012A,
SWAP0017A,
SWAP0022A, SWAP0030A, SWAP0045A,
SWAP0055A,SWAP0070A, SWAP0085A, SWAP0110, SWAP0135A,
SWAP0160A, SWAP0200A, SWAP0250A,SWAP0320A,
SWAGA0003A, SWAGA0005A, SWAGA0007A,
SWAGA0009A, SWAGA0012A, SWAGA0017A, SWAGB0022A,
SWAGB0030A, SWAGB0045A,
SWAGB0055A,SWAGC0070A, SWAGC0085A, SWAGC0110,
SWAGC0135A, SWAGC0160A, SWAGC0200A,
SWAGD0250A,SWAGD0320A,SWAWA0003A, SWAWA0005A,
SWAWA0007A, SWAWA0009A, SWAWA0012A,
SWAWA0017A, SWAWB0022A, SWAWB0030A, SWAWB0045A,
SWAWB0055A,SWAWC0070A, SWAWC0085A,
SWAWC0110, SWAWC0135A, SWAWC0160A, SWAWC0200A,
SWAWD0250A,SWAWD0320A,SWAP0415D,
SWAP0515D, SWAP0600D, SWAP0720D,SWAGD0415D,
SWAGD0515D, SWAGE0600D, SWAGE0720D,
SWAWD0415D, SWAWD0515D, SWAWE0600D, SWAWE0720D
美国上海航欧销售MTE 电机保护(LC)滤波器等其他
美国上海航欧销售MTE 的5KHz正弦波滤波器等其他是设计用于把PWM变频器输出波形转换成正弦波波形,从而可以消
除电机发热,开关噪音,端子过电压,以及与电机和变频器之间的电缆过长相关的有害的dV/dT。
在可变扭矩和恒定扭矩两中应用中都是根据电机的额定功率来选择滤波器等其他。这些滤波器等其他是根据NEC电机
额定电流设计以满足电机的电流要求。对超过NEC电机额定电流时就要选择更大一级的滤波器等其他。
对于电机和变频器之间的电缆长度少于850英尺和/或对PWM变频器的输出波形不是很敏感的非关键应用
,则可以使用AC线性/负载电抗器。而对于不是480V电压和要求THVD小于5%的情况,则需要使用MTE的2
– 8KHz正弦波滤波器等其他。
美国上海航欧销售MTE电机保护(LC)滤波器等其他代表型号:RL00303C,RL00313C, RL00508C, RL00518C, RL00803C,
RL00813, RL01203C, RL01213C, RL02503C,
RL02513C, RL03503C, RL03513C, RL04503C, RL04513C,
RL05503C, RL05513C, RL08003C,
RL08013C,SX5P096D,RL10013C, SX5P124D,RL13013C,
SX5P156D,RL16013C, SX5P180D, SX5GD180D,
SX5P240D, SX5GD240D, SX5P302D, SX5GD302D,
SX5P361D, SX5GD361D, SX5P477D, SX5GD477D
