上海航欧销售TransducerTechniques传感器、TransducerTechniques开关、TransducerTechniques变送器、TransducerTechniques阀、TransducerTechniques数显表
美国TransducerTechniques公司成立于1979年,从事设计和制造系列的称重传感器,扭矩传感器,传感器和相关仪器仪表。TransducerTechniques公司的传感器的设计重量和力量等多元化的过程控制,可在工厂自动化以及其他数百个应用服务等工业领域测量。
1.TransducerTechniques称重传感器
CLC-200KCapacity:200,000lbsCompressionLoadColumn
CLC-300KCapacity:300,000lbsCompressionLoadColumn
CLC-400KCapacity:400,000lbsCompressionLoadColumn
CAL-TEDSN/APlug&PlayOptionwithConnector
AMM-66SSN/AMathangougAssembly6ftCable
AMM-612SSN/AMathangougAssembly12ftCable
AMM-620SSN/AMathangougAssembly20ftCable
AMM-650SSN/AMathangougAssembly50ftCable
THA-50-PCapacity:50lbshangouLoadCell
THA-50-QCapacity:50lbshangouLoadCell
THA-100-PCapacity:100lbshangouLoadCell
THA-100-QCapacity:100lbshangouLoadCell
THA-250-PCapacity:250lbshangouLoadCell
THA-250-QCapacity:250lbshangouLoadCell
GS0-1010gramsCalibrationhangouCompression
GS0-2525gramsCalibrationhangouCompression
GS0-3030gramsCalibrationhangouCompression
GS0-5050gramsCalibrationhangouCompression
GS0-100100gramsCalibrationhangouCompression
GS0-150150gramsCalibrationhangouCompression
GS0-250250gramsCalibrationhangouCompression
GS0-500500gramsCalibrationhangouCompression
GS0-1K1,000gramsCalibrationhangouCompression
OPTION-TCN/ATensionCalibrationOption
ALS-04N/ALoadStem(Dia..200Length.250)
ALS-06N/ALoadStem(Dia..200Length.375)
ALS-08N/ALoadStem(Dia..200Length.500)
MDB-2.52.5lbsCalibrationhangouCompression
MDB-55lbsCalibrationhangouCompression
MDB-1010lbsCalibrationhangouCompression
MDB-2525lbsCalibrationhangouCompression
MDB-5050lbsCalibrationhangouCompression
MDB-7575lbsCalibrationhangouCompression
MDB-100100lbsCalibrationhangouCompression
MLP-10Capacity:10lbsCalibrationhangouCompression
MLP-25Capacity:25lbsCalibrationhangouCompression
MLP-50Capacity:50lbsCalibrationhangouCompression
MLP-75Capacity:75lbsCalibrationhangouCompression
MLP-100Capacity:100lbsCalibrationhangouCompression
MLP-150Capacity:150lbsCalibrationhangouCompression
MLP-200Capacity:200lbsCalibrationhangouCompression
MLP-300 Capacity: 300 lbs Calibration hang ou Compression
MLP-500 Capacity: 500 lbs Calibration hang ou Compression
MLP-750 Capacity: 750 lbs Calibration hang ou Compression
MLP-1K Capacity: 1,000 lbs Calibration hang ou Compression
OPTION-CO N/A Mhang oui Connector System Option
OPTION-DB N/A Dual Bridge
OPTION-TC N/A Tension Calibration Option
CAL-TEDS N/A Plug & Play Option
with Connector
SLB-25 Capacity: 25 lbs Mhang oui Compression Button
SLB-50 Capacity: 50 lbs Mhang oui Compression Button
SLB-100 Capacity: 100 lbs Mhang oui Compression Button
SLB-250 Capacity: 250 lbs Mhang oui Compression Button
SLB-500 Capacity: 500 lbs Mhang oui Compression Button
SLB-750 Capacity: 750 lbs Mhang oui Compression Button
SLB-1K Capacity: 1,000 lbs Mhang oui Compression Button
Option with Connector
LB0-100 Capacity: 100 lbs Compression Load Button
LB0-100A Capacity: 100 lbs Compression Load Button
LB0-250 Capacity: 250 lbs Compression Load Button
LB0-500 Capacity: 500 lbs Compression Load Button
LB0-750 Capacity: 750 lbs Compression Load Button
LB0-1K Capacity: 1,000 lbs Compression Load Button
LB0-2K Capacity: 2,000 lbs Compression Load Button
LB0-3K Capacity: 3,000 lbs Compression Load Button
LB0-5K Capacity: 5,000 lbs Compression Load Button
LB0-10K Capacity: 10,000
LB0-15K Capacity: 15,000
LB0-20K Capacity: 20,000
LB0-30K Capacity: 30,000
LB0-50K Capacity: 50,000
LBC-100 Capacity: 100 lbs Compression Load Button
LBC-100A Capacity: 100 lbs Compression Load Button
LBC-250 Capacity: 250 lbs Compression Load Button
LBC-500 Capacity: 500 lbs Compression Load Button
LBC-750 Capacity: 750 lbs Compression Load Button
LBC-1K Capacity: 1,000 lbs Compression Load Button
LBC-2K Capacity: 2,000 lbs Compression Load Button
LBC-3K Capacity: 3,000 lbs Compression Load Button
LBC-5K Capacity: 5,000 lbs Compression Load Button
LBC-10K Capacity: 10,000
LBC-15K Capacity: 15,000
LBC-20K Capacity: 20,000
LBC-30K Capacity: 30,000
LBC-50K Capacity: 50,000
LBM-50 Capacity: 50 lbs
Calibrated hang ou Compression
LBM-100 Capacity: 100 lbs
LBM-200 Capacity: 200 lbs
LBM-500 Capacity: 500 lbs
LBM-1K Capacity: 1,000 lbs
LBM-2K Capacity: 2,000 lbs
LBM-2.5K Capacity: 2,500 lbs
LBM-5K Capacity: 1,000 lbs
LBM-8K Capacity: 8,000 lbs
LBM-10K Capacity: 10,000 lbs
MLC-2K Capacity: 2,000 lbs Mhang oui Comp Load Column
MLC-3K Capacity: 3,000 lbs Mhang oui Comp Load Column
MLC-5K Capacity: 5,000 lbs Mhang oui Comp Load Column
MLC-7.5K Capacity: 7,500 lbs Mhang oui Comp Load Column
MLC-10K Capacity: 10,000
MLC-15K Capacity: 15,000
MLC-20K Capacity: 20,000 lbs Mhang oui Comp Load Column
MLC-30K Capacity: 30,000
CLC-50K Capacity: 50,000
lbs Compression Load Column
CLC-100K Capacity: 100,000 lbs Compression Load Column
THA-500-P Capacity: 500 lbs hang
ou Load Cell
THA-500-Q Capacity: 500 lbs hang
ou Load Cell
THB-100-P Capacity: 100 lbs hang
ou Load Cell
THB-100-Q Capacity: 100 lbs hang
ou Load Cell
THB-100-R Capacity: 100 lbs hang
ou Load Cell
THB-100-S Capacity: 100 lbs hang
ou Load Cell
THB-250-P Capacity: 250 lbs hang
ou Load Cell
THB-250-Q Capacity: 250 lbs hang
ou Load Cell
THB-250-R Capacity: 250 lbs hang
ou Load Cell
THB-250-S Capacity: 250 lbs hang
ou Load Cell
THB-500-P Capacity: 500 lbs hang
ou Load Cell
THB-500-Q Capacity: 500 lbs hang
ou Load Cell
THB-500-R Capacity: 500 lbs hang
ou Load Cell
THB-500-S Capacity: 500 lbs hang
ou Load Cell
THB-1K-P Capacity: 1,000 lbs hang ou Load Cell
THB-1K-Q Capacity: 1,000 lbs hang ou Load Cell
THB-1K-R Capacity: 1,000 lbs hang ou Load Cell
THB-1K-S Capacity: 1,000 lbs hang ou Load Cell
THB-2K-P Capacity: 2,000 lbs hang ou Load Cell
THB-2K-Q Capacity: 2,000 lbs hang ou Load Cell
THB-2K-R Capacity: 2,000 lbs hang ou Load Cell
THB-2K-S Capacity: 2,000 lbs hang ou Load Cell
THC-250-P Capacity: 250 lbs hang
ou Load Cell
THC-250-Q Capacity: 250 lbs hang
ou Load Cell
THC-250-R Capacity: 250 lbs hang
ou Load Cell
THC-250-S Capacity: 250 lbs hang
ou Load Cell
THC-250-T Capacity: 250 lbs hang
ou Load Cell
THC-250-V Capacity: 250 lbs hang
ou Load Cell
THC-500-P Capacity: 500 lbs hang
ou Load Cell
THC-500-Q Capacity: 500 lbs hang
ou Load Cell
THC-500-R Capacity: 500 lbs hang
ou Load Cell
THC-500-S Capacity: 500 lbs hang
ou Load Cell
THC-500-T Capacity: 500 lbs hang
ou Load Cell
THC-500-V Capacity: 500 lbs hang
ou Load Cell
THC-1K-P Capacity: 1,000 lbs hang ou Load Cell
THC-1K-Q Capacity: 1,000 lbs hang ou Load Cell
THC-1K-R Capacity: 1,000 lbs hang ou Load Cell
THC-1K-S Capacity: 1,000 lbs hang ou Load Cell
THC-1K-T Capacity: 1,000 lbs hang ou Load Cell
THC-1K-V Capacity: 1,000 lbs hang ou Load Cell
THC-2K-P Capacity: 2,000 lbs hang ou Load Cell
THC-2K-Q Capacity: 2,000 lbs hang ou Load Cell
THC-2K-R Capacity: 2,000 lbs hang ou Load Cell
THC-2K-S Capacity: 2,000 lbs hang ou Load Cell
THC-2K-T Capacity: 2,000 lbs hang ou Load Cell
THC-2K-V Capacity: 2,000 lbs hang ou Load Cell
THC-3K-P Capacity: 3,000 lbs hang ou Load Cell
THC-3K-Q Capacity: 3,000 lbs hang ou Load Cell
THC-3K-R Capacity: 3,000 lbs hang ou Load Cell
THC-3K-S Capacity: 3,000 lbs hang ou Load Cell
THC-3K-T Capacity: 3,000 lbs hang ou Load Cell
THC-3K-V Capacity: 3,000 lbs hang ou Load Cell
THC-5K-P Capacity: 5,000 lbs hang ou Load Cell
THC-5K-Q Capacity: 5,000 lbs hang ou Load Cell
THC-5K-R Capacity: 5,000 lbs hang ou Load Cell
THC-5K-S Capacity: 5,000 lbs hang ou Load Cell
THC-5K-T Capacity: 5,000 lbs hang ou Load Cell
THC-5K-V Capacity: 5,000 lbs hang ou Load Cell
with Connector
THC-7.5K-P Capacity: 7,500 lbs
hang ou Load Cell
THC-7.5K-Q Capacity: 7,500 lbs
hang ou Load Cell
THC-7.5K-R Capacity: 7,500 lbs
hang ou Load Cell
THC-7.5K-S Capacity: 7,500 lbs
hang ou Load Cell
THC-7.5K-T Capacity: 7,500 lbs
hang ou Load Cell
THC-7.5K-V Capacity: 7,500 lbs
hang ou Load Cell
Button
Button
Button
Button
Button
Button
Button
Button
Button
LBC-10K Capacity: 10,000 lbs Compression Load
Button
LBC-15K Capacity: 15,000 lbs Compression Load
Button
LBC-20K Capacity: 20,000 lbs Compression Load
Button
LBC-30K Capacity: 30,000 lbs Compression Load
Button
LBC-50K Capacity: 50,000 lbs Compression Load
Button
LBM-50 Capacity: 50 lbs Calibrated hang ou
Compression
LBM-100 Capacity: 100 lbs Calibrated hang ou
Compression
LBM-200 Capacity: 200 lbs Calibrated hang ou
Compression
LBM-500 Capacity: 500 lbs Calibrated hang ou
Compression
LBM-1K Capacity: 1,000 lbs Calibrated hang ou
Compression
LBM-2K Capacity: 2,000 lbs Calibrated hang ou
Compression
LBM-2.5K Capacity: 2,500 lbs Calibrated hang ou
Compression
LBM-5K Capacity: 1,000 lbs Calibrated hang ou
Compression
LBM-8K Capacity: 8,000 lbs Calibrated hang ou
Compression
LBM-10K Capacity: 10,000 lbs Calibrated hang ou
Compression
Button
Button
Button
Button
Button
Button
Compression Button
Button
THC-10K-P Capacity: 10,000
THC-10K-Q Capacity: 10,000
THC-10K-R Capacity: 10,000
THC-10K-S Capacity: 10,000
THC-10K-T Capacity: 10,000
THC-10K-V Capacity: 10,000
THD-2K-P Capacity: 2,000 lbs hang ou Load Cell
THD-2K-Q Capacity: 2,000 lbs hang ou Load Cell
THD-2K-R Capacity: 2,000 lbs hang ou Load Cell
THD-2K-S Capacity: 2,000 lbs hang ou Load Cell
THD-2K-T Capacity: 2,000 lbs hang ou Load Cell
THD-2K-V Capacity: 2,000 lbs hang ou Load Cell
THD-2K-W Capacity: 2,000 lbs hang ou Load Cell
THD-2K-Y Capacity: 2,000 lbs hang ou Load Cell
THD-2K-Z Capacity: 2,000 lbs hang ou Load Cell
THD-3K-P Capacity: 3,000 lbs hang ou Load Cell
THD-3K-Q Capacity: 3,000 lbs hang ou Load Cell
THD-3K-R Capacity: 3,000 lbs hang ou Load Cell
THD-3K-S Capacity: 3,000 lbs hang ou Load Cell
THD-3K-T Capacity: 3,000 lbs hang ou Load Cell
THD-3K-V Capacity: 3,000 lbs hang ou Load Cell
THD-3K-W Capacity: 3,000 lbs hang ou Load Cell
THD-3K-Y Capacity: 3,000 lbs hang ou Load Cell
THD-3K-Z Capacity: 3,000 lbs hang ou Load Cell
THD-5K-P Capacity: 5,000 lbs hang ou Load Cell
THD-5K-Q Capacity: 5,000 lbs hang ou Load Cell
THD-5K-R Capacity: 5,000 lbs hang ou Load Cell
THD-5K-S Capacity: 5,000 lbs hang ou Load Cell
THD-5K-T Capacity: 5,000 lbs hang ou Load Cell
THD-5K-V Capacity: 5,000 lbs hang ou Load Cell
THD-5K-W Capacity: 5,000 lbs hang ou Load Cell
THD-5K-Y Capacity: 5,000 lbs hang ou Load Cell
THD-5K-Z Capacity: 5,000 lbs hang ou Load Cell
THD-7.5K-P Capacity: 7,500 lbs
hang ou Load Cell
THD-7.5K-Q Capacity: 7,500 lbs
hang ou Load Cell
THD-7.5K-R Capacity: 7,500 lbs
hang ou Load Cell
THD-7.5K
Button
Button
Button
Button
Button
Button
Button
Button
LB0-10K Capacity: 10,000 lbs Compression Load
Button
LB0-15K Capacity: 15,000 lbs Compression Load
Button
LB0-20K Capacity: 20,000 lbs Compression Load
Button
LB0-30K Capacity: 30,000 lbs Compression Load
Button
LB0-50K Capacity: 50,000 lbs Compression Load
Button
Shanghai HangOu Mechanical & Electrical
Equipment Co., Ltd. was established in 2006, and is specializing in the
import of mechanical & electrical equipment spare parts, instruments and
other products and brands of worldwide. These products are widely used in
metallurgy, iron and steel, petrochemicals, energy, aerospace, container
terminals, automation, water conservancy, papermaking, power plant, textile,
injection molding, rubber, medical treatment, food packaging and other
fields. Our main product lines include: sensors, motors, switches,
electronic scale, encoders, controllers, analysis meters,optical fibers,
gratings,valves, warning lights, cable, towline, distributor, gearbox, relays,
buffers and imported hardware. ShangHai HangOu Mechanical And Electrical
Equipment Co.,Ltd
Address: Room 905, Building No.1, Guoson Centre, Lane 388, Zhongjiang
Road. Shanghai, China.
Tel:0086-21-51085161
0086-21-52391901
Fax:021-51870910
021-52391837
E-Mail:sales@shhangou.com
sales@shhangou.com.cn
Zip Code:200062
Website:www.shhangou.com
www.shhangou.com.cn
