上海航欧销上海航欧销售SENECA传感器SENECA电流传感器、SENECA开关SENECA编码器SENECA信号隔离器、SENECA适配器SENECA I/ O模块、SENECA通信通讯模块、SENECA面板显示仪
A-169DV12 A-169DV14 A-169YAGI A-DIN-T201
A-DIR-10-869 A-DIR-6-869 A-GPS A-GSM A-GSM-DIR-5M A-GSM-OMNIDIR
A-GSM-OMNIDIR-10 A-GSM-QUAD ANT-LINK1-MG A-STIL A-STIL-D B BATT-S C
CE-RJ45-RJ45-C CE-RJ45-RJ45-R CS-DB9F-CFV10 CS-DB9F-CLAMP CS-DB9F-DB25M SENECA电流传感器CS-DB9F-DB9F
CS-DB9F-TIP CS-DB9F-TIP-V CS-DB9M-DB9F CS-DB9M-DB9M CS-DB9M-MEF-1012
CS-DB9M-MEF-PH CS-DB9M-TIP CS-DB9M-TIP-V CS-JACK-DB9F CS-JACK-JACK CS-RJ10-AMP
CS-RJ10-DB25M-1 CS-RJ10-DB25M-2 CS-RJ10-DB9F CS-RJ10-DB9M CS-RJ10-TIP
CS-TPW-TIP CS-TPW-TPW CU-A-MICROB CU-A-MINIB-1 CU-A-MINIB-2 CU-A-MICRO-OTG D
DL169-RS232 DL169-RS232-Y DL-COUNT DL-MA DL-MV DL-V DOC-CENE-1510-0-ITA
DOC-CFS-1603-IE DOC-CLIS-1507-0-ITA DOC-CSIN-1603-0-ITA DOC-PCAT-1511-0-ENG DOC-PCAT-1511-0-DEU
DOC-PCAT-1602-0-SPA DOC-POVE-1410-0-SPA DOC-POVE-1411-0-ENG DOC-POVE-1411-0-RUS
DOC-POVE-1411-0-TED DOC-PCAT-1511-0-DEU DR-2 DR-4 DR-8 DR-16 DR-32 DR-64
DR-2-PLUS DR-4-PLUS DR-8-PLUS DR-16-PLUS DR-32-PLUS DR-64-PLUS E EASY RELAY
EASY-USB F FD01 FH190-24 FLEX-DIN K K107A K107B K107USB K109LV K109PT
K109PT1000 K109PT-HPC K109S K109TC K109UI K111 K111-C K112 K120RTD K120RTD-C
K121 K121-C K400CL K400CL-10 K-BUS K-SUPPLY KIT-USB L M MSD MY-0 MY-PT-150-3
MY-PT-250-2 MY-PT-150-3R MY-PT-KIT MY-TC-250-3 MY-TC-250-1.5 MY-TC-AC MY-TC-KIT
MY-UT MY2B-0-0-M-B MY2B-0-0-M-G MY2-KITIP66 MY2B-R-0-M-B MY2B-R-0-M-G
MY2B-0-0-M-B-4X MY2B-0-0-M-G-4X MY2B-R-0-M-B-4X MY2B-R-0-M-G-4X MY2G-0-0-M-B
MY2G-0-0-M-G MY2G-R-0-M-B MY2G-R-0-M-G MY2G-0-0-M-B-4X MY2G-0-0-M-G-4X
MY2G-R-0-M-B-4X MY2G-R-0-M-G-4X MY2S-0-0-M-B MY2S-0-0-M-G MY2S-R-0-M-B
MY2S-R-0-M-G MY2S-0-0-M-B-4X MY2S-0-0-M-G-4X MY2S-R-0-M-B-4X MY2S-R-0-M-G-4X O
OPC-SERVER OPC-SERVER-IO-1 OPC-SERVER-IO-2 OPC-SERVER-IO-3 OPC-SERVER-MB-1
OPC-SERVER-MB-2 OPC-SERVER-MB-3 P POZZ-100 POZZ-150 POZZ-200 POZZ-250 POZZ-300
POZZ-50 PT-150-3-M12 PT-250-2-M12 PT-150-3R-M12 PT100-100 PT100-100-MA
PT100-150 PT100-150-MA PT100-200 PT100-200-MA PT100-250 PT100-250-MA PT100-300
PT100-300-MA PT100-50 PT100-50-MA PT100-A PT100-A-MA PT100-SOLAR PT100-SOLAR-MA
R RC-V250-100 RC-V400-050 RC-V400-100 RC-V500-100 RC150-025-100-3M
RC150-040-100-3M RC150-060-100-3M RM169-169DV12 RM169-169YAGI RM169-169DV14
RM169 RTURADIO-169 RTURADIO-169DV14 RTURADIO-169DV12 RTURADIO-169YAGI S
S100S-1-ST S100S-3-ST S102-1-ST S104-1-ST S105CS1-B S105CS1-C S105TCS-1
S105TCS-2 S105TCS-3 S107P S107MBU S107USB S108 S109PT-1-ST S109REG-1-ST
S109REG-1-X7 S109S-1-ST S111-1-ST S112A-1-ST S112D-1-ST S112M-1-ST S112M-23-ST
S113S-1-ST S113T-1-ST S117P1 S170-1-ST S190-1-ST S2000-1-ST S2000-23-ST
S200-1-ST S200D-1-ST S200G S200REG-16 S200REG-24 S201D-1-ST S201DP-1-ST
S203RC-D S203T S203TA S203TA-D S20ADP S20ADP-CM S20ADP-CM-S S20ADP-IP65
S20N1-1-ST S20N1-23-ST S20N1EX-1-ST S20N1EX-23-ST S20N1IP65-1-ST
S20N1IP65-23-ST S20N1-KIT-1-ST S20N1-KIT-23-ST S21N1-1-ST S21N1-23-ST
S21N1EX-1-ST S21N1EX-23-ST S21N1IP65-1-ST S21N1IP65-23-ST S232-FO-MONO-SL
S232-FO-MONO-DL S232-FO-MULTI-SL S232-FO-MULTI-DL S301-1-R S301-1-R-AOC-S
S301-1-R-AR-S S301-23-R S301-23-R-AOC-S S301-23-R-AR-S S301B-1-R
S301B-1-R-AOC-S S301B-1-R-AR-S S301B-23-R S301B-23-R-AOC-S S301B-23-R-AR-S
S311A-11-H S311A-11-H-O S311A-11-L S311A-11-L-O S311A-4-H S311A-4-H-O S311A-4-L
S311A-4-L-O S311A-6-H S311A-6-H-O S311A-6-L S311A-6-L-O S311A-8-H S311A-8-H-O
S311A-8-L S311A-8-L-O S311AK-4-L S311AK-4-L-IP66 S311AK-4-L-IP66D S311D-11-H
S311D-11-H-O S311D-11-L S311D-11-L-O S311D-4-H S311D-4-H-O S311D-4-L
S311D-4-L-O S311D-6-H S311D-6-H-O S311D-6-L S311D-6-L-O S311D-8-H S311D-8-H-O
S311D-8-L S311D-8-L-O S311OPZ S311-T S312A-4-H-4R S312A-4-L-4R S315 S315-IP66
S315-IP66D S320A-1-ST S320A-1-ST-R S320A-23-ST S320A-23-ST-R S400CL S400HV
S400LV S400HV-2 S400HV-2-RIC-SL S400HV-2-RIC-SN S400LV-1 S400LV-1-RIC-SL
S400CL-1 S400CL-1-15 S400CL-1-P5 S400NET S400NET-RIC-SL S400ETH-DSK S401-L
S485-FO-MONO-DL S485-FO-MULTI-DL S485-FO-MONO-SL S485-FO-MULTI-SL S50-1-ST
S50-3-ST S500-MOD S500-MBU S500-ETH S501-32-0 S501-32-MBU-MID S502-80-MID
S502-80-R S504C-6-MOD-MID S504C-6-MBU-MID S504C-6-ETH-MID S504C-80-MOD-MID
S504C-80-MBU-MID S504C-80-ETH-MID S534-6-MID S534-80-MID S604B-6-MOD
S604B-6-ETH S604B-80-MOD S604B-80-ETH S604E-6-MOD S604E-6-ETH S604E-80-ETH
S604E-ROG-MOD-30 S604E-ROG-MOD-45 S604E-ROG-MOD-70 S604E-ROG-ETH-30
S604E-ROG-ETH-45 S604E-ROG-ETH-70 S6001-PC S6001-RTU S6001-RTU-E S711B6MOD
S711E6MOD S711E6ETH S711EROGETH45 S-DIN SCAN-FO-MONO-SL SCAN-FO-MONO-DL
SCAN-FO-MULTI-SL SCAN-FO-MULTI-DL SETH-FO-MONO-SL SETH-FO-MONO-DL
SETH-FO-MULTI-SL SETH-FO-MULTI-DL SG-EQ4 SG-EQ4-BOXPG7 SOFT-EDUC SOFT-OTLM
S-TOOL STRATON-D-USB STRATON-IDE256 STRATON-IDE512 STRATON-IDEUN STRATON-IEC-E1
STRATON-IEC-E2 STRATON-IEC-E3 STRATON-IEC-E4 STRATON-IEC-E5 STRATON-IEC-EF T
T120 T120-C T121 T121-C T201 T201DC T201DC100 T201DCH T201DCH100 T201DCH300
T201DCH50-LP T201DCH100-LP T201DCH300-LP TA100 TA15 TA25 TCK-250-3-M12 TCK-250-1.5-M12
TCK-W-1000-M12 TCK-AC-M12 TEST-4-PK TEST-4-R TEST-4-T TEST-4 U USB-SW-KEY
UT-M12 V VISUAL1 VISUAL2 VISUAL3 VISUAL4 VPN BOX Z Z102 Z104 Z107 Z109PT2-1
Z109REG Z109REG-BP Z109REG2-1 Z109REG2-H Z109S Z109S-DI Z109TC2-1 Z109UI2-1
Z-10-D-IN Z-10-D-OUT Z110D Z110S Z111 Z112A Z112D Z113-1 Z113D Z113S Z113T
Z170REG-1 Z190 Z201 Z201-H Z202 Z202-H Z202-LP Z203-1 Z204-1 Z-4DI-2AI-2DO
Z-3AO Z-4AI Z-4AI-D Z-4RTD2 Z-4TC Z-4TC-D Z-8AI Z-8R-10A Z-8TC Z-AIR
ZC-16DI-8DO ZC-24DI ZC-24DO ZC-3AO ZC-4RTD ZC-8AI ZC-8TC Z-CALC ZC-SG Z-DAQ-PID
Z-D-IN Z-D-IO Z-D-OUT ZE-2AI ZE-4DI-2AI-2DO Z-FLOWCOMPUTER Z-GPRS3 Z-KEY-0
Z-LINK1-NM Z-LOGGER3 Z-MINIRTU Z-MODEM Z-MODEM-3G Z-PASS1-0 Z-PASS2-A Z-PASS2-B
Z-PASS2-S-A Z-PASS2-S-B Z-PASS2-S-A-E Z-PASS2-S-B-E Z-PC-DIN1-35 Z-PC-DIN2-17.5
Z-PC-DIN4-35 Z-PC-DIN8-17.5 Z-PC-DINAL1-35 Z-PC-DINAL2-17.5 Z-PC-DINAL2-52.5
Z-POWER-115-15VA Z-POWER-230-15VA Z-POWER-230-25VA Z-SG Z-SUPPLY Z-TWS11
Z-TWS4-L-0 Z-TWS4-L-K Z-TWS4-S-0 Z-TWS4-S-K Z-TWS4-E-0 Z-TWS4-E-K Z-TWS5 上海航欧机电设备有限公司成立于2006年,专业从事进口机电设备、仪器仪表等备品备件的销售,是经营世界各地进口设备机电配件的企业。上海航欧公司与众多品牌电子元件供应商建立有良好的合作关系,在欧美、日本等地形成了稳定的供应网络,良好的供应商关系和多年的行业经验,使我们在价格及货期上有优势。经销产品供应的行业涉及冶金、钢铁、石化、能源、航天、集装箱码头、汽车、水利、造纸、电厂、纺织、注塑、橡胶、食品包装等。我们热忱地希望尽我们的努力,力争优惠的产品价格,供货周期以及服务质量,能够为您解决进口备件方面的问题。进口产品主要有:传感器,测速电机,接近开关,电子尺,编码器,控制器、分析仪,光纤,光栅,插装阀,电缆,拖链,分配器,马达,减速机,继电器、缓冲器和进口五金等
MTN/1185-25 现货查询
MTN/1185C-25 现货查询
MTN/1185CM-100 现货查询
MTN/1185CM-25/129 现货查询
MTN/1185CM8-20 现货查询
MTN/1185CM8-25F 现货查询
MTN/1185CQ-20(10米线缆) 现货查询
MTN/1185CQ-20(5米线缆) 现货查询
MTN/1185ICQ-20 现货查询
MTN/1185M-100 现货查询
MTN/1187-10
现货查询
MTN/1187C-5+MTN/MS067 现货查询
MTN/1187C-5+MTN/MS067(10米线缆) 现货查询
MTN/1187CM8-1/219 现货查询
MTN/1187CM8-7 现货查询
MTN/2285CM8-20 现货查询
MTN/CA137-1185(20米线缆) 现货查询
MTN/CA137-1185(30米线缆) 现货查询
MTN/CA137-1185(5米线缆) 现货查询
MTN/CA284 现货查询
MTN/IEIGW75-20M 现货查询
MTN/IEIRGW075-20M 现货查询
MTN/IEIRW50/372 现货查询
MTN/MH008 现货查询
MTN/MS002 现货查询
MTN/MS068
现货查询
MTS8M528-30 现货查询
MUP-110-1 现货查询
MVSI 15/200E-S02 现货查询
MXYZ-20B MXYZ-20 现货查询
model
843/N Mod.843/M 现货查询
N WE-D105 现货查询
084902N01D550-M 现货查询
NBS G 2100 现货查询
83607120NBS G 740 现货查询
NCB1 现货查询
NCB2 现货查询
NCB20 现货查询
NCR10 现货查询
NCR120 现货查询
NCR22 现货查询
NCR3 现货查询
NCT10 现货查询
NCT10i 现货查询
NCT2 现货查询
NCT29 现货查询
NCT29I 现货查询
NCT4 现货查询
NCT4i 现货查询
NCT5 现货查询
NEA5020 现货查询
NEA504 现货查询
NEA5050 现货查询
03108000NEG 50770 现货查询
NEG50120 现货查询
NEG5020 现货查询
NEG50200 现货查询
NEG5050 现货查询
NFB210C088 24VDC 现货查询
88631NG2HB-510SVM5 现货查询
NI50U-QV40-AP6X2-H1141 现货查询
NL2024HD22 现货查询
NM-521-H/24v 现货查询
NTK 40 NF 现货查询
NTK15X 现货查询
NTK16 现货查询
NTK18AL 现货查询
NTK25 现货查询
NTK25AL 现货查询
NTK8AL 现货查询
04325201NTP25 B+C 现货查询
NTS 120 NFL 现货查询
01912600NTS120HF 现货查询
NTS120NF 现货查询
NTS180HF 现货查询
01918500NTS180NF 现货查询
01925600NTS250HF 现货查询
NTS350HF 现货查询
1638-95798-01002Nano S 10-60 现货查询
OC 168 现货查询
PX11-11-1-MIC25 OC167 现货查询
OCF043-0700 现货查询
OG40A (OG400ABE) 现货查询
OGU
051 G3-T3 OGU 051 P3K-TSSL 现货查询
OGWSD 70 P3K-TSSL 现货查询
OPS1-5 现货查询
OPT292 现货查询
OPTO2S 现货查询
OT-SK M18-waterresistant 现货查询
OY2P303A0135 现货查询
P-UL,UM,UH-03,04-40UW (UL-03A40uW-1V滤芯) 现货查询![](http://www.cechina.cn/UpLoad/CompanyFile/2023/1/31/3d7d30a2-0e7b-426e-a5eb-96d1be5fb4ae.jpg)
