2019年LAMBRECHT工厂上海航欧中国区销售
LAMBRECHT风速仪、LAMBRECHT风向标、LAMBRECHT传感器、LAMBRECHT控制器、LAMBRECHT温度传感器、LAMBRECHT湿度传感器
LAMBRECHT风速仪LAMBRECHT风向标
LAMBRECHT00.02900.010025AneroidBarograph945...1051.7hPa;55...170m;7d
LAMBRECHT00.02900.030025AneroidBarograph945...1051.7hPa;55...170m;1d
LAMBRECHT00.02900.050025AneroidBarograph945...1051.7hPa;55...170m;31d
LAMBRECHT00.02920.110002Large-SizeBarograph865...1051.7hPa;930...0m;7d
LAMBRECHT00.02920.210002Large-SizeBarograph785...971.7hPa;1680...690m;7d
LAMBRECHT00.02920.310002Large-SizeBarograph705...981.7hPa;2500...1430m;7d
LAMBRECHT00.04853.095000DigitalPrecisionBarometer35...1300hPa
LAMBRECHT00.04853.195000DigitalPrecisionBarometer75...1150hPa
LAMBRECHT00.06040.100000MercuryBarometeracc.toLAMBRECHT840...1050hP
LAMBRECHT00.06040.100002MercuryBarometeracc.toLAMBRECHT840...1050hPa,officiallycalibrated
LAMBRECHT00.06070.100000MercuryBaroVacuumGaugeonrequest
LAMBRECHT00.06100.100000StationBarometeronrequest
LAMBRECHT00.06280.025000PitotTubesacc.toPrandtlL=250mm,D3
LAMBRECHT00.06286.000000Screwnecksfor(628)
LAMBRECHT00.06300.025000PitotTubesacc.toPrandtlL=250mm,D10
LAMBRECHT00.06300.050000PitotTubesacc.toPrandtlL=500mm,D10
LAMBRECHT00.06300.075000PitotTubesacc.toPrandtlL=750mm,D10
LAMBRECHT00.06306.000000Screwnecksfor(630)
LAMBRECHT00.06310.100000PitotTubesacc.toPrandtlL=1000mm,D17onrequest
LAMBRECHT00.06316.000000Screwnecksfor(631)50,00
LAMBRECHT00.06400.041000FlowMeter0.7...50m/s;E=400mm
LAMBRECHT00.06400.071000FlowMeter0.7...50m/s;E=700mm
LAMBRECHT00.06550.160000MicroManometeronrequest
LAMBRECHT00.07060.000020PsychrometerwithExtremeThermometers0.5°C/0.2°C
LAMBRECHT00.07060.000050PsychrometerwithExtremeThermometers0.2°C/0.2°C
LAMBRECHT00.07061.000020PsychrometerwithExtremeThermometers0.5°C/0.2°C
LAMBRECHT00.07061.000050PsychrometerwithExtremeThermometers0.2°C/0.2°C
LAMBRECHT00.07400.000010WhirlingPsychrometer
LAMBRECHT00.07610.000010AspirationPsychrometerAssmann-5...+60°C
LAMBRECHT00.07610.000012AspirationPsychrometerAssmann-5...+60°C,officiallycalibrated
LAMBRECHT00.07610.000020AspirationPsychrometerAssmann-30...+40°C
LAMBRECHT00.07610.000022AspirationPsychrometerAssmann-30...+40°C,officiallycalibrated
LAMBRECHT00.07680.030000Psychrometrictableacc.toSonntag
LAMBRECHT00.07710.020000Psychrometrictableacc.toBongards
LAMBRECHT00.08000.201010HumiditySensor0...100ohmlinear
LAMBRECHT00.08000.202030HumiditySensor50-30-50ohmlog.
LAMBRECHT00.01940.100000RoundHygrometer
LAMBRECHT00.01980.100000Thermo-Hygrometeronrequest
LAMBRECHT00.02020.100000LAMBRECHT-Polymeter
LAMBRECHT00.02350.125000MountingHygrometer
LAMBRECHT00.02500.111000Hygrograph100-0;7d
LAMBRECHT00.02500.131000Hygrograph100-0;7/1d
LAMBRECHT00.02510.010100Thermograph35-0-45;7d650,00
LAMBRECHT00.02510.010700Thermograph10-0-50;7d650,00
LAMBRECHT00.02510.010900Thermograph0-40;7d650,00
LAMBRECHT00.02510.030100Thermograph35-0-45;7/1d748,00
LAMBRECHT00.02510.050100Thermograph35-0-45;31d
LAMBRECHT00.02520.110100Thermo-Hygrograph35-0-45;100-0;7d
LAMBRECHT00.02520.110300Thermo-Hygrograph20-0-60;100-0;7d
LAMBRECHT00.02520.110700Thermo-Hygrograph10-0-50;100-0;7d
LAMBRECHT00.02520.110900Thermo-Hygrograph0-40;100-0;7d
LAMBRECHT00.02520.111200Thermo-Hygrograph0-80;100-0;7d
LAMBRECHT00.02520.130100Thermo-Hygrograph35-0-45;100-0;7/1d
LAMBRECHT00.02520.130300Thermo-Hygrograph20-0-60;100-0;7/1d
LAMBRECHT00.02520.130900Thermo-Hygrograph0-40;100-0;7/1d
LAMBRECHT00.02520.131200Thermo-Hygrograph0-80;100-0;7/1d
LAMBRECHT00.02520.150100Thermo-Hygrograph35-0-45;100-0;31d
LAMBRECHT00.02520.150700Thermo-Hygrograph10-0-50;100-0;31d
LAMBRECHT00.02520.150900Thermo-Hygrograph0-40;100-0;31d
LAMBRECHT00.02520.170700Thermo-Hygrograph10-0-50;100-0;7/1/31d
LAMBRECHT00.02520.170900Thermo-Hygrograph0-40;100-0;7/1/31d
LAMBRECHT00.02520.230900Thermo-Hygrograph,Pernix0-40;100-0;7/1d
LAMBRECHT00.02520.370600Thermo-Hygrograph,syntheticfiber10-0-40;100-0;7/1/31d
LAMBRECHT00.02520.370900Thermo-Hygrograph,syntheticfiber0-40;100-0;7/1/31d
LAMBRECHT00.02530.110124Meteorograph35-0-45;100-0;988;7d
LAMBRECHT传感器00.02530.110125Meteorograph35-0-45;100-0;998;7d
ENRZ-CVEN-050 现货查询
100-940303EO-4S 现货查询
010 017 0004EP 1500 现货查询
010 019 0002EP 2500 现货查询
EP-2RJ45-R-32 现货查询
EP-4EX 现货查询
EP-AP 16 现货查询
EP-RJ45-R-32 现货查询
EP08W2A02N04 现货查询
EP11(0-0.2MPA) 现货查询
EP12W2A02N05 现货查询
EP25L-A-FL-B 现货查询
EP3-16*1.5-10-BLUE 现货查询
FGE0213EP3640-1436-7-56BC-CU 现货查询
EP500 EP5 现货查询
460628EP5XX-HPGU-23K01-PV9DA-4Z 现货查询
EPB103/1PR 现货查询
EPB502/3PR 现货查询
108999EPDM DN150 现货查询
EPDM 零件编号:780827 现货查询
EPINUS 2K-NT-MKTS 现货查询
EPNSW 2420 现货查询
EPOWER/2PH-160A/600V/230V/XX/XXX/XXX/XX EPOWER/2PH-160A/600V/230V/XX/XXX/XXX/XX EPOWER 现货查询
ENG/250A/380V/1P/1P/TR/BF/TP/XX/XX//XX//X//XX/XX/XXEPOWER/2PH-250A/600V/230V/XXX/XXX/XXX/OO//Y2/XX/XX/XX/XXX/XF/XX/LTC/XXX/XXX/QS/
现货查询
EPP2M01-020 现货查询
EPP2M01-2KV 现货查询
EPP2M02-488 现货查询
P4CG4201D003 EPP3BC41U70020 现货查询
EPR-G01-2-1209-12 NO:69025 现货查询
EPR100S-000-SA01-01-03 现货查询
EPSH3-70-S50 现货查询
EPSR2-11-20-SG-1-24V-S 现货查询
EPV-500B 现货查询
EPX 现货查询
EQ 96E 100/5A 现货查询
EQ 96E 15A 现货查询
EQ 96E 200/5A 现货查询
EQ 96E 20A 现货查询
EQ 96E 30A 现货查询
EQ 96E 40/5A 现货查询
EQ 96E 500/5A 现货查询
EQ 96E 60/5A 现货查询
EQ 96E 80/5A 现货查询
EQ-34-PN-J 现货查询
674.120.1000.16EQ72K 250/1A 现货查询
674.120.1000EQ72K 400/1A 现货查询
EQ72KL
0...100/200A 现货查询
684.130.0635EQ96KL 500V 现货查询
ER-144A/EX 230VACER-144-A-6002E 现货查询
(002)
NJ LCR300LS115AC ER-25-01-M 现货查询
ER-PLX360 现货查询
ER104-92AP
现货查询
ER14505 现货查询
ER1830PPAS-1 现货查询
ER5KD286 现货查询
ER5KD341 现货查询
ER5KD358 现货查询
ER7-16 现货查询
ERA52NFD 现货查询
ERB7-45 现货查询
6151652860ERF3L 现货查询
317 393-02 ROD431.001-1024ERN 1331 1024 现货查询
ERO-85/QC 现货查询
ERP076152 现货查询
ERS2 6151656880 现货查询
6151656940ERSF2 1/5V 3-120W 现货查询
ERV-W DN250 PN10 NBR 现货查询
ERWPAB3002M020 现货查询
ERWPAB3002M030 现货查询
ERWPAU7011M010 现货查询
ERWPAU7011M020 现货查询
ES 现货查询
530200ES 2001/230V 50 HZ 现货查询
ES 33350.806 现货查询
24308317ES 790*840*100/12.5 (A open) NBR 现货查询
ES-10162.727 现货查询
ES-10170.843 现货查询
ES-10210.843 现货查询
ES-10230.376 现货查询
ES-10230.843 现货查询
ES-10250.843 现货查询
ES-4322 ES-4022 现货查询
ES-5021 现货查询
106435 ES-XA1E-BV3U02R 现货查询
ES0025 现货查询
ES024DC 现货查询
ES0350 现货查询
4220042007049 FS0350-NM40CWALTN-L27SKA-00XX ES0350H1A04A27KO
现货查询
4220196001003 FS0600-NM40CWALTN-L27SKA-00XX ES0600.M1A04A.27K0
现货查询
ES0950 现货查询
ES1000-9718 现货查询
