上海航欧销售BOSTON GEAR变送器BOSTON GEAR减速机BOSTON GEAR电机BOSTON GEAR衬套BOSTON GEAR齿轮BOSTON GEAR齿轮箱BOSTON GEAR滚轮BOSTON GEAR轴承
Boston Gear BOSTON GEAR滚轮F71330SVB5G6D0R
Gear Reducer Ratio 30 Input HP 0.32
NEW BOSTON GEAR FWC718300B5G FWC718-300-B5-G GEAR REDUCER 300:1 R14195
BOSTON GEAR F71330B5G SPEED REDUCER
NEW BOSTON GEAR CSSC150 CLAMPING SHAFT COLLAR SS 2-1/2X1-1/2X1/2IN
D229662
NEW BOSTON GEAR F715-5-B5-G SPEED REDUCER F7155B5G
Boston Gear RF718-60-B5-G SPEED REDUCER 60:1
NEW SEALED BOSTON GEAR 38494 X5984 CARBON BRUSH Lot of (4)
NEW BOSTON GEAR REDUCER RATO MOTOR F313-5-51 50.00
32431 Old-Stock, Boston Gear F73220B9692 Speed Reducer, 20:1 Ratio
BOSTON GEAR 1.110HP, 180LB/IN, 5 RATIO, SPEED REDUCER F713-5-B5-G
NEW BOSTON GEAR F72110B5G F721-10-B5-G 2.14HP 10:1 GEAR REDUCER 56C
D225996
Boston Gear Worm Gear DL 400-L 20 Teeth
Boston Gear 700 Series Gear Box Speed Reducer .46 H.P. 718406 NEW 75.00
Boston Gear F622A-8-B5 Gear Drive/Speed Reducer
28863 New In box, Boston Gear F718-10-B5-G Gearbox 10:1, 1.61 Input HP
BOSTON GEAR .670HP, 304LB/IN, SPEED REDUCER F315-15-G1-T2
NEW BOSTON GEAR REDUCER 5:1 RATIO 7/8" X 3/8" 1750 RPM
Boston Gear 001 F226D-17-B7 143T Face Mount 17:1 Ratio Speed Reducer
Gear Box
BOSTON GEAR SF71815NB5G 422LB-INCH WORM GEAR 3/41IN 0.91HP 15:1 REDUCER
B225235
BOSTON GEAR F715E-20X-B5-G-T1 0.53HP 20:1 GEAR 56C REDUCER D222422
NEW BOSTON GEAR F71820B5G SPEED REDUCER 20:1 RATIO 511 INLB OUTPUT
TORQUE
NEW BOSTON GEAR SF71820NB5J SF718-20NB5J 0.87HP 20:1 GEAR REDUCER
D222405
Boston Gear KSD60-1 Steel Sprocket
9.95
Boston Gear 718 AL U Horizontal Base Kit, Sealed / New
Boston Gear 2 5/8" Diameter 30 Teeth Spur Gear .25
BOSTON GEAR F726-60-B5-J WORM GEAR REDUCER 50:1 W/ BALDOR ? HP MOTOR
david boston 1999 edge 1st place hologold game gear ball cardinals
NEW BOSTON GEAR F718-30-B5-G F71830B5G 56C 0.63HP 30:1 GEAR REDUCER
D224271
71860J BOSTON GEAR REMANUFACTURED
Boston gear reducer 715-50-G, 50:1 ratio, 315-50-G, 71550G, 51627,
715-50-J,5162 39.50
Boston Gear F713-40-B5-G SPEED REDUCER 40:1 F71340B5G
BOSTON GEAR F226D-24-B5 0.980HP 24:1 GEAR REDUCER 1750RPM 809LB-IN
D201950
NEW BOSTON GEAR F718-60-B5-H 5/8 IN 7/8 IN 0.35HP 60:1 GEAR REDUCER
B225834
BOSTON GEAR F622A-12.5-B7 GEAR REDUCER 12.5:1 7/8IN INPUT 1IN OUTPUT
R23899
Boston F726-5-B9-G Speed Reducer Worm Gear Box 5:1 Ratio 5.75 HP NEW
Boston Gear F72625B7G 25:1 700 Series Speed Reducer 1.92 HP
Boston Gear Reducer 700 Series Cat. F724-40-B5-G Ratio 40:1 .96 Input HP
NWOB
BOSTON GEAR PART W/FC20 3/4 AND FC20 7/8 NEW
Boston gear reducer RF718-10-B5J, 10:1, RF318-10-B5, RF718-10-B5-J,
RF718-10-B5G 25.50
BOSTON GEAR FWA713600B46 GEAR REDUCER 600:1 42CZ 7/8IN INP 5/8IN OUT
R14078
BOSTON GEAR F710-10-B4-G GEAR REDUCER 10:1 0.33HP 1/2IN IN 1/2IN OUT
R21787
BOSTON GEAR 721-10-G SPPED REDUCER 51684 71010G NIB
Boston Gear FC301 Shaft Coupling Half, FC30 Coupling Size, 1 inch Bore
Boston F718-30-B5-G Speed Reducer Worm Gear Box 30:1 Ratio 0.53 HP 58
RPM
8215 New-No Box, Boston Gear F843B-56K-B5 Gearbox 54.28 Ratio
Boston Gear F721-15S-B5-G6-D0 Gear Reducer Input HP 1.40 Ratio 15 49.95
New Boston Gear Box 527-8050FL 14606-2810-00 Input .140HP Output 120
IN/LB
NEW BOSTON GEAR 18182 H1224R 5/8IN BORE 2IN PITCH HELICAL GEAR D221957
Boston Gear F72630B7G 30:1 700 Series Speed Reducer 143T 145T 1.5 HP NEW
Boston Gear ISO 9002 Speed Reducer Model HF71830B5HP16 Ratio 30 .53
Input HP New
Boston 724-40-G 72440G 40:1 Speed Reducer Gear Box 1750 RPM .96 in HP
New
NEW BOSTON GEAR F715-20-B5-6 5/8 IN 3/4 IN 0.63HP 20:1 GEAR REDUCER
B225826
BOSTON GEAR ISO 9002 / F72460B50 SPEED REDUCER, 0.7 HP INPUT, RATIO 60
NV
92839 Old-Stock, Boston Gear F73860B7G Speed Reducer 2.17 Input Hp
NEW BOSTON GEAR SF718-30NB5G SF71830NB5G 0.53HP 30:1 GEAR REDUCER
D222378
Boston Gear PM925AT-B 90v .25 1/4 HP 56 C 1750 Baldor
Boston Gear Reducer 700 Series Cat F724-15-B5-G Ratio 15:1 2.34 Input HP
NWOB
Boston Gear ISO 9002 Reducer Model F730-40-KT-B7-J3 Ratio 40 1.78 HP
NWOB
Boston Gear F315-20-G1 SPEED REDUCER RATIOMOTOR
Boston Gear 713-40 J Gear Head with Accessories
NEW BOSTON GEAR X726-11HA-BK HORIZONTAL BASE MOUNT KIT D210145
Boston Gear 300 Series Cat. F313-5-G1 Model No. 002 .750 Input Hp 120 in
lb NWOB
Boston Gear 700 Series Cat No. 715-5-J 1.550HP 250 lb/Inch Torque Gear
Box
NEW BOSTON GEAR F713-30-B5-G F71330B5G 30:1 0.39HP 56C GEAR REDUCER
D225554
BOSTON GEAR F843A-90S-B5 .470 HP 800 SERIES HELICAL GEAR DRIVE
NEW BOSTON GEAR F732-30-B7-G GEAR REDUCER 30:1 7/8IN IN 1-3/8IN OUT
R23629
BOSTON GEAR F713-5-B5-G 1.25HP 5:1 GEAR REDUCER 202LB-IN D203880
BOSTON GEAR F721-30-B5-6 SPEED REDUCER INPUT 0.99 OUTPUT 871 RATIO 30
NEW BOSTON GEAR F713-30-B5-G WORM GEAR SPEED REDUCER .32 HP 264 OUT.
30:1 RATIO
BOSTON GEAR FWA726-600-B5-6 GEAR REDUCER 600:1 5/8IN IN 1-1/8IN OUT
R26045
NEW BOSTON GEAR F710-50-B4-G SPEED GEAR REDUCER 50:1 RATIO .09HP INPUT
120LB OUT
Lot of 2 Boston Gear Rubber Insert Coupling Spiders Model XFCR-15 NWOB
Boston Gear ND-16B Spur Gear .95
BOSTON GEAR F721-30-B5-G 700 SEIRES C-FACE QUILLED REDUCER W/ ? HP MOTOR
Boston Gear 700 Series Reducer Model HF72140STB5H1P19 Ratio 40 .68 HP
NWOB
NOS BOSTON GEAR R1214 1:1 RATIO 3-WAY SPEED REDUCER 1150-RPM,
Boston Gear 700 Series F71520B5J 20:1 Speed Reducer Gear Box 1750 RPM
.63 In HP
40709 Old-Stock, Boston Gear F713-10-B5-J Gear Reducer .75Hp, 10:1 Ratio
28866 New In box, Boston Gear HF721-40-B5-H-P16 Gearbox 40:1 Ratio .81
Input HP
28867 New In box, Boston Gear HF721-25-B5-H-P20 Gearbox 25:1 Ratio 1.16
Input HP
28869 New In box, Boston Gear HF72440B5HP16 Gearbox 40:1 Ratio, 1.08 HP
NEW BOSTON GEAR F726-20-B7-G GEAR REDUCER 20:1 56C 7/8IN INPUT R23721
28864 Old-Stock, Boston Gear F718-40-B5-G Gearbox 40:1, 0.57 Input HP
Spur gear 12 pitch ND48 Boston Gear Unused
BOSTON GEAR F724-15-B7-G GEAR REDUCER 15:1 7/8IN INPUT 1-1/8IN
OUTPUTR23716
BOSTON GEAR F726-15-B7-G GEAR REDUCER 15:1 7/8IN INPUT R23805
BOSTON GEAR TWF113A-900-DM5 SPEED REDUCER
NEW BOSTON GEAR F710-10-B4-J GEAR SPEED REDUCER .37HP INPUT 123LB OUT
10:1 RATIO
BOSTON GEAR SPEED GEAR REDUCER F715-5-B5-G 5:1 RATIO 1.72HP 5/8IN INPUT
66715
BOSTON GEAR FC20-1 SPIDER CLUTCH JAW STEEL 1 IN KEYED BORE HUB COUPLING
B208943
Boston Gear H2060L Helical Gear
3.75
Boston gear reducer F718-20-B5J, 20:1, F318-20, F718-20-B5G,
F718-20-B5-J, F718 85.50
Boston gear reducer BKSF852BR25KB7, 25:1, 143/5TC, SF852-25-B7, F000529,
1.38" 49.50
BOSTON GEAR WORM GEAR SPEED REDUCER F71850B5G
BOSTON GEAR WORM GEAR SPEED REDUCER RF71815B5J
NEW BOSTON GEAR F71520B5G F715-20B5G 0.63HP 20:1 56C GEAR REDUCER
D224247
Boston F724-30-B5-G Flanged Worm Gear 30:1 1.5HP Input 980Lb Output Gear
Reducer 87.50
BOSTON GEAR STEEL SHAFT X231A-3PK
00.00
Boston Gear F71830ZB561 30:1 Gear Reducer - XLNT w/ 30 Day Warrantee !!
Gear reducer right angle 15:1 F313 15 J1 Boston Gear Unused
BOSTON GEAR RA1022 SPIRAL BEVEL 2 WAY 5/8X5/8IN 0.578HP 2:1 GEAR REDUCER
B232816
NEW BOSTON GEAR F71830B5G F718-30-B5-G 0.53HP 30:1 56C GEAR REDUCER
D234630
USED Boston Gear Flanged Reductor Ratiomotor
Boston gear reducer FWC713-1200-B5G, 1200:1 ratio, FWC713-1200-B5J, 56C,
FWA713 50.00
OFFER&WIN - BOSTON GEAR 713-25-G Speed Reducer,25:1
28870 New In box, Boston Gear HF721-60-B5-H-P16 Gearbox 60:1 Ratio, 0.55
Input H
Boston Gear Speed Reducer, 56c, 30:1
00.00
Boston Gear 700 Series Reduction Gearbox 00.00
NEW BOSTON HL155Y-G BEVEL GEAR, 10 PITCH, 40 TEETH, 1-1/4" BORE,
KWY, 1 S.S.
Boston gear reducer WC732-150-G, 150:1 ratio, WC732-150-J, WC732150G,
WC332-150 ,509.50
NEW BOSTON GEAR F713-15-B5-G 0.66HP 15:1 56C GEAR REDUCER D222482
NEW BOSTON GEAR J150 UNIVERSAL U-JOINT MISCELLANEOUS D236056
29877 New In box, Boston Gear SSHF73215KB7HSP20 Gearbox 15:1 Ratio
NEW BOSTON GEAR SRF71860NB5G SRF718-60N-B5G 0.92HP 60:1 56C GEAR REDUCER
D228772
NEW BOSTON RA1021 1750RPM BEVEL 5/8 IN 5/8 IN 1.575HP 1:1 GEAR REDUCER
B232600
Boston Gear NF20B-1 Spur Gear Pitch: 10 Teeth: 20, 1" Bore NIB
Boston Gear 700 Series Reducer Model F72415B7G Ratio 15 Input HP: 1.95
NWOB
BOSTON GEAR F726-40-B5-G 56C 1.24HP 40:1 GEAR REDUCER D201906
NEW BOSTON GEAR F726-40-B7-J 700 1.24HP 40:1 GEAR REDUCER D209840
BOSTON GEAR FCBB20 BRONZE COUPLING INERT SPIDER NEW
BOSTON GEAR F715-5-B5-G WORM GEAR 5/8 IN 3/4 IN 1.72HP 5:1 GEAR REDUCER
B210206
Boston Gear Series 300 Speed Reducer, F315-20-H1
NEW BOSTON GEAR 72B M12141-1-10 72 TOOTH 3-1/2IN BORE GEAR D225326
Boston gear reducer SBKF726B-40S-B5G, 40:1 ratio, 56C, F726-40-B5G, 326,
B5, 726 79.50
Boston Worm Gear Speed Reducer Drive F710-5-B5 700 Series F7105B5 Input
HP .600
BOSTON GEAR X221-12 GEAR REDUCER 20:1 56C 5/8IN INPUT 1IN OUTPUT R14650
NEW BOSTON GEAR F71810B5J F718-10-B5-J 1.43HP 10:1 56C GEAR REDUCER
D224181
Boston Gear Reducer Series 700, Ratio 15 RJ, .560HP 00.00
226D-14 BOSTON GEAR NEW
NEW BOSTON GEAR F721B-25X-B5-G3 GEAR REDUCER 25:1 56C 5/8IN IN 1IN OUT
R14204
NEW BOSTON GEAR F73225FB7J GEAR REDUCER 25:1 56C 1-3/8IN IN 1-3/8IN OUT
R14062
NEW BOSTON GEAR F732-30-B7-G GEAR REDUCER 30:1 56C 7/8IN IN 1-1/2IN OUT
R14531
Boston Gear 700 series F71820B5G 20:1 Speed Reducer .87 HP 56C NEMA
FRAME
NEW BOSTON GEAR F713-10-B5-J 0.86HP 10:1 GEAR REDUCER D222319
Boston Gear FCBB 20 Bronze Spider Coupling Insert New
Boston Gear Speed Reducer 1:1 Ratio Cat. VR137 Mtg QM5 1750 RPM 9.262 HP
Refurb
BOSTON GEAR 732-30-G GEAR REDUCER 30:1 7/8IN IN 1-3/8IN OUT R14466
BOSTON GEAR F732A-30S-B7-G GEAR REDUCER 30:1 56C 7/8IN IN 1-3/8IN OUT
R14538
BOSTON GEAR FWB726-100-B5-6 GEAR REDUCER 100:1 5/8IN IN 1-1/8IN OUT
R26044
F71850B5J BOSTON GEAR NEW
BOSTON GEAR F71530ZTB5G GEAR REDUCER 30:1 56C 1-1/8IN IN 3/4IN OUT
R14052
Boston gear reducer F726-20-B5G, 20:1, 56C, F726-40-B5J, F326, 52026,
F726B, B5 11.00
BOSTON GEAR F17820B56 WORM GEAR RATIO 20 INPUT .87 OUTPUT 511
BOSTON GEAR 700 SERIES GEAR REDUCER 20:1 182TC 1-1/8IN IN 1-3/8IN OUT
R14747
Boston gear reducer F726-30-B7J, 30:1 ratio, 143TC, 145TC, F726-30-B7G,
326, B7 11.00
Boston Gear speed reducer 50:1 ration Input HP .175; Torque 216 in.lbs.
56C
NEW BOSTON GEAR J125B UNIVERSAL U-JOINT 5/8 X 5/8IN BORE STEEL BODY
B232806
BOSTON GEAR F726-30S-B7-J3 GEAR REDUCER 30:1 1.5HP 7/8IN IN 1-1/8IN OUT
R14826
NEW BOSTON GEAR COUPLING SHAFT FC20 5/8" BORE
Boston Gear HF715155VB5H6P12 15:1 700 Series Speed Reducer 56C .73HP New
BOSTON GEAR F643-50-B7 REDUCTOR RATIOMOTOR 5/8IN 1-5/8IN GEAR REDUCER
200248
BOSTON GEAR F726-15-B7-G GEAR SPEED REDUCER 15:1 RATIO 2.47HP 7/8IN
INPUT 68117
BOSTON GEAR F71510B5G 1.07HP 10:1 GEAR REDUCER D222313
BOSTON GEAR 67552 CMBA140TU-6 BRAKE 6LB-FT 230/460V-AC 143T/145T C-FACE
D206103
NEW BOSTON GEAR F71815AVB5J1ROA GEAR REDUCER 15:1 56C 5/8IN IN 7/8IN OUT
R14116
BOSTON GEAR F732-15-B9-G GEAR REDUCER 15:1 3.59HP 1-1/8IN IN 1-5/8IN OUT
R14983
Boston Gear 715-50-J Speed Reducer Gearbox 1/4HP 50:1
BOSTON GEAR 2310-20 GEAR REDUCER 20:1 15/16IN INPUT 1-3/8IN OUTPUT
R23911
Boston Gear 700 Series Right Angle Reduction Gearbox 00.00
Boston Gear 700 Series Gear Box Speed Reducer F7107 5KB4J6 RATIO 7.5
NEW 50.00
NEW BOSTON GEAR F7135B5G F713-5-B5-G 1.25HP 5:1 56C GEAR REDUCER D234530
NEW BOSTON GEAR RF71310B5J RF713-10-B5J 0.75HP 10:1 56C GEAR REDUCER
D228286
Boston Gear Left Hand Worm Gear G1050A-LH 1/2" NIB
Boston Gear 700 Series Gear Box Speed Reducer F721-15S-B5-G6-D0R RATIO
15 0.00
NEW BOSTON GEAR F721-25-B5-6 GEAR REDUCER 25:1 56C 1-1/8IN IN 1IN OUT
R14089
BOSTON GEAR RF710-5-B4-G 5 TO 1
R14063
BOSTON GEAR F71815B5G 700 SERIES 0.91HP 15:1 LP GEAR REDUCER D207347
Boston gear reducer F726-40-B5J, 40:1 ratio, 56C, F726-40-B5G, 326, B5,
F726B 11.00
NEW BOSTON GEAR F713-10S-B5-G6-DDR GEAR REDUCER 10:1 56C 0.75HP R23625
NEW BOSTON GEAR F71820B5H F718-20B5H 0.87HP 20:1 GEAR REDUCER 56C
D222388
Boston 700-Series 713-30G 30:1 Ratio Worm Gear Speed Reducer w/Pulley
System
NEW BOSTON GEAR F71320B5J 5/8 IN 5/8 IN 0.45HP 20:1 GEAR REDUCER B225816
Boston Gear 700 Series Gear Box Speed Reducer RF718A10XB7HT1 RF718 RATIO
10 NEW 75.00
BOSTON GEAR RATIOPAX DC MOTOR CONTROL / CONTROLLER RP1R WITH 60155 BOARD
BOSTON GEAR F7010-30PK-B4-J6 SPEED 1/2 IN 0.2HP 30:1 GEAR REDUCER
B217588
NEW BOSTON GEAR 56587, 721 AL U HORZ, BASE KIT
NEW
BOSTON GEAR 56575, 710 HORZ, BASE KIT上海航欧销售BOSTON GEAR变送器BOSTON
![](http://www.cechina.cn/UpLoad/CompanyFile/2023/2/14/af7281d6-8655-489e-8c25-4eb430ceb499.jpg)
