  • Seametrics指示器EF81T-C-200
  • 发布时间:2023/4/4 8:51:13   修改时间:2023/4/4 8:51:13 浏览次数:740
  •  2013 Seametrics工厂上海航欧中国区销售
    上海航欧销售Seametrics流量计Seametrics电磁流量计Seametrics流量计探头Seametrics传感器Seametrics变送器Seametrics指示器Seametrics频率计Seametrics接头Seametrics探头,Seametrics传感器Seametrics流量计
    https://www.seametrics.com/distributors/
    Seametrics公司成立于1990年,一直致力于高效流量和控制类产品的研发和生产。
     2013
    FT415WBatteryPoweredPulseOutput,WallMount96
    Note:UseofHingedDisplayCoverisrecommendedforalloutdoorapplications.
    FT420W12-24Vdc,PulseOutput&4-20mAOutputs,WallMount70
    FT420P12-24Vdc,PulseOutput&4-20mAOutputs,PanelMount70
    FT420W-2712-24Vdc,110VacDualPowerSupply,HardWired,WallMount70
    Mount70
    OptionCode(s)Description
    06LMIPump4-PinConnector0
    106Roytronics?Series-APump5PinConnector0
    AO55Parts&Accessories
    Model#Description
    100471AO55ReplacementModule65
    100414Screw/WasherKit,Upperhousing(Qty4)1
    100364CordGrip1/4"I.D.2
    101850CordGrip,1/2"NPT8
    2014IndustrialListV2Page8January01,2014
    Rev.050114
    PC-SeriesPowerConverters
    Model#Description
    PC3110-115Vac,24Vdc,Unregulated6
    Model#Description
    EX810BFixedDepthInsertionMagmeter,Brass,1"-3"90
    EX810PFixedDepthInsertionMagmeter,PVC,1"-3"98
    EX810SFixedDepthInsertionMagmeter,316SS,1"-3"21
    EX820BFixedDepthInsertionMagmeter,Brass,4"-10"19
    EX820PFixedDepthInsertionMagmeter,PVC,4"-10"19
    EX820SFixedDepthInsertionMagmeter,316SS,4"-10"97
    EX830BFixedDepthInsertionMagmeter,Brass,12"87
    EX830PFixedDepthInsertionMagmeter,PVC,12"80
    EX830SFixedDepthInsertionMagmeter,316SS,12"83
    15ReverseFlow49
    40Immersible0
    50LowPowerNC
    125Viton?O-Ring6
    EX801SeriesFixedDepthInsertionMagmeter(FT420MeterMount)
    Model#Description
    EX811BFixedDepthInsertionMagmeter,Brass,1"-3",FT420160
    EX811PFixedDepthInsertionMagmeter,PVC,1"-3",FT420068
    EX811SFixedDepthInsertionMagmeter,316SS,1"-3",FT420291
    EX821BFixedDepthInsertionMagmeter,Brass,4"-10",FT420189
    EX821PFixedDepthInsertionMagmeter,PVC,4"-10",FT420089
    EX821SFixedDepthInsertionMagmeter,316SS,4"-10",FT420367
    EX831BFixedDepthInsertionMagmeter,Brass,12",FT420257
    EX831PFixedDepthInsertionMagmeter,PVC,12",FT420150
    EX831SFixedDepthInsertionMagmeter,316SS,12",FT420453
    Model#Description
    EX812BFixedDepthInsertionMagmeter,Brass,1"-3",AO55060
    EX812PFixedDepthInsertionMagmeter,PVC,1"-3",AO5568
    EX812SFixedDepthInsertionMagmeter,316SS,1"-3",AO55191
    EX822BFixedDepthInsertionMagmeter,Brass,4"-10",AO55089
    EX822PFixedDepthInsertionMagmeter,PVC,4"-10",AO5589
    EX822SFixedDepthInsertionMagmeter,316SS,4"-10",AO55267
    EX832BFixedDepthInsertionMagmeter,Brass,12",AO55157
    EX832PFixedDepthInsertionMagmeter,PVC,12",AO55050
    EX832SFixedDepthInsertionMagmeter,316SS,12",AO55353
    15ReverseFlow49
    50LowPowerNC
    125Viton?O-Ring6
    2014IndustrialListV2Page13January01,2014
    Rev.050114
    EX806SeriesFixedDepthInsertionMagmeter(DL76MeterMount)
    Model#Description
    EX816B Fixed Depth Insertion Magmeter, Brass, 1"-3", DL76 045
    EX816P Fixed Depth Insertion Magmeter, PVC, 1"-3", DL76 53
    EX816S Fixed Depth Insertion Magmeter, 316 SS, 1"-3", DL76 176
    EX826B Fixed Depth Insertion Magmeter, Brass, 4"-10", DL76 074
    EX826P Fixed Depth Insertion Magmeter, PVC, 4"-10", DL76 74
    EX826S Fixed Depth Insertion Magmeter, 316 SS, 4"-10", DL76 252
    EX836B Fixed Depth Insertion Magmeter, Brass, 12", DL76 142
    EX836P Fixed Depth Insertion Magmeter, PVC, 12", DL76 035
    EX836S Fixed Depth Insertion Magmeter, 316 SS, 12", DL76 338
    Option Code(s) Description
    15 Reverse Flow 49
    32 Tamper-Evident Kit, Wire, Seal 1
    50 Low Power NC
    125 Viton? O-Ring 6
    EX808 Series Fixed Depth Insertion Magmeter (PD10 Meter Mount)
    Model # Description
    EX818B Fixed Depth Insertion Magmeter, Brass, 1"-3", PD10 48
    EX818P Fixed Depth Insertion Magmeter, PVC, 1"-3", PD10 56
    EX818S Fixed Depth Insertion Magmeter, 316 SS, 1"-3", PD10 79
    EX828B Fixed Depth Insertion Magmeter, Brass, 4"-10", PD10 77
    EX828P Fixed Depth Insertion Magmeter, PVC, 4"-10", PD10 77
    EX828S Fixed Depth Insertion Magmeter, 316 SS, 4"-10", PD10 055
    EX838B Fixed Depth Insertion Magmeter, Brass, 12", PD10 45
    EX838P Fixed Depth Insertion Magmeter, PVC, 12", PD10 38
    EX838S Fixed Depth Insertion Magmeter, 316 SS, 12", PD10 141
    EX800 Series Tee Fittings
    Model # Description
    Bronze
    EF81T-B-100 Tee Fitting, Bronze, Threaded, 1", EX 44
    EF81T-B-150 Tee Fitting, Bronze, Threaded, 1-1/2", EX 59
    EF81T-B-200 Tee Fitting, Bronze, Threaded, 2", EX 79
    EF81T-B-300 Tee Fitting, Bronze, Threaded, 3", EX 44
    EF81T-B-400 Tee Fitting, Bronze, Threaded, 4", EX 76
    EF81TC-B-100 Tee Fitting, Bronze, Sweat, 1", EX 44
    EF81TC-B-150 Tee Fitting, Bronze, Sweat, 1-1/2", EX 59
    EF81TC-B-200 Tee Fitting, Bronze, Sweat, 2", EX 79
    EF81TC-B-300 Tee Fitting, Bronze, Sweat, 3", EX 44
    EF81TC-B-400 Tee Fitting, Bronze, Sweat, 4", EX 76
    PVC
    EF81T-P-100 Tee Fitting, PVC, 1", EX 24
    EF81T-P-150 Tee Fitting, PVC, 1-1/2", EX 28
    EF81T-P-200 Tee Fitting, PVC, 2", EX 35
    EF81T-P-200-18 Tee Fitting, PVC, Flanged Ends, 2",EX 45
    Carbon Steel
    EF81T-C-100 Tee Fitting, Carbon Steel, 1", EX 79
    EF81T-C-150 Tee Fitting, Carbon Steel, 1-1/2", EX 20
    Seametrics指示器EF81T-C-200 Tee Fitting, Carbon Steel, 2", EX 61
    EF81T-C-200-34 Tee Fitting, Carbon Steel, Flanged Ends, 2", EX 41
    Stainless Steel
    EF81T-S-100 Tee Fitting, 304 SS, 1",EX 57
    EF81T-S-150 Tee Fitting, 304 SS, 1-1/2", EX 67
    EF81T-S-200 Tee Fitting, 304 SS, 2", EX 77
    EF81T-S-100-14 Tee Fitting, 316 SS, 1",EX 18
    EF81T-S-150-14 Tee Fitting, 316 SS , 1-1/2", EX 38
    EF81T-S-200-14 Tee Fitting, 316 SS, 2", EX 63
    EF81T-S-200-20 Tee Fitting, 304 SS, Flanged Ends, 2", EX 17
    EF81T-S-200-14-20 Tee Fitting, 316 SS, Flanged Ends, 2", EX 003
    2014 Industrial  List V2 Page 15 January 01, 2014
    Rev. 050114
    EX800 Series Saddle Fittings
    Model # Description
    Ductile Iron
    EF82S-F-300 Saddle, Iron, 3", EX 72
    EF82S-F-400 Saddle, Iron, 4", EX 06
    EF82S-F-600 Saddle, Iron, 6", EX 61
    EF82S-F-800 Saddle, Iron, 8", EX 95
    EF82S-F-1000 Saddle, Iron, 10", EX 67
    EF82S-F-1200 Saddle, Iron, 12", EX 55
    PVC
    EF82S-P-300 Saddle, PVC, 3", EX 15
    EF82S-P-400 Saddle, PVC, 4", EX 31
    EF82S-P-600 Saddle, PVC, 6", EX 51
    EF82S-P-800 Saddle, PVC, 8", EX 79
    Note: PVC saddles supplied with Buna-O O-rings only.
    For Chemical service, O-ring must be removed and saddle glued to pipe with PVC cement.
    See Instructions for more detail.
    EF82S-P-300-16 Saddle, PVC, 3", w/ 16" Pipe Stub, EX 84
    EF82S-P-400-16 Saddle, PVC, 4", w/ 16" Pipe Stub, EX 05
    EF82S-P-600-16 Saddle, PVC, 6", w/ 16" Pipe Stub, EX 30
    EF82S-P-800-16 Saddle, PVC, 8", w/ 16" Pipe Stub, EX 63
    EF82W-B-300 Weldolet, Brass, 3", EX 40
    EF82W-B-400 Weldolet, Brass, 4", EX 40
    EF82W-B-600 Weldolet, Brass, 6", EX 40
    EF82W-B-800 Weldolet, Brass, 8", EX 40
    EF82W-B-1000 Weldolet, Brass, 10", EX 40
    EF82W-B-1200 Weldolet, Brass, 12", EX 40
    Carbon Steel
    EF82W-C-300 Weldolet, Carbon Steel, 3", EX 18
    EF82W-C-400 Weldolet, Carbon Steel, 4", EX 18
    EF82W-C-600 Weldolet, Carbon Steel, 6", EX 18
    EF82W-C-800 Weldolet, Carbon Steel, 8", EX 18
    EF82W-C-1000 Weldolet, Carbon Steel, 10", EX 18
    EF82W-C-1200 Weldolet, Carbon Steel, 12", EX 18
    Stainless Steel
    EF82W-S-300 Weldolet, 316 SS, 3", EX 06
    EF82W-S-400 Weldolet, 316 SS, 4", EX 06
    EF82W-S-600 Weldolet, 316 SS, 6", EX 06
    EF82W-S-800 Weldolet, 316 SS, 8", EX 06
    EF82W-S-1000 Weldolet, 316 SS, 10", EX 06
    72 12" Extension (210/250 Series Only) 02
    EX150/250 Hot-Tap Adjustable Depth Insertion Magmeter (Sensor Only)
    Model # Description
    EX150B Hot Tap Adj Depth Insertion Magmeter, Brass, 3-10" 331
    EX150S Hot Tap Adj Depth Insertion Magmeter, 316 SS, 3-10" 576
    EX250B Hot Tap Adj Depth Insertion Magmeter, Brass, 10-48" 593
    Model # Description
    MF101F-300-150 Saddle, Iron, NPT Thread, 3" X 1-1/2" 36
    MF101F-400-150 Saddle, Iron, NPT Thread, 4" X 1-1/2" 44
    MF101F-600-150 Saddle, Iron, NPT Thread, 6" X 1-1/2" 48
    MF101F-800-150 Saddle, Iron, NPT Thread, 8" X 1-1/2" 78
    MF101F-1000-150 Saddle, Iron, NPT Thread, 10" X 1-1/2" 58
    MF101F-1200-150 Saddle, Iron, NPT Thread, 12" X 1-1/2" 20
    MF101F-1400-150 Saddle, Iron, NPT Thread, 14" X 1-1/2" 90
    MF101F-1600-150 Saddle, Iron, NPT Thread, 16" X 1-1/2" 55
    MF101F-1800-150 Saddle, Iron, NPT Thread, 18" X 1-1/2" 29
    MF101F-2000-150 Saddle, Iron, NPT Thread, 20" X 1-1/2" 02
    MF101F-2200-150 Saddle, Iron, NPT Thread, 22" X 1-1/2" 50
    MF101F-2400-150 Saddle, Iron, NPT Thread, 24" X 1-1/2" 95
    MF101B-300-150 Saddle, Bronze, NPT Thread, 3" X 1-1/2" 93
    MF101B-400-150 Saddle, Bronze, NPT Thread 4" X 1-1/2" 24
    EX150/250 Series Saddle Fittings
    Model # Description
    MF101F-300-200 Saddle, Iron, NPT Thread, 3" X 2" 36
    MF101F-400-200 Saddle, Iron, NPT Thread, 4" X 2" 44
    MF101F-600-200 Saddle, Iron, NPT Thread, 6" X 2" 48
    MF101F-800-200 Saddle, Iron, NPT Thread, 8" X 2" 78
    MF101F-1000-200 Saddle, Iron, NPT Thread, 10" X 2" 58
    MF101F-1200-200 Saddle, Iron, NPT Thread, 12" X 2" 20
    MF101F-1400-200 Saddle, Iron, NPT Thread, 14" X 2" 90
    MF101F-1600-200 Saddle, Iron, NPT Thread, 16" X 2" 55
    MF101F-1800-200 Saddle, Iron, NPT Thread, 18" X 2" 29
    MF101F-2000-200 Saddle, Iron, NPT Thread, 20" X 2" 02
    MF101F-2200-200 Saddle, Iron, NPT Thread, 22" X 2" 50
    MF101F-2400-200 Saddle, Iron, NPT Thread, 24" X 2" 95
    MF101B-300-200 Saddle, Bronze, NPT Thread, 3" X 2" 93
    MF101B-400-200 Saddle, Bronze, NPT Thread, 4" X 2" 24
    Model # Description
    TX810B Fixed Depth Insertion Turbine Meter, Brass, 1-1/2"-3" 93
    TX810P Fixed Depth Insertion Turbine Meter, PVC, 1-1/2"-3" 96
    TX810S Fixed Depth Insertion Turbine Meter, 316 SS, 1-1/2"-3" 23
    TX810S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 1-1/2"-3" 98
    TX820B Fixed Depth Insertion Turbine Meter, Brass, 4"-8" 23
    TX820P Fixed Depth Insertion Turbine Meter, PVC, 4"-8" 17
    TX820S Fixed Depth Insertion Turbine Meter, 316 SS, 4"-8" 01
    TX820S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 4"-8" 76
    Model # Description
    TX811B Fixed Depth Insertion Turbine Meter, Brass, 1-1/2"-3", FT420 163
    TX811P Fixed Depth Insertion Turbine Meter, PVC, 1-1/2"-3", FT420 066
    TX811S Fixed Depth Insertion Turbine Meter, 316 SS, 1-1/2"-3", FT420 293
    TX811S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 1-1/2"-3", FT420 368
    TX821B Fixed Depth Insertion Turbine Meter, Brass, 4"-8", FT420 193
    TX821P Fixed Depth Insertion Turbine Meter, PVC, 4"-8", FT420 087
    TX821S Fixed Depth Insertion Turbine Meter, 316 SS, 4"-8", FT420 371
    TX821S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 4"-8", FT420 446
    TX812B Fixed Depth Insertion Turbine Meter, Brass, 1-1/2"-3", AO55 063
    TX812P Fixed Depth Insertion Turbine Meter, PVC, 1-1/2"-3", AO55 66
    TX812S Fixed Depth Insertion Turbine Meter, 316 SS, 1-1/2"-3", AO55 193
    TX812S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 1-1/2"-3", AO55 268
    TX822B Fixed Depth Insertion Turbine Meter, Brass, 4"-8", AO55 093
    TX822P Fixed Depth Insertion Turbine Meter, PVC, 4"-8", AO55 87
    TX822S Fixed Depth Insertion Turbine Meter, 316 SS, 4"-8", AO55 271
    TX822S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 4"-8", AO55 346
    06 LMI Pump 4-Pin Connector 0
    60 Viton? O-Ring 6
    106 Roytronics? Series-A Pump 5-Pin Connector 0
    Note: If the -HP option is ordered, a Carbon or Stainless fitting must also be ordered.
    HP units are not interchangable with standard units.
    TX804 Series Fixed Depth Insertion Turbine Meter (FT415 Meter Mount)
    Model # Description
    TX814B Fixed Depth Insertion Turbine Meter, Brass, 1-1/2"-3", FT415 189
    TX814P Fixed Depth Insertion Turbine Meter, PVC, 1-1/2"-3", FT415 092
    TX814S Fixed Depth Insertion Turbine Meter, 316 SS, 1-1/2"-3", FT415 319
    TX814S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 1-1/2"-3", FT415 394
    TX824B Fixed Depth Insertion Turbine Meter, Brass, 4"-8", FT415 219
    TX824P Fixed Depth Insertion Turbine Meter, PVC, 4"-8", FT415 113
    TX824S Fixed Depth Insertion Turbine Meter, 316 SS, 4"-8", FT415 397
    TX824S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 4"-8", FT415 472
    60 Viton? O-Ring 6
    64 Non-Resettable Total 7
    126 Hinged Display Cover 3
    2014 Industrial  List V2 Page 29 January 01, 2014
    Rev. 050114
    TX806 Series Fixed Depth Insertion Turbine Meter (DL76 Meter Mount)
    Model # Description
    TX816B Fixed Depth Insertion Turbine Meter, Brass, 1-1/2"-3", DL76 048
    TX816P Fixed Depth Insertion Turbine Meter, PVC, 1-1/2"-3", DL76 51
    TX816S Fixed Depth Insertion Turbine Meter, 316 SS, 1-1/2"-3", DL76 178
    TX816S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 1-1/2"-3", DL76 253
    TX826B Fixed Depth Insertion Turbine Meter, Brass, 4"-8", DL76 078
    TX826P Fixed Depth Insertion Turbine Meter, PVC, 4"-8", DL76 72
    TX826S Fixed Depth Insertion Turbine Meter, 316 SS, 4"-8", DL76 256
    TX826S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 4"-8", DL76 331
    60 Viton? O-Ring 6
    TX808 Series Fixed Depth Insertion Turbine Meter (PD10 Meter Mount)
    Model # Description
    TX818B Fixed Depth Insertion Turbine Meter, Brass, 1-1/2"-3", PD10 51
    TX818P Fixed Depth Insertion Turbine Meter, PVC, 1-1/2"-3", PD10 54
    TX818S Fixed Depth Insertion Turbine Meter, 316 SS, 1-1/2"-3", PD10 81
    TX818S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 1-1/2"-3", PD10 056
    TX828B Fixed Depth Insertion Turbine Meter, Brass, 4"-8", PD10 81
    TX828P Fixed Depth Insertion Turbine Meter, PVC, 4"-8", PD10 75
    TX828S Fixed Depth Insertion Turbine Meter, 316 SS, 4"-8", PD10 059
    TX828S-HP Fixed Depth Insertion Turbine Meter, 316 SS, Hi Pres, 4"-8", PD10 134
    37 10 Ft. Cable for LMI Connector 2
    60 Viton? O-Ring 6
    2014 Industrial  List V2 Page 30 January 01, 2014
    Rev. 050114
    TX800 Series Tee Fittings
    Model # Description
    Bronze
    TF81T-B-150 Tee Fitting, Bronze, Threaded, 1-1/2", TX 59
    TF81T-B-200 Tee Fitting, Bronze, Threaded, 2", TX 79
    TF81T-B-300 Tee Fitting, Bronze, Threaded, 3", TX 44
    TF81T-B-400 Tee Fitting, Bronze, Threaded, 4", TX 76
    TF81TC-B-150 Tee Fitting, Bronze, Sweat, 1-1/2", TX 59
    TF81TC-B-200 Tee Fitting, Bronze, Sweat, 2", TX 79
    TF81TC-B-300 Tee Fitting, Bronze, Sweat, 3", TX 44
    TF81TC-B-400 Tee Fitting, Bronze, Sweat, 4", TX 76
    PVC
    TF81T-P-150 Tee Fitting, PVC, 1-1/2", TX 28
    TF81T-P-200 Tee Fitting, PVC, 2", TX 35
    Carbon Steel
    TF81T-C-150 Tee Fitting, Carbon Steel, 1-1/2", TX 20
    TF81T-C-200 Tee Fitting, Carbon Steel, 2", TX 61
    TF81T-C-150-HP Tee Fitting, Carbon Steel, Hi Pres, 1-1/2", TX 35
    TF81T-C-200-HP Tee Fitting, Carbon Steel, Hi Pres, 2", TX 76
    Stainless Steel
    TF81T-S-150 Tee Fitting, 304 SS, 1-1/2", TX 67
    TF81T-S-200 Tee Fitting, 304 SS, 2", TX 77
    TF81T-S-150-14 Tee Fitting, 316 SS, 1-1/2", TX 38
    TF81T-S-200-14 Tee Fitting, 316 SS, 2", TX 63
    TF81T-S-150-HP Tee Fitting, 304 SS, Hi Pres, 1-1/2", TX 82
    TF81T-S-200-HP Tee Fitting, 304 SS, Hi Pres, 2", TX 92
    TF81T-S-150-14-HP Tee Fitting, 316 SS, Hi Pres, 1-1/2", TX 53
    TF81T-S-200-14-HP Tee Fitting, 316 SS, Hi Pres, 2", TX 78
    2014 Industrial  List V2 Page 31 January 01, 2014
    Rev. 050114
    TX800 Series Saddle Fittings
    Model # Description
    Bronze
    MF82S-B-300 Saddle, Bronze, 3" 74
    MF82S-B-400 Saddle, Bronze, 4" 15
    PVC
    MF82S-P-300 Saddle, PVC, 3" 15
    MF82S-P-400 Saddle, PVC, 4" 31
    MF82S-P-600 Saddle, PVC, 6" 51
    MF82S-P-800 Saddle, PVC, 8" 79
    MF82S-P-300-16 Saddle, PVC, 3", w/ 16" Pipe Stub 84
    MF82S-P-400-16 Saddle, PVC, 4", w/ 16" Pipe Stub 05
    MF82S-P-600-16 Saddle, PVC, 6", w/ 16" Pipe Stub 30
    MF82S-P-800-16 Saddle, PVC, 8", w/ 16" Pipe Stub 63
    PVC saddles ordered with -16 option will be calibrated for K-Factor before shipping.
    Ductile Iron
    MF82S-F-300 Saddle, Iron, 3" 72
    MF82S-F-400 Saddle, Iron, 4" 06
    MF82S-F-600 Saddle, Iron, 6" 61
    MF82S-F-800 Saddle, Iron, 8" 95
    2014 Industrial  List V2 Page 32 January 01, 2014
    Rev. 050114
    TX800 Series Weld/Braze Fittings
    Model # Description
    Brass
    MF82W-B-300 Weldolet, Brass, 3" 40
    MF82W-B-400 Weldolet, Brass, 4" 40
    MF82W-B-600 Weldolet, Brass, 6" 40
    MF82W-B-800 Weldolet, Brass, 8" 40
    Carbon Steel
    MF82W-C-300 Weldolet, Carbon Steel, 3" 18
    MF82W-C-400 Weldolet, Carbon Steel, 4" 18
    MF82W-C-600 Weldolet, Carbon Steel, 6" 18
    MF82W-C-800 Weldolet, Carbon Steel, 8" 18
    MF82W-C-300-HP Weldolet, Carbon Steel, Hi Pres, 3" 33
    MF82W-C-400-HP Weldolet, Carbon Steel, Hi Pres, 4" 33
    MF82W-C-600-HP Weldolet, Carbon Steel, Hi Pres, 6" 33
    MF82W-C-800-HP Weldolet, Carbon Steel, Hi Pres, 8" 33
    Stainless Steel
    MF82W-S-300 Weldolet, 316 SS, 3" 06
    MF82W-S-400 Weldolet, 316 SS, 4" 06
    MF82W-S-600 Weldolet, 316 SS, 6" 06
    MF82W-S-800 Weldolet, 316 SS, 8" 06
    MF82W-S-300-HP Weldolet, 316 SS, Hi Pres, 3" 21
    MF82W-S-400-HP Weldolet, 316 SS, Hi Pres, 4" 21
    TX150S Hot Tap Adj Depth Insertion Turbine Meter, 316 SS, 3"-12" 577
    TX152/252 Hot-Tap Adjustable Depth Insertion Turbine Meter (AO55 Meter Mount)
    Model # Description
    TX152B Hot Tap Adj Depth Insertion Turbine Meter, Brass, 3"-12", AO55 695
    TX152S Hot Tap Adj Depth Insertion Turbine Meter, 316 SS, 3"-12", AO55 947
    TX252B Hot Tap Adj Depth Insertion Turbine Meter, Brass, 12"- 40", AO55 956
    TX114B Adj Depth Insertion Turbine Meter, Brass, 3"-12", FT415 583
    TX114S Adj Depth Insertion Turbine Meter, 316 SS, 3"-12", FT415 866
    TX214B Adj Depth Insertion Turbine Meter, Brass, 12"- 40", FT415 763
    TX214S Adj Depth Insertion Turbine Meter, 316 SS, 12"- 40", FT415 988
    02 Adapter Fitting, 2" NPT Threads, Brass 6
    02 Adapter Fitting, 2" NPT Threads, SS 6
    03 Bi-Directional 13
    23 Adapter, 1-1/2" BSP Thread Tapered, Brass 3
    24 Adapter, 1-1/2" BSP Thread Tapered, SS 7
    35 Old Style Adapter, 1-1/2" NPT Thread 03
    TX150/250 Saddle Fittings
    Model # Description
    Model # Description
    IP811B Fixed Depth Insertion Paddlewheel Meter, Brass, 1/2"-3", FT420 42
    IP811S Fixed Depth Insertion Paddlewheel Meter, 316 SS, 1/2"-3", FT420 70
    IP811P Fixed Depth Insertion Paddlewheel Meter, PVC, 1/2"-3", FT420 73
    IP811Y Fixed Depth Insertion Paddlewheel Meter, Polypro, 1/2"-3", FT420 84
    IP811S-HP Fixed Depth Insertion Paddlewheel Meter, 316 SS, Hi Pres,1/2"-3",FT420 063
    IP821B Fixed Depth Insertion Paddlewheel Meter, Brass, 4"-8", FT420 68
    IP821S Fixed Depth Insertion Paddlewheel Meter, 316 SS, 4"-8", FT420 88
    IP821P Fixed Depth Insertion Paddlewheel Meter, PVC, 4"-8", FT420 90
    IP821Y Fixed Depth Insertion Paddlewheel Meter, Polypro, 4"-8", FT420 03
    IP821S-HP Fixed Depth Insertion Paddlewheel Meter, 316 SS, Hi Pres, 4"-8", FT420 063
    Bronze
    MF81TC-B-050 Tee Fitting, Bronze, Sweat, 1/2", IP 24
    MF81TC-B-075 Tee Fitting, Bronze, Sweat, 3/4", IP 34
    MF81TC-B-100 Tee Fitting, Bronze, Sweat, 1", IP 44
    MF81TC-B-150 Tee Fitting, Bronze, Sweat, 1-1/2", IP 59
    MF81TC-B-200 Tee Fitting, Bronze, Sweat, 2", IP 79
    MF81TC-B-300 Tee Fitting, Bronze, Sweat, 3", IP 44
    MF81TC-B-400 Tee Fitting, Bronze, Sweat, 4, IP 76
    MF81T-B-050 Tee Fitting, Bronze, 1/2", Threaded, IP 24
    MF81T-B-075 Tee Fitting, Bronze, 3/4", Threaded, IP 34
    MF81T-B-100 Tee Fitting, Bronze, 1", Threaded, IP 44
    MF81T-B-150 Tee Fitting, Bronze, 1-1/2", Threaded, IP 59
    MF81T-B-200 Tee Fitting, Bronze, 2", Threaded, IP 79
    MF81T-B-300 Tee Fitting, Bronze, 3", Threaded, IP 44
    MF81T-B-400 Tee Fitting, Bronze, 4", Threaded, IP 76
    PVC
    MF81T-P-050 Tee Fitting, PVC, 1/2", IP 04
    MF81T-P-075 Tee Fitting, PVC, 3/4", IP 14
    MF81T-P-100 Tee Fitting, PVC, 1", IP 24
    MF81T-P-150 Tee Fitting, PVC, 1-1/2", IP 28
    MF81T-P-200 Tee Fitting, PVC, 2", IP 35
    MF81T-P-200-18 Tee Fitting, PVC, Flanged Ends, 2", IP 45
    Carbon Steel
    MF81T-C-050 Tee Fitting, Carbon Steel, 1/2", IP 51
    MF81T-C-075 Tee Fitting, Carbon Steel, 3/4", IP 51
    MF81T-C-100 Tee Fitting, Carbon Steel, 1", IP 79
    MF81T-C-150 Tee Fitting, Carbon Steel, 1-1/2", IP 20
    MF81T-C-200 Tee Fitting, Carbon Steel, 2", IP 61
    MF81T-C-200-34 Tee Fitting, Carbon Steel, Flanged Ends, 2", IP 41
    MF81T-C-050-HP Tee Fitting, Carbon Steel, Hi Pres, 1/2", IP 66
    MF81T-C-075-HP Tee Fitting, Carbon Steel, Hi Pres, 3/4", IP 66
    MF81T-C-100-HP Tee Fitting, Carbon Steel, Hi Pres, 1", IP 94
    MF81T-C-150-HP Tee Fitting, Carbon Steel, Hi Pres, 1-1/2", IP 35
    MF81T-C-200-HP Tee Fitting, Carbon Steel, Hi Pres, 2", IP 76
    MF81T-C-200-34-HP Tee Fitting, Carbon Steel, Flanged Ends, Hi Pres, 2", IP 56
    2014 Industrial  List V2 Page 49 January 01, 2014
    Rev. 050114
    IP800 Series Tee Fittings
    Model # Description
    Stainless Steel
    MF81T-S-050 Tee Fitting, 304 SS, 1/2", IP 16
    MF81T-S-075 Tee Fitting, 304 SS, 3/4", IP 16
    MF81T-S-100 Tee Fitting, 304 SS, 1", IP 57
    MF81T-S-150 Tee Fitting, 304 SS, 1-1/2", IP 67
    MF81T-S-200 Tee Fitting, 304 SS, 2", IP 77
    MF81T-S-050-14 Tee Fitting, 316 SS, 1/2", IP 52
    MF81T-S-075-14 Tee Fitting, 316 SS, 3/4", IP 62
    MF81T-S-100-14 Tee Fitting, 316 SS, 1", IP 18
    MF81T-S-150-14 Tee Fitting, 316 SS, 1-1/2", IP 38
    MF81T-S-200-14 Tee Fitting, 316 SS, 2", IP 63
    MF81T-S-050-HP Tee Fitting, 304 SS, Hi Pres, 1/2", IP 67
    MF81T-S-075-HP Tee Fitting, 304 SS, Hi Pres, 3/4", IP 77
    MF81T-S-100-HP Tee Fitting, 304 SS, Hi Pres, 1", IP 33
    MF81T-S-150-HP Tee Fitting, 304 SS, Hi Pres, 1-1/2", IP 53
    MF81T-S-200-HP Tee Fitting, 304 SS, Hi Pres, 2", IP 78
    MF81T-S-050-14-HP Tee Fitting, 316 SS, Hi Pres, 1/2", IP 67
    MF81T-S-075-14-HP Tee Fitting, 316 SS, Hi Pres, 3/4", IP 77
    MF81T-S-100-14-HP Tee Fitting, 316 SS, Hi Pres, 1", IP 33
    MF81T-S-150-14-HP Tee Fitting, 316 SS, Hi Pres, 1-1/2", IP 53
    MF81T-S-200-14-HP Tee Fitting, 316 SS, Hi Pres, 2", IP 78
    MF81T-S-200-20 Tee Fitting, 304 SS, 2", Flanged Ends, IP 17
    MF81T-S-200-20-HP Tee Fitting, 304 SS,Flanged Ends, Hi Pres, 2", IP 32
    MF81T-S-200-14-20-HP Tee Fitting, 316 SS, Flanged Ends, Hi Pres, 2", IP 118
    IP800 Series Saddle Fittings
    Model # Description
    Ductile Iron
    Bronze
    PVC
    Note: PVC saddles supplied with Buna-N O-rings only.
    2014 Industrial  List V2 Page 50 January 01, 2014
    Rev. 050114
    IP800 Series Weld/Braze Fittings
    Model # Description
    Brass
    Carbon Steel
    Stainless Steel
    IP114B Adj Depth Insertion Paddlewheel Meter, Brass, 3"-12", FT415 94
    IP114P Adj Depth Insertion Paddlewheel Meter, PVC, 3"-12", FT415 99
    IP114S Adj Depth Insertion Paddlewheel Meter, 316 SS, 3"-12", FT415 121
    IP214B Adj Depth Insertion Paddlewheel Meter, Brass, 12"- 40", FT415 081
    IP214P Adj Depth Insertion Paddlewheel Meter, PVC, 12"- 40", FT415 59
    IP214S Adj Depth Insertion Paddlewheel Meter, 316 SS, 12"- 40", FT415 154
    Model # Description
    IP154B Hot Tap Adj Depth Insertion Paddlewheel Meter, Brass, 3"-12", FT415 301
    Model # Description
    IP116B Adj Depth Insertion Paddlewheel Meter, Brass, 3"-12", DL76 53
    IP116P Adj Depth Insertion Paddlewheel Meter, PVC, 3"-12", DL76 58
    IP116S Adj Depth Insertion Paddlewheel Meter, 316 SS, 3"-12", DL76 80
    IP216B Adj Depth Insertion Paddlewheel Meter, Brass, 12"- 40", DL76 40
    IP156/256 Hot-Tap Adjustable Depth Insertion Paddlewheel Meter (DL76 Meter Mount)
    Model # Description
    IP156B Hot Tap Adj Depth Insertion Paddlewheel Meter, Brass, 3"-12", DL76 160
    IP156P Hot Tap Adj Depth Insertion Paddlewheel Meter, PVC, 3"-12", DL76 103
    IP156S Hot Tap Adj Depth Insertion Paddlewheel Meter, 316 SS, 3"-12", DL76 290
    IP256B Hot Tap Adj Depth Insertion Paddlewheel Meter, Brass, 12"- 40", DL76 211
    IP256P Hot Tap Adj Depth Insertion Paddlewheel Meter, PVC, 12"- 40", DL76 178
    IP256S Hot Tap Adj Depth Insertion Paddlewheel Meter, 316 SS, 12"- 40", DL76 320
    01 Rotor w/ Ceramic Shaft, PVDF, Kynar? 9
    Model # Description
    IP158B Hot Tap Adj Depth Insertion Paddlewheel Meter, Brass, 3"-12", PD10 63
    IP158P Hot Tap Adj Depth Insertion Paddlewheel Meter, PVC, 3"-12", PD10 06
    IP158S Hot Tap Adj Depth Insertion Paddlewheel Meter, 316 SS, 3"-12", PD10 093
    IP258B Hot Tap Adj Depth Insertion Paddlewheel Meter, Brass, 12"- 40", PD10 014
    IP258P Hot Tap Adj Depth Insertion Paddlewheel Meter, PVC, 12"- 40", PD10 81
    IP258S Hot Tap Adj Depth Insertion Paddlewheel Meter, 316 SS, 12"- 40", PD10 123
    Model # Description
    Saddle Fittings For IP150/250
    Model # Description
    Model # Description
    WTC100-200 In-Line Turbine Meter, Carbon Steel, 2" Sensor Only 035
    WTC101-200 In-Line Turbine Meter, Carbon Steel, 2", FT420 505
    WTC102-200 In-Line Turbine Meter, Carbon Steel, 2", AO55 405
    WTC104-200 In-Line Turbine Meter, Carbon Steel, 2", FT415 531
    34 2" Body 80
    WTC100-300 In-Line Turbine Meter, Carbon Steel, 3" Sensor Only 299
    WTC101-300 In-Line Turbine Meter, Carbon Steel, 3", FT420 769
    WTC102-300 In-Line Turbine Meter, Carbon Steel, 3", AO55 669
    WTC104-300 In-Line Turbine Meter, Carbon Steel, 3", FT415 795
    WTC100-400 In-Line Turbine Meter, Carbon Steel, 4" Sensor Only 583
    WTC101-400 In-Line Turbine Meter, Carbon Steel, 4", FT420 053
    WTC102-400 In-Line Turbine Meter, Carbon Steel, 4", AO55 953
    WTP100-200 In-Line Turbine Meter, PVC, 2" Sensor Only 02
    WTP101-200 In-Line Turbine Meter, PVC, 2", FT420 272
    WTP102-200 In-Line Turbine Meter, PVC, 2", AO55 172
    WTP104-200 In-Line Turbine Meter, PVC, 2", FT415 298
    Model # Description
    WTS100-200 In-Line Turbine Meter, 304 SS, 2" 655
    WTS101-200 In-Line Turbine Meter, 304 SS, 2", FT420 125
    WTS102-200 In-Line Turbine Meter, 304 SS, 2", AO55 025
    WTS104-200 In-Line Turbine Meter, 304 SS, 2", FT415 151
    14 All 316 SS 28
    20 Flanged Ends 40
    WTS100-300 In-Line Turbine Meter, 304 SS, 3" 250
    WTS101-300 In-Line Turbine Meter, 304 SS, 3", FT420 720
    WTS102-300 In-Line Turbine Meter, 304 SS, 3", AO55 620
    WTS104-300 In-Line Turbine Meter, 304 SS, 3", FT415 746
    14 All 316 SS 54
    WTS100-400 In-Line Turbine Meter, 304 SS, 4" 670
    WTS101-400 In-Line Turbine Meter, 304 SS, 4", FT420 140
    WTS102-400 In-Line Turbine Meter, 304 SS, 4", AO55 040
    WTS104-400 In-Line Turbine Meter, 304 SS, 4", FT415 166
    14 All 316 SS 014
    WTS100-600 In-Line Turbine Meter, 304 SS, 6" 634
    WTS101-600 In-Line Turbine Meter, 304 SS, 6", FT420 104
    WTS102-600 In-Line Turbine Meter, 304 SS, 6", AO55 004
    WTS104-600 In-Line Turbine Meter, 304 SS, 6", FT415 130
    WMP101-200 Plastic Bodied In-Line Magmeter, DC Powered, 2" 35
    WMP101-300 Plastic Bodied In-Line Magmeter, DC Powered, 3" 128
    WMP104-100 Plastic Bodied In-Line Magmeter, Battery Powered, 1" 65
    WMP104-200 Plastic Bodied In-Line Magmeter, Battery Powered, 2" 36
    WMP104-300 Plastic Bodied In-Line Magmeter, Battery Powered, 3" 96
    WMX101-400 Flanged In-Line Magmeter, 2 AA Backup Batteries, 4" 962
    WMX101-600 Flanged In-Line Magmeter, 2 AA Backup Batteries, 6" 113
    WMX101-800 Flanged In-Line Magmeter, 2 AA Backup Batteries, 8" 345
    WMX101-1000 Flanged In-Line Magmeter, 2 AA Backup Batteries, 10" 699
    WMX101-1200 Flanged In-Line Magmeter, 2 AA Backup Batteries, 12" 900
    WMX104-400 Flanged In-Line Magmeter, 2 DD Cell Batteries, 4" 862
    WMX104-600 Flanged In-Line Magmeter, 2 DD Cell Batteries, 6" 013
    WMX104-800 Flanged In-Line Magmeter, 2 DD Cell Batteries, 8" 245
    WMX104-1000 Flanged In-Line Magmeter, 2 DD Cell Batteries, 10" 599
    WMX104-1200 Flanged In-Line Magmeter, 2 DD Cell Batteries, 12" 800
    Model # Description
    AG2000-168-300 Flanged In-Line Magmeter, 2 AA Backup Batteries, IP68 3" 137
    AG2000-168-400 Flanged In-Line Magmeter, 2 AA Backup Batteries, IP68, 4" 378
    AG2000-168-600 Flanged In-Line Magmeter, 2 AA Backup Batteries, IP68, 6" 630
    AG2000-168-800 Flanged In-Line Magmeter, 2 AA Backup Batteries, IP68, 8" 858
    AG2000-168-1000 Flanged In-Line Magmeter, 2 AA Backup Batteries, IP68, 10" 238
    AG2000-168-300 Flanged In-Line Magmeter, 2 DD Cell Batteries, IP68 3" 961
    Rate/Total unit Selection)
    Ordering Example WMX101-168 NO
    CABLE:
    WMX101-400-168-GPM/CFT
    Ordering Example WMX101-168 W/CABLE:
    WMX101-400-168-GPM/CFT-PxX
    2014 Industrial  List V2 Page 73 January 01, 2014
    MJ Bronze Body Pulse Meters (COLD for temperature 105°F and below)
    Model # Description
    MJE-075 Cold-Water, Solid-state Pickup, 3/4" 65
    MJE-100 Cold-Water, Solid-state Pickup, 1" 31
    MJE-150 Cold-Water, Solid-state Pickup, 1-1/2" 24
    MJE-200 Cold-Water, Solid-state Pickup, 2" 32
    MJR-075 Cold-Water, Reed Switch (Dry Contact), 3/4" 41
    MJR-100 Cold-Water, Reed Switch (Dry Contact), 1" 08
    MJR-150 Cold-Water, Reed Switch (Dry Contact), 1-1/2" 77
    MJR-200 Cold-Water, Reed Switch (Dry Contact), 2" 09
    MJT-075 Cold Water, Mechanical Register Only, 3/4" 05
    MJT-100 Cold Water, Mechanical Register Only, 1" 71
    MJT-150 Cold Water, Mechanical Register Only, 1-1/2" 43
    MJT-200 Cold Water, Mechanical Register Only, 2" 70
    Note: s reflect standard pulse rates expressed in gallons.
    There is an additional charge of 0 if you need indication in Cubic Feet or Cubic Meters.
    Available pulse rates are 20, 10, 4, 2, 1 Pulses/Gallon, and 1, 5, 10, 50, 100 Gallons/Pulse.
    Specify MJR/MJE pulse rate at time of order.
    Consult Spec sheet for corresponding meter sizes, and CF and CM pulse rates.
    07 Seametrics Control Connector 0
    106 Roytronics? Series-A Pump 5 Pin Connector 0
    Note: Options not available with MJT
    MJH Bronze Body Pulse Meters (HOT for temperatures 194°F and below)
    Model # Description
    MJHE-075 Hot-Water, Solid-state Pickup, 3/4" 27
    MJHE-100 Hot-Water, Solid-state Pickup, 1" 17
    MJHE-150 Hot-Water, Solid-state Pickup, 1-1/2" 53
    MJHE-200 Hot-Water, Solid-state Pickup, 2" 20
    MJHR-075 Hot-Water, Reed Switch (Dry Contact), 3/4" 15
    MJHR-100 Hot-Water, Reed Switch (Dry Contact), 1" 00
    MJHR-150 Hot-Water, Reed Switch (Dry Contact), 1-1/2" 18
    MJHR-200 Hot-Water, Reed Switch (Dry Contact), 2" 77
    MJHT-075 Hot-Water, Mechanical Register Only, 3/4" 45
    MJHT-100 Hot-Water, Mechanical Register Only, 1" 35
    MJHT-150 Hot-Water, Mechanical Register Only, 1-1/2" 55
    MJHT-200 Hot-Water, Mechanical Register Only, 2" 24
    Model # Description
    MJNE-075 Cold-Water, Solid-state Pickup, 3/4" NSF 82
    MJNE-100 Cold-Water, Solid-state Pickup, 1" NSF 84
    MJNE-150 Cold-Water, Solid-state Pickup, 1-1/2" NSF 43
    MJNE-200 Cold-Water, Solid-state Pickup, 2" NSF 86
    MJNR-075 Cold Water Reed Switch Dry Contact, 3/4" NSF 54
    MJNR-100 Cold Water Reed Switch Dry Contact, 1" NSF 55
    MJNR-150 Cold Water Reed Switch Dry Contact, 1-1/2" NSF 80
    MJNR-200 Cold Water Reed Switch Dry Contact, 2" NSF 53
    MJNT-075 Cold-Water Mechanical Register Only, 3/4" NSF 16
    MJNT-100 Cold-Water Mechanical Register Only, 1" NSF 10
    MJNT-150 Cold-Water Mechanical Register Only, 1-1/2" NSF 51
    103318 Screw Kit, 1/4-20 x 0.625", SH, SS 2
    100264 O-Ring, EPDM, Black 4
    100973 O-Ring, Viton? Teflon Coated 3
    100556 Rotor Repair Kit, Kynar? Silicone Carbide, 6 Magnet 85
    2014 Industrial  List V2 Page 86 January 01, 2014
    Rev. 050114
    SPT Single Jet Low Flow Meters
    Model # Description
    SPT-038 Single Jet Low Flow, PTFE, PTFE Cover, 3/8" 20
    SPT-038-70 Single Jet Low Flow, PTFE, PTFE Cover, SAE Ports, 3/8" 79
    SPT-038-117 Single Jet Low Flow, PTFE, PTFE Cover, BSP Threads, 3/8" 74
    SPT-050 Single Jet Low Flow, PTFE, PTFE Cover, 1/2" 20
    SPT-050-70 Single Jet Low Flow, PTFE, PTFE Cover, SAE Ports, 1/2" 79
    SPT-050-117 Single Jet Low Flow, PTFE, PTFE Cover, BSP Threads, 1/2" 74
    SPX Single Jet Low Flow Meters
    Model # Description
    SPX-038 Single Jet Low Flow, Acrylic Cover, Polypro, 3/8" 95
    SPX-038-70 Single Jet Low Flow, Acrylic Cover, SAE Ports, Polypro, 3/8" 54
    SPX-038-116 Single Jet Low Flow, Acrylic Cover, BSP Threads, Polypro, 3/8" 49
    SPX-050 Single Jet Low Flow, Acrylic Cover, Polypro, 1/2" 95
    SPX-050-70 Single Jet Low Flow, Acrylic Cover, SAE Ports, Polypro, 1/2" 54
    SPX-050-116 Single Jet Low Flow, Acrylic Cover, BSP Threads, Polypro, 1/2" 49
    SPX-075 Single Jet Low Flow, Acrylic Cover, Polypro, 3/4" 95
    SPX-075-70 Single Jet Low Flow, Acrylic Cover, SAE Ports, Polypro, 3/4" 54
    SPX-075-116 Single Jet Low Flow, Acrylic Cover, BSP Threads, Polypro, 3/4" 49
    SPX-100 Single Jet Low Flow, Acrylic Cover, Polypro, 1" 95
    SPX-100-70 Single Jet Low Flow, Acrylic Cover, SAE Ports, Polypro, 1" 54
    SPX-100-116 Single Jet Low Flow, Acrylic Cover, BSP Threads, Polypro, 1" 49
    PE102-038
    101422 Cable, PE Output, 8 Pin, 6 Meter, Shield 3
    103254 PE102-038 PVDF Adapter Kit, 1/4" MNPT, EPDM O-Ring (101688 & 101684) 26
    103255 PE102-038 PVDF Adapter Kit, 1/4" MNPT Viton? O-Ring (101688 & 101685) 34
    103256 PE102-038 PP Adapter Kit, 1/4" MNPT EPDM O-Ring (103014 & 101684) 4
    103257 PE102-038 PP Adapter Kit, 1/4" MNPT Viton? O-Ring (103014 & 101685) 2
    103258 PE102-038 PVDF Adapter Kit, 3/8" MNPT EPDM O-Ring (101672 & 101684) 26
    103259 PE102-038 PVDF Adapter Kit, 3/8" MNPT Viton? O-Ring (101672 & 101685) 34
    103260 PE102-038 PP Adapter Kit, 3/8" MNPT EPDM O-Ring (103013 & 101684) 4
    103261 PE102-038 PP Adapter Kit, 3/8" MNPT Viton? O-Ring (103013 & 101685) 2
    103262 PE102-038 PVDF Adapter Kit, 1/2" MNPT EPDM O-Ring (101940 & 101684) 4
    103263 PE102-038 PVDF Adapter Kit, 1/2" MNPT Viton? O-Ring (101940 & 101685) 2
    103264 PE102-038 PVDF Adapter Kit, 1/2" FNPT EPDM O-Ring (102180 & 101684) 26
    103265 PE102-038 PVDF Adapter Kit, 1/2" FNPT Viton? O-Ring (102180 & 101685) 34
    103266 PE102-038 PP Adapter Kit, 1/2" FNPT EPDM O-Ring (103011 & 101684) 4
    103267 PE102-038 PP Adapter Kit, 1/2" FNPT Viton? O-Ring (103011 & 101685) 2
    101689 Nut, Flaretek, 0.375" (2 Required) 8
    101690 Tool, Flaretek 0.375" 94
    103320 O-Ring Kit, EPDM, 70-Duro, 2-205 8
    103321 O-Ring Kit, Viton, Brown, 75-Duro, 2-205 6
    PE102-075
    103270 PE102-075 PVDF Adapter Kit, 1/2" MNPT EPDM O-Ring (101396 & 100996) 26
    103271 PE102-075 PVDF Adapter Kit, 1/2" MNPT Viton? O-Ring (101396 & 101290) 34
    103272 PE102-075 PP Adapter Kit, 1/2" MNPT EPDM O-Ring (103016 & 100996) 4
    103273 PE102-075 PP Adapter Kit, 1/2" MNPT Viton? O-Ring (103016 & 101290) 2
    103274 PE102-075 PVDF Adapter Kit, 1/2" FNPT EPDM O-Ring (102181 & 100996) 26
    103275 PE102-075 PVDF Adapter Kit, 1/2" FNPT Viton? O-Ring (102181 &101290) 34
    103276 PE102-075 PP Adapter Kit, 1/2" FNPT EPDM O-Ring (103012 &100996) 4
    103277 PE102-075 PP Adapter Kit, 1/2" FNPT Viton? O-Ring (103012 & 101290) 2
    103278 PE102-075 PVDF Adapter Kit, 3/4" MNPT EPDM O-Ring (101252 & 100996) 26
    103279 PE102-075 PVDF Adapter Kit, 3/4" MNPT Viton? O-Ring (101252 & 101290) 34
    103280 PE102-075 PP Adapter Kit, 3/4" MNPT EPDM O-Ring (103015 & 100996)) 4
    103281 PE102-075 PP Adapter Kit, 3/4" MNPT Viton? O-Ring (103015 & 101290) 2
    101284 Nut, Flaretek , 3/4" (2 Required) 8
    101370 Register, MJH CF, 1-1/2" 80
    101371 Register, MJH CF, 2" 80
    101372 Register, MJH, GAL, 3/4" 79
    101373 Register, MJH, GAL, 1" 79
    101374 Register, MJH, GAL, 1-1/2" 80
    101375 Register, MJH, GAL, 2" 80
    101379 Strainer, Internal, MJH, 3/4" 79
    101380 Strainer, Internal, MJH, 1" 79
    101381 Strainer, Internal, MJH, 1-1/2" and 2" 80
    101382 Strainer, Tubular, MJH, 3/4" 79
    101383 Strainer, Tubular, MJH, 1" 79
    2014 Industrial  List V2 Page 99 January 01, 2014
    Rev. 050114
    101384 Strainer, Tubular, MJH, 1-1/2" 80
    101385 Strainer, Tubular, MJH, 2" 80
    101442 Insert Assy, WTC, 3"-8" 67
    101443 Flange, Blanking, Carbon Steel, 3"-8" 67
    101446 Insert Assy, WTC/WTS 2" 67
    101492 Cordset, 5 Pin, 6 Meter, Power/Output Cable for WMP101 70
    101516 Lid & Hinge Pin Assy, WJ Series 76
    101594 Replacement Batteries, WMP, 2 C-Cell (WMP104 only) 70
    101621 Equalization Cable, AG/WMX-400 74
    101622 Equalization Cable, AG/WMX-600/800 74
    101623 Equalization Cable, AG/WMX-1000/1200 74
    101850 Cord Grip, 1/2" NPT 7, 8, 18, 25, 34, 42, 43, 52, 60, 61,
    67 101862 Rotor Assy, Kynar? w/ Carbide Shaft, TX 34, 42, 43, 67
    101868 Housing, Rotor, Brass, TX 42, 43
    101869 Housing, Rotor, 316 SS, TX 42, 43
    101912 Rotor Repair Kit, TX, Kynar?, Carbide Shaft (Rotor, Bearings, Shaft) 34, 43, 67
    101949 Hinged Display Cover 70, 74
    102073 Kit, 3" WMP FNPT Flange Clamps 70
    102157 Grounding Ring, AG/WMX-300 74
    102203 Kit, 2", WMP BSP Flange Clamps (Male Thread) 70
    102204 Kit, 3", WMP BSP Flange Clamps (Male Thread) 70
    102228 O-Ring, Buna-N, 70-Duro, MJ, 1-1/2" and 2" 78, 79, 82, 83
    101684)
    89
    101685)
    89
    101684)
    89
    101685)
    89
    101684)
    89
    101685)
    89
    101684)
    89
    101685)
    89
    101684)
    89
    101685)
    89
    101684)
    89
    100996)
    89
    101290)
    89
    100996)
    89
    101290)
    89
    100996)
    89
    &101290)
    89
    &100996)
    89
    101290)
    89
    100996)
    89
    103308 Kit, Capscrew 10-32 x 2", Socket Head, SS 87
    103309 Kit, 1/4-20 x 1" M/S, SS, WT 67
    103310 Kit, Nut 10-32 Hex, SS 87
    103311 Kit, Gasket Coupling Fiber, 0.625" 86
    103312 Kit, Shaft Assembly, Ceramic, WT/TX 34, 42, 43, 67
    103313 Bearing Assembly Kit, SPX/SPT/SES 86, 87
    103315 Bearing Assembly Kit, IP/TX, Kynar 34, 42, 43, 52, 60, 61
    103316 Gasket Kit, Coupling, Fiber, SEB, 3/4" 86
    103317 Shaft Assy Kit, Carbide, WT 3" to 8" 67
    103318 Screw Kit, 1/4-20 x 0.625", SH, SS 86
    103324 Strain Relief Kit, .069" to .25" Cable 7
    103325 Coupling Assy, Brass, SEB-050 86
    2014 Industrial  List V2 Page 100 January 01, 2014
    Rev. 050114
    103326 Coupling Assy, Brass, SEB-075 86
    DC100 Field-Installed Power/Output Cable, 30M (100 ft) 74
    DC30 Field-Installed Power/Output Cable, 6m (20 ft) 74
    DC30S Field-Installed Power/Output Cable, 6m (20 ft) 74
    DC35 Field-Installed Power/Output Cable, 15m (50 ft) 74
    DC35S Field-Installed Power/Output Cable, 15m (50 ft) 74
    EF81T-B-100 Tee Fitting, Bronze, Threaded, 1", EX 15
    EF81T-B-150 Tee Fitting, Bronze, Threaded, 1-1/2", EX 15
    EF81T-B-200 Tee Fitting, Bronze, Threaded, 2", EX 15
    EF81T-B-300 Tee Fitting, Bronze, Threaded, 3", EX 15
    EF81T-B-400 Tee Fitting, Bronze, Threaded, 4", EX 15
    EF81T-C-100 Tee Fitting, Carbon Steel, 1", EX 15
    EF81T-C-150 Tee Fitting, Carbon Steel, 1-1/2", EX 15
    EF81T-C-200 Tee Fitting, Carbon Steel, 2", EX 15
    EF81T-C-200-34 Tee Fitting, Carbon Steel, Flanged Ends, 2", EX 15
    EF81TC-B-100 Tee Fitting, Bronze, Sweat, 1", EX 15
    EF81TC-B-150 Tee Fitting, Bronze, Sweat, 1-1/2", EX 15
    EF81TC-B-200 Tee Fitting, Bronze, Sweat, 2", EX 15
    EF81TC-B-300 Tee Fitting, Bronze, Sweat, 3", EX 15
    EF81TC-B-400 Tee Fitting, Bronze, Sweat, 4", EX 15
    EF81T-P-100 Tee Fitting, PVC, 1", EX 15
    EF81T-P-150 Tee Fitting, PVC, 1-1/2", EX 15
    EF81T-P-200 Tee Fitting, PVC, 2", EX 15
    EF81T-P-200-18 Tee Fitting, PVC, Flanged Ends, 2",EX 15
    EF81T-S-100 Tee Fitting, 304 SS, 1",EX 15
    EF81T-S-100-14 Tee Fitting, 316 SS, 1",EX 15
    EF81T-S-150 Tee Fitting, 304 SS, 1-1/2", EX 15
    EF81T-S-150-14 Tee Fitting, 316 SS , 1-1/2", EX 15
    EF81T-S-200 Tee Fitting, 304 SS, 2", EX 15
    EF81T-S-200-14 Tee Fitting, 316 SS, 2", EX 15
    EF81T-S-200-20 Tee Fitting, 304 SS, Flanged Ends, 2", EX 15
    EF82S-B-300 Saddle, Bronze, 3", EX 16
    EF82S-B-400 Saddle, Bronze, 4", EX 16
    EF82S-F-1000 Saddle, Iron, 10", EX 16
    EF82S-F-1200 Saddle, Iron, 12", EX 16
    EF82S-F-300 Saddle, Iron, 3", EX 16
    EF82S-F-400 Saddle, Iron, 4", EX 16
    EF82S-F-600 Saddle, Iron, 6", EX 16
    EF82S-F-800 Saddle, Iron, 8", EX 16
    EF82S-P-300 Saddle, PVC, 3", EX 16
    EF82S-P-300-16 Saddle, PVC, 3", w/ 16" Pipe Stub, EX 16
    EF82S-P-400 Saddle, PVC, 4", EX 16
    EF82S-P-400-16 Saddle, PVC, 4", w/ 16" Pipe Stub, EX 16
    EF82S-P-600 Saddle, PVC, 6", EX 16
    EF82S-P-600-16 Saddle, PVC, 6", w/ 16" Pipe Stub, EX 16
    EF82S-P-800 Saddle, PVC, 8", EX 16
    EF82S-P-800-16 Saddle, PVC, 8", w/ 16" Pipe Stub, EX 16
    EF82W-B-1000 Weldolet, Brass, 10", EX 17
    EF82W-B-1200 Weldolet, Brass, 12", EX 17
    EF82W-B-300 Weldolet, Brass, 3", EX 17
    EF82W-B-400 Weldolet, Brass, 4", EX 17
    EF82W-B-600 Weldolet, Brass, 6", EX 17
    EF82W-B-800 Weldolet, Brass, 8", EX 17
    EF82W-C-1000 Weldolet, Carbon Steel, 10", EX 17
    2014 Industrial  List V2 Page 101 January 01, 2014
    Rev. 050114
    EF82W-C-1200 Weldolet, Carbon Steel, 12", EX 17
    EF82W-C-300 Weldolet, Carbon Steel, 3", EX 17
    EF82W-C-400 Weldolet, Carbon Steel, 4", EX 17
    EF82W-C-600 Weldolet, Carbon Steel, 6", EX 17
    EF82W-C-800 Weldolet, Carbon Steel, 8", EX 17
    EF82W-S-1000 Weldolet, 316 SS, 10", EX 17
    EF82W-S-1200 Weldolet, 316 SS, 12", EX 17
    EF82W-S-300 Weldolet, 316 SS, 3", EX 17
    EF82W-S-400 Weldolet, 316 SS, 4", EX 17
    EF82W-S-600 Weldolet, 316 SS, 6", EX 17
    EF82W-S-800 Weldolet, 316 SS, 8", EX 17
    MF101B-300-150 Saddle, Bronze, NPT Thread, 3" X 1-1/2" 24, 41, 59
    MF101B-300-200 Saddle, Bronze, NPT Thread, 3" X 2" 24, 41, 59
    MF101B-400-150 Saddle, Bronze, NPT Thread 4" X 1-1/2" 24, 41, 59
    MF101B-400-200 Saddle, Bronze, NPT Thread, 4" X 2" 24, 41, 59
    MF101F-1000-150 Saddle, Iron, NPT Thread, 10" X 1-1/2" 24, 41, 59
    MF101F-1000-200 Saddle, Iron, NPT Thread, 10" X 2" 24, 41, 59
    MF101F-1200-150 Saddle, Iron, NPT Thread, 12" X 1-1/2" 24, 41, 59
    MF101F-1200-200 Saddle, Iron, NPT Thread, 12" X 2" 24, 41, 59
    MF101F-1400-150 Saddle, Iron, NPT Thread, 14" X 1-1/2" 24, 41, 59
    MF101F-1400-200 Saddle, Iron, NPT Thread, 14" X 2" 24, 41, 59
    MF101F-1600-150 Saddle, Iron, NPT Thread, 16" X 1-1/2" 24, 41, 59
    MF101F-1600-200 Saddle, Iron, NPT Thread, 16" X 2" 24, 41, 59
    MF101F-1800-150 Saddle, Iron, NPT Thread, 18" X 1-1/2" 24, 41, 59
    MF101F-1800-200 Saddle, Iron, NPT Thread, 18" X 2" 24, 41, 59
    MF101F-2000-150 Saddle, Iron, NPT Thread, 20" X 1-1/2" 24, 41, 59
    MF101F-2000-200 Saddle, Iron, NPT Thread, 20" X 2" 24, 41, 59
    MF101F-2200-150 Saddle, Iron, NPT Thread, 22" X 1-1/2" 24, 41, 59
    MF101F-2200-200 Saddle, Iron, NPT Thread, 22" X 2" 24, 41, 59
    MF101F-2400-150 Saddle, Iron, NPT Thread, 24" X 1-1/2" 24, 41, 59
    MF101F-2400-200 Saddle, Iron, NPT Thread, 24" X 2" 24, 41, 59
    MF101F-300-150 Saddle, Iron, NPT Thread, 3" X 1-1/2" 24, 41, 59
    MF101F-300-200 Saddle, Iron, NPT Thread, 3" X 2" 24, 41, 59
    MF101F-400-150 Saddle, Iron, NPT Thread, 4" X 1-1/2" 24, 41, 59
    MF101F-400-200 Saddle, Iron, NPT Thread, 4" X 2" 24, 41, 59
    MF101F-600-150 Saddle, Iron, NPT Thread, 6" X 1-1/2" 24, 41, 59
    MF101F-600-200 Saddle, Iron, NPT Thread, 6" X 2" 24, 41, 59
    MF101F-800-150 Saddle, Iron, NPT Thread, 8" X 1-1/2" 24, 41, 59
    MF101F-800-200 Saddle, Iron, NPT Thread, 8" X 2" 24, 41, 59
    MF81T-B-050 Tee Fitting, Bronze, 1/2", Threaded, IP 49
    MF81T-B-075 Tee Fitting, Bronze, 3/4", Threaded, IP 49
    MF81T-B-100 Tee Fitting, Bronze, 1", Threaded, IP 49
    MF81T-B-150 Tee Fitting, Bronze, 1-1/2", Threaded, IP 49
    MF81T-B-200 Tee Fitting, Bronze, 2", Threaded, IP 49
    MF81T-B-300 Tee Fitting, Bronze, 3", Threaded, IP 49
    MF81T-B-400 Tee Fitting, Bronze, 4", Threaded, IP 49
    MF81T-C-050 Tee Fitting, Carbon Steel, 1/2", IP 49
    MF81T-C-050-HP Tee Fitting, Carbon Steel, Hi Pres, 1/2", IP 49
    MF81T-C-075 Tee Fitting, Carbon Steel, 3/4", IP 49
    MF81T-C-075-HP Tee Fitting, Carbon Steel, Hi Pres, 3/4", IP 49
    MF81T-C-100 Tee Fitting, Carbon Steel, 1", IP 49
    MF81T-C-100-HP Tee Fitting, Carbon Steel, Hi Pres, 1", IP 49
    MF81T-C-150 Tee Fitting, Carbon Steel, 1-1/2", IP 49
    MF81T-C-150-HP Tee Fitting, Carbon Steel, Hi Pres, 1-1/2", IP 49
    2014 Industrial  List V2 Page 102 January 01, 2014
    Rev. 050114
    MF81T-C-200 Tee Fitting, Carbon Steel, 2", IP 49
    MF81T-C-200-34 Tee Fitting, Carbon Steel, Flanged Ends, 2", IP 49
    MF81T-C-200-HP Tee Fitting, Carbon Steel, Hi Pres, 2", IP 49
    MF81TC-B-050 Tee Fitting, Bronze, Sweat, 1/2", IP 49
    MF81TC-B-075 Tee Fitting, Bronze, Sweat, 3/4", IP 49
    MF81TC-B-100 Tee Fitting, Bronze, Sweat, 1", IP 49
    MF81TC-B-150 Tee Fitting, Bronze, Sweat, 1-1/2", IP 49
    MF81TC-B-200 Tee Fitting, Bronze, Sweat, 2", IP 49
    MF81TC-B-300 Tee Fitting, Bronze, Sweat, 3", IP 49
    MF81TC-B-400 Tee Fitting, Bronze, Sweat, 4, IP 49
    MF81T-P-050 Tee Fitting, PVC, 1/2", IP 49
    MF81T-P-075 Tee Fitting, PVC, 3/4", IP 49
    MF81T-P-100 Tee Fitting, PVC, 1", IP 49
    MF81T-P-150 Tee Fitting, PVC, 1-1/2", IP 49
    MF81T-P-200 Tee Fitting, PVC, 2", IP 49
    MF81T-P-200-18 Tee Fitting, PVC, Flanged Ends, 2", IP 49
    MF81T-S-050 Tee Fitting, 304 SS, 1/2", IP 50
    MF81T-S-050-14 Tee Fitting, 316 SS, 1/2", IP 50
    MF81T-S-050-14-HP Tee Fitting, 316 SS, Hi Pres, 1/2", IP 50
    MF81T-S-050-HP Tee Fitting, 304 SS, Hi Pres, 1/2", IP 50
    MF81T-S-075 Tee Fitting, 304 SS, 3/4", IP 50
    MF81T-S-075-14 Tee Fitting, 316 SS, 3/4", IP 50
    MF81T-S-075-14-HP Tee Fitting, 316 SS, Hi Pres, 3/4", IP 50
    MF81T-S-075-HP Tee Fitting, 304 SS, Hi Pres, 3/4", IP 50
    MF81T-S-100 Tee Fitting, 304 SS, 1", IP 50
    MF81T-S-100-14 Tee Fitting, 316 SS, 1", IP 50
    MF81T-S-100-14-HP Tee Fitting, 316 SS, Hi Pres, 1", IP 50
    MF81T-S-100-HP Tee Fitting, 304 SS, Hi Pres, 1", IP 50
    MF81T-S-150 Tee Fitting, 304 SS, 1-1/2", IP 50
    MF81T-S-150-14 Tee Fitting, 316 SS, 1-1/2", IP 50
    MF81T-S-150-14-HP Tee Fitting, 316 SS, Hi Pres, 1-1/2", IP 50
    MF81T-S-150-HP Tee Fitting, 304 SS, Hi Pres, 1-1/2", IP 50
    MF81T-S-200 Tee Fitting, 304 SS, 2", IP 50
    MF81T-S-200-14 Tee Fitting, 316 SS, 2", IP 50
    MF81T-S-200-14-HP Tee Fitting, 316 SS, Hi Pres, 2", IP 50
    MF81T-S-200-20 Tee Fitting, 304 SS, 2", Flanged Ends, IP 50
    MF81T-S-200-HP Tee Fitting, 304 SS, Hi Pres, 2", IP 50
    MF82S-B-300 Saddle, Bronze, 3" 32, 50
    MF82S-B-400 Saddle, Bronze, 4" 32, 50
    MF82S-F-300 Saddle, Iron, 3" 32, 50
    MF82S-F-400 Saddle, Iron, 4" 32, 50
    MF82S-F-600 Saddle, Iron, 6" 32, 50
    MF82S-F-800 Saddle, Iron, 8" 32, 50
    MF82S-P-300 Saddle, PVC, 3" 32, 50
    MF82S-P-300-16 Saddle, PVC, 3", w/ 16" Pipe Stub 32, 50
    MF82S-P-400 Saddle, PVC, 4" 32, 50
    MF82S-P-400-16 Saddle, PVC, 4", w/ 16" Pipe Stub 32, 50
    MF82S-P-600 Saddle, PVC, 6" 32, 50
    MF82S-P-600-16 Saddle, PVC, 6", w/ 16" Pipe Stub 32, 50
    MF82S-P-800 Saddle, PVC, 8" 32, 50
    MF82S-P-800-16 Saddle, PVC, 8", w/ 16" Pipe Stub 32, 50
    MF82W-B-300 Weldolet, Brass, 3" 33, 51
    MF82W-B-400 Weldolet, Brass, 4" 33, 51
    MF82W-B-600 Weldolet, Brass, 6" 33, 51
    2014 Industrial  List V2 Page 103 January 01, 2014
    Rev. 050114
    MF82W-B-800 Weldolet, Brass, 8" 33, 51
    MF82W-C-300 Weldolet, Carbon Steel, 3" 33, 51
    MF82W-C-300-HP Weldolet, Carbon Steel, Hi Pres, 3" 33, 51
    MF82W-C-400 Weldolet, Carbon Steel, 4" 33, 51
    MF82W-C-400-HP Weldolet, Carbon Steel, Hi Pres, 4" 33, 51
    MF82W-C-600 Weldolet, Carbon Steel, 6" 33, 51
    MF82W-C-600-HP Weldolet, Carbon Steel, Hi Pres, 6" 33, 51
    MF82W-C-800 Weldolet, Carbon Steel, 8" 33, 51
    MF82W-C-800-HP Weldolet, Carbon Steel, Hi Pres, 8" 33, 51
    MF82W-S-300 Weldolet, 316 SS, 3" 33, 51
    MF82W-S-300-HP Weldolet, 316 SS, Hi Pres, 3" 33, 51
    MF82W-S-400 Weldolet, 316 SS, 4" 33, 51
    MF82W-S-400-HP Weldolet, 316 SS, Hi Pres, 4" 33, 51
    MF82W-S-600 Weldolet, 316 SS, 6" 33, 51
    MF82W-S-600-HP Weldolet, 316 SS, Hi Pres, 6" 33, 51
    MF82W-S-800 Weldolet, 316 SS, 8" 33, 51
    MF82W-S-800-HP Weldolet, 316 SS, Hi Pres, 8" 33, 51
    TF81T-B-150 Tee Fitting, Bronze, Threaded, 1-1/2", TX 31
    TF81T-B-200 Tee Fitting, Bronze, Threaded, 2", TX 31
    TF81T-B-300 Tee Fitting, Bronze, Threaded, 3", TX 31
    TF81T-B-400 Tee Fitting, Bronze, Threaded, 4", TX 31
    TF81T-C-150 Tee Fitting, Carbon Steel, 1-1/2", TX 31
    TF81T-C-150-HP Tee Fitting, Carbon Steel, Hi Pres, 1-1/2", TX 31
    TF81T-C-200 Tee Fitting, Carbon Steel, 2", TX 31
    TF81T-C-200-HP Tee Fitting, Carbon Steel, Hi Pres, 2", TX 31
    TF81TC-B-150 Tee Fitting, Bronze, Sweat, 1-1/2", TX 31
    TF81TC-B-200 Tee Fitting, Bronze, Sweat, 2", TX 31
    TF81TC-B-300 Tee Fitting, Bronze, Sweat, 3", TX 31
    TF81TC-B-400 Tee Fitting, Bronze, Sweat, 4", TX 31
    TF81T-P-150 Tee Fitting, PVC, 1-1/2", TX 31
    TF81T-P-200 Tee Fitting, PVC, 2", TX 31
    TF81T-S-150 Tee Fitting, 304 SS, 1-1/2", TX 31
    TF81T-S-150-14 Tee Fitting, 316 SS, 1-1/2", TX 31
    TF81T-S-150-14-HP Tee Fitting, 316 SS, Hi Pres, 1-1/2", TX 31
    TF81T-S-150-HP Tee Fitting, 304 SS, Hi Pres, 1-1/2", TX 31
    TF81T-S-200 Tee Fitting, 304 SS, 2", TX 31
    TF81T-S-200-14 Tee Fitting, 316 SS, 2", TX 31
    TF81T-S-200-14-HP Tee Fitting, 316 SS, Hi Pres, 2", TX 31
    TF81T-S-200-HP Tee Fitting, 304 SS, Hi Pres, 2", TX 31
     2013
    Mount70
    Model#Description
    Rev.050114
    Model#Description
    Model#Description
    15ReverseFlow49
    40Immersible0
    50LowPowerNC
    125Viton?O-Ring6
    Model#Description
    Model#Description
    15ReverseFlow49
    50LowPowerNC
    125Viton?O-Ring6
    Rev.050114
    Model#Description
    15 Reverse Flow 49
    50 Low Power NC
    125 Viton? O-Ring 6
    Model # Description
    Model # Description
    Bronze
    PVC
    Carbon Steel
    Stainless Steel
    Rev. 050114
    Model # Description
    Ductile Iron
    PVC
    Carbon Steel
    Stainless Steel
    Model # Description
    Model # Description
    Model # Description
    Model # Description
    Model # Description
    60 Viton? O-Ring 6
    Model # Description
    60 Viton? O-Ring 6
    Rev. 050114
    Model # Description
    60 Viton? O-Ring 6
    Model # Description
    60 Viton? O-Ring 6
    Rev. 050114
    Model # Description
    Bronze
    PVC
    Carbon Steel
    Stainless Steel
    Rev. 050114
    Model # Description
    Bronze
    PVC
    Ductile Iron
    Rev. 050114
    Model # Description
    Brass
    Carbon Steel
    Stainless Steel
    Model # Description
    Model # Description
    Model # Description
    Bronze
    PVC
    Carbon Steel
    Rev. 050114
    Model # Description
    Stainless Steel
    Model # Description
    Ductile Iron
    Bronze
    PVC
    Rev. 050114
    Model # Description
    Brass
    Carbon Steel
    Stainless Steel
    Model # Description
    Model # Description
    Model # Description
    Model # Description
    Model # Description
    Model # Description
    Model # Description
    34 2" Body 80
    Model # Description
    14 All 316 SS 28
    20 Flanged Ends 40
    14 All 316 SS 54
    14 All 316 SS 014
    Model # Description
    CABLE:
    Model # Description
    Model # Description
    Model # Description
    Rev. 050114
    Model # Description
    Model # Description
    PE102-038
    PE102-075
    Rev. 050114
    101684)
    89
    101685)
    89
    101684)
    89
    101685)
    89
    101684)
    89
    101685)
    89
    101684)
    89
    101685)
    89
    101684)
    89
    101685)
    89
    101684)
    89
    100996)
    89
    101290)
    89
    100996)
    89
    101290)
    89
    100996)
    89
    &101290)
    89
    &100996)
    89
    101290)
    89
    100996)
    89
    Rev. 050114
    Rev. 050114
    Rev. 050114
    Rev. 050114
  • 蔡莉 在2025/2/26 15:49:00留言
  • 详细留言:CTC AC184—1A 需求报价及购买方式
  • 刘飞 在2025/2/21 11:49:00留言
  • 详细留言:SB35HF140-50F10/112-1这个型号的蓄能器是否有货
  • 江生 在2025/2/13 14:39:00留言
  • 详细留言:K2BB47-11A,230VAC,50/60Hz 风机或者电机是否有现货?
