上海航欧ARIS电机ARIS调节阀ARIS变送器ARIS调节器ARIS蝶阀ARIS执行机构ARIS显示屏ARIS开关ARIS执行器ARIS液压伺服缸ARIS伺服器ARIS伺服电动机![](http://www.cechina.cn/UpLoad/CompanyFile/2023/9/3/c31474d5-580d-48a7-b0a7-a2610460b1d3.jpg)
ARIS
PD35
ARIS
PE55-06
ARIS
BE41-21003
ARIS
ACTUATINGDRIVE|K3006230V\50HZ,IP54 0429-4002-01003
ARIS
EF06-1
ARIS
K3006/1242-84873-01001
ARIS
FNr.1420-6259-01010;Typ:EF 1 MA333312
ARIS
PE40-08
ARIS Antriebe und Steuerungen GmbH PE30-08
aris
FNr: 0736-67622-01002
aris
6443LI 230V 50/60HZ 18VA 375/450RPM 92MA 0.56??F Nr.000429
ARIS
N5 RD-S/DN 250d 230V 50??60??HZ FNr??0620-62724-01001
Aris
PMR2 0700002 NR:0216-52001-001
ARIS
0542-61428-02010 N-B1-E
Aris
K3006 FNR.1137-5461-01059
ARIS
FNr:1142-5481-02040
ARIS
FNr:1219-83411-01003
Aris
K3012,Stroke -- 300mm;actuating force --- 1200N;voltage ---
230V/50Hz;actuating speed --- 1.7(2) sec;
ARIS
PD35 90 degrees, bushings for the plum-shaped CH.22, counterclockwise
81020/06
ARIS
PE55-06 S4, 90 degrees, bushings for the plum-shaped CH.27,
counterclockwise 81928/03
ARIS
N 5 1209-82710-01003 30 s / 90??+ PMR 3
ARIS
Typ:NL-90/120 FNr:1209-82710-02017 230V 50/60Hz 18VA 120Nm 90?? IP65
ARIS
FNr:0908-4966-01008 Typ:EF1
ARIS
NL-90/120
ARIS
Aris
Type: K3012 1,7/1200 2ZW RP19; Rated power: 0,031 kw; Nominal voltage:
220,000 V; Nominal voltage: 230,000 V; Nominal frequency: 60,000 hz; Nominal
frequency: 50,000 hz; Degree of protection: IP54; Stroke: 300,000
ARIS
TYP.N5 FNr.1117-79726-01002
