2017年ADELsystem工厂上海航欧中国区销售
ADEL电源ADEL开关电源ADEL变送器ADEL差压变送器ADELSYSTEM开关电源、ADELSYSTEMADELSYSTEM电源供应器、ADELSYSTEM模块、ADELSYSTEM接口
2017年 ADELsystem工厂上海航欧中国区销售
意大利ADELSYSTEM开关电源SCE12ADELSYSTEM电源、ADELSYSTEM开关电源、ADELSYSTEM、ADELSYSTEM电源供应器、ADELSYSTEM模块、ADELSYSTEM接口
主要型号:
DFLEX
Switchingpowersupplies-Input115–230Vac
DFX1512ASwitchingPowersupplyOutput:12Vdc1AInput:115-230VacD/P
DFX4512ASwitchingPowersupplyOutput:12Vdc3AInput:115-230VacD/P
DFX6012ASwitchingPowersupplyOutput:12Vdc6AInput:115-230VacD/P
DFX1524ASwitchingPowersupplyOutput:24Vdc0.5AInput:115-230VacD/P
DFX4524ASwitchingPowersupplyOutput:24Vdc1.75AInput:115-230VacD/P
DFX6024ASwitchingPowersupplyOutput:24Vdc3AInput:115-230VacD/P
FLEX
FLEX6005ASwitchingPowersupplyOutput:5Vdc5AInput:115-230VacD
FLEX6012ASwitchingPowersupplyOutput:12Vdc6AInput:230VacD
FLEX17012ASwitchingPowersupplyOutput:12Vdc14AInput:230VacD
FLEX28012ASwitchingPowersupplyOutput:12Vdc20AInput:230VacD
FLEX6024ASwitchingPowersupplyOutput:24Vdc3AInput:115-230VacD
FLEX9024ASwitchingPowersupplyOutput:24Vdc5AInput:115-230VacD
FLEX17024ASwitchingPowersupplyOutput:24Vdc7,5AInput:115-230VacD
FLEX28024ASwitchingPowersupplyOutput:24Vdc14AInput:115-230VacD
FLEX50024ASwitchingPowersupplyOutput:24Vdc25AInput:115-230VacD
Switchingpowersupplies-Input230-400–500Vac2and3Phase
FLEX9024BSwitchingPowersupplyOutput:24Vdc5A(2Phase)D
FLEX17024BSwitchingPowersupplyOutput:24Vdc7,5A(2Phase)D
FLEX28024BSwitchingPowersupplyOutput:24Vdc14A(2Phase)D
FLEX50024BSwitchingPowersupplyOutput:24Vdc25A(3Phase)D
FLEX17048ASwitchingPowersupplyOutput:48Vdc3,8AInput:115-230VacD
FLEX28048ASwitchingPowersupplyOutput:48Vdc7,5AInput:115-230VacD
FLEX50048ASwitchingPowersupplyOutput:48Vdc12,5AInput:115-230VacD
PST
Switchingpowersupplies-Input400–480Vac3-Phase
PST2440BSwitchingPowersupplyOutput:24Vdc40AD
"PSTseries"Switchingpowersupplies-Input400–480Vac3-Phase(DriverApplications)
PST4810BSwitchingPowersupplyOutput:48Vdc10A-35Amax.D
SW
AC/DCandDC/DCConverters"NotIsolated"-LowVoltageInputACorDC24V
Input:24V
SW053LCSwitchingPowersupplyOutput:5Vdc3AD
SW103LCSwitchingPowersupplyOutput:10Vdc3AD
SW125HPSwitchingPowersupplyOutput:12Vdc5AD
SW243LCSwitchingPowersupplyOutput:24Vdc3AD
SW245HPSwitchingPowersupplyOutput:24Vdc5AD
SW247HPSwitchingPowersupplyOutput:24Vdc7AD
Input:48V
SW245HP/48SwitchingPowersupplyOutput:24Vdc3A-Input48VdcD
PFAL
AC/DcandDC/DCConverters"NotIsolated"-LowVoltageInputAcorDC-AdjustableoutputVdc+/-10%
Input:24V
PFAL2410SwitchingPowersupplyOutput:24Vdc10AD
PFAL2420 Switching
Power supply Output:24Vdc 20A D
Input: 48V
PFAL2420/48 Switching
Power supply Output:24Vdc 15A - Input 48Vdc D
Input 6-28Vac/8-39Vdc
PFALVP3
Vout Adjustable from 1.25 - 27 Vdc 2 A D
SCM
Switching power supplies - Input 115–230
Vac
SCM4012A Switching
Power supply Output: 12Vdc 3.5 A Input: 115 - 230 Vac P
SCM7512A Switching
Power supply Output: 12Vdc 6.3 A Input: 115 - 230 Vac P
SCM10012A Switching
Power supply Output: 12Vdc 8.5 A Input: 115 - 230 Vac P
SCM4024A Switching
Power supply Output: 24Vdc 1.8 A Input: 115 - 230 Vac P
SCM7524A Switching
Power supply Output: 24Vdc 3.2 A Input: 115 - 230 Vac P
SCM10024A Switching
Power supply Output: 24Vdc 4.5 A Input: 115 - 230 Vac P
Product group 2 DC / DC Converter
SUP
STEP-UP DC/DC Converters "Not
Isolated"- Low Input Vdc- Adjustable output Vdc +/-10%
Input: 12V
SUP3-1224 STEP-UP
Dc/Dc ing. 12V out. 24V 3A D
SUP6-1224 STEP-UP
Dc/Dc ing. 12V out. 24V 6A D
Input: 12V
SUP3-1230 STEP-UP
Dc/Dc ing. 12V out. 30V 3A D
Input: 12V
SUP3-1240 STEP-UP
Dc/Dc ing. 12V out. 40V 3A D
Input: 24V
SUP3-2448 STEP-UP
Dc/Dc ing. 24V out. 48V 3A D
SUP6-2448 STEP-UP
Dc/Dc ing. 24V out. 48V 6A D
Input: 24V
SUP3-2460 STEP-UP
Dc/Dc ing. 24V out. 60V 2,5A D
SUP6-2460 STEP-UP
Dc/Dc ing. 24V out. 60V 6A D
SUP ISO
DC/DC Converters "Isolated"- Low
Voltage Input DC to DC - Adjustable output Vdc +/-10%
Input 12Vdc
SUP30-12/24 Switching
Power supply Input 10 - 18 Vdc Output:
24 Vdc 1.3 A P
SUP50-12/12 Dc/Dc
Converter Input 10 - 15 Vdc Output: 12
Vdc 4.2 A (Isolated) P
SUP50-12/24 Switching
24 Vdc 2.1 A P
Input 24Vdc
SUP30-24/24 Switching
Power supply Input 18 - 36 Vdc Output:
24 Vdc 1.3 A P
SUP50-24/24 Switching
24 Vdc 2.1 A P
SUP70-24/24 Switching
24 Vdc 3 A P
SUP100-24/24 Switching Power supply Input 18 - 36
Vdc Output: 24 Vdc 4.2 A P
SUP200-24/24 Switching Power supply Input 18 - 36
Vdc Output: 24 Vdc 8.4 A P
Input 48Vdc
SUP30-48/24 Switching
Power supply Input 36 - 72 Vdc Output:
24 Vdc 1.3 A P
SUP70-48/24 Switching
Power supply Input 36- 72 Vdc Output: 24
Vdc 3 A P
SUP150-48/24 Switching Power supply Input 36 - 72
Vdc Output: 24 Vdc 6.3 A P
SUP200-48/24 Switching Power supply Input 36 - 72
SUP200-48/12 Switching Power supply Input 36 - 72 Vdc Output: 12 Vdc
16.7 A P
DINSUP Support
for Din Rail "SUP Line" D
Product group 3 DC-UPS
CBI
DC-UPS -
ALL IN ONE = Battery Charger + Continuity BackUp Module +
Power Supply in one unit
Input 115-230-270 Vac
CBI123A DC-UPS
Out 12 Vdc 3A In 115-230-270 Vac, no NiCd battery, with Temperature
Compensation D
CBI123A-NiCd DC-UPS Out 12 Vdc 3A In 115-230-270 Vac, NiCd battery enabled, no
Temperature Compensation D
CBI126A DC-UPS
Out 12 Vdc 6A In 115-230-270 Vac, no NiCd battery, with Temperature
Compensation D
CBI126A-NiCd DC-UPS Out 12 Vdc 6A In 115-230-270 Vac, NiCd battery enabled, no
ADEL变送器CBI1210A DC-UPS Out 12 Vdc
10A In 115-230-270 Vac, no NiCd battery, with Temperature Compensation D
CBI1210A-NiCd DC-UPS Out 12 Vdc 10A In 115-230-270 Vac, NiCd battery
enabled, no Temperature Compensation D
CBI1235A DC-UPS
Out 12 Vdc 35A In 115-230-270 Vac - MODbus connection D
CBI1235AP DC-UPS
Out 12 Vdc 35A In 115-230-270 Vac (parallel connection enabled) D
CBI1235AR DC-UPS
Out 12 Vdc 35A In 115-230-270 Vac - (Battery charging redundancy, MR220 module
required) D
Input 115–230-270 Vac
CBI243A DC-UPS
Out 24 Vdc 3A In 115-230-270 Vac, no NiCd battery, with Temperature
Compensation D
CBI243A-NiCd DC-UPS Out 24 Vdc 3A In 115-230-270 Vac, NiCd battery enabled, no
CBI245A DC-UPS
Out 24 Vdc 5A In 115-230-270 Vac, no NiCd battery, with Temperature
Compensation D
CBI245ATB DC-UPS
Out 24 Vdc 5A In 115-230-270 Vac, no NiCd battery, with Temperature Compensation,
Time Buffering 5' D
CBI245ATB1 DC-UPS
Out 24 Vdc 5A In 115-230-270 Vac, no NiCd battery, with Temp. Compensation,
Time Buffering 0.5 min in Low batt; UPS Enabling D
CBI245A-NiCd DC-UPS Out 24 Vdc 5A In 115-230-270 Vac, NiCd battery enabled, no Temperature
Compensation D
CBI2410A DC-UPS
Out 24 Vdc 10A In 115-230-270 Vac-No Battery start-up,No NiCd battery,Yes
Temperature compensation D
CBI2410ATB DC-UPS
Temperature compensation,Time Buffering 5' D
CBI2410A-NiCd DC-UPS Out 24 Vdc 10A In 115-230-270 Vac-No Battery
start-up,Yes NiCd battery,No Temperature compensation D
CBI2410A/S DC-UPS
Out 24 Vdc 10A In 115-230-270 Vac-Yes Battery start-up,No NiCd battery,Yes
CBI2420A DC-UPS
Out 24 Vdc 20A In 115-230-270 Vac - MODbus connection D
CBI2420AP DC-UPS
Out 24 Vdc 20A In 115-230-270 Vac (parallel connection enabled) D
CBI2420AR DC-UPS
Out 24 Vdc 20A In 115-230-270 Vac - (Battery charging redundancy, MR220 module
required) D
CBI485A DC-UPS
Out 48 Vdc 5A In 115-230-270 Vac-No Battery start-up,No NiCd battery,Yes
CBI485A-NiCd DC-UPS Out 48 Vdc 5A In 115-230-270 Vac-No Battery start-up, Yes
NiCd battery,NoTemperature compensation D
CBI485A/S DC-UPS
Out 48 Vdc 5A In 115-230-270 Vac -Yes Battery start-up,No NiCD battery,Yes
CBI4810A DC-UPS
Out 48 Vdc 10A In 115-230-270 Vac - MODbus connection D
CBI4810AP DC-UPS
Out 48 Vdc 10A In 115-230-270 Vac (parallel connection enabled) D
CBI4810AR DC-UPS
Out 48 Vdc 10A In 115-230-270 Vac - (Battery charging redundancy, MR220 module
required) D
CBI2801224A DC
UPS Out 12-24 Vdc(selectable)280W In:115-230-277Vac Modbus D
Input 230 - 400 - 500 Vac
CBI2801224B DC
UPS Out 12-24 Vdc(selectable)280W In:230-400-500Vac Modbus D
Accessories for CBI
RTCONN Connector
for position 5 (Start from battery) with Two Wires (2 m)
RJTEMP451 Temperature
compensation probe with connector 1m (For all CBI models except for CBI280)
RJTEMP453 Temperature
compensation probe with connector 3m (For all CBI models except for CBI280)
RJTEMP111 Temperature
compensation probe with RJ11 connector 1m (Specific for CBI2801224A and B)
RJTEMP113 Temperature
compensation probe with RJ11 connector 3m (Specific for CBI2801224A and B)
ERJ.CBI.004 Paralleling
Cable Connector RJ45/RJ45 1m (Suitable for CBI1235A,2420A,4810A and for Modbus
connection on CBI280)
Demo Kit
CBI demo Kit Demonstrative panel composed of CBI1210A and Batt1.2 for Show
room
Input 400
Vac
UPS2410B DC-UPS,
400Vac in, 10A 24 Vdc out D
UPS2410B/RS DC-UPS,
400Vac in, 10A 24 Vdc out - RS232 D
PSM
Switching power supplies and Battery
Charger - Input 115–230 Vac
PSM123A Out
Load 13.8 V 3A; Battery 13.3; 0.1A D
PSM241A Out
Load 24 V 1.5 A; Battery 27 V ; 0.1A D
UPL
UPL5512A Out
Load 13.8 V 4 A; Battery 13.4 ; 0.23A D
UPL10012A Out
Load 13.8 V 6A; Battery 13.3; 0.5A D
UPL5524A Out
Load 27.6 V; 2A; Battery 26.5; 0.16A D
UPL10024A Out
Load 27.6 V 3A; 27.V; 0.5A D
Product group 4 Battery Charger
CB
CB - Battery chargers. They Test and
Recharge the battery Input 115–230-270 Vac
CB123A Battery
Charger 3 Level Out 12 Vdc 3A In 115-230-270 Vac D
CB123A/48 Battery
Charger 3 Level Out 12 Vdc 3A In 48 Vdc D
CB1210A Battery
Charger 3 Level Out 12 Vdc 10A In 115-230-270 Vac D
CB1235A Battery
Charger 3 Level Out 12 Vdc 35A In 115-230-270 Vac D
CB243A Battery
Charger 3 Level Out 24 Vdc 3A In 115-230-270 Vac D
CB245A Battery
Charger 3 Level Out 24 Vdc 5A In 115-230-270 Vac D
CB2410AC Battery
Charger 3 Level Out 24 Vdc 10A In 115-230-270 Vac D
CB2420A Battery
Charger 3 Level Out 24 Vdc 20A In 115-230-270 Vac D
CB363A Battery
Charger 3 Level Out 36 Vdc 3A In 115-230-270 Vac D
CB12245A Battery
Charger 4 Level Out 12-24 Vdc(selectable)120W In:115-230-277Vac D
Product group 5 Battery Bank
VRLA
Enclosure + Battery
BATT 123 12
Vdc Battery 3.2Ah ( N.1 battery+Battery Chest) P
BATT 123DIN 12
Vdc Battery 3.2Ah ( N.1 battery+Battery Chest) with DIN clip D
BATT 127 12
Vdc Battery 7.2Ah ( N.1 battery+Battery Chest) P
BATT 127DIN 12
Vdc Battery 7.2Ah ( N.1 battery+Battery Chest) with DIN clip D
BATT 1.2Ah 24
Vdc Battery 1.2Ah ( N.2 batteries+Battery Chest) P
BATT 1.2AhDIN 24 Vdc Battery 1.2Ah ( N.2 batteries+Battery Chest) with DIN
clip D
BATT 3.2Ah 24
Vdc Battery 3.2Ah ( N.2 batteries+Battery Chest) P
BATT 3.2AhDIN 24 Vdc Battery 3.2Ah ( N.2 batteries+Battery Chest) with DIN
clip D
BATT 7.2Ah 24
Vdc Battery 7.2Ah ( N.2 batteries+Battery Chest) P
BATT 7.2AhDIN 24 Vdc Battery 7.2Ah ( N.2 batteries+Battery Chest) with DIN
clip D
Enclosure
BATTHOLDER123 Battery chest for battery 12V/3.2Ah - without battery P
BATTHOLDER123DIN Battery chest for battery 12V/3.2Ah - without battery with DIN
clip D
BATTHOLDER127 Battery chest for battery 12V/7.2Ah - without battery P
BATTHOLDER127DIN Battery chest for battery 12V/7.2Ah - without battery with DIN
clip D
BATTHOLDER1212 Battery chest for battery 12V/12Ah - without battery P
Small VRLA
Enclosure + Battery
BAT1.2VRLA 24
Vdc Battery 1.2Ah ( N.2 batteries+Battery Enclosure) DIN & Wall mount D/P
BAT3.4VRLA 24
Vdc Battery 3.2Ah ( N.2 batteries+Battery Enclosure) DIN & Wall mount D/P
BAT7.2VRLA 24
Vdc Battery 7.2Ah ( N.2 batteries+Battery Enclosure) DIN & Wall mount D/P
BAT12VRLA 24
Vdc Battery 12Ah ( N.2 batteries+Battery Enclosure) Wall mount P
Enclosure
BTH1.2VRLA 24
Vdc Battery Enclosure for N.2 batteries 12V/1.2Ah - without battery, DIN &
Wall mount D/P
BTH3.4VRLA 24
Vdc Battery Enclosure for N.2 batteries 12V/3.4Ah - without battery, DIN &
Wall mount D/P
BTH7.2VRLA 24
Vdc Battery Enclosure for N.2 batteries 12V/7.2Ah - without battery, DIN &
Wall mount D/P
BTH12VRLA 24
Vdc Battery Enclosure for N.2 batteries 12V/12Ah - without battery, Wall mount P
SFP
SFP544 Panel
for EN54.4 field. Can contain batteries VRLA from 1.2 up to 18Ah and all range
of DC UPS "CBI" P
Product group 6 Interfaces
MR
Decoupler
MR220 Decoupling
Module In - Out 10 - 60 Vdc 25A D
Product group 7 Multimediality
Power Bus
PBI122 2017年ADELsystem工厂上海航欧中国区销售
