  • 航欧销售Waddington变速循环控制单元
  • 发布时间:2024/11/14 10:56:20   修改时间:2024/11/14 10:56:20 浏览次数:46
  • 2016Waddington工厂上海航欧中国区销售
    上海航欧销售Waddington变速循环控制单元Waddington传感器Waddington超声波传感器Waddington开关 Waddington电源,Waddington控制器,Waddington动力控制
     主要型号:PSPCB10000
     PSPCB10000-BIN
     PSENC10000
     PSENC10031
     PSENC10032
     PSENC10009
     PSENC10010
     PSENC10000-NE
     PSENC10001
     PSENC10021
     PSENC10035
     PSENC50002
     PCDIO10003
     PCDIO10008
     PCDIO10000
     PCDIO10008
     PCDIO10003
     PCDIO10000
     STTOPLIMIT1
     STTOPLIMIT2
     STBOTTOMLIMIT1
     STBOTTOMLIMIT2
     ST2NDTOPLIMIT
     ST2NDBOTTOMLIMI
     PSCBL70012
     PSCBL70006
     PSCBL70008
     PSCBL70013
     PSCBL70014
     PSCBL70019
     PSCBL70015
     WESTAMRSH2R1
     WESTAMRSH2R2
     WESTAMRSH2R2SST
     WESTAMRSH3
     WESTAMRSH2R1H
     WESTAMRSH2R2H
     WESTAMRSH2FG
     WESTAMRSH2R1H
     WESTAMRSH2R2HFG
     WESTASSH1
     WESTASSH2
     STHEADsonatrolheadoptionsExtrasensors
     WESTAMRSH2R1mrsh-2/r15in-20ftsonarsensor3800
     WESTAMRSH2R2mrsh-2/r218in-20ftsonarsenso3800
     WESTAMRSH2R2SSTmrsh-2/r218in-20ftsstransdu5500
     WESTAMRSH3sonatrolsensorwithdual7700
     WESTAMRSH2R1Hr1sensorw/hornN8800
     WESTAMRSH2R2Hr2sensorw/hornN8800
     WESTAMRSH2FGmrsh-2fgsensorr2fixedgain0000
     WESTAMRSH2R2HFGr2sensorw/hornandfixedgainN2000
     WESTASSSH1 r-1 stainless steel sensor  7500
     WESTASSSH2 r-2 stainless steel sensor  7500
     STWESTA30FT st6z mods for 30 ft range  Range Mods
     WESTA30FT st6z mods for 30 ft range  000
     STWESTAAOAB air output a/b option
     WESTAAOAB air output a / b selec switch  $ -
     STWESTAAUTO/MAN auto manual out put option
     WESTAAUTO/MAN auto/manual selector switch  $ -
     STWESTAF/V1 freq to voltage option
     WEEZAFV1 f/v-1 frequency to voltage oe Y $ -
     STWESTAGUIDE001 sensor guide adjust able width  call
     WESTASTANDWH1 stand-wh sensor stand w/wheels N 3000
     STWESTAMTRSEL dc motor sel a/b contactor
     WESTAMTRSEL dc motor sel a/b contactor  5000
     STWESTAUTF1 upper time filter option
     WESTAUTF1 utf-1 upper time filter option  $ -
     STWEST/F1 voltage to frequecny option
     PSMDL04 v/f-1 voltage to frequency  $ -
     WESTAQCON Sensor Head quick connector  $ -
     STWESTAMUX2 option analog multiplier
     WESTAMUX2 mux-2 analog multiplier option  8900
     STWESTAHVAO1 option 0-90v dc output
     WESTAHVAO1 hvao-1 0-90vdc output option  2500
     STWESTAJOG option jog option
     WESTAJOG jog pushbutton option  $ -
     STWESTALFO1 option ac line filter
     WESTALFO1 lfo-1 ac line filter option  500
     STWESTATAP1 option percent taper option
     WESTATAP1 tap-1 percent taper option  1800
     STWESTATW1 option limit thumbwheel setpoi
     WESTATW1 thumbwheel set point pot  5000
     STWESTARP1 option remote distance pot
     WESTARP1 rp-1 10 turn remote distance  000
     STWESTARP2 option remote gain pot
     WESTARP2 rp-2 ten turn remote gain  000
     STWESTARP3 option remote speed on output
     WESTARP3 option remote speed on output  000
     STWESTAPT1 option payoff/takeup switch
     WESTAPT1 payout take up switch option  500
     STWESTAFR1 option forward reverse switch
     WESTAFR1 fr-1 forward-reverse switch  500
     STWESTAMAO20 option 4-20 ma output  current loop optput
     WESTAMAO20 mao-20 4-20ma output option  6600
     STWESTAMAO10 option 0-10 ma output
     WESTAMAO10 mao-10 0-10ma output option  6600
     STWESTABOB1 option 12 bit binary output  12 bit binary output
     WESTABOB1 bob-1 12bit binary output  5000
     STWESTASY2M option sy2 sequencer(master op  Sequencer for 2 units operating close together
     WESTASY2M sy2-m sy-2 sequencer master  5000 master
     STWESTASYS option sle option
     WESTASYS sy-s sle option  000 sle
     STWESTASY8 option sy8 sequencer
     WESTASY8 sy-8 8 unit sequencing option  6000 8 CH sequencer for up to 8 units close together
     STWESTASTAND1 option sensorhead stand
     WESTASTAND1A stand-1 sensor head stand N 0900 Sensor Stands
     WESTASTAND10 stand with spool guide N $ -
     WESTASTAND1B sensor head stand with guides N $ -
     STWESTASTANDWH1 stand-wh sensor stand w/wheels
     WESTASTANDWH1 stand-wh sensor stand w/wheels N 8200
     STWESTARAAC1 cable adapter rapid air raac1  Adapter Cables for other OEM equipment
     WESTARAAC1 raac-1 5 pin rapid adapter  000
     STWESTARAAC2 option 15 pin rapidair cable
     WESTARAAC2 raac-2 V2 rapid air adapter  500
     STWESTARAAC2J option 15 pin rapidair cable
     WESTARAAC2J raac-2j rapid air adapter  0000
     STWESTAGOODMAN1 option cable to goodman cutter
     WESTAGOODMAN1 goodman cutter adapter 15 ft  000
     STWESTARAAC3 option d shell rapidair connec
     WESTARAAC3 rapid air d-shell adapter  500
     STWESTADIV2 option analog divider
     WESTADIV2 div-2 analog divider option  0000
     STWESTABSO1 option base speed option
     WESTABSO1 bso-1 base speed option  7500
     STWESTAAOM1 option anolog meter  output meters
     WESTAAOM2 analog meter 0-90 vdc  $ -
     WESTAAOM1 aom-1 analog output meter+-15  0000
     STWESTADMS1 option digital display
     WESTADMS1 dms-1 digital display  9900
     STWESTAEAO1 option extra analog output  Extra analog outputs
     WESTAEAO1 eoa-1 normal extra analog  5000
     STWESTAEAON1 option extra analog output inv
     WESTAEAON1 eaon-1 inverted extra analog  5000
     STWESTADUAL option relay for dual sensor o
     WESTADUAL relay option for dual heads  6500 Relay for 2nd sensor switchable
     STWESTATOGGLE option on off toggle switch
     WESTATOGGLE on/off toggle switch option  500 on off power switch
     STWESTASUM3 option line speed summing
     WESTASUM3 sum-3 3input summing amplifier  7600 Summing input
     STWESTATC6 option tension control(auto/ma
     WESTATC6 tc-6 tension control option  0000
     STWESTADF1 option dust filter option  Dust filter for sensor
     WESTADF1 df-1 dust filter for  500
     STWESTAPID2 option pid output
     WESTAPID2 pid2 output option  6500 PID Output
     STWESTAONOFF two setpoint on off control
     WESTAONOFF 2-set point on/off relay  500 dual setpoint On/Off relay
    WEPTAONOFFNS
    WEPTAPT1LSA
    WEPTAPT1-1
    PTTOPLIMIT
    WEPTATL1
    PTBOTTOMLIMIT
    WEPTABL1
    PTSTAND
    WEPTASTAND
    PTWESTAEXTBASE
    WESTAEXTBASE
    STWESTAMAO20
    WESTAMAO20
    STWESTAMAO10
    WESTAMAO10
    STWESTARAAC1
    WESTARAAC1
    STWESTARAAC2
    WESTARAAC2
    STWESTARAAC2J
    WESTARAAC2J
    STWESTARAAC3
    WESTARAAC3
    STWESTASUM3
    WESTASUM3
    PSOSDA10003
    PSENC10032-PT
    PSDRV10001-PT
    PSDRV10002-PT
    PSSPR10000
    PSPTA10006
    PSOPR10001
    PTTOPLIMIT
    WEPTATL1
    PTBOTTOMLIMIT
    WEPTABL1
    PTSTAND
    WEPTASTAND
    STWESTAF/V1
    WEEZAFV1
    PTWESTAEXTBASE
    WESTAEXTBASE
    STWESTAMAO20
    WESTAMAO20
    STWESTAMAO10
    WESTAMAO10
    STWESTARAAC1
    WESTARAAC1
    STWESTARAAC2
    WESTARAAC2
    STWESTARAAC2J
    WESTARAAC2J
    STWESTARAAC3
    WESTARAAC3
    STWESTAAOM1
    WESTAAOM2
    WESTAAOM1
    STWESTASUM3
    WESTASUM3
    H705B-020      现货查询上海航欧                         HEDLAND
    BA71 B4 0.37KW IP54 F     现货查询上海航欧                         MGM
    1300637 现货查询上海航欧                         Haldex
    BE-3020U        现货查询上海航欧                         Univer
    170M6419 1600A 690V 现货查询上海航欧                         BUSSMANN
    E82EV551K4C 现货查询上海航欧                         LENZE
    MTN/1185M-100   现货查询上海航欧                         Monitran
    K330AO-C        现货查询上海航欧                         DOMNICK HUNTER DH)
    AG-3050  现货查询上海航欧                         Univer
    MXYZ-20 现货查询上海航欧                 MXYZ-20B        Z-LASER
    EEM33-71        现货查询上海航欧                         NOVO
    4324056204   现货查询上海航欧                         WABCO
    S40-PH-5-M03-PH 10-30VDC PNP 现货查询上海航欧                 QMIS/0P-0F        DATASENSOR
    TS 10       现货查询上海航欧                         SCHRAMM
    GS4200-250    现货查询上海航欧                         ESI-ELLISON
    CH03M-DO-SP-SH1 现货查询上海航欧                         NKE
    DDBVZ-16S-03S/35 现货查询上海航欧                         IMAV
    438F-115-1.5  现货查询上海航欧                         ARTISAN
    603-M     现货查询上海航欧                         DESTACO
    DDBVZ-10S-5C/35   现货查询上海航欧                         IMAV
    FS-925 P/N:161864        现货查询上海航欧                         GEMS
    F1-SU1Z/UV1ZD UN       现货查询上海航欧        6161000203            BERNSTEIN
    6A45  WITH 1.125 BORE WITH KEYWAY * WITH 1.375 BORE WITH KEYWAY      现货查询上海航欧                     ZERO-MAX
    6A52C  WITH 38 mm BORE WITH KEYWAYWITH 38 mm BORE WITH KEYWAY       现货查询上海航欧                     ZERO-MAX
    TH100-AOS      现货查询上海航欧                 TH110-AOS      KIMO
    SONAR-SENSOR-215U1-30BL-L280       现货查询上海航欧                 SONAR-SENSOR 205/215U1-30BL-L430 644-36939-5     LINCOLN
    310 39 RC 120V 50/60HZ       现货查询上海航欧                         HUMPHREY
    BM63刹车组 零件代码(73/74/75/77/78/79/85 现货查询上海航欧                         MGM
    YPCI-LAN-HA-224    现货查询上海航欧                 YPCILANFA224        SUN
    TLC-1004FG20        现货查询上海航欧                         TACO
    CH03M-DO-SP 现货查询上海航欧                         NKE
    Z109REG  9-40VDC/19-28VAC      现货查询上海航欧                Z109REG2-1    SENECA
    adam with 3 m cable 5*0.34 2TLJ020051R0200   现货查询上海航欧                         JOKAB SAFETY
    ST-02G-3A-U2X      现货查询上海航欧                 ST-02G-4A-U2X       METO-FER
    M8YV-A6A-R   现货查询上海航欧                         M-SYSTEM
    SPX-075   现货查询上海航欧                         SEAMETRICS
    C40089-600    现货查询上海航欧                         WICHITA
    M2SES-2AA-R/N      现货查询上海航欧                         M-SYSTEM
    EKCA4 KUC/KUC      现货查询上海航欧                         WAIRCOM
    GF4C(PF090300150002)        现货查询上海航欧                         TER
    FR692-D1        现货查询上海航欧                         PIZZATO
    4.054+APO      现货查询上海航欧                         WINKEL
    T-300N    现货查询上海航欧                         KYOWA
    EV21 21561203 230VAC/0.03A     现货查询上海航欧                 FHF21561212 EV 21 Voice  85 - 265 VAC         FHF
    92B-AAH-CJ3-DM-DJAP-1DG  现货查询上海航欧                         MAC
    R-32 现货查询上海航欧                         GIMATIC
    R11-C2-000     现货查询上海航欧                         WILKERSON
    OAB513002A00      现货查询上海航欧                         KENDRION
    81 P ML A3/2 242   现货查询上海航欧                 081P00 8P070A B   OMC
    AGMZO-A-10/210 20      现货查询上海航欧                         ATOS
    SKKT 106/16E 现货查询上海航欧                         SEMIKRON
    HTP25      现货查询上海航欧                         TELCON
    4514A     现货查询上海航欧                         FAIRCHILD
    FR78B-400230        现货查询上海航欧        Art no.3-070-100686              Noratel
    MTN/1185CQ-205米线缆)     现货查询上海航欧                         Monitran
    FDBA-LAN        现货查询上海航欧                         SUN
    CXBA-XCN        现货查询上海航欧                         SUN
    CR8-1/XCR81   现货查询上海航欧                         CABUR
    RVZ-16S-P       现货查询上海航欧                         IMAV
    HP602A-010F1S10 现货查询上海航欧                         HEDLAND
    ATM60-A4A12X12  现货查询上海航欧                         SICK
    B01AN22NO   现货查询上海航欧                         Selet
    M5MS-A-R      现货查询上海航欧                         M-SYSTEM
    D-103      现货查询上海航欧                         GUTEKUNST
    VEM/K21R 63 K 2   现货查询上海航欧                         VEM
    WS6B/24WSB006.502121)        现货查询上海航欧                 OAC006029     HAHN MAGNET
    AS-U30D 现货查询上海航欧                         TAKEX
    KWD2      现货查询上海航欧        E760                 AMK
    VLT10       现货查询上海航欧                 V-VTN16  RIETSCHLE
    TR-0050   现货查询上海航欧                         NOVO
    TR-0025 现货查询上海航欧                         NOVO
    TR-0100   现货查询上海航欧                         NOVO
    94000000FM  现货查询上海航欧                         CAL
    TC-R50 1KΩ+15%   现货查询上海航欧                         OFEL
    MUW250-4    现货查询上海航欧                         VOLFA
    ACCON-NETLINK-USB COMPACT    现货查询上海航欧        161701-USB    161701-PRO        DELTALOGIC
    TOP-3RD-25T   现货查询上海航欧                         NIPPON
    S.G.C VULCATHERM 30789-03        现货查询上海航欧                 30789-22        Vulcanic
    F.205.1G  现货查询上海航欧                         NOVO
    D-249      现货查询上海航欧                         GUTEKUNST
    D634-319C      现货查询上海航欧                         MOOG
    BC-3CP-MD _1/15HP 230V 50/60HZ     现货查询上海航欧                         MARCH PUMP
    UP-10S-PAB+TT       现货查询上海航欧                         IMAV
    FAN39B   现货查询上海航欧        FAN39BN0B             TEXA
    5KH36MNA445AX          现货查询上海航欧        H684                MARATHON
    NTK15X   现货查询上海航欧                         NETTER
    STP-MTR-23079      现货查询上海航欧                         automation direct
    Z1M18B-F-532-PZ   现货查询上海航欧                         Z-LASER
    020PD9   现货查询上海航欧                         Elfin
    D-1000Z-E       现货查询上海航欧                         MUTOH
    50-610-7612   现货查询上海航欧                         SETRAB
    SG-EFS 104 ZK2/1   现货查询上海航欧                         MAYSER
    MGZ-06S-A1/T2/10-04   现货查询上海航欧                         IMAV
    LV200-AW/2/SP1    现货查询上海航欧                         LEM
    ULCRV/R02400        现货查询上海航欧                         WAIRCOM
    S42 C/WS74 电动执行机构(开关型)  现货查询上海航欧                         BRAY CONTROLS
    325PA D=25mm(125现货查询上海航欧                         STAUFF
    137G-2590      现货查询上海航欧                         HEADLINE
    MAS-2 300-400-500-600A     现货查询上海航欧                         ELEKTROBA
    RJ1A60D20U   现货查询上海航欧                         CARLO GAVAZZI
    φ40TIPO CPU-CORSA ;行程1310mm 现货查询上海航欧        40/1310 CPU          WAIRCOM
    RT424012        现货查询上海航欧                         SCHRACK
    HP0652A10ANP01 现货查询上海航欧                         MP-FILTRI
    FTVR /MCOEVR 输入:0-100V 输出:0-10V tropicalized < 50ms 115/230Vac Class: 0.5        现货查询上海航欧                 MROVS1         FRER
    A-1 DN125 PN16    现货查询上海航欧                         STENFLEX
    MTN/1185CM-25   现货查询上海航欧                         Monitran
    MPZ-10S-A+B-B02   现货查询上海航欧                         IMAV
    YS212AF94V6DG4  现货查询上海航欧                         KONAN
    RIEGEL 0 NP/TP OHNE RASTUNG   现货查询上海航欧        073535            EUCHNER
    CEV58M-00167      现货查询上海航欧                 CEV582M-10167     TR
    972-0DP10      现货查询上海航欧        MSIP-REM-YVP                Vipa
    AZ16-12ZVRK-M16 现货查询上海航欧                         SCHMERSAL
    EFS2000-11114(G)  现货查询上海航欧                         SENSORIK
    MTN/1185CM8-25F        现货查询上海航欧                         Monitran
    PI 3115 PS 10  现货查询上海航欧        60020368                MAHLE
    PI 3108 PS 10,订货号:77680341     现货查询上海航欧        60020422                MAHLE
    PI 2205 SMX VST 3 现货查询上海航欧                 PI 2205 PS VST 3     MAHLE
    FCPA132SB-4   现货查询上海航欧                 FCPA132S 4/PHE     AC-MOTOREN
    S42 C/W:S01手柄  现货查询上海航欧                         BRAY CONTROLS
    MS7114,0.25KW,50HZ,230/400V(/Y),1.3A/0.75A,1390r/min,绝缘F,IP55,S1,Art NO:521332     现货查询上海航欧                 YE3-71M1-4    OLAER
    1UHH2    现货查询上海航欧                         DAYTON
    XCSD30F  现货查询上海航欧                 XCSD1060W012VAD       CABUR
    RF3-0050-4     现货查询上海航欧                         MTE
    35A-SCC-DFFJ-2KJ   现货查询上海航欧                         MAC
    8CB250  142096JB        现货查询上海航欧                         AIRFLEX
    QE3 现货查询上海航欧                         HUMPHREY
    ZPUU1-100BL-L670         现货查询上海航欧        664-34009-3        ZPUU1-100BL-L670/664-85324-5  LINCOLN
    SZL-WL-E-N     现货查询上海航欧                 SZL-WL-E-C01H       HONEYWELL
    9914-0965      现货查询上海航欧                         PULSOTRONIC
    TE500C12D2A1A6+T1-1/2P8 现货查询上海航欧                         GREYSTONE
    EH9997/084 AC/DC24V US=12-70V       现货查询上海航欧        0045504          DOLD
    41PP        现货查询上海航欧                         HUMPHREY
    1//2'NPT 1.4539 HH500 VAC(50/60HZ) PALL:00890     现货查询上海航欧                         BADGER
    240839    现货查询上海航欧                         DORNER
    M435       现货查询上海航欧                         MERCOTAC
    KE160-80        现货查询上海航欧                 KE160-80G      GOPA
    GDB-5F40        现货查询上海航欧                         MELEC
    LV-31       现货查询上海航欧                 LVN-10     OMEGA
    NTS 120 NFL   现货查询上海航欧                         NETTER
    11020 24V/220mA DC    现货查询上海航欧                 11021      W&T
    No.2PN    现货查询上海航欧                         SANTEST
  • 在2024/11/13 14:14:00留言
  • 详细留言:AM22242R025010 28PCS需求
  • 在2024/10/5 10:11:00留言
  • 详细留言:mox cpu
  • XjnUUyieIDTe 在2024/10/1 5:32:00留言
  • 详细留言:
  • LhGBtvKv 在2024/9/23 5:18:00留言
  • 详细留言:
  • 在2024/9/19 9:33:00留言
  • 详细留言:D13H0001 D13H0001
