  • 2015年NKTECHNOLOGIES工厂上海航欧中国区销售
  • 发布时间:2025/1/11 11:44:37   修改时间:2025/1/11 11:44:37 浏览次数:3
    NK technologies电流互感器NK technologies烟雾报警器NK technologies指示灯NK technologies传感器NK technologies电流传感器NK technologies接地故障传感器NK technologies变送器NK technologies检测开关NK technologies继电器NK technologies转换开关NK technologies电流变送器NK technologies变换器NK technologies湿度传感器NK technologies油位传感器NK technologies接头
    https://www.nktechnologies.com/find-a-local-sales-contact/
     Solid-Core
     AS0-NOAC-24U FieldAdjustable,3-350mASetpointRange,24VAC/VDCPowered
     AS0-NOAC-120 FieldAdjustable,3-350mASetpointRange,120VACPowered
     AS0-NCAC-24U FieldAdjustable,3-350mASetpointRange,24VAC/VDCPowered
     AS0-NCAC-120 FieldAdjustable,3-350mASetpointRange,120VACPowered
     AS0-NODC-24U FieldAdjustable,3-350mASetpointRange,24VAC/VDCPowered
     AS0-NODC-120 FieldAdjustable,3-350mASetpointRange,120VACPowered
     AS0-NCDC-24U FieldAdjustable,3-350mASetpointRange,24VAC/VDCPowered
     AS0-NCDC-120 FieldAdjustable,3-350mASetpointRange,120VACPowered
     AS1Series,ACCurrentSwitches
     Solid-Core
     AS1-NOU-FF AdjustableSetpoint,1-150Amps,FrontTerminals,SmartLED
     AS1-NOU-FF-NL AdjustableSetpoint,1-150Amps,FrontTerminals,w/oLED
     AS1-NOU-FF-GO Fixed0.75AmpMaximumSetpoint,FrontTerminals,w/oLED
     AS1-NOU-FT AdjustableSetpoint,1-150Amps,TopTerminals,SmartLED
     AS1-NOU-FT-NL AdjustableSetpoint,1-150Amps,TopTerminals,w/oLED
     AS1-NOU-FT-GO Fixed0.75AmpMaximumSetpoint,TopTerminals,w/oLED
     AS1-NCU-FF AdjustableSetpoint,1-150Amps,FrontTerminals,SmartLED
     AS1-NCU-FT AdjustableSetpoint,1-150Amps,TopTerminals,SmartLED
     AS1-NCU-FT-NL AdjustableSetpoint,1-150Amps,TopTerminals,w/oLED
     AS1-NCU-FT-GO Fixed0.75AmpMaximumSetpoint,TopTerminals,w/oLED
     Split-Core
     AS1-NOU-SP AdjustableSetpoint,1.5-150Amps,TopTerminals,SmartLED
     AS1-NOU-SP-NL AdjustableSetpoint,1.5-150Amps,TopTerminals,w/oLED
     AS1-NOU-SP-GO Fixed1.5AmpMaximumSetpoint,TopTerminals,w/oLED
     AS1-NCU-SP AdjustableSetpoint,1.5-150Amps,TopTerminals,SmartLED
     AS1-NCU-SP-NL AdjustableSetpoint,1.5-150Amps,TopTerminals,w/oLED
     AS1-NCU-SP-GO Fixed1.5AmpMaximumSetpoint,TopTerminals,w/oLED
     AS1Series,ACCurrentSwitcheswithHighOutputContactRating
     Solid-Core
     AS1-NOR-FT-GO Fixed5.8AmpMaximumSetpoint,TopTerminals,w/oLED
     AS1Series,ACCurrentSwitcheswithOutputBypass
     Solid-Core
     AS1-NOU-FT-Y39 AdjustableSetpoint,1.5-150Amps,TopTerminals,SmartLED
     AS1-NCU-FT-Y39 AdjustableSetpoint,1.5-150Amps,TopTerminals,SmartLED
     AS1Series,ACCurrentSwitcheswithDualIndependentOutputs
     Solid-Core
     AS1-DODC-FL AdjustableSetpoint,0.75-20Amps,TopTerminals,SmartLED
     AS2-DODC-FL AdjustableSetpoint,20-50Amps,TopTerminals,SmartLED
     AS1Series,ACCurrentSwitchesinaCompactCase
     Solid-Core
     AS1-NOU-CC Fixed0.5AmpMaximumSetpoint,TopTerminalswith24"Leads
     AS1-NCU-CC Fixed0.5AmpMaximumSetpoint,TopTerminalswith24"Leads
     ACISeries,AMPFlasherACCurrentIndicator
     Solid-Core
     ACI-0.5-L FlashingLEDwithACcurrentover0.5A,maximum100A
     ACI-0.5-P LEDmountedon24"leads
     AS3-NOAC-FF AdjustableSetpoint,1-6,6-40&40-175AmpRanges,FrontTerminals,SmartLED
     AS3-NOAC-FF-NL AdjustableSetpoint,1-6,6-40&40-175AmpRanges,FrontTerminals,w/oLED
     AS3-NOAC-FF-15 AdjustableSetpoint,1-6,6-40&40-175AmpRanges,FrontTerminals,SmartLED
     AS3-NOAC-FT AdjustableSetpoint,1-6,6-40&40-175AmpRanges,TopTerminals,SmartLED
    DSLC PX VX  230V  现货查询上海航欧                   VPM-VC V1.0   DUNGS
    FM157E/C        现货查询上海航欧                            WAIRCOM
    4200-06-9243  现货查询上海航欧                            SPARTAN
    6P45C (孔径1"/ 1")货号:6P45C  WITH 1.000 BORE WITH KEYWAY * WITH 1.000 BORE WITH KEYWAY         现货查询上海航欧         6P45C-007-007-01            ZERO-MAX
    H23204802253F     现货查询上海航欧                            DYNAPAR
    40MPG-1 1/2   现货查询上海航欧                            RUBBERFAB
    430-SS      现货查询上海航欧                            MERCOTAC
    XCSG500C        现货查询上海航欧                            CABUR
    MF1002P25NBP01  现货查询上海航欧                            MP-FILTRI
    AWI58X-082-300      现货查询上海航欧                            HOHNER
    00.79.0228       现货查询上海航欧                            DALMEC
    CLS-K-65/S        现货查询上海航欧         10042787         CLS1000-AI-NPN      ELTROTEC
    UBC10.241       现货查询上海航欧                            PULS
    AWI40X-008-120      现货查询上海航欧                            HOHNER
    PSR 230/24-1.3         现货查询上海航欧                   PM-0124-020-0        BLOCK
    99143781005  现货查询上海航欧                            BINDER
    223.2461.000  现货查询上海航欧                            taconova
    SO 50003-10-7 056.0031.180  现货查询上海航欧                            SERTO
    C1518PB00U6468          现货查询上海航欧                   C1518PB00UOM      RGS
    KR-41B     现货查询上海航欧                            lahti precision
    TPL-300T-0-0-LS1-LP1V0004130      现货查询上海航欧                   TPL-400T-0-0-LS1-LP1      lahti precision
    CF/CB1-20        现货查询上海航欧                            DIELL
    PI 5205 PS VST 6       现货查询上海航欧                            MAHLE
    EM1-2-2048-I  现货查询上海航欧                            US DIGITAL
    HUBDISK-2-2048-984-IE  现货查询上海航欧                            US DIGITAL
    ZWS-15/CD/QS         现货查询上海航欧                            MICROSONIC
    TB-1225 IM 24V GS d=40H7PN       现货查询上海航欧                            WARNER
    1DM401  现货查询上海航欧                            HONEYWELL
    FC90L-4 2.2kw 现货查询上海航欧         2212351  T2A90L4 2.2KW B5 220/380V 50HZ         ELECTRO ADDA
    E106DE45///20E      现货查询上海航欧                            ACL
    84-6020.0020A      现货查询上海航欧                   84-6820.0020A         EAO
    mic+35/D/TC/E        现货查询上海航欧                            MICROSONIC
    AWi58S-102R081-2500    现货查询上海航欧                            HOHNER
    9007C54B2      现货查询上海航欧                            SQUARE D
    16055-400/5A         现货查询上海航欧                            MBS
    ASK 41.4  200/5A  10VA  Kl.1     现货查询上海航欧                            MBS
    170M1564 690V,50A       现货查询上海航欧                            BUSSMANN
    FR 515      现货查询上海航欧                            PIZZATO
    AMX5/MKT      现货查询上海航欧                            BTI
    LT 120 TB45 5          现货查询上海航欧                            TELCO
    PN7001    现货查询上海航欧                   PN7071    IFM
    FL604-S1  现货查询上海航欧                            PIZZATO
    mic+340/IU/TC         现货查询上海航欧                            MICROSONIC
    EXTRACTOR2000     现货查询上海航欧                            WAGNER
    00.14522.100043   现货查询上海航欧                            LAMBRECHT
    CA-PI/PO 现货查询上海航欧                   XCAPIPO3         CABUR
    DF 7-6 CHROME       现货查询上海航欧                            ALPHA
    D-257B     现货查询上海航欧                            GUTEKUNST
    AF11243-221-01000/G2/AF 100 174-003         现货查询上海航欧                            MAHLE
    TESTO 465        现货查询上海航欧                   TESTO460 0550 0460       TESTO
    PKL 2100/4       现货查询上海航欧         03621100                   NETTER
    QB2TFIE100     现货查询上海航欧                   QB2TBNIEZP100PSG3D   PROPORTION-AIR
    SDN5-24-100P 现货查询上海航欧                            SOLA
    JPA-1A-H  现货查询上海航欧                            M-SYSTEM
    DLCA        现货查询上海航欧                            MAGPOWR
    3050-0006        现货查询上海航欧                            HEW
    USTE 630/2x115       现货查询上海航欧                            BLOCK
    MKVC-11-1E           现货查询上海航欧                            SAKAMOTO
    R11-S01F1-A20A      现货查询上海航欧                            HAROWE
    961EN-4006     现货查询上海航欧                            ACROMAG
    EM1-0-500-I     现货查询上海航欧                            US DIGITAL
    2000-60PA        现货查询上海航欧                            DWYER
    UHD-SR70        现货查询上海航欧                            UNICEL
    316-17-056     现货查询上海航欧                            WARNER
    42A5BEPM-E3 4583         现货查询上海航欧                   42A5FEPM-FX3 5054        BODINE
    CES65M-00027         现货查询上海航欧                            TR
    Mass charge24/25-2        现货查询上海航欧                            mastervolt
    TM3I230  现货查询上海航欧                            IME
    10284 PLATE,BACKING,5H40  现货查询上海航欧                            NEXEN
    8953 KEY,RECT         现货查询上海航欧                            NEXEN
    31852 Hub,906910 5H40-1      现货查询上海航欧                            NEXEN
    Z5M18B3-F-520-x15g      现货查询上海航欧         ZM18GF563              Z-LASER
    HP1111R/10/10       现货查询上海航欧                   HP11R30/10/10       HOHNER
    CWD4850P       现货查询上海航欧                            CRYDOM
    VM130     现货查询上海航欧                            ATR
    NSS-A        现货查询上海航欧                   SPS   MUTOH
    P21-1-1-1 现货查询上海航欧                   P21-59H   DELTA
    P21-1-1-1-1      现货查询上海航欧         P21-58 (5 SECTIONS)       P21-58    DELTA
    83338            现货查询上海航欧         SL-32                  LINCOLN
    8064A7716-AA         现货查询上海航欧                            AMOT
    M22-6-M-B07C-1-4-D-XMB31 2130X000X00          现货查询上海航欧                            GEFRAN
    ET-JL06-18        现货查询上海航欧                            JAE
    MAVO-MONITOR-USB     现货查询上海航欧         M504G              GOSSEN
    M18B-L3000P-CX9C4U2 现货查询上海航欧                            SCAN
    MF1801P25NBP01  现货查询上海航欧                            MP-FILTRI
    SCHNAPPBEF. ASK 31.4   现货查询上海航欧         54011                MBS
    AL09SB-16F-4  现货查询上海航欧                            ANYWIRE
    25/25UDC        现货查询上海航欧                            WAIRCOM
    30242       现货查询上海航欧                            FAIRCHILD
    4382 IN /3M   现货查询上海航欧                            WOERTZ
    EIPH2-004RK03-11         现货查询上海航欧                   EIPS2-005RA04-11 S111          ECKERLE
    17109-2   现货查询上海航欧                            HASKEL
    GC-M25.PVS.E          现货查询上海航欧                            MICROPUMP
    SK1-8-M12-P-nb-S-MS-Y2         现货查询上海航欧                   BCS M12BBE2-PSC80H-S04K   SIE
    MCT5-005E2    现货查询上海航欧                            OHIO SEMITRONICS
    236-10697-1    现货查询上海航欧                            LINCOLN
    PSR 230/24-2.5         现货查询上海航欧                   PM-0124-020-0        BLOCK
    PI 2005-046 FPM      现货查询上海航欧         61000061         PI 2005-046 FKM      MAHLE
    CUB5B000        现货查询上海航欧                            REDLION
    R3221R0.31/8 现货查询上海航欧                            HOHNER
    TI196P3(0/100)C      现货查询上海航欧                            MINCO
    ACE66T S/N.669783         现货查询上海航欧                            Mini motor
    PE606-2-NO  现货查询上海航欧                            Gordon
    KW8 现货查询上海航欧                            AMK
    1125 vms 现货查询上海航欧                            CLEVELAND
    RSI 503 507664-26  现货查询上海航欧                            LEINE&LINDE
    050ASLFI12      现货查询上海航欧                            Elfin
    7510DIN  现货查询上海航欧                   7511         TRUMETER
    IT65-Y-1800ZND2ER        现货查询上海航欧                            LIKA
    CH3-151P-HA  现货查询上海航欧                   CHT3-151P-H/TG-SR        CAPTRON
    AWI90E-122/R008-0100  现货查询上海航欧                   TR1121R.56/100      HOHNER
    STR0502SG1M90P01       现货查询上海航欧                            MP-FILTRI
    OMV800/151B3104         现货查询上海航欧                            DANFOSS
    DIB01C7245A  现货查询上海航欧                   DIB01CD485A CARLO GAVAZZI
    A612B-00          现货查询上海航欧                            watanabe
    UF-15P23BTH  现货查询上海航欧                            FULLTECH
    SM413.70.1 X33【产编同426614      现货查询上海航欧                            SCHREIBER
    8V1090.00-2    现货查询上海航欧                            B&R
    FM-0910-4F      现货查询上海航欧                            BIMBA
    EAHM-709        现货查询上海航欧                            TOSOKU
    41206701         现货查询上海航欧                            MADLER
    79001-06 现货查询上海航欧                            ITW
    R3321R0.04-24        现货查询上海航欧                            HOHNER
    EKCA8 KUC/KUC       现货查询上海航欧                            WAIRCOM
    TLK110 25*34  现货查询上海航欧                            TOLLOK
    FT50 RLH-PAL4        现货查询上海航欧         572-51008                 SENSOPART
    MMS 22-S-M8-PNP          现货查询上海航欧         0301032            SCHUNK
    225G010BGD4N106 0-10bar 24VDC 4-20mA 现货查询上海航欧                            SETRA
    644-37460-1    现货查询上海航欧                            LINCOLN
    ASK 41.4 250/5A 10VA Kl.1      现货查询上海航欧         13054                MBS
    MAK-4214-P-1 现货查询上海航欧         6410442628              BERNSTEIN
    FT290-01 1/4" 现货查询上海航欧                            TOGNELLA
    TFM 061-06-01         现货查询上海航欧                            LEAG
    TFM 181-12-01         现货查询上海航欧                            LEAG
    VS2EPO54V32N11/4   Item no.19506          现货查询上海航欧                   VSI 2/1 EPO 54V 42R11/5  10..28VDC      VSE
    TFM 181-18-01         现货查询上海航欧         80323                LEAG
    CMW58M-00017     现货查询上海航欧                            TR
    CT-1/60          现货查询上海航欧                            FANOX
    NTP25B    现货查询上海航欧                            NETTER
    NM-521-H/24v         现货查询上海航欧                            BAR
    BIK-3208-P-25B        现货查询上海航欧                            VERSA
  • 杜振一 在2024/12/11 13:59:00留言
  • 详细留言:购买Teknic, inc品牌的CPM-SDHP-N0563A-ELS
  • 罗经理 在2024/12/4 9:50:00留言
  • 详细留言:(MPL)/ 502-V-G-RANGE-F 我想购买这个
  • 王金龙 在2024/11/29 20:58:00留言
  • 详细留言:我需要寻找一些Coelbo产品
  • 在2024/11/13 14:14:00留言
  • 详细留言:AM22242R025010 28PCS需求
  • 在2024/10/5 10:11:00留言
  • 详细留言:mox cpu
