2016年brusatori工厂上海欧航中国区销售
brusatori电机、brusatori马达、brusatori泵、brusatori配件
![](http://www.cechina.cn/UpLoad/CompanyFile/2021/5/6/090f2e8f-7d6f-4d04-a174-7d2cc560bcd7.jpg)
上海航欧销售brusatori电机,brusatori马达
brusatori电机,brusatori马达brusatori泵brusatori配件
主要型号:BR120,553
BR140,871
BR161,193
BR221,160
BR241,985
BR262,415
BR28343
BR51221
BR52442
BR535,467
BR546,993
BR558,224
BR569,358
BR5710,482
BR5811,506
BR715,8228,1295
BR72117515,448
BR7315,32821,400
BR7419,58127,353
BR7522,53531,507
BR76269236,464
BR7730524225
BR78341647,690
BR82306248.026
BR8457.14385.309
BR8680.436115.612
BR88105.754147.938
BR9292.572120.787
BR94179.369236.603
BR96255.992338.251
BR98332.914442.181
Brushlessmotors-BRseries-EXPORT
Validfrom01/01/2015to31/12/2015
Prezzo
FEEDBACK
2 POLES
RESOLVER Include
2 POLES
RESOLVER Included in the price above
Incremental
encoder EF36K6-1024-only for BR1 / BR2 0
Incremental
encoder 1024 ppr 0
Incremental
encoder 2048 ppr 0
Incremental
encoder 4096 ppr 0
Incremental
encoder ERN 1323 4096 ppr 36
SinCos
encoder Heidenhain ERN 1385 00
EnDat
encoder Heidenhain EQN 1325 25
CONNECTORS
Flying
power connector for BR1 / BR2 3
Flying
signal connector for BR1 / BR2 3
Flying
power connector per BR3 / BR5 / BR7 5
Flying
signal connector per BR3 / BR5 / BR7 / BR8 / BR9 0
Strip
Phoenix clamps 5
BRAKES
Holding
brake BR1 00
Holding
brake BR2 27
Holding
brake BR5 7
Holding
brake BR7 07
Holding
brake BR8 60
Holding
brake BR92/BR94 57
Holding
brake BR96/BR98 22
FEET MOUNT
Feet for
BR5 5
Feet for
BR7 5
Feet for
BR8 1
Feet for
BR9 4
PROTECTION
DEGREE
IP65
protection 0
OBJ
INSULATION SYSTEM
BR5 10%
BR7 8%
BR8 5%
BR9 4%
SPECIAL
SHAFT (After technical approval)
Special
shaft for BR5 1
Special
shaft for BR7 1
Special
shaft for BR8 15
Special
shaft for BR9 15
VL 132 S
16 KW 95
VL 132 M
21 KW 05
VL 132 L
24 KW 18
VL 132 P
30 KW 35
VL 132 X
33 KW 30
VL 160 S
40 KW 30
VL 160 M
45 KW 02
VL 160 L
49 KW 12
VL 160 P
52 KW .012
VL 180 S
64 KW 40
VL 180 M
80 KW 80
VL 180 L
88 KW 45
VL 225 S
93 KW 80
VL 225 M
130 KW 20
VL 225 L
184 KW 10
VL 280 S
270 KW 550
VL 280 M
264 KW 645
VL 280 L
342 KW 970VL 132 S 23 KW 94
VL 132 M
31 KW 02
VL 132 L
34 KW 16
VL 132 P
39 KW 35
VL 132 X
42 KW 75
VL 160 S
63 KW 80
VL 160 M
71 KW 26
VL 160 L
82 KW 72
VL 160 P
88 KW .072
VL 180 S
100 KW 32
VL 180 M
124 KW 76
VL 180 L
138 KW 50
VL 225 S
144 KW 30
VL 225 M
190 KW .065
VL 225 L
280 KW .056
VL 280 S
407 KW 585
VL 280 M
401 KW 700
VL 280 L
524 KW 900VL132 VL160 VL180 VL225 VL280
-- 16 65
12 --
Flange
VL132
VL160 VL180 VL225
Mounting
B3/B5 5 5 45 70
Bearings
VL 132 VL
Ball
bearing Std Std Std Std
Insulated
bearing -- 60 40 40 .074
Brake
(Motor IP54)
K7 KTD K9
K9D K9D NIA63 NIA400
VL 132 65
20
VL 160 25
090
VL 180 420
VL 225 700
VL 280
Brake
(Motor IP23)
K7 KTD K9
VL 132 08
60
VL 160 056
260
VL 180 415
VL 225 700
VL 280
Feedback
VFS60 -
Incremental programmable encoder 15
VT 71 M
0,37 2,5
VT 71 L
0,63 4,0
VT 80 S
0,75 3,8
VT 80 L
1,1 5,1
VT 90 S
1,5 10,1
VT 90 L
2,2 14,8
VT 90 P 3
20
VT 90 X 4
25 920
VT100A 4
25
VT 100 S 6
38
VT 100 M
7,5 46
VT 100 L
8,5 54
VT 100 P
10 60
VT 132 S
11 72
VT 132 M
17 110
VT 132 L
22 143
VT 132 P
28 176
产品型号 ZB24532 MTL
产品型号 4610044 HAPPICH
产品型号 R075024 HAPPICH
产品型号 pluto programing cable 2TLA020070R5800 JOKAB SAFETY
产品型号 PGT-10-PRO SICK
产品型号 0903UTL101 LUMBERG
产品型号 CES58M-00046 TR
产品型号 AH387775U001 EUROTHERM
产品型号 60800-122 SCHROFF
产品型号 CEV65M-01460 TR
产品型号 171-01052 ZE65M 171-01052 TR
产品型号 CES58M-00002 CES582M-10002 TR
产品型号 ZH65M 175-00003 CES65M-10019 TR
产品型号 ZE115M 173-00001 TR
产品型号 CEV65M-00444 TR
产品型号 IH76A 243-00067 TR
产品型号 IE58A 219-00773 TR
产品型号 CH58M 5842-00024 TR
产品型号 CE100M 100-00390 CEV65M-10857 TR
产品型号 CE65M 110-01767 CEW65M-01767 TR
产品型号 CEV65M-01570 TR
产品型号 GEL260-V-000500B031 LENORD&BAUER
产品型号 CEV115M-10021 TR
产品型号 EH40A360Z5/28P6x6PR2 EL40A360Z5/28P6x6PR2 ELTRA
产品型号 ZE65M 171-50124 TR
产品型号 58B-10/5/1-ABC-PT-62 IMG
产品型号 60B-50/1000/1-A/BD/C-PT-62 IMG
产品型号 HS351024844B7 HS35R102484P7 DYNAPAR
产品型号 RE-15-1-A14 LTN
产品型号 G71DSLDBI-2500-121-15 LTN
产品型号 RE-15-4-D01 LTN
产品型号 P/N:90757-001 RENCO
产品型号 P/N:388619-0B RENCO
产品型号 P/N:388701-09 RENCO
产品型号 P/N:77678-044 D/C 0726 RENCO
产品型号 EL58C5000Z8/24L6S3PR ER58C5000Z5/28L6S3PR ELTRA
产品型号 CE65M 110-02807 TR
产品型号 CE58M 5802-00036 TR
产品型号 R3321R0.05/24 HOHNER
产品型号 RE-21-1-V15 LTN
产品型号 AMC5812/4096PB-15+CC-PB
LIKA
产品型号 FINH58 12 A5 9 3R/
1024 MEYLE
产品型号 HS351024D1442PS HS35R1024E172PS DYNAPAR
产品型号 CE100S 102-00114 CEV65S-10182 TR
产品型号 MES-40-512PE H5 MTL
产品型号 T1-81100201 MINICOD-T
R11/30B1000R 1F687 TELESTAR
产品型号 5812-4096-YB00DP03PG OCD-DPC1B-1212-S060-H3P FRABA
产品型号 D5400 MUTOH
产品型号 CE65M 110-02098 CEV65M-02098 TR
产品型号 S-100-V MUTOH
产品型号 AC58/0014ES 41DPZ HENGSTLER
产品型号 MES-30-2000P E MTL
产品型号 VRE-P062FAC NSD
产品型号 861007455-2048 LEINE&LINDE
产品型号 DE-04-E MUTOH
产品型号 EL115A1000S8/24L11X3MR ER115A1000S5/28L11X6MR ELTRA
产品型号 IV-20 490-00006 TR
产品型号 IE58A 219-01281 TR
产品型号 PAM58C10-BF6XXR-4096/4096
E000 ELCO
产品型号 CEV65M-02041 TR
产品型号 9000M-2/30L/5LD/10-27FC GAEBRIDGE
产品型号 ZE65S 170-50002 COV58S-00077 TR
产品型号 D-1000Z-C MUTOH
产品型号 E2-100-197-I-H-D-B US DIGITAL
产品型号 HES-2048-2MD-800-050-00E NEMICON
产品型号 5812-4096-FB00K300SW OCD-IBA1B-1212-C100-PRI FRABA
产品型号 CE100M 100-00060 TR
产品型号 H2310240032*512 DYNAPAR
产品型号 HAS10 nr:810-635862 HOHNER
产品型号 F3-180-1828-BZ-CM I/63-180-1828-BZ-CM SICOD
产品型号 AWC5812-1-ZBB1DP03PG+AH58-B1DP-3PG OCD-DPC1B-0012-S100-H3P FRABA
产品型号 EL50FA1024Z5/28L8X6PR EH50FA1024Z5/30L8X6PR ELTRA
产品型号 HS350600C3000 HS35R0600D310 DYNAPAR
产品型号 CEW58M-00021 TR
产品型号 MIG 200-19-50 MN+200-19-0025_9 STROTER
产品型号 EL42A360Z5/28P6X6PR2 ELTRA
产品型号 NH-10800 MUTOH
产品型号 EH115A2000Z5L-2000Z5L11*3MR.305 ELTRA
产品型号 CEV65M-01542 TR
产品型号 CEV65M-01360 TR
产品型号 TS5013N60 TAMAGAWA
产品型号 MRE-32SP062FAC NSD
产品型号 CEV65M-10076 TR
产品型号 E7R-RL101-000SE AUTOTECH
产品型号 AWI90E-122R008-022 HOHNER
产品型号 AWI90E-122R008-100 HOHNER
产品型号 CES65M-10019 TR
产品型号 HR6251024633104 DYNAPAR
产品型号 MCN-N5 DYNAPAR
产品型号 EK4002 CH204864 E+L
产品型号 TS5013N68 2048PPR TAMAGAWA
产品型号 FINS5810 593R/1024
MY029 5-30VDC MEYLE
产品型号 CEV65M-02919 TR
产品型号 521590-01 LEINE&LINDE
产品型号 CEV65S-00202 TR
产品型号 MRE-G64SP062FAC NSD
产品型号 CS58M 5822-00012 TR
产品型号 MRE-G64SP062FBC NSD
产品型号 ITD40 A4Y90 2048 H NI
KR1 E10 IP65 68 THALHEIM
产品型号 PTB2-30-05-A SERVO-TEK
产品型号 D-540 MUTOH
产品型号 SAC-RL100-010 AUTOTECH
产品型号 KHK53-AXB00107 SICK
产品型号 DHO514-0512-005(DHO5_14//5GT9//00512//G3R020) BEI IDEACOD
产品型号 G2M2H.110A102 IVO
产品型号 CEV58M-00167 TR
产品型号 FINS 5810C593R-1024
5-30V MEYLE
产品型号 CEV65M-02633 TR
产品型号 H5-500-I-S H5-500-IE-S US DIGITAL
产品型号 LHD-007-600A SUMTAK
产品型号 G71SSLDBI-5000-111-15 LTN
产品型号 EL63G500Z5/28P10X3JR ER63G500Z5/28P10X3JR ELTRA
产品型号 DHM510-1024-003 BEI
产品型号 ULR-600 MUTOH
产品型号 IRC125/1250KBP LARM
产品型号 RSI 503 51 9-30Vdc
100ppr HTL Ra.8pM12 537401-04 LEINE&LINDE
产品型号 861900220-1024 LEINE&LINDE
产品型号 E2-200-394-N-H-D-B-S4182 E2-200-394-NE-H-D-B-S4182 US DIGITAL
产品型号 CEV65M-02209 TR
产品型号 CEH582M-10230 TR
产品型号 IEH582-00030 TR
产品型号 711*-S Serial
Number:1112424 ACCU-CODER
产品型号 EL53B1024Z5L8X6JR ELTRA
产品型号 D-1000Z-V-H MUTOH
产品型号 MEH-130-1024PE10M MTL
产品型号 CMW58M-00025 TR
产品型号 01070-1390(HS35F-100-BS-1000-ABC-28V/V-SM16-S) 01070-1390 BEI
产品型号 DTRE-1024PWFJ-2 DTRE-1024PWFJ-TS UNITEC
产品型号 F3-360-1828-BZ-CM I/63-360-1828-BZ-CM SICOD
产品型号 DE-04-C MUTOH
产品型号 ER5KD286 ATAS NACHOD
产品型号 MA3-A10-125-B US DIGITAL
产品型号 MIG140-14-030 75 MN+140-14-030 75 STROTER
产品型号 E5-360-375-N-D-H-G-3 E5-360-375-NE-D-H-G-3 US DIGITAL
产品型号 2210241000 DYNAPAR
产品型号 521006351-1024 507687-01 LEINE&LINDE
产品型号 HS351024G54B7 HS35R1024H5P7 DYNAPAR
产品型号 HS20102463340 DYNAPAR
产品型号 SEB200C824PP SEB200C530PP ELAP
产品型号 DBS36E-BBAM01024 SICK
产品型号 HWI 103X-023-100 HOHNER
产品型号 VLT12-01-SF-0400-N-5-R-PP-F00 ACCU-CODER
产品型号 M531000/013FDH4 MAGMOTOR
产品型号 CEV58M-00030 TR
产品型号 CE65S 111-00132 CEV65S-00046 TR
产品型号 OCD-DPC1B-1212-C10V-H3P FRABA
产品型号 RI58-O/ 2048EK.42RH 0525408 HENGSTLER
产品型号 MINICOD-T-5/30 B 250
RO F12 T40398869 TELESTAR
产品型号 40397636 TELESTAR
产品型号 CMV58M-00004 TR
产品型号 DS624-B400CE-5 HENGSTLER
产品型号 8.5820.3P32.0360 10-30
VDC , 150mA KUBLER
产品型号 8.9080.4C32.3001 KUBLER
产品型号 S315A5 02/1024 HOHNER
产品型号 DEX-01-C MUTOH
产品型号 CEV65M-10487 TR
产品型号 LA66K 312-01711 TR
产品型号 3229/OAAO/0001 HOHNER
产品型号 H231024100235 DYNAPAR
产品型号 H58050011113009 NORTHSTAR
产品型号 RHI504 14MM THS RS422
1024PPR CABLE 6M PART NO:649598-01 LEINE&LINDE
产品型号 T8.5850.ZP8S.G132 KUBLER
产品型号 CEW65M-01983 带接线盒
SL3020-X1(GS 130/K/F) TR
产品型号 19862004 GEMCO
产品型号 ZE65M
4096/4096/171-01052 TR
产品型号 HS3510248446B7 HS35R102484P7 DYNAPAR
产品型号 21-212B3/100 HOHNER
