2016年Waddington工厂上海航欧中国区销售
上海航欧销售Waddington变速循环控制单元Waddington传感器Waddington超声波传感器Waddington开关 Waddington电源,Waddington控制器,Waddington动力控制
主要型号:PSPCB10000
PSPCB10000-BIN
PSENC10000
PSENC10031
PSENC10032
PSENC10009
PSENC10010
PSENC10000-NE
PSENC10001
PSENC10021
PSENC10035
PSENC50002
PCDIO10003
PCDIO10008
PCDIO10000
PCDIO10008
PCDIO10003
PCDIO10000
STTOPLIMIT1
STTOPLIMIT2
STBOTTOMLIMIT1
STBOTTOMLIMIT2
ST2NDTOPLIMIT
ST2NDBOTTOMLIMI
PSCBL70012
PSCBL70006
PSCBL70008
PSCBL70013
PSCBL70014
PSCBL70019
PSCBL70015
WESTAMRSH2R1
WESTAMRSH2R2
WESTAMRSH2R2SST
WESTAMRSH3
WESTAMRSH2R1H
WESTAMRSH2R2H
WESTAMRSH2FG
WESTAMRSH2R1H
WESTAMRSH2R2HFG
WESTASSH1
WESTASSH2
STHEADsonatrolheadoptionsExtrasensors
WESTAMRSH2R1mrsh-2/r15in-20ftsonarsensor3800
WESTAMRSH2R2mrsh-2/r218in-20ftsonarsenso3800
WESTAMRSH2R2SSTmrsh-2/r218in-20ftsstransdu5500
WESTAMRSH3sonatrolsensorwithdual7700
WESTAMRSH2R1Hr1sensorw/hornN8800
WESTAMRSH2R2Hr2sensorw/hornN8800
WESTAMRSH2FGmrsh-2fgsensorr2fixedgain0000
WESTAMRSH2R2HFGr2sensorw/hornandfixedgainN2000
WESTASSSH1 r-1 stainless steel sensor 7500
WESTASSSH2
r-2 stainless steel sensor 7500
STWESTA30FT st6z mods for 30 ft range Range Mods
WESTA30FT st6z mods for 30 ft range 000
STWESTAAOAB air output a/b option
WESTAAOAB air output a / b selec switch $ -
STWESTAAUTO/MAN auto manual out put option
WESTAAUTO/MAN auto/manual selector switch $ -
STWESTAF/V1 freq to voltage option
WEEZAFV1 f/v-1 frequency to voltage oe Y $ -
STWESTAGUIDE001 sensor guide adjust able
width call
WESTASTANDWH1 stand-wh sensor stand w/wheels N
3000
STWESTAMTRSEL dc motor sel a/b contactor
WESTAMTRSEL dc motor sel a/b contactor 5000
STWESTAUTF1 upper time filter option
WESTAUTF1 utf-1 upper time filter option $ -
STWEST/F1 voltage to frequecny option
PSMDL04 v/f-1 voltage to frequency $ -
WESTAQCON Sensor Head quick connector $ -
STWESTAMUX2 option analog multiplier
WESTAMUX2 mux-2 analog multiplier option 8900
STWESTAHVAO1 option 0-90v dc output
WESTAHVAO1 hvao-1 0-90vdc output option 2500
STWESTAJOG option jog option
WESTAJOG jog pushbutton option $ -
STWESTALFO1 option ac line filter
WESTALFO1 lfo-1 ac line filter option 500
STWESTATAP1 option percent taper option
WESTATAP1 tap-1 percent taper option 1800
STWESTATW1 option limit thumbwheel setpoi
WESTATW1 thumbwheel set point pot 5000
STWESTARP1 option remote distance pot
WESTARP1 rp-1 10 turn remote distance 000
STWESTARP2 option remote gain pot
WESTARP2 rp-2 ten turn remote gain 000
STWESTARP3 option remote speed on output
WESTARP3 option remote speed on output 000
STWESTAPT1 option payoff/takeup switch
WESTAPT1 payout take up switch option 500
STWESTAFR1 option forward reverse switch
WESTAFR1 fr-1 forward-reverse switch 500
STWESTAMAO20 option 4-20 ma output current loop optput
WESTAMAO20 mao-20 4-20ma output option 6600
STWESTAMAO10 option 0-10 ma output
WESTAMAO10 mao-10 0-10ma output option 6600
STWESTABOB1 option 12 bit binary output 12 bit binary output
WESTABOB1 bob-1 12bit binary output 5000
STWESTASY2M option sy2 sequencer(master
op Sequencer for 2 units operating close
together
WESTASY2M sy2-m sy-2 sequencer master 5000 master
STWESTASYS option sle option
WESTASYS sy-s sle option 000 sle
STWESTASY8 option sy8 sequencer
WESTASY8 sy-8 8 unit sequencing option 6000 8 CH sequencer for up to 8 units close
together
STWESTASTAND1 option sensorhead stand
WESTASTAND1A stand-1 sensor head stand N 0900
Sensor Stands
WESTASTAND10 stand with spool guide N $ -
WESTASTAND1B sensor head stand with guides N $
STWESTASTANDWH1 stand-wh sensor stand w/wheels
8200
STWESTARAAC1 cable adapter rapid air
raac1 Adapter Cables for other OEM
equipment
WESTARAAC1 raac-1 5 pin rapid adapter 000
STWESTARAAC2 option 15 pin rapidair cable
WESTARAAC2 raac-2 V2 rapid air adapter 500
STWESTARAAC2J option 15 pin rapidair cable
WESTARAAC2J raac-2j rapid air adapter 0000
STWESTAGOODMAN1 option cable to goodman cutter
WESTAGOODMAN1 goodman cutter adapter 15
ft 000
STWESTARAAC3 option d shell rapidair connec
WESTARAAC3 rapid air d-shell adapter 500
STWESTADIV2 option analog divider
WESTADIV2 div-2 analog divider option 0000
STWESTABSO1 option base speed option
WESTABSO1 bso-1 base speed option 7500
STWESTAAOM1 option anolog meter output meters
WESTAAOM2 analog meter 0-90 vdc $ -
WESTAAOM1 aom-1 analog output meter+-15 0000
STWESTADMS1 option digital display
WESTADMS1 dms-1 digital display 9900
STWESTAEAO1 option extra analog output Extra analog outputs
WESTAEAO1 eoa-1 normal extra analog 5000
STWESTAEAON1 option extra analog output inv
WESTAEAON1 eaon-1 inverted extra analog 5000
STWESTADUAL option relay for dual sensor o
WESTADUAL relay option for dual heads 6500 Relay for 2nd sensor switchable
STWESTATOGGLE option on off toggle switch
WESTATOGGLE on/off toggle switch option 500 on off power switch
STWESTASUM3 option line speed summing
WESTASUM3 sum-3 3input summing amplifier 7600 Summing input
STWESTATC6 option tension control(auto/ma
WESTATC6 tc-6 tension control option 0000
STWESTADF1 option dust filter option Dust filter for sensor
WESTADF1 df-1 dust filter for 500
STWESTAPID2 option pid output
WESTAPID2 pid2 output option 6500 PID Output
STWESTAONOFF two setpoint on off control
WESTAONOFF 2-set point on/off relay 500 dual setpoint On/Off relay
WEPTAONOFFNS
WEPTAPT1LSA
WEPTAPT1-1
PTTOPLIMIT
WEPTATL1
PTBOTTOMLIMIT
WEPTABL1
PTSTAND
WEPTASTAND
PTWESTAEXTBASE
WESTAEXTBASE
STWESTAMAO20
WESTAMAO20
STWESTAMAO10
WESTAMAO10
STWESTARAAC1
WESTARAAC1
STWESTARAAC2
WESTARAAC2
STWESTARAAC2J
WESTARAAC2J
STWESTARAAC3
WESTARAAC3
STWESTASUM3
WESTASUM3
PSOSDA10003
PSENC10032-PT
PSDRV10001-PT
PSDRV10002-PT
PSSPR10000
PSPTA10006
PSOPR10001
PTTOPLIMIT
WEPTATL1
PTBOTTOMLIMIT
WEPTABL1
PTSTAND
WEPTASTAND
STWESTAF/V1
WEEZAFV1
PTWESTAEXTBASE
WESTAEXTBASE
STWESTAMAO20
WESTAMAO20
STWESTAMAO10
WESTAMAO10
STWESTARAAC1
WESTARAAC1
STWESTARAAC2
WESTARAAC2
STWESTARAAC2J
WESTARAAC2J
STWESTARAAC3
WESTARAAC3
STWESTAAOM1
WESTAAOM2
WESTAAOM1
STWESTASUM3
WESTASUM3
; USAG
产品型号 18-611-20 EMILE MAURIN上海航欧机电设备有限公司成立于2006年,专业从事进口机电设备、仪器仪表等备品备件的销售,是经营世界各地进口设备机电配件的企业。上海航欧公司与众多品牌电子元件供应商建立有良好的合作关系,在欧美、日本等地形成了稳定的供应网络,良好的供应商关系和多年的行业经验,使我们在价格及货期上有优势。经销产品供应的行业涉及冶金、钢铁、石化、能源、航天、集装箱码头、汽车、水利、造纸、电厂、纺织、注塑、橡胶、食品包装等。我们热忱地希望尽我们的努力,力争优惠的产品价格,供货周期以及服务质量,能够为您解决进口备件方面的问题。进口产品主要有:传感器,测速电机,接近开关,电子尺,编码器,控制器、分析仪,光纤,光栅,插装阀,电缆,拖链,分配器,马达,减速机,继电器、缓冲器和进口五金等
产品型号 SEQ 632242 MATHESON
产品型号 DRO63/431.111 -1…12.5bar
R410a BAUMER
产品型号 DRO 63/431.111
-1..24BAR R404A BAUMER
产品型号 DRO 63/431.111/0-6BAR BAUMER
产品型号 MEX5D30B77 BOURDON
产品型号 GA2 ENERPAC
产品型号 FT290-14 TOGNELLA
产品型号 15300119 420312 BEDIA
产品型号 3403-10-D1.37 HYDROTECHNIK
产品型号 420311 15300116 BEDIA
产品型号 3403-53-C4.37 HYDROTECHNIK
产品型号 VESIM20 760038 0-20MPa VALCOM
产品型号 U2B 2KN 2mv/v HBM
产品型号 SX-12-V-025-HP SENSOREX
产品型号 QE-022-PS-02L METO-FER
产品型号 AAP0540089-00210 CAMERON
产品型号 IR5056
IR-3002-BPKG/V4A IFM
产品型号 VPRQ-A3-30MPA-S-5 VALCOM
产品型号 VD71-10-M14 PAG9-21-06I2A NORIS
产品型号 PT5-07M PT4-07M EMERSON
产品型号 VPRF-A3-20MPA-4C VALCOM
产品型号 311-B-RD-2-CJ GP:50
产品型号 PR-274-R6-VDC MAMAC SYSTEMS
产品型号 VHR3-A3-20KP(ABS)W-5 VALCOM
产品型号 MLC-5K TRANSDUCER
产品型号 MLC-7.5K TRANSDUCER
产品型号 PR-23XEn/81873.5 232390.0001 KELLER
产品型号 511.930003141 0-10bar
OUT:4-20mA IN:8-33VDC HUBA
CONTROL
产品型号 275071 GRANVILLE-PHILLIPS
产品型号 T99-AS3237/SS 5000kg Sherborne
产品型号 PA-21Y 8155433
0-250BAR 4-20MA P/N:222155 0143 KELLER
产品型号 ATM100104 (0-10bar) 231.1011.0105.00.QTZ STS
产品型号 1200SG1B001A3UA GEMS
产品型号 90061-AACC SENDEV
产品型号 891.13.500.160
4-20mA,0-160mbar S-10 WIKA
产品型号 511.930603941 511.930603942 HUBA CONTROL
产品型号 3405BFGBY 34BBFS VIATRAN
产品型号 628-18-CH-P1-E1-S1-LED
0-3000PSI DWYER
产品型号 AST4700A00100P3A0000 AST
产品型号 LBC-100Lbs TransducerTechniques
产品型号 PTD25-20-0100H automation direct
产品型号 BSP B250-EV002-A02A0B-S4 BALLUFF
产品型号 MN1-6-M-B35D-4-5-E F022925 GEFRAN
产品型号 211-B-RD-2-CL/GJ GP:50
产品型号 SETRA 225G1R7BCC41106 SETRA
产品型号 ATM 231.0111.0105.20.U STS
产品型号 VPRF-1MPW VALCOM
产品型号 82130746 WIKA
产品型号 PN7007 EFECTOR
产品型号 VPRF-A3-500BarS-4 VALCOM
产品型号 PT4624-35MPA-12/30-SIL2 DYNISCO
产品型号 FTG1088.00EX JAQUET
产品型号 VPRQ-A5-10KS-4C VPRQ-A5-10KS-4 VALCOM
产品型号 PPM2 0-10000PSI, 0.05级 HEISE
产品型号 PPM2 0-500PSI, 0.05级 HEISE
产品型号 82130745 WIKA
产品型号 82130747 WIKA
产品型号 PIS 3151.3152.3153 2SP-LED-M12x1-SU MAHLE
产品型号 82157621 WIKA
产品型号 PK6532 IFM
产品型号 PK6531 IFM
产品型号 PA907-DS PROPORTION-AIR
产品型号 DP-102 PANASONIC
产品型号 HXI-300KP-05-V SENSEZ
产品型号 FTG1088.00EX KTV-B JAQUET
产品型号 P400-15W3A-X/1914 WASCO
产品型号 PN7007 PN7097 IFM
产品型号 1900-1611-A1GB04 DANFOSS
产品型号 119055(-10-450
PISG,4-20mA) PMC
产品型号 987.4276.846 508543-0002 Trafag
产品型号 VTR-20I-500N VALCOM
产品型号 X13790828-01 TRANE
产品型号 VPRT-1000K VALCOM
产品型号 P255-15G-D4A KAVLICO
产品型号 DSX100S1180-17/H23 PROPORTION-AIR
产品型号 DP2-40E DP-102A SUNX
产品型号 SX150A HONEYWELL
产品型号 211-C-RB-2-CJ/GJ GP:50
产品型号 VD71-04-M14 PAG9-21-04I2A NORIS
产品型号 142DRF6AA GP:50
产品型号 142DRV6AA GP:50
产品型号 HDA4345-A-0010-000-F1 HYDAC
产品型号 RFS150E/0300/12/3/O/4-20 681341 HONIGMANN
产品型号 FSR402 interlink power
产品型号 528.932103L411 HUBA CONTROL
产品型号 VHR3-500N 5M VALCOM
产品型号 PPM2 0-3000SI, 0.05级 HEISE
产品型号 8252.G4.2517.24.17.44.61.1M Trafag
产品型号 8252.G4.2517.24.19.44.61.1M Trafag
产品型号 8252.H4.2517.24.17.44.61.1M Trafag
产品型号 8252.H4.2517.24.19.44.61.1M Trafag
产品型号 142DRX6AA GP:50
产品型号 SMP-MC1 0-0.4MPa MEIYO
产品型号 SMP-MC1 0-1.0MPa MEIYO
产品型号 SMP-MC2 0-0.6MPa MEIYO
产品型号 VESY050R2 2米线 VALCOM
产品型号 270-ROHS SETRA
产品型号 DMP331 110-1000-1-5-100-100-1-000 BD SENSORS
产品型号 3403-40-D1.37S 804 078 HYDROTECHNIK
产品型号 311-B-RH-7-CJ GP:50
产品型号 DP18P1000DC1NA ALPHA
产品型号 VESIM10 2米线 VALCOM
产品型号 PT5-18M PT4-18M EMERSON
产品型号 DMU 2 0-50mbar KALINSKY
产品型号 8498.26.2818 036038.0.00.04 8472.26.5718.05.19.58.62.T2 Trafag
产品型号 VPRH-A3-19.99MPa-1S(H)-1U VALCOM
产品型号 BPS32NVM3000P BARKSDALE
产品型号 FPG1BM-1AK-2E-3D-5C-6A-14C HONEYWELL
产品型号 PX319-005GI OMEGA
产品型号 P992-1-C 682-P992-1-C KAVLICO
产品型号 P992-5B-A KAVLICO
产品型号 MPX5500DP FREESCALE
产品型号 VST-32-7-3500kPa-H3500KPGC2 VALCOM
产品型号 M231-110 sensordata
产品型号 PTX5072-TC-A1-CA-J1-PA DRUCK
产品型号 VESY100R2 5m VALCOM
产品型号 8A5000-32 BRAD HARRISON
产品型号 与NPV876-1/2-50MPA-25/45
配套信号线 DYNISCO
产品型号 D-190 GUTEKUNST
产品型号 D-190A GUTEKUNST
产品型号 D-420 GUTEKUNST
产品型号 D3000-04DT-Z034-01 AIRCOM
产品型号 10282BPJY FAIRCHILD
产品型号 400.25.93 450.00.00 Dopag
产品型号 400.25.94 450.00.13 Dopag
产品型号 QB2TBNICZP145PSG-3D
+PSR-2PN +DSBEY00ZP145PSG-A PROPORTION-AIR
产品型号 11-802-974 NORGREN
产品型号 LRP-1/4-2,5 162834 FESTO
产品型号 MC7805CTG ON SEMICONDUCTOR
产品型号 F-351.P/024/1110 ELB
产品型号 1763.80.NR 2-10BAR PNEUMAX
产品型号 PA641-125REV1-QBT PROPORTION-AIR
产品型号 PA641-125REV1-PSR PROPORTION-AIR
产品型号 4ZM08A DAYTON
产品型号 F-351.PF/230/1110 Serial no.13078 ELB
产品型号 5522500 Metal Work
产品型号 2304C-1000(400psi) KEPNER
产品型号 DSB6300 G1/2" 131438 MIT
产品型号 DSB6300-05EE-160-32A 131266 MIT
产品型号 DSB6300 G1 DN25 PN16 131224 MIT
产品型号 LPU-250 TransducerTechniques
产品型号 S12-10 8704000 REFLEX
产品型号 C37N-SA4-PD F37N-S VALCOM
产品型号 000407057P CITEC
产品型号 VPRQF-A3-20MPaW-4-Y 5M VPRQF-A3-20MPaW-4 5m缆线 VALCOM
产品型号 375-001 INFICON
产品型号 377-003 INFICON
产品型号 1201PG-4C-4.5F,0-20PSID ORANGE RESEARCH
产品型号 C25SGSB13N DMIC
产品型号 ZM1000 M1000-AN0030 (1551 mmHg) MERIAM
产品型号 PE80H-P100G14IP2SQ BANNA
产品型号 M0132A-033-BAO MANOCOMB-IP65/2KA/VA pressure range:0-250bar PINTER
产品型号 M0131A-026-AAO MANOCOMB-IP65/2KA prssure range:0-10bar PINTER
产品型号 M0131A-027-AAO MANOCOMB-IP65/2KA prssure range:0-16bar PINTER
产品型号 M0031A-028-AAO MANOCOMB-IP65/2KA prssure range:0-25bar PINTER
产品型号 M0131A-031-BAO MANOCOMB-IP65/2KA/VA prssure range:0-100bar PINTER
产品型号 PN5004,1-10bar IFM
产品型号 2111122 4111122 EUROSWITCH
产品型号 DS-W12-4 DS-W12-2 DSA1-S12W-1M1A VOGEL
产品型号 8021204002 ANTUNES CONTROLS
产品型号 3110123 EUROSWITCH
产品型号 PMC5 ELETTROTEC
产品型号 M0031A-026-AAO MANOCOMB-IP65/2KA prssure range:0-10bar PINTER
产品型号 420304 15300083 BEDIA
产品型号 420308 15300088 BEDIA
产品型号 420161 15301960 BEDIA
产品型号 DCM10 FEMA
sp; EMILE MAURIN
