2023年WOHRLE工厂授权上海航欧中国区代理
上海航欧销售WOHRLE电源选型、WOHRLE单相电源选型WOHRLE不间断电源选型WOHRLE模块选型、WOHRLE继电器选型、WOHRLE开关选型根据客户需要提供系统定制解决方案
WOHRLE液晶显示器、WOHRLE电源、WOHRLE模块、WOHRLE继电器、WOHRLE开关
主要型号:
ATS2-440-11-400;MS224009;PH120-1306;EPH231506;AV3-220-06-300;ANKA-V3-220-06-300;MS2-240-09-11-201;AV3-220-06-300WOHRLE航欧 WISUS-K-6主轴驱动
WOHRLE航欧 AKKU-SYS24180S
WOHRLE航欧 SW-200-01
WOHRLE航欧 USVWISUS-M(360-480kVA)
WOHRLE航欧 DPNW2420
WOHRLE航欧 Profibus-ConverteralsErg?nzungzumCS121-SCM;
WOHRLE航欧 DB-14C/SK2/PC/203/UB
WOHRLE航欧 USVWISUS-K(6-20kVA)
WOHRLE航欧 RS232-Kabel,9-polig
WOHRLE航欧 EPNSW240588-264VAC/24-28VDC5A
WOHRLE航欧 UGVC2412超级电容
WOHRLE航欧 EPNW2404
WOHRLE航欧 EDI-RED20UE?0,5V
WOHRLE航欧 DPNW2440
WOHRLE航欧 SNMP-AdapterCS121BudgetUniversal-Box
WOHRLE航欧 EPNW2405
WOHRLE航欧 UGV-LI2402
WOHRLE航欧 BE2405CY
WOHRLE航欧 EPNW1202
WOHRLE航欧 CS-121-SPI-2显示器和LCD显示器
WOHRLE航欧 UGVC2420超级电容
WOHRLE航欧 USVWISUS-M(25-480kVA)
WOHRLE航欧 Tiefentladeschutzbis100VDC
WOHRLE航欧 EPN233020/N
WOHRLE航欧 STS16
WOHRLE航欧 DPNW2410
WOHRLE航欧 SNMP-AdapterCS121SlotProfessionalmitModbus
WOHRLE航欧 AV4-240-06-100高压电源
WOHRLE航欧 EPNSW240185-264VAC/21,6-26,4VDC1A
WOHRLE航欧 SNMP-AdapterCS121BudgetSlot
WOHRLE航欧 EPNSW240285-264VAC/24-30VDC2,5A
WOHRLE航欧 ZPNW2405
WOHRLE航欧 AV3-220-06-300温度控制器
WOHRLE航欧 Entkoppeldiode
WOHRLE航欧 CS-121-BL编码器
WOHRLE航欧 BE2405CY24–29V
WOHRLE航欧 CONVERTVT1
WOHRLE航欧 EPNW240332430Ue=690VUimp=8kvLu=25A50/510HzIEC60439-1
熔断器开关WOHNER160ALTS-00
液晶面板WOHRLEANKANr.:ATS2-440-06-11-400SN:PN-100C0.4/3.090.75AMP
电源WOHRLEMP1001050364整流电源NGI402430Prim:3*400+5%1-3A
DISPLAYWOHRLEMP6121103022100COMMUNICATIONWITHPROCESSOR
备件WOHRLEEU-ANW-WD1/230230VS-NYH60146
配件WOHRLEANKAG50173AN:AV3-220-06-30024VDC0.4AVERS50.2
显示器WOHRLEMBF2-14C-21111100
操作显示屏WOHRLEANKAARTNR:AV3-220-06-30
显示器WOHRLEANKAART:AV3-240-06-300SN:K5.000424DC
操作箱WOHRLEANKAART.NR:ATS2-440-06-11-400SN:PN-10024VDC0.75AMP
配件WOHRLE21235DC24V20A继电器
备件WOHRLETPYE:ANKAARTNR:AV3-220-06-300SERNR:M50012
显示器WOHRLEANKAR4-02224VDC0.40AArtNO:AV3-220-06-300
显示器WOHRLEMC-09/SK2L-103序列号:10156
显示器WOHRLEATS2-440-06-11-400815-057-21
upsWOHRLE71144steinenbronnUNG402420prim3*400V±5%(A)
显示器WOHRLECB-09/SK2L-303ser-nr.K8-09290-260VAC
文本显示器WOHRLEAV3-220-06-300E6000424V/DC0.4AE0.2文本显示器
显示屏WOHRLEDB5-14C-3525AA-0221000SERNO:G8-008230V50/60HZ
显示屏WOHRLEDM-14C/SK20PCSERNO:12344/15220VAC50/60HZ显示屏
配件WOHRLE21295DC24V20A继电器
传感器WOHRLETYPE:ANKAARTNR:AV3-200-06-30024VDC
光学传感器WOLF&BECKOTM3A-20
光学传感器WOLF&BECKOTM3A-50
备件WOLFERD315M-4B
备件WOLFERD180L-4
备件WOLFERD112M-4
电机WOLFERDRKO200L-4B/SFB16HT30KWSN:156476
WOHRLE航欧 KA-USV-Typ01
WOHRLE航欧 DPN402480/W
WOHRLE航欧 DB5-1211AA-0221000CPU和处理器
WOHRLE航欧 CS-121-SC图表记录
WOHRLE航欧 BP/CON6k电子离合器,刹车模块
WOHRLE航欧 CS-121-Mini计时器
WOHRLE航欧 USVWISUS-M(25-320kVA)
WOHRLE航欧 wandeltMODBUSinProfibus
WOHRLE航欧 EPNW2410
WOHRLE航欧 EDI4021–28V
WOHRLE航欧 AV3-240-06-100
WOHRLE航欧 Akkumulatoren-Systembestehendaus2Akkumulatoren12V/18Ah,Halterung,Sicherung40A
WOHRLE航欧 AV3-240-09-300
WOHRLE航欧 EPNSW4810
WOHRLE航欧 WISUS-K-20
WOHRLE航欧 ZPNW2420
WOHRLE航欧 SW-100-01100A9,1VDC
WOHRLE航欧 CONVERT19KIT
WOHRLE电源 DB-12/SK2L/CP/200流量计
WOHRLE电源 USR244021–29V
WOHRLE电源 überwachungs-undSteuerbaugruppefür24VDCUSV-Anlagen
WOHRLE电源 UGVCM2420-100超级电容
WOHRLE电源 CP526CP581DB06WF470
WOHRLE电源 USVWISUS-G(30-120kVA)
WOHRLE电源 CONVERTVT3
WOHRLE电源 WISUS-K-10电子离合器,刹车模块
WOHRLE电源 EntkoppeldiodemitEingangsüberwachung
WOHRLE电源 SW-50-0150A9,1VDC
WOHRLE电源 AS2-440-06-11-00-00矢量驱动
WOHRLE电源 USVWISUS-M(25-480kVA)
WOHRLE电源 CONVERTVT6
WOHRLE电源 EPNSW240488-264VAC/24-30VDC4A
WOHRLE电源 MO12TC/20/U电源
WOHRLE电源 BS2-240-09-111-400HVAC控制系统
WOHRLE电源 CS-121-SCM模拟和数字电路板
WOHRLE电源 AV3-240-06-101数控机床控制
WOHRLE电源 EPNW2420
WOHRLE电源 EPNSW241088-264VAC/24-28VDC10A
WOHRLE电源 AV3-240-09-101离合器和制动器
上海航欧销售WOHRLE液晶显示器、WOHRLE电源、WOHRLE模块、WOHRLE继电器、WOHRLE开关
S2-025-U-04 starter kit 除了S2-025-U-04和sick 传感器 现货查询上海航欧 ENFIELD
EAM58CR4096/4096G828PPX10S3PCR 现货查询上海航欧 ELTRA
SPN112E4AD-B 现货查询上海航欧 ZIMMER
DPB71CM48 现货查询上海航欧 CARLO GAVAZZI
G25XKCTHFECA 现货查询上海航欧 HYDRA CELL
KW-SC1 现货查询上海航欧 KU-SC1 AMK
NFG553A421 24VDC 现货查询上海航欧 ASCO
MPS-100CLTPO 现货查询上海航欧 SICK
D2153b4012 现货查询上海航欧 ROSS
SF2-AH36 P 现货查询上海航欧 SF4D-H36 SUNX
V6EPB-B-S-3-B 现货查询上海航欧 DWYER
EA530-47702 现货查询上海航欧 NAMCO
4WDH4-2020-T5G-M00 现货查询上海航欧 MICRO POINT PRO
CMI-4 10μF±5%,450VAC 现货查询上海航欧 5.014.02.FD.4 MECO
6A30-AC-1 18.00mm * 22.23mm(7/8") 不带键槽 现货查询上海航欧 6A30-AC WITH 18mm BORE WITHOUT KEYWAY * WITH 0.875 BORE WITHOUT KEYWAY ZERO-MAX
MOX-3N-13E 1M 1% 现货查询上海航欧 OHMITE
SGEA01M02028FG 现货查询上海航欧 MP-FILTRI
SGEA01FSZBR 现货查询上海航欧 MP-FILTRI
ETP-EXPRESS-32 现货查询上海航欧 ETP
TM4I3602 现货查询上海航欧 IME
983-T60404-N4644x052 现货查询上海航欧 T60404-N4644-X052 4644-052(正确型号) VAC
MK 63.1 A40 T12 120° 现货查询上海航欧 TUNKERS
545-10-1504四件套 现货查询上海航欧 TAI JENG
HBA-111892 现货查询上海航欧 EUCHNER
MODEL NO.2100,0.1GPM,SPDT 现货查询上海航欧 12704 THOMAS PRODUCTS
EP16W2A05N05 现货查询上海航欧 WINNER
88520 现货查询上海航欧 TUTHILL
SS-12-57-100 现货查询上海航欧 HEADLINE
HCS-20-SC-A-10 现货查询上海航欧 URD
PQ72K 0-100A 4-20mA 现货查询上海航欧 WEIGEL
0240R005ON 现货查询上海航欧 HYDAC
0160R010ON 现货查询上海航欧 HYDAC
4132/7s 现货查询上海航欧 castel
9182/10-50-12S 现货查询上海航欧 9182/10-51-14s STAHL
"ET049STD02928C-L(3
80V/50HZ)" 现货查询上海航欧 CEG
"ET049STD02929C-R(3
RX-1003PUI 现货查询上海航欧 TOHO SEISAKUSHO
31-742-32 现货查询上海航欧 EMILE MAURIN
1580U-10 现货查询上海航欧 PNEUMAX
D3/2 CMNR 现货查询上海航欧 WAIRCOM
27732 现货查询上海航欧 27634 Maxon
GA000-016 现货查询上海航欧 SGF
GA000-024 现货查询上海航欧 SGF
PFA9167A0015050 现货查询上海航欧 TER
M42.VR.TP.N.W.1660.B.P2.1.1400.CHL.CS.PMG1480 现货查询上海航欧 20-3705 FRANCIA
87530 现货查询上海航欧 MESABI
3D0480.6 现货查询上海航欧 B&R
513-403-10E 现货查询上海航欧 513-403-10(老款) MITUTOYO
513-425-10E 现货查询上海航欧 MITUTOYO
700-158-3DP02 现货查询上海航欧 DP/PN Coupler HELMHOLZ
GS-22-150-AA-800N 现货查询上海航欧 ACE
FDRA020142NV 现货查询上海航欧 RONZIO
C0C72-M12-B 现货查询上海航欧 STASTO
ALPHA 900 24 30 现货查询上海航欧 AEES
VDA/FL 6-38/TR.S.VRR 现货查询上海航欧 1214021101 Walvoil
CTF-5A 现货查询上海航欧 Multi
3241 DN20 PN40(阀体部分) 现货查询上海航欧 SAMSON
1415369F/0500 现货查询上海航欧 HOHNER
MDI1FRD23B7-EQ 现货查询上海航欧 IMS
AZC11113HK01 现货查询上海航欧 PANASONIC
TU56610000700.0000 现货查询上海航欧 CDC
290-2035(290-20354) 现货查询上海航欧 Simatec
220-5008(220-50080) 现货查询上海航欧 Simatec
290-2035-S(290-20350) 现货查询上海航欧 Simatec
FL. USCITA / output flange WG 030 FB 现货查询上海航欧 ELVEM
WG 030 1/60 PAM 56 B14 现货查询上海航欧 ELVEM
JB20H 现货查询上海航欧 2890002 ANVER
PM-0124-040-0 现货查询上海航欧 BLOCK
8CM010.12-1 现货查询上海航欧 B&R
MC-2180 现货查询上海航欧 FLAIR
K63 AS A10 T12 现货查询上海航欧 TUNKERS
SZ 50 UZ-LB 现货查询上海航欧 TUNKERS
FGL30-RK-30-PS-M3(832-11000) 现货查询上海航欧 SENSOPART
1056-02-22-35-DP-UL 现货查询上海航欧 EMERSON
K60 UZ T12 A19.9 L4=45+1.65 (订货提供铭牌) 现货查询上海航欧 TUNKERS
TCN-100-1-718-V01 现货查询上海航欧 TUNKERS
TCN-100-1-700-D600 现货查询上海航欧 TUNKERS
TCN-100-2-700-D800(T=400)tail 现货查询上海航欧 TUNKERS
AFS-100-2-700-D2000(T=600)tai 现货查询上海航欧 TUNKERS
TCN-100-2-700-D800(T=400)head 现货查询上海航欧 TUNKERS
A106S-0080C (DN80 PN16) 现货查询上海航欧 Conex Banninger
360507 现货查询上海航欧 BAMO
30809-411 现货查询上海航欧 SCHROFF
IE1-S-6-M-B35D-1-4-D-P 2130X000X00 现货查询上海航欧 GEFRAN
41.15.10 DIAPHRAGM (EPDM) NSF 现货查询上海航欧 EMERSON
VTD22-32-32-00-D(材质升级) 现货查询上海航欧 VTD21-32-32-00-D VORTEK(Tek-Air)
VTD22-22-20-00-D(材质升级) 现货查询上海航欧 VTD21-22-20-00-D VORTEK(Tek-Air)
D1VW004CNJEE93 现货查询上海航欧 PARKER
D1VW020BNJEE91 现货查询上海航欧 PARKER
205 032 现货查询上海航欧 STOGER
VK-FH54/55/EF14-RS232 现货查询上海航欧 MAGNET-PHYSIK
KTA3-25(0.1A-0.16A) 现货查询上海航欧 KTA9-32S-0.16A SPRECHERSCHUH
KTA3-25(0.16A-0.25A) 现货查询上海航欧 KTA9-32S-0.25A SPRECHERSCHUH
PW 6-8-A3 218238 {同ERP产编:492356} 现货查询上海航欧 TUNKERS
8CE010.12-1 现货查询上海航欧 B&R
KV9508A 现货查询上海航欧 Black box
UT2.5 Nr:2053/21 现货查询上海航欧 MARX
BKS09-ATBM0520 现货查询上海航欧 SICK
60809-032 现货查询上海航欧 SCHROFF
94245K54 现货查询上海航欧 MCMASTER CARR
MSQB30R 现货查询上海航欧 SMC
LFKL.MLF52-155-ZR-4400 现货查询上海航欧 INA
S109501015N 现货查询上海航欧 SMSTORK
UCP209 现货查询上海航欧 timken
DBS60E-S4FC01024 现货查询上海航欧 SICK
HP AB052D-0.2PM 现货查询上海航欧 PIZZATO
4576A0.5NC1 现货查询上海航欧 KISTLER
GA000-025 现货查询上海航欧 SGF
GA000-023 现货查询上海航欧 SGF
DNCB-32-600-PPV-A 现货查询上海航欧 DSBC-32-600-PPVA-N3 FESTO
IMG58B-1000-ABN-PT-35 现货查询上海航欧 IMG60B-1000-ABN-PT-35 IMG
25 mm Filter Membrane, 5-6 Micron 现货查询上海航欧 450254 Savillex
FTL31-AA4M3AAWDJ 现货查询上海航欧 E+H
LOFCZDV 现货查询上海航欧 SUN
07F46AC 现货查询上海航欧 PARKER
TADBR901TTG-125-ST-LB 现货查询上海航欧 NIPPON
S101733PD3T40 现货查询上海航欧 MINCO
0021 现货查询上海航欧 FRANKE
FLFA-XDN 现货查询上海航欧 SUN
XD6/207 220V 50Hz - 370W 1510316232016=code158123 + MOTOR FAN 现货查询上海航欧 SIMEL SPA
MX3-1-FR0000 现货查询上海航欧 CAMOZZI
9530001 现货查询上海航欧 AGILENT
315A-50C 1/4"NPT 现货查询上海航欧 HEADLINE
KOZ ST 36-52 现货查询上海航欧 koz products
KOZ ST 50-75 现货查询上海航欧 koz products
452H25.22 现货查询上海航欧 30059337 HUCO
JP220180 现货查询上海航欧 HBC
6923K62 现货查询上海航欧 MCMASTER CARR
VD71-40-M14 0-40bar DC30V 现货查询上海航欧 NORIS
56T17V5330-CAT N646 现货查询上海航欧 119468.00 MARATHON
XHPBS 红色 现货查询上海航欧 4369-2 ADALET
S1016.01.015V 现货查询上海航欧 SMSTORK
2607XH-PM400-3 现货查询上海航欧 NIPPON
CL-H 25-013 现货查询上海航欧 2314-14527-01002 ARIS
SUS-01.T.Q G/R 110DC 现货查询上海航欧 ELECO
SO50003-12-9 现货查询上海航欧 SERTO
50-3L 现货查询上海航欧 VIBCO
PS-6400-24-001 现货查询上海航欧 ELECTRO CAM
FAC12SM0404300 现货查询上海航欧 CANFIELD CONNECTOR
CFC-5M 现货查询上海航欧 FABCO-AIR
FR801-T125-1(含设定块F2.5) 现货查询上海航欧 Trulok
