  • TransducerTechniques开关CLC-300
  • 发布时间:2024/11/18 9:02:03   修改时间:2024/11/18 9:02:03 浏览次数:641
  • 上海航欧销售TransducerTechniques传感器、TransducerTechniques开关、TransducerTechniques变送器、TransducerTechniques阀、TransducerTechniques数显表
     美国TransducerTechniques公司成立于1979年,从事设计和制造系列的称重传感器,扭矩传感器,传感器和相关仪器仪表。TransducerTechniques公司的传感器的设计重量和力量等多元化的过程控制,可在工厂自动化以及其他数百个应用服务等工业领域测量。
    1.TransducerTechniques称重传感器
    CLC-200KCapacity:200,000lbsCompressionLoadColumn
    CLC-300KCapacity:300,000lbsCompressionLoadColumn
    CLC-400KCapacity:400,000lbsCompressionLoadColumn
    CAL-TEDSN/APlug&PlayOptionwithConnector
    AMM-66SSN/AMathangougAssembly6ftCable
    AMM-612SSN/AMathangougAssembly12ftCable
    AMM-620SSN/AMathangougAssembly20ftCable
    AMM-650SSN/AMathangougAssembly50ftCable
    THA-50-PCapacity:50lbshangouLoadCell
    THA-50-QCapacity:50lbshangouLoadCell
    THA-100-PCapacity:100lbshangouLoadCell
    THA-100-QCapacity:100lbshangouLoadCell
    THA-250-PCapacity:250lbshangouLoadCell
    THA-250-QCapacity:250lbshangouLoadCell
    GS0-1010gramsCalibrationhangouCompression
    GS0-2525gramsCalibrationhangouCompression
    GS0-3030gramsCalibrationhangouCompression
    GS0-5050gramsCalibrationhangouCompression
    GS0-100100gramsCalibrationhangouCompression
    GS0-150150gramsCalibrationhangouCompression
    GS0-250250gramsCalibrationhangouCompression
    GS0-500500gramsCalibrationhangouCompression
    GS0-1K1,000gramsCalibrationhangouCompression
    OPTION-TCN/ATensionCalibrationOption
    ALS-04N/ALoadStem(Dia..200Length.250)
    ALS-06N/ALoadStem(Dia..200Length.375)
    ALS-08N/ALoadStem(Dia..200Length.500)
    MDB-2.52.5lbsCalibrationhangouCompression
    MDB-55lbsCalibrationhangouCompression
    MDB-1010lbsCalibrationhangouCompression
    MDB-2525lbsCalibrationhangouCompression
    MDB-5050lbsCalibrationhangouCompression
    MDB-7575lbsCalibrationhangouCompression
    MDB-100100lbsCalibrationhangouCompression
    MLP-10Capacity:10lbsCalibrationhangouCompression
    MLP-25Capacity:25lbsCalibrationhangouCompression
    MLP-50Capacity:50lbsCalibrationhangouCompression
    MLP-75Capacity:75lbsCalibrationhangouCompression
    MLP-100Capacity:100lbsCalibrationhangouCompression
    MLP-150Capacity:150lbsCalibrationhangouCompression
    MLP-200Capacity:200lbsCalibrationhangouCompression
      MLP-300   Capacity: 300 lbs  Calibration hang ou Compression
      MLP-500   Capacity: 500 lbs  Calibration hang ou Compression
      MLP-750   Capacity: 750 lbs  Calibration hang ou Compression
      MLP-1K    Capacity: 1,000 lbs  Calibration hang ou Compression
      OPTION-CO N/A Mhang oui Connector System Option
      OPTION-DB N/A Dual Bridge
      OPTION-TC N/A Tension Calibration Option
      CAL-TEDS  N/A Plug & Play Option with Connector
      SLB-25    Capacity: 25 lbs  Mhang oui Compression Button
      SLB-50    Capacity: 50 lbs  Mhang oui Compression Button
      SLB-100   Capacity: 100 lbs  Mhang oui Compression Button
      SLB-250   Capacity: 250 lbs  Mhang oui Compression Button
      SLB-500   Capacity: 500 lbs  Mhang oui Compression Button
      SLB-750   Capacity: 750 lbs  Mhang oui Compression Button
      SLB-1K    Capacity: 1,000 lbs  Mhang oui Compression Button
      LB0-100   Capacity: 100 lbs  Compression Load Button
      LB0-100A  Capacity: 100 lbs  Compression Load Button
      LB0-250   Capacity: 250 lbs  Compression Load Button
      LB0-500   Capacity: 500 lbs  Compression Load Button
      LB0-750   Capacity: 750 lbs  Compression Load Button
      LB0-1K    Capacity: 1,000 lbs  Compression Load Button
      LB0-2K    Capacity: 2,000 lbs  Compression Load Button
      LB0-3K    Capacity: 3,000 lbs  Compression Load Button
      LB0-5K    Capacity: 5,000 lbs  Compression Load Button
      LB0-10K   Capacity: 10,000 lbs  Compression Load Button
      LB0-15K   Capacity: 15,000 lbs  Compression Load Button
      LB0-20K   Capacity: 20,000 lbs  Compression Load Button
      LB0-30K   Capacity: 30,000 lbs  Compression Load Button
      LB0-50K   Capacity: 50,000 lbs  Compression Load Button
      LBC-100   Capacity: 100 lbs  Compression Load Button
      LBC-100A  Capacity: 100 lbs  Compression Load Button
      LBC-250   Capacity: 250 lbs  Compression Load Button
      LBC-500   Capacity: 500 lbs  Compression Load Button
      LBC-750   Capacity: 750 lbs  Compression Load Button
      LBC-1K    Capacity: 1,000 lbs  Compression Load Button
      LBC-2K    Capacity: 2,000 lbs  Compression Load Button
      LBC-3K    Capacity: 3,000 lbs  Compression Load Button
      LBC-5K    Capacity: 5,000 lbs  Compression Load Button
      LBC-10K   Capacity: 10,000 lbs  Compression Load Button
      LBC-15K   Capacity: 15,000 lbs  Compression Load Button
      LBC-20K   Capacity: 20,000 lbs  Compression Load Button
      LBC-30K   Capacity: 30,000 lbs  Compression Load Button
      LBC-50K   Capacity: 50,000 lbs  Compression Load Button
      LBM-50    Capacity: 50 lbs Calibrated hang ou Compression
      LBM-100   Capacity: 100 lbs Calibrated hang ou Compression
      LBM-200   Capacity: 200 lbs Calibrated hang ou Compression
      LBM-500   Capacity: 500 lbs Calibrated hang ou Compression
      LBM-1K    Capacity: 1,000 lbs Calibrated hang ou Compression
      LBM-2K    Capacity: 2,000 lbs Calibrated hang ou Compression
      LBM-2.5K  Capacity: 2,500 lbs Calibrated hang ou Compression
      LBM-5K    Capacity: 1,000 lbs Calibrated hang ou Compression
      LBM-8K    Capacity: 8,000 lbs Calibrated hang ou Compression
      LBM-10K   Capacity: 10,000 lbs Calibrated hang ou Compression
      MLC-2K    Capacity: 2,000 lbs  Mhang oui Comp Load Column
      MLC-3K    Capacity: 3,000 lbs  Mhang oui Comp Load Column
      MLC-5K    Capacity: 5,000 lbs  Mhang oui Comp Load Column
      MLC-7.5K  Capacity: 7,500 lbs  Mhang oui Comp Load Column
      MLC-10K   Capacity: 10,000 lbs  Mhang oui Comp Load Column
      MLC-15K   Capacity: 15,000 lbs  Mhang oui Comp Load Column
      MLC-20K   Capacity: 20,000 lbs  Mhang oui Comp Load Column
      MLC-30K   Capacity: 30,000 lbs  Mhang oui Comp Load Column
      CLC-50K   Capacity: 50,000 lbs  Compression Load Column
      CLC-100K  Capacity: 100,000 lbs  Compression Load Column
      THA-500-P Capacity: 500 lbs  hang ou Load Cell
      THA-500-Q Capacity: 500 lbs  hang ou Load Cell
      THB-100-P Capacity: 100 lbs  hang ou Load Cell
      THB-100-Q Capacity: 100 lbs  hang ou Load Cell
      THB-100-R Capacity: 100 lbs  hang ou Load Cell
      THB-100-S Capacity: 100 lbs  hang ou Load Cell
      THB-250-P Capacity: 250 lbs  hang ou Load Cell
      THB-250-Q Capacity: 250 lbs  hang ou Load Cell
      THB-250-R Capacity: 250 lbs  hang ou Load Cell
      THB-250-S Capacity: 250 lbs  hang ou Load Cell
      THB-500-P Capacity: 500 lbs  hang ou Load Cell
      THB-500-Q Capacity: 500 lbs  hang ou Load Cell
      THB-500-R Capacity: 500 lbs  hang ou Load Cell
      THB-500-S Capacity: 500 lbs  hang ou Load Cell
      THB-1K-P  Capacity: 1,000 lbs  hang ou Load Cell
      THB-1K-Q  Capacity: 1,000 lbs  hang ou Load Cell
      THB-1K-R  Capacity: 1,000 lbs  hang ou Load Cell
      THB-1K-S  Capacity: 1,000 lbs  hang ou Load Cell
      THB-2K-P  Capacity: 2,000 lbs  hang ou Load Cell
      THB-2K-Q  Capacity: 2,000 lbs  hang ou Load Cell
      THB-2K-R  Capacity: 2,000 lbs  hang ou Load Cell
      THB-2K-S  Capacity: 2,000 lbs  hang ou Load Cell
      THC-250-P Capacity: 250 lbs  hang ou Load Cell
      THC-250-Q Capacity: 250 lbs  hang ou Load Cell
      THC-250-R Capacity: 250 lbs  hang ou Load Cell
      THC-250-S Capacity: 250 lbs  hang ou Load Cell
      THC-250-T Capacity: 250 lbs  hang ou Load Cell
      THC-250-V Capacity: 250 lbs  hang ou Load Cell
      THC-500-P Capacity: 500 lbs  hang ou Load Cell
      THC-500-Q Capacity: 500 lbs  hang ou Load Cell
      THC-500-R Capacity: 500 lbs  hang ou Load Cell
      THC-500-S Capacity: 500 lbs  hang ou Load Cell
      THC-500-T Capacity: 500 lbs  hang ou Load Cell
      THC-500-V Capacity: 500 lbs  hang ou Load Cell
      THC-1K-P  Capacity: 1,000 lbs  hang ou Load Cell
      THC-1K-Q  Capacity: 1,000 lbs  hang ou Load Cell
      THC-1K-R  Capacity: 1,000 lbs  hang ou Load Cell
      THC-1K-S  Capacity: 1,000 lbs  hang ou Load Cell
      THC-1K-T  Capacity: 1,000 lbs  hang ou Load Cell
      THC-1K-V  Capacity: 1,000 lbs  hang ou Load Cell
      THC-2K-P  Capacity: 2,000 lbs  hang ou Load Cell
      THC-2K-Q  Capacity: 2,000 lbs  hang ou Load Cell
      THC-2K-R  Capacity: 2,000 lbs  hang ou Load Cell
      THC-2K-S  Capacity: 2,000 lbs  hang ou Load Cell
      THC-2K-T  Capacity: 2,000 lbs  hang ou Load Cell
      THC-2K-V  Capacity: 2,000 lbs  hang ou Load Cell
      THC-3K-P  Capacity: 3,000 lbs  hang ou Load Cell
      THC-3K-Q  Capacity: 3,000 lbs  hang ou Load Cell
      THC-3K-R  Capacity: 3,000 lbs  hang ou Load Cell
      THC-3K-S  Capacity: 3,000 lbs  hang ou Load Cell
      THC-3K-T  Capacity: 3,000 lbs  hang ou Load Cell
      THC-3K-V  Capacity: 3,000 lbs  hang ou Load Cell
      THC-5K-P  Capacity: 5,000 lbs  hang ou Load Cell
      THC-5K-Q  Capacity: 5,000 lbs  hang ou Load Cell
      THC-5K-R  Capacity: 5,000 lbs  hang ou Load Cell
      THC-5K-S  Capacity: 5,000 lbs  hang ou Load Cell
      THC-5K-T  Capacity: 5,000 lbs  hang ou Load Cell
      THC-5K-V  Capacity: 5,000 lbs  hang ou Load Cell
      THC-7.5K-P Capacity: 7,500 lbs  hang ou Load Cell
      THC-7.5K-Q Capacity: 7,500 lbs  hang ou Load Cell
      THC-7.5K-R Capacity: 7,500 lbs  hang ou Load Cell
      THC-7.5K-S Capacity: 7,500 lbs  hang ou Load Cell
      THC-7.5K-T Capacity: 7,500 lbs  hang ou Load Cell
      THC-7.5K-V Capacity: 7,500 lbs  hang ou Load Cell
      THC-10K-P  Capacity: 10,000 lbs  hang ou Load Cell
      THC-10K-Q  Capacity: 10,000 lbs  hang ou Load Cell
      THC-10K-R  Capacity: 10,000 lbs  hang ou Load Cell
      THC-10K-S  Capacity: 10,000 lbs  hang ou Load Cell
      THC-10K-T  Capacity: 10,000 lbs  hang ou Load Cell
      THC-10K-V  Capacity: 10,000 lbs  hang ou Load Cell
      THD-2K-P  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-Q  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-R  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-S  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-T  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-V  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-W  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-Y  Capacity: 2,000 lbs  hang ou Load Cell
      THD-2K-Z  Capacity: 2,000 lbs  hang ou Load Cell
      THD-3K-P  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-Q  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-R  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-S  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-T  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-V  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-W  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-Y  Capacity: 3,000 lbs  hang ou Load Cell
      THD-3K-Z  Capacity: 3,000 lbs  hang ou Load Cell
      THD-5K-P  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-Q  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-R  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-S  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-T  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-V  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-W  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-Y  Capacity: 5,000 lbs  hang ou Load Cell
      THD-5K-Z  Capacity: 5,000 lbs  hang ou Load Cell
      THD-7.5K-P Capacity: 7,500 lbs  hang ou Load Cell
      THD-7.5K-Q Capacity: 7,500 lbs  hang ou Load Cell
      THD-7.5K-R Capacity: 7,500 lbs  hang ou Load Cell
      THD-7.5K
  • 蔡莉 在2025/2/26 15:49:00留言
  • 详细留言:CTC AC184—1A 需求报价及购买方式
  • 刘飞 在2025/2/21 11:49:00留言
  • 详细留言:SB35HF140-50F10/112-1这个型号的蓄能器是否有货
