  • MONITRAN代理MTN/ECPD2AC4-20mA
  • 发布时间:2025/3/22 10:24:21   修改时间:2025/3/22 10:24:21 浏览次数:513
  • 2010年MONITRAN工厂上海航欧中国区销售
     MONITRAN加速计、MONITRAN加速度传感器、MONITRAN传感器、MONITRAN编码器、MONITRAN震动探头
     上海航欧销售英国MONITRAN传感器,成立于1986年,是英国的振动传感器制造商。Monitran对速度计、机械保护和维修涡流探头的开发、生产和应用。Monitran的振动传感器,固定和移动监测系统及其辅助设备,如传感器,探头,转接器加速器探头驱动器和电缆组件等产品,Monitran产品通过ISO9001:2008认证,Monitran的加速计用于监测,如水泵、电机、传感器、加速器、探头风机、发动机、探头驱动器、
     常用型号:
     MTN/1185CM8-20
     1185CMPG7-100
     MTN/1185IC-50
     MTN/1185-CM8-25F
     MTN/1185CQ-20
     MTN/1185CM-25
     MTN/EP080
     MTN/1187-10
     MTN/1187CM8-1/219
     MTN/IEAIW-75
     MTN/1185IC-20
     IEIRG050
     MTN/1187-10
     MTN/1188Q-1
     MTN/1120IHCF1/4
     MTN/1185ICM-25
     MTN/MH008
     MTN/1185
     MTN/1187
     VM120
     MTN/1100SC,,,5shanghaihangousalesesarmouredETFE
     Extratwincore,screened,overbraidedETFEcable,
     MTN/1100WSubmersible,,waterproofgland,5shanghaihangousaleses
     PUwaterproofshanghaihangousalest
     MTN/1100SWSubmersible,,waterproofgland,5shanghaihangousaleses
     PUwaterproofshanghaihangousalestr
     Extrathree-core,polyurethane,waterproofcable,
     MTN/1100IATEX/IECEx,,,2pinMS
     MTN/1100ICATEX/IECEx,,,5shanghaihangousaleses
     armouredETFEcableshanghaihangousales
     MTN/1100ISATEX/IECEx,,,2pinMS
     MTN/1100ISCATEX/IECEx,,,5shanghaihangousaleses
     MTN/7100Low,strain,smallfourmet
     MTN/7110Low,strain,largefourshanghaihangousales
     MTN/7120Low,strain,shanghaihangoushanghaihangousales
     Aboveallsuppliedwith5shanghaihangousalesesoverbraidedcable.Specifyrangeing
     MTN/7200Low,4-20mA,smallfourshanghaihangousales
     MTN/7210Low,4-20mA,largefourshanghaihangousales
    MTN/7220Low , 4-20mA , shanghai hangou shanghai hangou sales
    Above all supplied with 5 shanghai hangou saleses overbraided cable. Specify range in g
    MTN/P1100, charge , 1100pC/g, TNC connectorshanghai hangou sales
    MTN/P100T, charge , 20pC/g,
    MTN/P100, charge , 20pC/g,
    MTN/P50, charge , 50pC/g, , 5 shanghai hangou saleseshanghai hangou sales
    MTN/P05, charge , 5pC/g, , 5 shanghai hangou saleseshanghai hangou sales
    MTN/CA003In-line charge amplifier in stainless steel enclosure with connectors, 2mV/pC
    MTN/MS001Quick-fit to glue studshanghai hangou sales3.20metshanghai hangou sales2.70
    MTN/MS002Quick-fit to M8 male studshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS003Quick-fit to M10 male studshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS004Quick-fit to 1/4"UNF male studshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS005Quick-fit to 1/4"UNF femaleshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS006Quick-fit to M6 male studshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS007Quick-fit to 10-32UNF femaleshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS008Quick-fit to M8 female studshanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS00910-32UNF to male glue studshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS010Quick-fit to glue stud (for 1020Q/1120Q series)shanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS0131/4"-28UNF male to glue studshanghai hangou sales3.20shanghai hangou sales356shanghai hangou sales2.70
    MTN/MS01410-32UNF male to glue studshanghai hangou sales3.20shanghai hangou sales356shanghai hangou sales2.70
    MTN/MS055Quick-fit to M8 male stud (for 1020Q/1120Q series)shanghai hangou sales3.20shanghai hangou sales2.70
    MTN/MS0671/4"-28UNF to M8shanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS0361/4"-28UNF to M6shanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS1241/4"-28UNF to M10shanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS1321/4"-28UNF to M12shanghai hangou sales3.50shanghai hangou sales3.20met
    MTN/MS02410-32 UNF grub screwshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS032M6 x 12mm grub screwshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS0681/4"-28UNF grub screwshanghai hangou sales3.50shanghai hangou sales3.20shanghai hangou sales
    MTN/MS11Quick-fit female - 1/4" UNF malemet
    MTN/MS15Quick-fit female - 10-32 UNF maleshanghai hangou sales
    MTN/MS034Isolation Adaptor 1/4"-28UNF male to 1/4"-28UNF femaleshanghai hangou sales
    MTN/MS062Isolation Adaptor 10-32UNF male to 10-32UNF malemet
    MTN/MS093Isolation Adaptor Q/F male to M8 maleshanghai hangou sales
    MTN/MS112Isolation Adaptor M8 male to M8 femaleshanghai hangou sales
    MTN/MM0011/4"-28UNF male, 35mm, 2 pole type, 20kgsmet
    MTN/MM00210-32UNF male, 19mm, 7kgsshanghai hangou sales
    MTN/MM0031/4"-28UNF male, 38mm, 2 pole typemet
    MTN/MM00410-32UNF male, 35mm, 2 pole type, 20kgsshanghai hangou sales
    MTN/MM005Quick-fit male, 35mm, 2 pole type, 20kgsmet
    MTN/MM006M6 female, 19mm, 7kgsshanghai hangou sales
    MTN/MM007M8 female, 35mm, 2 pole type, 20kgsmet
    MTN/MM0081/4"-28UNF male 25.35mm, 2 pole type, 11kgsshanghai hangou sales
    MTN/MM00910-32UNF male, 25mm, 2 pole typemet
    MTN/MM010Quick-fit male, 25mm, 2 pole typemet
    MTN/MM0231/4"-28UNF female, 35mm, 20kgs shanghai hangou sales
    MTN/MM027M10 female, 35mm, 2 pole typeshanghai hangou sales
    MTN/PS0011/4" UNF , 25mmshanghai hangou sales
    MTN/PS0021/4" UNF , 100mmmet
    MTN/PS0031/4" UNF , 150mmmet
    MTN/PS0041/4" UNF , 200mmshanghai hangou sales
    MTN/PS00510-32 UNF , 25mmshanghai hangou sales
    MTN/PS00610-32 UNF , 100mmshanghai hangou sales4
    MTN/PS00710-32 UNF , 150mmshanghai hangou sales
    MTN/PS00810-32 UNF , 200mmshanghai hangou sales
    MTNMH001M8 spot face toolmet
    MTN/MH010ing stud adhesive (liquid steel type), for 20 -25 glue-on adaptorsmet
    MTN/3008Switch box, 8 , , IP65shanghai hangou sales
    MTN/3010Switch box, 10 , , IP65shanghai hangou sales
    MTN/3012Switch box, 12 , , IP65met
    MTN/3014Switch box, 14 , , IP65shanghai hangou sales
    MTN/3016Switch box, 16 , , IP65met
    MTN/3018Switch box, 18 , , IP65shanghai hangou sales
    MTN/3020Switch box, 20 , , IP65shanghai hangou sales
    MTN/3025Switch box, 25 , , IP65shanghai hangou sales
    MTN/3040Switch box, 40 , , IP65shanghai hangou sales
    MTN/3064Switch box, 64 , , IP65shanghai hangou sales
    MTN/9003-HD3 ,
    MTN/9004-HD4 ,
    MTN/9005-HD5 ,  shanghai hangou sales
    MTN/9006-HD6 ,  shanghai hangou sales
    MTN/9007-HD7 ,
    MTN/9008-HD8 ,  shanghai hangou sales
    MTN/9009-HD9 ,  shanghai hangou sales
    MTN/9010-HD10 ,  shanghai hangou sales
    MTN/9011-HD11 ,  shanghai hangou sales
    MTN/9012-HD12 ,  shanghai hangou sales
    MTN/9025-HD25 ,  shanghai hangou sales
    MTN/9040-HD40 ,  shanghai hangou sales
    MTN/9002-GRP2 t
    MTN/9003-GRP3 t
    MTN/9004-GRP4 shanghai hangou sales
    MTN/9005-GRP5 shanghai hangou sales
    MTN/9006-GRP6
    MTN/9007-GRP7 shanghai hangou sales
    MTN/9008-GRP8 t
    MTN/9009-GRP9 shanghai hangou sales
    MTN/9010-GRP10 shanghai hangou sales
    MTN/9011-GRP11 t
    MTN/9012-GRP12 t
    MTN/9002-ABS2
    MTN/9003-ABS3
    MTN/9004-ABS4 shanghai hangou sales
    MTN/9005-ABS5
    MTN/9006-ABS6
    MTN/9007-ABS7
    MTN/9008-ABS8
    MTN/9009-ABS9
    MTN/9010-ABS10 shanghai hangou sales
    MTN/9011-ABS11 shanghai hangou sales
    MTN/9012-ABS12 shanghai hangou sales
    Consult the sales office for other sizes
    MTN9000-GRP Series Junction Boxes
    hangou sales
    MTN/VM120KVM120, probe, cable, magnet, spike, case - kit as aboveshanghai hangou sales
    MTN/VM110Meter onlymet
    MTN/VM120Meter onlymet
    MTN/2100Hand held  probe with coiled cable (CA418), 1/4"-28UNF
    female ingshanghai hangou sales15556shanghai hangou sales14356shanghai hangou sales13256
    MTN/CA418Coiled cable assembly TNC to IA110 for use with MTN/2100 hand-held
    probeshanghai hangou sales4556shanghai hangou sales4256shanghai hangou sales3856
    MTN/1100, , , 2 pin MS connectormet
    MTN/CA042Coiled cable assembly 2 pin MS to IA110 for use with MTN/1100shanghai hangou sales
    MTN/1020, , , TNC connectormet
    MTN/CA043Coiled cable assembly TNC to IA110 for use with MTN/1020shanghai hangou sales
    MTN/MM001Magnetic base, 1/4"-28UNF male, 2 pole, 35mm dia, 20Kg forcemet
    MTN/PS001Spike probe, stainless steel, 25mm, 1/4"-28UNF maleshanghai hangou sales
    MTN/PS002Spike probe, stainless steel, 100mm, 1/4"-28UNF maleshanghai hangou sales
    MTN/PS003Spike probe, stainless steel, 150mm, 1/4"-28UNF maleshanghai hangou sales
    MTN/PS004Spike probe, stainless steel, 200mm, 1/4"-28UNF maleshanghai hangou sales
    MTN/HE001Carrying case with foam cutoutsshanghai hangou sales
    MTN/RC0100Recalibration, recommended annuallyshanghai hangou sales
    MTN/6000
    MTN/HE003Wall ed enclosure to accommodate shanghai hangou rackshanghai hangou sales25056shanghai hangou sales23156
    MTN/HE004Wall ed enclosure to accommodate two racksshanghai hangou sales35056shanghai hangou sales32456
    MTN/6200
    MTN/6100V
    MTN/6100GVibration module as above but measuring  (g)
    MTN/6500-1Temperature module for AD590, 1μA/oK  temperature sensormet
    MTN/6500-2Temperature module for PT100 2 wireshanghai hangou sales
    MTN/6500-3Temperature module for PT100 3 wireshanghai hangou sales
    MTN/6500-4Temperature module for 10mV/oC  temperature sensorshanghai hangou sales
    MTN/MH007Flashing light and sirenshanghai hangou sales
    MTN/MH099Flashing light onlyshanghai hangou sales20056shanghai hangou sales18556
    A complete 6000 system consists of an electronics rack with power supply,
    display, various signal input cards (one reqired for each sensor input) in an
    IP65 enclosure with up to 12 s, temperature sensors or eddy
    current probes. See the relevant sections for individual sensor prices.
    Any complete 6000 monitoring system including 6 or more  and
    sensors will receive a 5% overall discount.
    Model 6050 4 channel monitor
    MTN/6050-65
    MTN/6200
    MTN/6050-4V
    MTN/6050-4VT
    MONITORING SYSTEMS
    MONITORING SYSTEMS
    MTN/MH0022 pin MS mating connector, femaleshanghai hangou sales
    MTN/MH0083 pin 62GB mating connector, femaleshanghai hangou sales
    MTN/CA067BNC plug with strain relief, fitted to  cable. For connection to
    datalogger having a BNC socketshanghai hangou sales
    MTN/CA054BNC socket with dust cap in 90deg bracket, fitted to  cable.
    For connection to datalogger through accessory cable fitted with BNC plug or
    VS0004 vibration switchshanghai hangou sales
    MTN/CA0532 pin MS socket to free ends, overbraided ETFE, 5 shanghai hangou salesesshanghai hangou sales
    MTN/CA1373 pin 62GB socket to free ends, overbraided ETFE, 5 shanghai hangou salesesshanghai hangou sales
    Extra twin core, screened, armoured ETFE cable, per shanghai hangou salese
    Above are for connecting remote sensors to switch boxes, junction boxes or
    data systems. For other cable assemblies and cables to connect to portable
    data loggers please contact the sales office. We will need to know the type of
    cable required, length, sensor and measuring device to give a price.
    MTN/8301 cable checkershanghai hangou sales
    MTN/8302 signal simulatorshanghai hangou sales
    MTN/APSU01Battery powered constant current power supply with BNC socket for shanghai hangou
    MTN/8001Constant current power supply in DIN rail ed enclosure for use on
    24VDCshanghai hangou sales
    MTN/8001BNCConstant current power supply in DIN rail ed enclosure for use on
    24VDC with integral BNC socketshanghai hangou sales
    MTN/VC10Vibration calibrator shanghai hangou sales2,
    MTN/EP0802mm range, M8 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
    MTN/EP2005mm range, M16 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
    MTN/EP3408.5mm range, M24 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
    MTN/EP340F8.5mm range, 3  flange including 1 shanghai hangou salese armoured cableshanghai hangou sales
    MTN/EP48012mm range, M30 thread including 1 shanghai hangou salese armoured cableshanghai hangou sales
    Extra cable (priced per shanghai hangou salese)shanghai hangou sales
    Up to a maximum of 9 shanghai hangou saleses including the extension
    Alternative probe length and thread sizes available, consult the sales office
    MTN/EX--1 shanghai hangou salese extension cableshanghai hangou sales4
    Up to a maximum of 9 shanghai hangou saleses including the probe
    MTN/ECPDDriver, 0-16VDC  gap, -24VDCshanghai hangou sales
    MTN/ECPD+24Driver, 0-16VDC  gap, +24VDCshanghai hangou sales
    MTN/ECPD/78Driver, 0-10VDC  gap, +24VDCshanghai hangou sales
    MTN/ECPD/604-20mA  vibration, three wireshanghai hangou sales
    MTN/ECPD/854-20mA  gap, three wireshanghai hangou sales
    MTN/ECPD2AC4-20mA  vibration, two wire loop poweredshanghai hangou sales
    MTN/ECPD2DC4-20mA  gap, two wire loop poweredshanghai hangou sales
    MTN/P2424V DC power supply housed in die-cast box with glanded , 240 or
    110 volts input to power above drivers.shanghai hangou sales
    MTN/RC0600Eddy Probe recalibration and certification in factory.met
  • 蔡莉 在2025/2/26 15:49:00留言
  • 详细留言:CTC AC184—1A 需求报价及购买方式
