英国翠欧(TRIO)运动技术公司
  • 英国翠欧独立式运动控制器P192MC302X
  • 发布时间:2006/12/14 9:30:03   修改时间:2007/1/15 15:04:35 浏览次数:7805
  •   the new mc302x:
      new improved pcb layout:
      single board controller.
      new improved power supply:
      no electrolytic caps.
      new fpga:
      smaller.
      new improved application memory 4mbit (apps ram).
      new memory arrangement, arm7 based processor with internal flash memory of 16 mbit
      new improved encoder/stepper transceiver with new esd protection devices allowing a better esd protection.
      connection to encoder and/or stepper axis via 2 d-type connector like on the mc206x.
      possibility to use axis0 as stepper encoder and axis1 as stepper only or axis1 as stepper encoder and axis0 as servo/encoder. (see d-type pin desc-ription).
      new can controller, 3.3v oki can controller ml9620.
      new dac isolation using icoupler technology.
      new improved rs485 transceiver, better esd protection and voltage threshold.
      two serial connector, one minidin connector for rs232 port#0, on other one for port#1 rs232 or rs485. (see serial connectors pin connection)
      new wdog circuitry using a single solid state relay.
      new improved clock generator circuitry, smaller surface mount xtal and better spread spectrum device.
      new output drivers, quad channel high side driver.
      new atype 46 to use as a stepper encoder with external encoder input.
      atype 4 use as a stepper encoder with internal encoder loop back as for mc206.
      axis pin desc-ription:
      standard atype:
    atype axis(0)=46 (stepper encoder type with external encoder input )
    atype axis(1)=46 (stepper encoder type with external encoder input )
英国 TRIO 公司 (Trio Motion Technology Ltd) 成立于 1987 年,该公司的创始人都毕业于英国帝国理工学院。近年来,该公司为世界许多著名的公司都提供了优质的产品和技术. 目前为止, TRIO 公司已经开发了 20 多种通用及专用的子板,例如通讯用的子板: Ethernet 、 S…  更多>>
英国翠欧(TRIO)运动技术公司
联系人:ZhaoTienan
地址:上海市浦东新区张杨路188号B1701
邮编:200122
电话:021-58797659
传真:021-58794289
公司网址:http://www.triomotion.com
  • 杨先生 在2024/11/21 8:55:00留言
  • 详细留言:之前设备使用了一台控制器,但是不知道怎么二次开发,也不知道是什么型号,需要协助
  • 在2024/9/21 11:28:00留言
  • 详细留言:MC6N-ECAT P961
  • 张军健 在2024/9/11 19:29:00留言
  • 详细留言:MC664运动控制器不工作
  • 贾女士 在2024/5/28 15:15:00留言
  • 详细留言:需要EURO 205X 价格信息
  • 在2024/3/5 15:46:00留言
  • 详细留言:需要了解:可以接26位的BISS_C的光栅尺的型号控制器。 需要四轴或者四轴以上的,具体的价格分别是多少
