深圳市鑫合利科技有限公司
  • 合利推出MINI型车载电源CAR PC电源
  • 发布时间:2007/9/19 9:18:22   修改时间:2007/4/4 11:11:57 浏览次数:1434
  • 鑫合利科技有限公司近期推出MINI型的车载电脑CARPC电源,尺寸只有:44.5mm(L) * 20mm(W) * 30mm (H)大小,特别适用用MINI型的CARPC电脑.该电源在这么小的尺寸中保留和原有的车载电源的各项功能,如ITPS等功能等,表明了,合利科技在电源技术上的超凡的技术和前瞻.
    以下是电源的相关参数:
    120Watts DC-DC ATX Power Supply
    Power Ratings (Max Load = 140 Watts)
    Output
    Max Load (A)
    Peak Load (A)
    Regulation%
    5V
    6A
    8A
    +/-1.5%
    3.3V
    6A
    8A
    +/-1.5%
    5VSB
    1.5A
    2A
    +/-1.5%
    -12V
    0.05A
    0.2A
    +/-1.5%
    12V
    7A
    10A
    Switched input
    At max load, forced air ventilation is required. For fanless operation de-rate the output of the 3.3 and 5V rails by ~20%. Peak load should not exceed 60 seconds.
    Size: 44.5mm(L) * 20mm(W) * 30mm (H) (1U compliant)
    Weight: 57gramms, including cable harness, 27 grams without cable harness.
    DC-Jack: Female, panel mount, 2.5*5.5*10 mm.
    Connectors
    Molex 39-01-2200, two 3.5” drive power connector, 1 floppy. P4-12V 4
    pin header adapter sold separately.
    Overload protection
    Over load protection will be effected when either of the loads (+5V &
    +3.3V) exceeds > 200% Max Load.
    Turn-on Delay
    After turning on, at least 20 ms will be needed for the rise of +5VSB
    output voltage (measured from 10% to 95%) to reach its peak.
    Remote ON/OFF control
    Logic level is LOW -Output voltage is enabled (PS_ON pin)
    Logic level is HIGH -Output voltage is disabled (PS_ON pin)
    Operating environment: Temperature: -20 to 85 degree centigrade.
    Relative Humidity: 10 to 90 percent, non-condensing.
    Efficiency, MTBF: 95%. MTBF=100K hours at 55Celsius.
深圳市鑫合利科技有限公司是致力于工控系统,嵌入式系统,车载系统,智能化系统以及网络计算机等领域的拓展的厂商,专门研发、生产和代理计算机系统网络产品的专业厂商,与国内外知名的厂商具有良好的战略合作关系,是国内第一个车载电脑CarPC…  更多>>
深圳市鑫合利科技有限公司
联系人:熊言寒
地址:深圳市南山区科技园汇景豪苑海逸阁21E
邮编:518057
电话:0755-26583455
传真:0755-26583595
公司网址:http://www.hopely.net/
  • 夏生 在2011/7/4 18:30:00留言
  • 详细留言:要具体了解下。
