深圳市鑫合利科技有限公司
  • OBD-II
  • 发布时间:2007/2/9 14:40:12   修改时间:2007/2/9 14:40:12 浏览次数:5836
  • OBD-II
  • 产品名称:OBD-II
    产品型号:OBD-II
    Product Name: ELM327
    Product model number:E327
    Net Weight: 0.58KG
    Features
    ELM327 is the latest PC-based scan tool. It supports all OBD-II protocols and is dispatched with a number of compatible programs. The processor is an ELM327. The output protocol (connection to laptop) is RS232.
    Processor: ELM327
    OBD-II Protocols: • ISO15765-4 (CAN)
    • ISO14230-4 (KWP2000)
    • ISO9141-2
    • J1850 VPW
    • J1850 PWM
    Output protocol: RS232
    Baud rate: 9600 or 38400
    Indicator LEDs: OBD Tx/Rx, RS232 Tx/Rx, Power
    Operating voltage: 12V, internal protection from short circuits/overvoltages
    Nominal idle current: 45 mA
    Description:
    OBD-II Software for ELM327 is a free program that allows you to use your PC and a hardware interface to get the information from your car's computer.
    The program is very user-friendly, and easy to learn. It is also very easy to install: simply extract the files into a folder on your computer's hard drive, and you're ready to go. To uninstall the program, simply delete the entire contents of the folder where the program resides.
    The software supports two platforms - DOS and Windows.
    Features:
    The program lets you perform the following operations:
    Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
    Clear trouble codes and turn off the MIL ("Check Engine" light)
    Display current sensor data, including:
    Engine RPM
    Calculated Load Value
    Coolant Temperature
    Fuel System Status
    Vehicle Speed
    Short Term Fuel Trim
    Long Term Fuel Trim
    Intake Manifold Pressure
    Timing Advance
    Intake Air Temperature
    Air Flow Rate
    Absolute Throttle Position
    Oxygen sensor voltages/associated short term fuel trims
    Fuel System status
    Fuel Pressure
    Many others...
    Upcoming Features:
    Data graphing and logging
    Freeze Frame data
    Continuous and Non-Continuous Oxygen Sensor test results
    Free software:
    Scantool.net
    GM Mode 22 Scan Tool by Terry
    OBD Gauge for PalmOS and Pocket PC by Dana Peters
    OBD Logger by Jonathan Senkerik
    OBD-II ScanMaster by Wladimir Gurskij (ScanMaster 3.52 - local copy)
    obd2crazy.com
    OBD2 Scantool by Ivan Andrewjeski
    OBDII for ELM322 by David Huffman
    pyOBD by Donour Sizemore for MacOSX and Linux
    RDDTC by Pete Calinski
    Real Scan by Brent Harris
    ScanTest for Pocket PC by Ivan Ganev aka a-ser
    wOBD by WDT
深圳市鑫合利科技有限公司是致力于工控系统,嵌入式系统,车载系统,智能化系统以及网络计算机等领域的拓展的厂商,专门研发、生产和代理计算机系统网络产品的专业厂商,与国内外知名的厂商具有良好的战略合作关系,是国内第一个车载电脑CarPC…  更多>>
深圳市鑫合利科技有限公司
联系人:熊言寒
地址:深圳市南山区科技园汇景豪苑海逸阁21E
邮编:518057
电话:0755-26583455
传真:0755-26583595
公司网址:http://www.hopely.net/
  • 夏生 在2011/7/4 18:30:00留言
  • 详细留言:要具体了解下。
