新汉电脑股份有限公司
  • 新汉PEAK 735VL2:Intel® Socket 478 Pentium® 4 处理器可达3.2 GHz 400/533/800 MHz FSB
  • 发布时间:2007/7/17 16:34:18   修改时间:2009/4/7 15:54:43 浏览次数:3830
  •  主要特点
     Socket 478 for Intel? Pentium? 4 处理器可达3.2 GHz with 400/533/800 MHz FSB
     Intel? 865GV/ICH5 芯片组
     2 x 184-pin DIMM, 支持 DDR 266/333/400 SDRAM Memory up to 2 GB
     Intel? 82547EI 千兆网& Intel? 82551 QM 以太网
     2 x Serial ATA
     2 x USB 2.0
      规格
    CPU
      Intel? Pentium? 4 or Celeron? (D) processor in the mPGA478 package
      FSB: 800/533/400MHz
      CPU support up to 3.4GHZ (Intel Desktop Processor) and Up to 3.0GHZ (Intel Embedded Processor)
      Supports Hyper- Threading technology
    内存
      2 x 184-pin DIMM, supports DDR 266/333/400 memory up to 2 GB
      Dual 64-bit DDR channels, 3.2 GB/s bandwidth per channel
      Supports un-buffered and non-ECC DIMMs only
    芯片组
      Intel? 865GV (GMCH) (Intel? 865G for RoHS Version)
      Intel? ICH5 (I/O controller Hub)
    BIOS
      Award System BIOS
      Plug & Play support
      Advanced Power Management support
      ACPI (Advanced Configuration &Power Interface) support
      4 Mbit flash ROM
    网络
      Intel? 82547EI Gigabit Ethernet controller (dedicated by CSA port directly from the Intel? 865GV GMCH) and 1 x Intel? 82551QM 10/100 Ethernet controller for PEAK 735VL2G
      Single Intel? 82551QM 10/100 Fast Ethernet controller for PEAK 735VL
      Compliant with IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3y, IEEE 802.3ab
      2 x RJ45 with LED
    显示
      Intel? 865GV (GMCH) chipset with integrated graphics controller
      Hardware motion compensation assist for software MPEG/DVD decoding
      Access system memory
      1 x 15-pin CRT connector
    I/O
      2 x On-board USB port, USB 2.0 compliant
      Ultra ATA 100/66/33 support, 2 x 40-pin connector, 2-pin power connector for DOM (Disk On Module)
      Serial ATA support, 2 x SATA connector, data transfer bandwidth up to 150 MB/s
      ITE 8712F-A Super I/O
      2 x SIO , with 16C550 UARTs, 10-pin header
      1 x PIO, bi-directional, EPP/ECP support, 26-pin connector
      Floppy disk controller: 1 x 34-pin connector1 x 6-pin mini DIN connector , for PS/2 Keyboard/Mouse, 1 x 5-pin connector (for external keyboard)
      1 x On-board buzzer
      GPIO (4 in, 4 out)
      1 x On-board 2-pin header for I2C
      1 x On-board 5-pin header for IrDA
      On-board 2-pin header for reset SW, 4-pin for speaker, 5-pin for keylock, 2-pin for IDE active LED, 2-pin ATX power SW
      One 3-pin power header for 3-pin power cable connect to backplane board to support ATX power on function.
      On-board 4-pin additional power source input
    看门狗
      Watchdog timeout can be programmed by software from 1, 2, 4, 8, 16, 32,…...256 seconds
    板载RTC
      On-chip RTC with battery back up
      1 x External Li Battery
    ISA
      ITE 8888F x 1 PCI to ISA Bridge
      Provides 64 mA high driving capability to maximize ISA signals and supports up to 20 ISA cards on the backplane ISA Slot
    系统监控
      Derived from Super I/O ITE 8712F-A to support system monitor.
      8 voltage (For+1.5 V, +3.3 V, +5 V, -5 V, +12 V, -12 V, Vcore and +5 Vsb)
      2 fan speed (one is for CPU, one is for system)
      2 temperature (one is for internal CPU, one is for external system)
      2 temperature sensor (one is for internal CPU, one is for external system)
    电源需求
      CPU : 3.0 GHz
      +12 V: 6.5 A
      +5 V: 5.4 A
      +3.3 V: 0.5 A
      +5 Vsb: 0.5 A
      CPU : 2.4 GHz
      +12 V: 4.5 A
      +5 V: 4 A
      +3.3 V: 0.5 A
      +5 Vsb: 0.5 A
    尺寸
      338.58 mm (L) x 122 mm (W)
    环境
      Board level operating temperature: 0°C to 60°C
      Storage temperature: -20°C to 80°C
      Relative humidity: 10% to 90% (Non-condensing)
    认证
      CE approval
      FCC Class A
新汉电脑股份有限公司(NEXCOM International Co.,Ltd.)成立于1992年, 在工业计算机领域,至今已拥有领导产业的三大产品线:嵌入式工业计算机,网络安全以及刀片服务器。籍由顶尖技术的专业IT团队,高品质的设计和制造能力,多运算平台构架,人机界面工…  更多>>
新汉电脑股份有限公司
联系人:norachu
地址:北京海淀区北清路68号院用友软件园北区16号楼A座1F&2F
邮编:100094
电话:010-57042680
传真:010-57042681
公司网址:http://www.nexcom.cn
  • 徐泳格 在2025/4/21 16:47:00留言
  • 详细留言:NISE4000P4E系统(Nexcom)工业计算机
  • Eric Jones 在2024/9/25 1:38:00留言
  • 详细留言:Dear cechina.cn Webmaster! this is Eric and I ran across cechina.cn a few minutes ago. Looks great… but now what? By that I mean, when someone like me finds your website – either through Search or just bouncing around – what happens next? Do you get a lot of leads from your site, or at least enough to make you happy? Honestly, most business websites fall a bit short when it comes to generating paying customers. Studies show that 70% of a site’s visitors disappear and are gone forever after just a moment. Here’s an idea… How about making it really EASY for every visitor who shows up to get a personal phone call you as soon as they hit your site… You can – Web Visitors Into Leads is a software widget that’s works on your site, ready to capture any visitor’s Name, Email address and Phone Number. It signals you the moment they let you know they’re interested – so that you can talk to that lead while they’re literally looking over your site. CLICK HERE https://rushleadgeneration.com to try out a Live Demo with Web Visitors Into Leads now to see exactly how it works. You’ll be amazed - the difference between contacting someone within 5 minutes versus a half-hour or more later could increase your results 100-fold. It gets even better… once you’ve captured their phone number, with our new SMS Text With Lead feature, you can automatically start a text (SMS) conversation. That way, even if you don’t close a deal right away, you can follow up with text messages for new offers, content links, even just how you doing? notes to build a relationship. Pretty sweet – AND effective. CLICK HERE https://rushleadgeneration.com to discover what Web Visitors Into Leads can do for your business. You could be converting up to 100X more leads today! Eric PS: Web Visitors Into Leads offers a FREE 14 days trial – and it even includes International Long Distance Calling. You have customers waiting to talk with you right now… don’t keep them waiting. CLICK HERE https://rushleadgeneration.com to try Web Visitors Into Leads now. If you'd like to unsubscribe click here https://rushleadgeneration.com/unsubscribe.aspx?d=cechina.cn
  • 黄工 在2022/10/9 17:39:00留言
  • 详细留言:操作椅触摸屏电脑主机,NEXCOM NISE2110,数量4台,需咨询价格,请邮件回复,谢谢!
  • 丘桐 在2021/8/24 9:26:00留言
  • 详细留言:咨询贵公司电脑的价格
  • JOJO 在2021/8/23 16:49:00留言
  • 详细留言:咨询价格
