新汉电脑股份有限公司
  • 新汉PEAK 760VL2:Intel® LGA775 Pentium® 4/ Celeron® D with PCI Express 和 2 x 千兆网
  • 发布时间:2007/7/17 16:35:36   修改时间:2009/4/7 15:54:29 浏览次数:2909
  • 主要特点
    单槽 LGA775, 支持 Intel? Pentium? 4533/800 MHz FSB up to 3.8 GHz
    4 x DDR2 240-pin DIMM, 支持双通道DDR2 400/533 MHz up to 4 GB
    2 x Intel? 82573L PCI Express 千兆网
    4 x SATA, 6 x USB 2.0, 2 x COM
    符合RoHS 规范
     规格
    CPU
      Single socket LGA775
      Supports Intel? Pentium 4 with 533/800 MHz FSB for speeds up to 3.8 GHz
      Supports Hyper-Threading Technology
    内存
      4 x 240-pin DIMM sockets, up to 4 GB Dual channel non-ECC DDR2 400/533 MHz
    Note: 4 GB is a maximum spec according to the chipset, but due to I/O address issues, the actual memory support size might not reach the 4 GB maximum
    芯片组
      Intel? 915GV +ICH6 chipset
    BIOS
      Award System BIOS
    支持即插即用
      Advanced Power Management and Advanced Configuration & Power Interface support
    网络
      2 x Intel? 82573L PCI Express Gigabit Ethernet LAN
      2-pin header for extended LAN LED
      Supports Boot From LAN (PXE)
      Supports Wake On LAN (When 5Vsb power available)
    显示
      Chipset w/built-in integrated graphics device
      Analog display supports up to 2048 x 1536 @ 85 Hz CRT
    I/O
      USB 2.0: 6 x USB 2.0, with 1x6 JST, bandwidth: 480 Mb/s
      Serial port: 2 ports, with 2x5 box header , supports RS232 only
      Parallel port: 1 port, with 2x13 box-header
      PS2: 1 x Mini-DIN Keyboard/Mouse
    1 x 5-pin connector for external KB/ Mouse
      IDE:1 x 40-pin connector, support ultra ATA 100/66/33
      SATA: 4 ports, bandwidth: 150 MB/s
      Floppy: 1 x 34-pin connector
      Digital I/O Port: 4 in, 4 out with TTL level interface
      1 x on-board buzzer /1 x 4-pin for speaker/1 x 2-pin power-on button switch/1 x 2-pin header for SMBus 2.0
      1 x 4-pin fan JST (for CPU); 2 x 3-pin fan JST (for System)
      1 x 5-pin connector for chassis or backplane front keyboard
      I/O on bracket
    1 x VGA DB-15 connector
    2 x RJ45 GbE port
    1 x Mini-DIN for Keyboard/Mouse
    看门狗
      1-minute increments from 1 to 255 minutes
      1-second increments from 1 to 255 seconds
    板载RTC
      On-chip RTC with battery backup
      1 x External Li Battery
    板载模块
      Disk On Module: 1 x 2-pin power connector for DOM
    ISA
      Through PCI to ISA Interface
      No ISA Master Device Support. / No Support for ISA DMA
      Maximum of 3 ISA slots supported
    系统监控
      System monitor controller from Super I/O
      8 voltage (For +1.5 V, +3.3 V, +5 V, -5 V, +12 V, -12 V, Vcore and +5 Vsb)
      2 temperature (For CPU and system)
      3 fan speed monitors (one for CPU and 2 for systems)
    电源输入
      Power source from backplane through PCI/ISA Golden Finger
      Supports both AT or ATX Power Supplies (Automatically)
      +3.3 V is converted from +5 V and not directly from backplane or power supply
      +5 Vsb (Standby power) is connected from backplane via a 3-pin connector
      4-pin +12 V Power Input Connector
    电源需求
      5 V : 20 A
      12 V: 15 A
      5 Vsb : 1.5 A
    尺寸
      338.58 mm (L) x 122 mm (W)
    环境
      Board level operating temperature: 0°C to 60°C
      Storage temperature: -20°C to 80°C
      Relative humidity: 10% to 90% (Non-condensing)
    认证
      CE approval
      FCC Class A
新汉电脑股份有限公司(NEXCOM International Co.,Ltd.)成立于1992年, 在工业计算机领域,至今已拥有领导产业的三大产品线:嵌入式工业计算机,网络安全以及刀片服务器。籍由顶尖技术的专业IT团队,高品质的设计和制造能力,多运算平台构架,人机界面工…  更多>>
新汉电脑股份有限公司
联系人:norachu
地址:北京海淀区北清路68号院用友软件园北区16号楼A座1F&2F
邮编:100094
电话:010-57042680
传真:010-57042681
公司网址:http://www.nexcom.cn
  • 徐泳格 在2025/4/21 16:47:00留言
  • 详细留言:NISE4000P4E系统(Nexcom)工业计算机
  • Eric Jones 在2024/9/25 1:38:00留言
  • 详细留言:Dear cechina.cn Webmaster! this is Eric and I ran across cechina.cn a few minutes ago. Looks great… but now what? By that I mean, when someone like me finds your website – either through Search or just bouncing around – what happens next? Do you get a lot of leads from your site, or at least enough to make you happy? Honestly, most business websites fall a bit short when it comes to generating paying customers. Studies show that 70% of a site’s visitors disappear and are gone forever after just a moment. Here’s an idea… How about making it really EASY for every visitor who shows up to get a personal phone call you as soon as they hit your site… You can – Web Visitors Into Leads is a software widget that’s works on your site, ready to capture any visitor’s Name, Email address and Phone Number. It signals you the moment they let you know they’re interested – so that you can talk to that lead while they’re literally looking over your site. CLICK HERE https://rushleadgeneration.com to try out a Live Demo with Web Visitors Into Leads now to see exactly how it works. You’ll be amazed - the difference between contacting someone within 5 minutes versus a half-hour or more later could increase your results 100-fold. It gets even better… once you’ve captured their phone number, with our new SMS Text With Lead feature, you can automatically start a text (SMS) conversation. That way, even if you don’t close a deal right away, you can follow up with text messages for new offers, content links, even just how you doing? notes to build a relationship. Pretty sweet – AND effective. CLICK HERE https://rushleadgeneration.com to discover what Web Visitors Into Leads can do for your business. You could be converting up to 100X more leads today! Eric PS: Web Visitors Into Leads offers a FREE 14 days trial – and it even includes International Long Distance Calling. You have customers waiting to talk with you right now… don’t keep them waiting. CLICK HERE https://rushleadgeneration.com to try Web Visitors Into Leads now. If you'd like to unsubscribe click here https://rushleadgeneration.com/unsubscribe.aspx?d=cechina.cn
  • 黄工 在2022/10/9 17:39:00留言
  • 详细留言:操作椅触摸屏电脑主机,NEXCOM NISE2110,数量4台,需咨询价格,请邮件回复,谢谢!
  • 丘桐 在2021/8/24 9:26:00留言
  • 详细留言:咨询贵公司电脑的价格
  • JOJO 在2021/8/23 16:49:00留言
  • 详细留言:咨询价格
