新汉电脑股份有限公司
  • 新汉PEAK 765VL2:Intel® Core™ 2 Duo LGA775 带2 PCI Express千兆网 / SATA / VGA / USB2.0
  • 发布时间:2007/7/17 16:42:06   修改时间:2009/4/7 15:54:15 浏览次数:2900
  • 主要特点
    单槽LGA775, 支持 Intel? Core? 2 Duo533/800/1066 MHz FSB
    Intel? Q965 and ICH8 芯片组
    2 x 240-pin DIMM, 支持双通道533/667/800 MHz DDR2
    2 x Intel? 82573L PCI Express 千兆网
    4 x SATA, 6 x USB 2.0, 2 x COM
    规格
    CPU
      Supports Intel? LGA775 Core 2 Duo / Pentium? 4 / Pentium? D / Celeron? D processors
      Intel? Embedded Processors List (Intel? Longevity CPU)
    Intel? Core? 2 Duo Processor E6400 & E4300
    Intel? Pentium? 4 Processor 651 & 551
    Intel? Celeron? D Processor 352 & 341
    Intel? Celeron? Processor 440
      533/800/1066 MHz System Bus
    内存
      2 x 240-pin DIMM, support Dual channel 533/667/800 MHz SDRAM DDR2 memory up to 4 GB
    芯片组
      Intel? Q965 Graphics Memory Controller Hub (GMCH)
      Intel? 82801HB (ICH8) I/O Controller Hub
    BIOS
      Award System BIOS
      Plug & Play support
      8M-bit flash ROM
    网络
      2 x Intel? 82573L PCI Express Gigabit Ethernet LAN
      2 x RJ45 with LED
      Supports Boot From LAN (PXE)
      Supports Wake on LAN (When 5Vsb power available, and for LAN 2 only)
    显示
      Intel? Q965 GMCH Integrated Intel? GMA 3000
      Max 256 MB of DVMT for graphics memory
      CRT:
    1 x DB15 VGA connector
    Resolution up to 2048 x 1536
    I/O
      USB 2.0: 6 ports, 2 ports through I/O bracket, 4 ports through 1x6 JST
      Serial port: 2 ports, with 2x5 box header(2.0mm) , supports RS232 only
      Parallel port: 1 port, with 2x13 box-header(2.0mm)
      PS2: 1 x 6-pin JST connector(2.0mm) for KB/ Mouse
      Fan: 4-pin wafer for CPU; 3-pin wafer for System; 3-pin wafer for MCH
      2-pin header for SMB; 2-pin header for reset; 2-pin headerfor power on switch
      2-pin header for power LED; 2-pin header for HDD LED
      On-board buzzer / IrDA (share with COM2)
      I/O on bracket
    2 x RJ45 GbE port
    2 x USB2.0
    存储
      SATA: 4 ports
    看门狗
      Watchdog timeout can be programmable by Software from 1 second to 255 seconds
      Tolerance 15% under room temperature 25°C
    板载RTC
      On-chip RTC with battery backup
      1 x External Li Battery
      Torrance less than 2sec (24 hours) under 25?C
    ISA
      Through PCI to ISA Interface (ITE 8888)
      No ISA Master Devices but ISA DMA Devices
      Maximize ISA Slot support up to 3 only
    系统监控
      4 voltage (For +3.3V, +5V, +12V, Vcore)
      3 Temperatures (CPU, two external Temperature Sensor)
      3 FANs speed (CPU, System and MCH FANs)
    电源
      Power source from backplane through PCI/ISA Golden Finger
      Supports both AT or ATX Power Supplies (Automatically, BIOS default :AT Mode)
      When change to ATX, the BIOS default setting is as follow: POWER -SUPPLY
    TYPE--> [ATX]
    AUTO PWR-FAILURE RESUME -->[ON]
      +3.3V is Converted from +5V and not directly from Backplane or Power Supply
      +5Vsb (Standby power) is connected from Backplane through 3pins Connectors
      4 Pins +12V Power Input Connector
    尺寸
      338.58 mm (L) x 122 mm (W)
    环境
      Board level operating temperature: 0°C to 60°C
      Storage temperature: -20°C to 85°C
      Relative humidity: 10% to 90% (Non-condensing) Non-operating 5%~95%, non-condensing
    认证
      CE approval
      FCC Class A
新汉电脑股份有限公司(NEXCOM International Co.,Ltd.)成立于1992年, 在工业计算机领域,至今已拥有领导产业的三大产品线:嵌入式工业计算机,网络安全以及刀片服务器。籍由顶尖技术的专业IT团队,高品质的设计和制造能力,多运算平台构架,人机界面工…  更多>>
新汉电脑股份有限公司
联系人:norachu
地址:北京海淀区北清路68号院用友软件园北区16号楼A座1F&2F
邮编:100094
电话:010-57042680
传真:010-57042681
公司网址:http://www.nexcom.cn
  • Eric Jones 在2024/9/25 1:38:00留言
  • 详细留言:Dear cechina.cn Webmaster! this is Eric and I ran across cechina.cn a few minutes ago. Looks great… but now what? By that I mean, when someone like me finds your website – either through Search or just bouncing around – what happens next? Do you get a lot of leads from your site, or at least enough to make you happy? Honestly, most business websites fall a bit short when it comes to generating paying customers. Studies show that 70% of a site’s visitors disappear and are gone forever after just a moment. Here’s an idea… How about making it really EASY for every visitor who shows up to get a personal phone call you as soon as they hit your site… You can – Web Visitors Into Leads is a software widget that’s works on your site, ready to capture any visitor’s Name, Email address and Phone Number. It signals you the moment they let you know they’re interested – so that you can talk to that lead while they’re literally looking over your site. CLICK HERE https://rushleadgeneration.com to try out a Live Demo with Web Visitors Into Leads now to see exactly how it works. You’ll be amazed - the difference between contacting someone within 5 minutes versus a half-hour or more later could increase your results 100-fold. It gets even better… once you’ve captured their phone number, with our new SMS Text With Lead feature, you can automatically start a text (SMS) conversation. That way, even if you don’t close a deal right away, you can follow up with text messages for new offers, content links, even just how you doing? notes to build a relationship. Pretty sweet – AND effective. CLICK HERE https://rushleadgeneration.com to discover what Web Visitors Into Leads can do for your business. You could be converting up to 100X more leads today! Eric PS: Web Visitors Into Leads offers a FREE 14 days trial – and it even includes International Long Distance Calling. You have customers waiting to talk with you right now… don’t keep them waiting. CLICK HERE https://rushleadgeneration.com to try Web Visitors Into Leads now. If you'd like to unsubscribe click here https://rushleadgeneration.com/unsubscribe.aspx?d=cechina.cn
  • 黄工 在2022/10/9 17:39:00留言
  • 详细留言:操作椅触摸屏电脑主机,NEXCOM NISE2110,数量4台,需咨询价格,请邮件回复,谢谢!
  • 丘桐 在2021/8/24 9:26:00留言
  • 详细留言:咨询贵公司电脑的价格
  • JOJO 在2021/8/23 16:49:00留言
  • 详细留言:咨询价格
  • MATHIYALAGAN KUPPUSA 在2020/11/5 11:57:00留言
  • 详细留言:New Han NISE3100e series of industry-specific machines
