新汉电脑股份有限公司
  • 新汉PEAK 7220VL2G:Intel® 插槽604 Dual Xeon®/LV Xeon® 处理器可达2.8 GHz,400/533 MHz FSB
  • 发布时间:2007/7/20 16:25:36   修改时间:2009/4/7 15:53:49 浏览次数:3786
  • 主要特点
    604插槽,Dual Intel? Xeon?/LV Xeon? 处理器可达 2.8 GHz , 400/533 MHz FSB
    184-pin DIMM x 4 , 支持DDR 200/266 SDRAM 内存可达 8 GB
    Intel? E7501/P64H2 芯片组
    ATI Rage? XL VGA, 8 MB Frame Buffer 内存
    2 x Intel? 82545GM千兆网
    可客制化的2U 散热器/风扇,适用Dual Xeon 处理器
    规格
    CPU
    Supports Socket 604 Dual Intel? Xeon?/LV Xeon? processors up to 2.8 GHz with 400/533 MHz FSB or LV Xeon? up to 2.4 GHz with 400/533 MHz FSB
    2 x On-board intelligent switching type power regulator
    Supports streaming SIMD instruction
    Supports uni-processor implementation
    Supports Hyper-Threading technology
    内存
    Four 184-pin DIMM sockets for up to 8 GB Registered ECC DDR 200/266 SDRAM
    Support twos 64-bit DDR channels
    芯片组
    Intel? E7501
    Intel? ICH3-S (82801CA)
    Intel? P64H2 (82870P2)
    Intel? Firmware Hub (FWH)
    BIOS
    Award System BIOS
    Plug & Play support
    Advanced Power Management support
    ACPI 2.0 compliant
    8 Mbit flash ROM
    网络
    2 x Intel? 82545EM (82545GM for RoHS Model) Gigabit Ethernet controllers
    2 x RJ45 with LED
    显示
    ATI Rage? XL with 8 MB frame buffer memory
    1 x 15-pin CRT connector
    I/O
    4 x on-board USB port
    SMBus 2.0 controller
    FWH interface/LPC interface/ AC’ 97 2.0 interface
    USB 1.1 compliant
    Integrated System Management Controller
    ITE 8712F-A super I/O
    SIO: 2 ports with 2x5 pin header
    PIO: 1 x 26-pin connector, Bi-directional, EPP/ECP
    Floppy Disk port: 1 x 34-pin connector
    PS/2 Keyboard/Mouse port: 1 x 6-pin mini DIN connector , 1 x 5-pin connector (for external keyboard)
    1 x On-board buzzer
    GPIO x 8 (4 in, 4 out)
    1 x on-board 2-pin header for I2C
    1 x on-board 2-pin header for reset SW/ 1 x 2-pin for IDE active LED/1 x2-pin ATX power SW
    1 x 3-pin power header for 3-pin power cable to connect to backplane board to support ATX power on function.
    Extra on-board 4-pin power source input
    AC’ 97 output, 1 x 10-pin header
    I/O On Bracket
    1 x VGA DB-15 connector
    2 x RJ45 Gigabit Ethernet LAN port
    1 x Mini-DIN for Keyboard/Mouse
    4 x USB 1.0 ports
    看门狗
    Programmable Watchdog Timer from 1, 2, 4, 8,16, 32,…...256 seconds
    板载RTC
    On-chip RTC with battery backup
    1 x External battery
    板载模块
    HDD: 2 x 40-pin connector ; Ultra DMA 33/66/100 support
    IDE active LED: 1 x 2-pin header
    ISA
    1 x ITE 8888 PCI to ISA Bridge
    Provides 64 mA high driving capability to maximize ISA signals for support for up to 20 ISA cards on the backplane ISA Slot
    系统监控
    Derived from Super I/O ITE 8712F-A to support system monitor
    8 voltage (For +1.5 V, +3.3 V, +5 V, -5 V, +12 V, -12 V, Vcore and Vcc 5 V Standby)
    One for CPU fan speed
    Two temperature (one for CPU, another for external system use)
    电源
    Power source from backplane through PCI/ISA golden finger
    Supports both AT or ATX power supplies
    +3.3 V is converted from +5 V and not directly from backplane or power supply
    +5 Vsb (standby power) available from backplane through 3-pin connector
    4-pin +12 V power input connector
    尺寸
    338.58 mm (L) x 122 mm (W)
    环境
    Operating temperature: 0°C to 60°C (0°C to 50°C for 2.8 GHz CPU or above)
    Storage temperature: -20°C to 80°C
    Relative humidity: 10% to 90% (Non-condensing)
    认证
    CE approval
    FCC Class A
新汉电脑股份有限公司(NEXCOM International Co.,Ltd.)成立于1992年, 在工业计算机领域,至今已拥有领导产业的三大产品线:嵌入式工业计算机,网络安全以及刀片服务器。籍由顶尖技术的专业IT团队,高品质的设计和制造能力,多运算平台构架,人机界面工…  更多>>
新汉电脑股份有限公司
联系人:norachu
地址:北京海淀区北清路68号院用友软件园北区16号楼A座1F&2F
邮编:100094
电话:010-57042680
传真:010-57042681
公司网址:http://www.nexcom.cn
  • 徐泳格 在2025/4/21 16:47:00留言
  • 详细留言:NISE4000P4E系统(Nexcom)工业计算机
  • Eric Jones 在2024/9/25 1:38:00留言
  • 详细留言:Dear cechina.cn Webmaster! this is Eric and I ran across cechina.cn a few minutes ago. Looks great… but now what? By that I mean, when someone like me finds your website – either through Search or just bouncing around – what happens next? Do you get a lot of leads from your site, or at least enough to make you happy? Honestly, most business websites fall a bit short when it comes to generating paying customers. Studies show that 70% of a site’s visitors disappear and are gone forever after just a moment. Here’s an idea… How about making it really EASY for every visitor who shows up to get a personal phone call you as soon as they hit your site… You can – Web Visitors Into Leads is a software widget that’s works on your site, ready to capture any visitor’s Name, Email address and Phone Number. It signals you the moment they let you know they’re interested – so that you can talk to that lead while they’re literally looking over your site. CLICK HERE https://rushleadgeneration.com to try out a Live Demo with Web Visitors Into Leads now to see exactly how it works. You’ll be amazed - the difference between contacting someone within 5 minutes versus a half-hour or more later could increase your results 100-fold. It gets even better… once you’ve captured their phone number, with our new SMS Text With Lead feature, you can automatically start a text (SMS) conversation. That way, even if you don’t close a deal right away, you can follow up with text messages for new offers, content links, even just how you doing? notes to build a relationship. Pretty sweet – AND effective. CLICK HERE https://rushleadgeneration.com to discover what Web Visitors Into Leads can do for your business. You could be converting up to 100X more leads today! Eric PS: Web Visitors Into Leads offers a FREE 14 days trial – and it even includes International Long Distance Calling. You have customers waiting to talk with you right now… don’t keep them waiting. CLICK HERE https://rushleadgeneration.com to try Web Visitors Into Leads now. If you'd like to unsubscribe click here https://rushleadgeneration.com/unsubscribe.aspx?d=cechina.cn
  • 黄工 在2022/10/9 17:39:00留言
  • 详细留言:操作椅触摸屏电脑主机,NEXCOM NISE2110,数量4台,需咨询价格,请邮件回复,谢谢!
  • 丘桐 在2021/8/24 9:26:00留言
  • 详细留言:咨询贵公司电脑的价格
  • JOJO 在2021/8/23 16:49:00留言
  • 详细留言:咨询价格
