.三菱PLC:
A1SJ71QE71N-B2 , AJ61QBT11 , AJ72QBR15 ,
AJ72QLP25G , AJ72QLP25 , AJ71QBR11 , AJ71QLP21G
, AJ71QLP21S , AJ71QLP21 , AJ71QC24N-R4 ,
AJ71QC24N-R2 , AJ71QC24N, AJ71QC24-R4 ,
AJ71QC24-R2 , AJ71QC24 , AJ71QE71N-B5T ,
AJ71QE71N-B2 , A61RP , A1S38HB , A38HB , A68RB
, A37RHB ,A33RB ,AJ71AR21 , AJ71AP21 ,
AJ71E71-S3 , AJ71C22-S1 , AJ71UC24-S2 , AJ71UC24
, AD51H-S3 , AD75P3-S3 , AD75P2-S3 , AD75P1-S3
, AD72 , AD71TU , AD71-S2 ,A2ACPUP21 , A2ACPU
, A2ACPUR21-S1 , A2ACPUP21-S1 ,A2ACPU-S1 ,
A3ACPUR21 , A3ACPUP21 ,A3ACPU , QC100B , QC50B
, QC30B , QC12B , QC06B , QA1S68B , QA1S65B ,
QA1S38B , QA1S35B,QA1S33B,Q2MEM-1MBS,Q6BAT,
Q06HCPU-A , Q02HCPU-A,Q02CPU-A,QG60,QA65B,
QA1S68B,QA1S65B ,QJ71FL71-B2 , SW1IVD-AD51HP ,
QD51-R24, QD51 , QJ71CMO , QJ71C24-R2 ,QJ71C24
, QJ61BT11 , Q80BD-J71BR11 , Q80BD-J71LP21G ,
Q80BD-J71LP21-25 , QJ72BR15 , QJ71BR11 ,
QJ72LP25G , QJ72LP25-25 , QJ71LP21G , QJ71LP21-
25 , QJ71E71-100 , QJ71E71B2 ,QJ71E71 , QD70P8
, QD70P4, QD75M4 , QD75M2 , QD75M1 , QD75D4 ,
QD75D2 , QD75D1 ,QD75P4 , QD75P2, QD75P1 ,
QD62E , QD62D , QD62 , Q64TCRTBW , Q64TCRT ,
Q64TCTTBW,Q64TCTT,Q64RD,Q64TD ,Q68DAI,Q68DAV,
Q64DA,Q62DA,Q68ADI,Q68ADV,Q64AD,QI60 ,
A6CON3E , A6CON2E , A6CON1E , A6CON3 , A6CON2,
A6CON1,QX48Y57,QH42P,QY81P,QY80,QY71,QY70 ,
QY68A,QY50 ,QY42P,QY41P,QY40P,QY22,QY18A,
QY10,QX81,QX80,QX72,QX71,QX70,QX42-S1 ,QX42
,QX41-S1,QX41,QX40-S1,QX40,QX28,QX10,MX
LINK-E ,MX COMPONENT,GX-CONFIG. - SC,GX-CONFIG.
- QP,GX-CONFIG. - PT,GX-CONFIG. - FL, AJ71PT32-
S3, A7BDE-J71AR21, A7BDE-J71AP21, AJ72T25B ,
AJ71AT21B , AJ72R25, AJ72P25,A616DAV, A62DA-S1
, A62DA, A68DAI-S1, A68DAV, A60MXT,A616TD,
A60MXR, A60MX, A616AD, A68ADN, A68AD, AH42 ,
A42XY,AY82EP, AY81EP, AY81, AY80, AY72,AY71,
AY70, AY60S, AY60E, AY60,AY51-S1, AY51, AY50
, AY42-S3, AY42-S1, AY42, AY41P, AY41 , AY40P
, AY40A , AY40 , AY23 , AY22 , AY13E , AY13
,AY11E , AY11A , AY11 , AY10A , AY10 , AX82
,6KHROM, AX81 , AX80E , AX80 , AX71 , AX70 ,
AX60-S1 , AX50-S1 , AX42-S1 , AX42, AX41-S1 ,
AX41 , AX40 , AX21 , AX20 ,AX11 , AX10 ,
A6BSW-P-S5 , A6BSW-P-S4 , A6BSW-P-S3 , 256KWROM
, 128KWROM , 64KWROM , 4KEROM , 16KQROM,
16KROM ,8KROM , 4KROM , 16KRAM , 4KRAM ,
A3NMCA-56 , A3NMCA-40 , A3NMCA-24 , A3NMCA-16 ,
A3NMCA-8 , A3NMCA-4 , A3NMCA-2 , A3NMCA-0 ,
A68P , A66P , A65P , A63P , A62P , A61P ,
A68B , A65B , A62B , A58B , A55B ,A52B,A38B,
A35B,A32B,A0J2HCPU,A1NCPUR21,A1NCPUP21,A1NCPU
, A2NCPUR21,A2NCPUP21,A2NCPU,A2NCPUR21-S1,
A2NCPUP21-S1,A2NCPU-S1,A3NCPUR21,A3NCPUP21,
A3NCPU,A2ACPUR21,AJ71QC24N-R2,AJ71QC24N ,
AJ71QC24-R4,AJ71QC24-R2,AJ71QC24,AJ71QE71N-B5T,
AJ71QE71N-B2,A61RP,A1S38HB, A38HB , A68RB ,
A37RHB , A33RB ,AJ71AR21 , AJ71AP21 , AJ71E71-
S3 , AJ71C22-S1 , AJ71UC24-S2 , AJ71UC24 ,
AD51H-S3 , AD75P3-S3 , AD75P2-S3 , AD75P1-S3 ,
AD72 , AD71TU , AD71-S2 , AD61S1 , AD61 ,
A84AD , A68RD4, A68RD3, AC12MX , A616DAI ,
A32RB, Q2ASHCPU , Q2ASHCPU-S1 , Q2ASCPU ,
Q2ASCPU-S1 , Q2AHCPU , Q2AHCPU-S1 , Q2ACPU ,
Q2ACPU-S1 , Q3ACPU , Q4ACPU , Q4ARCPU , A6SW32
, A6SW16 , AC30R2 , AC30R4 , AC300R4, AC20R4-
A8PU , A8PUE , A7PU ,AG62 , AG60 , AS91 ,
A6FD , A11VC , AI61 , AJ61BT11 , A6BR10-DC,
A6BR10, AJ71BR11 , AJ71LP21GE , AJ71LP21G ,
AJ71LP21 ,Q68B , Q65B , Q63B , Q312B , Q38B ,
Q35B , Q33B , Q25PHCPU , Q12PHCPU , Q25HCPU
,Q12HCPU, Q06HCPU,Q02HCPU, Q02CPU, Q01CPU, Q00CPU,
Q00JCPU, AC50TB, AC30TB, AC20TB ,AC10TB, AC05TB,
A6TBX70-E, A6TBY54-E, A6TBX54-E, A6TBY36-E,
A6TBX36-E, A6TBX70, A6TBXY54, A6TBXY36 A1STA32-7,
A1STA32-3, A1STA32, AC100TE, AC50TE, AC30TE,
AC10TE, AC06TE, A6TE2-6SRN, A1SC50NB,A1SC30NB
A1SC07NB, A1SC05NB, A1SC60B, A1SC03B, A1SC01B,
A1SG62, A1SG60, A6BAT, A6CON3, A6CON2, A6CON1,
AC30R4-PUS, A7PUS, A2SWA-28P, A6WA-28P,
A1SJ71PB92D, A1SJ71PB96F, A1SJ71LP21GE, A1SD51S,
A1SJ71UC24-R4-S2 ,A1SJ71UC24-R2-S2, A1SJ71UC24-PRF,
A1SJ71UC24-R4, A1SJ71UC24-R2 ,A1SJ71T32-
S3,A1SJ71PT32-S3, A1SJ71E71-B5,A1SJ71E71-B2,
A1SJ72T25B, A1SJ71AT21B, A1SJ71AR21,A1SJ71AP21,
A1SJ71BR11,A1SJ71LP21,AJ55TB32-16DR,AJ55TB32-8DR,
AJ55TB32-4DR, AJ55TB32-16DT, AJ55TB32-8DT,AJ55TB32
-4DT,AJ55TB2-16R,AJ55TB2-8R, AJ55TB2-4R, AJ55TB2-
16T,AJ55TB 2-8T,AJ55TB2-4T,AJ55TB3-16D,AJ55TB3-
8D,AJ55TB3-4D, A1SJ51T64, A6CON-P520, A6CON-P514,
A6CON-P220, A6CON-P214, A6CVR-32, A6CVR-16, A6CVR-
8, A6CPA-WP1, A6CAP-DC1, AJ65SBT-62DA, AJ65SBT-
64AD, AJ65BT-64RD4, AJ65BT-64RD3, AJ65BT-68TD,
AJ65BT-64DAI, AJ65BT-64DAV ,AJ65BT-4AD, AJ65BT-G4,
AJ65BT-R2, AJ65BT-D75P2-S3, AJ65BT-D62D-S1, AJ65BT
-D62D, AJ65BT-D62, AJ65SBT-RPI-10B, AJ65SBT-RPI-
10A, AJ65SBT-RPT, A80BDE-J61BT13, A80BDE-J61BT11,
AJ65SBTCF1-32T,AJ65SBTCF1-32D, AJ65SBTB1-32T1
,AJ65SBTB1-16T1, AJ65SBTB1-32DT, AJ65SBTCF1-32DT,
AJ65SBTW4-16DT, AJ65SBTC4-16TD, AJ65SBTB1-8T,
AJ65SBTW4-16D ,AJ65SBTC4-16D, AJ65SBTC1-32DT1,
AJ65SBTC1-32DT, AJ65SBTC1-32T, AJ65SBTB1-32T,
AJ65SBTB1-16T, AJ65SBTC1-32D1 ,AJ65SBTC1-32D,
AJ65SBTB1-32D1, AJ65SBTB1-32D, AJ65SBTB1-16D1,
AJ65SBTB1-16D, AJ65BTB2-16DR, AJ65BTB2-16DT
,AJ65BTB1-16DT, AJ65BTB2-16R, AJ65BTC1-
32T,AJ65BTB2-16T,AJ65BTB1-16T,AJ65BTC1-
32D,AJ65BTB2-16D,AJ65BTB1-16D,AJ65SBTB1-
D,A1SJ61BT11,A1SI61, A1 SD62D, A1SD62E, A1SD62,
A1SD61, AD75TU, A1SD75M3,A1SD75M2, A1SD75M1
,A1SP60, A1SD75-C01H, A1SD75P3-S3, A1SD75P2-S3,
A1SD75P1-S3, A1SD71-S7, A1SD71-S6, A1SD71-S2,
A1SD70, A1S64TCRTBW-S1 ,A1S64TCRT-S1, A1S64TCTTBW-
S1, A1S64TCTT-S1, A1S62RD4, A1S62RD3, A1S68TD,
A1ST60, A1S68DAV, A1S68DAI, A1S62DA, A1S68AD,
A1S64AD, A1S66ADA, A1S63ADA, A1SX48Y58, A1SX48Y18,
A1SH42,A1SY28EU, A1SY18AEU, A1SY14EU, A1SY10EU,
A1SY81, A1SY80, A1SY71, A1SY68A, A1SY60, A1SY50,
A1SY42, A1SY41, A1SY40, A1SY28A, A1SY22, A1SY18A,
A1SY10, A1SX81-S1, A1SX20EU, A1SX10EU, A1SX81-S2,
A1SX81,A1SX80-S2, A1SX80-S1, A1SX80, A1SX71,
A1S42X, A1SX42-S2, A1SX42-S1, A1SX42, A1SX41-
S2,A1SX41-S1, A1SX41,A1SX40-S2, A1SX40-S1, A1SX40,
A1SX30, A1SX20, A1SX10, A1SG62, A1SG60, A1S63P,
A1S62PN, A1S61PN, A2SMCA-60KE,A2SMCA-30KP, A2SNMCA
-30KE, A2SMCA-14KP, A1SNMCA-8KE, A1SNMCA-2KE,
A1SNMCA-8KP,A1S68B-S1, A1S65B-S1, A1S58B-S1,
A1S55B-S1, A1S52B-S1, A1S38B ,A1S35B, A1S33B,
A1S32B, A1SJHCPU-S8, A1SJHCPU, A1SCPUC24-R2,
A2ASCPU-S60, A2USHCPU-S1, A2ASCPU-S1, A2ASCPU,
A2SHCPU-S1, A2SHCPU , A1SHCPU, FX2-16MT, FX2-24MT,
FX2-32MT, FX2-48MT, FX2-64MT, FX2-80MT, FX2-128MT,
FX2-24MR-D, FX2-48MR-D, FX2-64MR-D ,FX2-80MR-D,
FX2-16MR, FX2-24MR, FX2-32MR, FX2-48MR, FX2-64MR,
FX2-80MR, FX2-128MR,FX0N-8EYR, FX0N-8EX, FX0N-8ER,
FX0N-16EYT , FX0N-16EYR, FX0N-16EX, FX0N-40ET,
FX0N-40ER, FX0S-10MT-D, FX0S-14MT-D, FX0S-20MT-D,
FX0S-30MT-D, FX0S-10MR-D , FX0S-14MR-D, FX0S-20MR-
D, FX0S-30MR-D, FX0S-10MT, FX0S-14MT, FX0S-20MT,
FX0S-30MT,FX0S-10MR-001 , FX0S-14MR-001, FX0S-20MR
-001, FX0S-30MR-001, FX0N-24MT-D, FX0N-40MT-D,
FX0N-60MT-D, FX0N-24MR-D ,FX0N-40MR-D, FX0N-60MR-D,
FX0N-24MT, FX0N-40MT, FX0N-60MT, FX0N-24MR-001,
FX0N-40MR-001 , FX0N-60MR-001, FX1NC-32MT, FX1NC-
16MT, FX1N-EEPROM-8L, FX1S-10MT-D,FX1N-8AV-BD,
FX1N-485-BD , FX1N-422-BD, FX1N-232-BD, FX1N-24MT-
D, FX1N-40MT-D, FX1N-60MT-D, FX1N-24MR-D, FX1N-
40MR-D ,FX1N-60MR-D, FX1N-24MT, FX1N-40MT, FX1N-
60MT, FX1N-14MR-001, FX1N-24MR-001, FX1N-40MR-001,
FX1N-60MR-001, FX2N-16LNK, FX2N-32ASI-M, FX2N-
32CCL,FX2N-16CCL-M, F2-RS-5CAB, FX2N-RS-5CAB ,F2-
720RSV, FX2N-1RM-E-SET, FX-PCS-VPS/WIN-E, FX2N-
20GM, FX2N-10GM, FX2N-10PG-E, FX2N-1PG-E , FX2N-
232IF, FX2N-1HC, FX2N-2LC, FX2N-4AD-TC, FX2N-4AD-
PT, FX2N-8AD, FX2N-4AD, FX2N-4DA , FX2N-2AD, FX2N-
2DA,FX2N-422-BD, FX2N-485-BD, FX2N-232-BD, FX2N-
8AV-BD, FX2N-CNV-IF, FX2N-CNV-BC, FX2N-CNV-BD,
FX2N-16EYT, FX2N-16EYR, FX2N-16EX, FX2N-32ET, FX2N
-32ER, FX2N-48ET, FX2N-48ER , FX2NC-16MT, FX2NC-
32MT, FX2NC-64MT, FX2NC-96MT, FX2N-16MT, FX2N-
32MT,FX2N-48MT, FX2N-64MT , FX2N-80MT, FX2N-128MT,
FX2N-32MR-D, FX2N-48MR-D, FX2N-64MR-D, FX2N-80MR-D,
FX2N-16MR-001 ,FX2N-32MR-001, FX2N-48MR-001, FX2N
-64MR-001, FX2N-80MR-001 , FX2N-128MR-001
