通诚电子仪器有限公司
  • 调制信号发生器MG3670B MG3670C
  • 发布时间:2007/2/2 10:00:22   修改时间:2007/2/2 10:00:22 浏览次数:1303
    深圳银通仪器 谢小姐13724272334 83251855
    ★宽频带范围:300KHz~2.25GHz
    ★可通过后面板扩展连接器MG0301C/ 0302A/ 0305A/ 0307A/ 0311A调制单元扩展
    ★与日本,北美和欧洲的通信系统测量信号相兼容
    ★高调制精度(矢量误差≤1.8%rms)
    ★输出调制信号与每个通信系统匹配
    ★带数据编辑及倒频功能的内部图象发生器
    ★输出IS-95通道多路传输信号
    技术指标
    Carrierfrequency Frequency range 300kHz to 2250 MHz(mg3670B/C),300kHz to 2750MHz(MG3671A/B and MG3672A)
    Accuracy Dependson installed reference cscillator*^1
    Intemalreference oscillator Frequency:10MHz
    Start-up characteristics:≤1*10^-7/day(after 30 min.warm-up),≤5*10^-8/day(after60 min.warm-up)
    Aging rate:≤2*10^-8/day(after 24 h warm-up)
    Temperaturecharacteristics:Aging rate:≤±5*10^-8(0 °to 50℃)
    Extemalreference input 10 MHz or 13MHz(±10ppm),,2to 5 Vp-p,BNC connector(rear panel)
    Referenceoutput 10 MHz,2 to 5Vp-p,BNC connector(rearpanel)
    Output Levelrange*^2 -143 to +13 dBm(resolution:0.1dB)
    Frequency response ≤±dB(at0 dBm output)
    Level accuracy*^2 Outputlevel/frequency ≤1000MHz >1000MHz
    -33 to +13dBm ±1dB ±2dB
    -123 to -33.1dBm ±1.5dB ±2dB
    -136 to 123.4dBm ±3dB ±4dB
    Impedance 50Ω,N-typeconnctor
    Continuously varible level*^2 Continuouslyvariableoutput over 20dB rqnge(+8 to -12dB) in 0.1dB steps within upper and lowerlimlits of any output level
    Level unit dBm,dBμ,μV,mV,V(dBμ,μV,mV,Vselected terminate/open voltagedisplay)
    Interferenceraeiation ≤1μV*Measured 25 mm from cabinet(exceptrear pane)with two-turn 25 mm diameter loop antenna ,terminated with 50Ω load,≤+5dBmoutput ,CW
    Signal purity Spurious
    (at ≤+5 dBm output) ≤-65dBc(≥100kHz offset,≤±100MHz,≤-50dBc(≥100kHzoffset ,full band)
    ≤-40dBc (≥2.65 HGz,spurious at 5.4-Fout (carrier frequency)GHz],≤-30dBc (harmonics)
    SSB phase noise ≤-120dBc /Hz(100 kHz,offset,CW)
    Dingitalmodulation Intermal modulaton Dependson installed modulationunit(MG030C/0.02A/0.10A/0311A/0312A/0314A
    External
    modulation  ForMG3670B/C,MG3671A/B
    Any modulation using I/Q input signal
    Input frequency:DCto 1.2 MHz*^3
    Input level:sqr(I^2+Q^2)≤0.5 Vrms,BNC connector *I/Q≤1.5Vp-p(50Ω),I/Q≤10%to 100% of 1.5Vp-p(CMOS)
    Vector error:≤1.8%rsm (I/Q input level:1 Vrms/50Ω
    ,at ≤+5 dBm output
    For MG3672A
    50Ωinput
    Input frequency:DC to 30MHz(BW:3dB,18° to 30℃)
    Input level:sqr(I^2+Q^2)≤1.0 Vrms,I/Q≤1.5V p-p
    CMOSinput
    Input frequency:DC to 1.2 MHz,Input level:sqr(I^2+Q^2)≤1.0 Vrms,I/Q≤1.5Vp-p
    I/Q output OutputsI/Q signal at internal modulation(MG0310A/
    0305A/0307A/0310A/0311A/0312A/0314Ainstalled
    Pulse
    modulation Input TTL level,BNC connector,polarity selectable
    On/offratio ≥40 dB (at ≥0 dBm output)
    Transiton time ≤2μs,minimum pulse width:10μs
    Memory
    function  Frequency memory 1000carrier frequencies(save and recall)
    Pqrqmetermemory 100 pansettings(save and recall)
    Other
    function  Relativedisplay Carrier frequency.output level
    I/Q signal adjustment Varableoffset,balance,phase(only output)
    of I/Q input/output signal(DC to 1.2 MHz)
    Backup  Lastsettings stored at power-off
    Reverse power
    protecton  Maximum reverse input power:50W(<1000MHz)
    ±50Vdc
    GPB Allfunctions except power switch and panel
    lock switch controlled Interfacefunction:
    SH1,AH1,T6,L4,SR1,RL1,PP0,DC1,C0,EF2
    Operatingtermperatue 0 °to 50 ℃
    Power 100to 120/200 to 240 Vac (switchable)47.5 to 63Hz
    ≤550VA
    Dimensionsand mass (426±5)W*(221.5±4)H*(451±5)Dmm≤27kg
    EMC*^4 EN55011(1991,Group1, Class A),EN50082-1(1992)
    ,Harmonic curent emissionsEN61000-3-2(1995)
    Safety EN61010-1:1993(InstallationCategoryⅡ,
    Pollution DegreeⅡ)
    Model/OrderNo.
     Name
    MG3670B
    MG3670C
    MG3671A
    MG3671B
    MG3671A
    MG0301C
    MG0302A
    MG0303B
    MG0305A
    MG0307A
    MG0310A
    MG0311A
    MG0312A
    MG0314A
    J0576B
    J0127A
    J0017F
    B0325
    F0014
    F0012
    W0869AE
    W0932AE
    W0869BE
    W1462AE
    W0872AE
    W0691AE
    W1462AE
    W0872AE
    W0691AE
    W0851AE
    W0949AE
    W1183AE
    B0405A
    B0406A
    W1050AE
    W1412Ae
    B0416A
    B0418A
     Mainframe
    Digital Modulation Signal Generator
    Digital ModulationSignal Generator
    DigitalModulation Signal Generator
    Expansion units (factory installed)
    μ/4DQPSK Mdodulation Unit(for PDC,PDC_H,PHS,NADC and TFTS communication systems)
    GMSKModulation Unit(for GSM,PCN (DCS1800),and CT2 communication system)
    BurstFunction Unit (for PDC,PDC_H,PHS,NADC,TFTS,GSM,PCN(DCS1800),CT2,DECT communicationsystem)
    μ/4 DQPSK Modulation Unit(for PACS,WCPE,PHS communication system)
    QPSKModulation Unit
    W-CDMA Modulaiton Unit
    Standard accessories(for mainframe)
    Coaxialcord(N-P.5D-2W.N-P),1m:
    Power cord,2.5m
    Shieled cover for GPIB:
    Fuse,6.3A(for100 Vac power supply)
    Fuse,3.15A(for 200 Vac power supply)
    MG3670A/Boperation manual
    MG3671A/B operation manual
    MG3672B/C,MG3671A/B servicemanual
    MG3672A operation manual
    Standard accessories(for expansionunits)
    MG0301C/0303B operation manual
    MG0302A/0303B operation manual
    MG0305A/0303Boperation manual
    Mg0307A/0303B operation manual
    MG0310A operationmanual
    Exchange sheet for front panel
    Exchange sheet for real lpalnel
    Mg0312Aoperation manual
    Mg0314A operation manual
    Exchange front panel sheet
    Exchangerear panel sheet
    MG3670/3671/3672-01
    MG3670/3671/3672-02
    MG3670/3671/3672-03
    MG3670-20
    MG3670B/3671A-25
    MG0301C-22
    MG0302A-23
    J0127C
    J0003A
    J0576D
    J0004
    J0007
    J0008
    B0329D
    B0331D
    B0332
    B0333D
    B0334D
    MS8604A
    MT8801B
    MD1620B
    MD6420A
    MP1201C
    MS2602A
     1 pc
    2pcs
    1pc
    1pc
    2pcs
    2pcs
    1copy
    1copy
    1copy
    1copy
    1copy
    1copy
    1copy
    1copy
    1copy1pc
    1pc
    1copy
    1copy
    1pc
    1pc
    Model Start-upcharacteristics Aging rate Temperaturecharacteristic(0°to 50℃
    MG3670/3671/3672Option 01 7*10/day(after 30min.warm-up)
    3*10/day(after60min.warm-up)
     5*10/day(after 24-h warm-up) ±5*10/day
    MG3670/3671/3672 Option 02 2*10/day(after60min.warm-up) 2*10/day(after48-h warm-up) ±1.5*10/day
    MG3670/3671/3672Option 03 - 5*10/day(after48-h warm-up) ±5*10/day
    MG3670BOption 20 RF off release function(When RFis off,level setting is enabled.)
    MG0301COption 22 RHS LCCH super frame control patternfunction(artificial base station signal output for field strength measurement:APS connection test is impossible.)
    MG0302AOption23 CT2 MUX3 control pattern function
    MG3670B/3671A Option 25 Formatupgrade(enables MG0310A to be used in MG3670B/3671A
本公司是一家集仪器、仪表研发、生产、代理于一体的高科技企业。公司除电子仪器销售外,还有环境试验设备,分析仪器,质检仪器,计量仪器的销售及服务。现将部分产品介绍如下,如有需求,欢迎来电来函查询。1、电源线厂专用仪器和设备:二芯、…  更多>>
通诚电子仪器有限公司
联系人:谢冬梅
地址:深圳市福田区振华路
邮编:518031
电话:0755-83222025
传真:0755-83322550
公司网址:http://yintong.web.jonweb.net/
