通诚电子仪器有限公司
  • 矢量信号发生器SMIQ03
  • 发布时间:2007/2/2 10:13:39   修改时间:2007/2/2 10:13:39 浏览次数:1457
  • 矢量信号发生器SMIQ03
  • 矢量信号发生器SMIQ03
    深圳银通仪器 谢小姐13724272334 83251855
    Rohde SMIQ03 Measurements/Features
    Wireless comp Design & Test
    Manufacturing Test
    Mobile Phone Design and Test
    Base Station Design & Test
    Dig Video Comp & System Design
    Wideband CDMA Development
    Univesal modulation coder
    Fading simulator
    Rohde SMIQ03 Performance Characteristics
    Form Factor Benchtop
    Minimum Frequency 300 kHz
    Maximum Frequency 3.3 GHz
    Frequency Resolution 0.1 Hz
    Frequency Switching Time 15 ms
    Time base stability 0.000001 /yr
    External Frequency Reference 16 MHz
    Minimum Output Power -140 dBm
    Maximum Output Power 13 dBm
    Power Resolution 0.1 dB
    Output Impedance 50 Ohm
    Minimum Single-Side-Band Noise -135 dBc/Hz
    Maximum Single-Side-Band Noise -130 dBc/Hz
    Harmonics (noise) -30 dBc
    Non-harmonics (noise) -60 dBc
    Modulation AM,FM,Pulse
    External Modulation Inputs(Types) Yes
    Sweep Modes Linear,List,Log
    Rohde SMIQ03 Programmability/Connectivity
    User Interface Proprietary
    Ports to Peripheral Devices IEEE488
    Test Pattern Storage 50 Patterns
    Programming Language SCPI
    Rohde SMIQ03 Life Cycle Data
    Out of Production  Nov-01-2000
    Rohde SMIQ03 Compliance
    CE Compliance Not on file
    UL Compliance Not compliant
    Rohde SMIQ03 Power Requirements
    Input Power Universal (Auto Sense and Switch)
    Rohde SMIQ03 Physical Dimensions
    Width 435 mm(17.12 in)
    Height 192 mm(7.55 in)
    Length 460 mm(18.11 in)
    Weight 25 kg(55.11 lb)
本公司是一家集仪器、仪表研发、生产、代理于一体的高科技企业。公司除电子仪器销售外,还有环境试验设备,分析仪器,质检仪器,计量仪器的销售及服务。现将部分产品介绍如下,如有需求,欢迎来电来函查询。1、电源线厂专用仪器和设备:二芯、…  更多>>
通诚电子仪器有限公司
联系人:谢冬梅
地址:深圳市福田区振华路
邮编:518031
电话:0755-83222025
传真:0755-83322550
公司网址:http://yintong.web.jonweb.net/
