通诚电子仪器有限公司
  • 频率计 FC-7150 (韩国EZDLGLTAL)
  • 发布时间:2007/3/1 9:09:40   修改时间:2007/3/1 9:09:40 浏览次数:4944
    产品描述:频率计 FC-7150 (韩国EZDLGLTAL)
    产品名称:频率计 FC-7150
    制造厂家:韩国EZDLGLTAL
    产品简单介绍:Display: 9 digit large green LED display
    产品介绍
    Frequency measuring range : 0.1Hz to 150MHz in A input, 50MHz ~ 1.5GHz in C input
    Period / Total / RPM measurement for input A
    9 digit display with 0.01mHz resolution in 1 sec.
    High sensitivity external reference input function (higher than 20mVrms)
    Microprocessor controlled
    Reciprocal technique for high resolution at low counting frequency
    Self check function executed to perform an automatic self diagnosis of various counter function
    Push-scanning for selecting function and gate time
    Low-pass filter(100kHz, -3dB) installed for removing noise signal in low frequency measuring
    AC/DC coupling function (selectable X1 / X10 attenuator)
    Data hold function
    Optional RS-232C serial interface function for communication with computer
    产品功能描述
    Display:9 digit large green LED display(Overflow, gate time, mHz, Hz,kHz, MHz,
    ns, µs, s,hold)
    Range:0.1Hz~1.5GHz
    Gate time:0.01s, 0.1s, 1s, 10s
    Resolution:1nH~10Hz
    Accuracy:【 resolution 【 time base 【 1 count
    Terminal:A, C
    Sensitivity:20mVrms A, B input / 30mVrms C input
    Impedance :1Mз < 40pF A, B input / 50з C input
    Max. voltage:250Vrms A, B input / 3Vrms C input
    Attenuator:X 1, X 10 A, B input
    Slope A, B:+ or – selectable
    Trigger A:preset or variable
    Low pass filter:100kHz(-3dB) A, B input
    Period:10ms ~ 10s range with 1ps ~ 1ns resolution / 【 resolution 【
    trigger error 【 1 count accuracy
    Totalize:5Hz ~ 30MHz range / 0 ~ 999999999(Max)
    RPM:6 ~ 900 X 106 RPM
    Internal time base:10MHz TCO frequency, 3 X 10-7/ month, under 5 X 10-6 (0 + 50∩);
    temperature stability, under 1 X 10-7for 10% variation line voltage
    Frequency output:10MHz frequency / 2.5Vp-p amplitude / 500з impedance
    External input:10MHz frequency / 20mVrms ~ 5Vrms input level / 500з impedance
    Operating environments:0∩ ~ 50∩
    Range for guaranteed:25∩【 5∩
    Power requirement:AC 115 / 230V 【 10%, 50/60Hz
    Acessories:power cord, fuse, operation manual, BNC cable
    Factory optional sel:RS-232C interface / TCXO
本公司是一家集仪器、仪表研发、生产、代理于一体的高科技企业。公司除电子仪器销售外,还有环境试验设备,分析仪器,质检仪器,计量仪器的销售及服务。现将部分产品介绍如下,如有需求,欢迎来电来函查询。1、电源线厂专用仪器和设备:二芯、…  更多>>
通诚电子仪器有限公司
联系人:谢冬梅
地址:深圳市福田区振华路
邮编:518031
电话:0755-83222025
传真:0755-83322550
公司网址:http://yintong.web.jonweb.net/
