通诚电子仪器有限公司
  • 逻辑分析仪 HP1660CS
  • 发布时间:2007/3/3 10:46:14   修改时间:2007/3/3 10:46:14 浏览次数:1780
  • 逻辑分析仪 HP1660CS
  •  逻辑分析仪 HP1660CS
    产品名称: 逻辑分析仪 HP1660CS
    品  牌: HP
    产品型号: 1660CS
    产品指标: 100MHz-500MHz
    产品信息: 逻辑分析仪 HP1660CS
    频率范围:100MHz-500MHz
    主要功能:逻辑加示波器64CH
      The HP 1660CS 136-channel portable logic analyzer with oscilloscope helps you get to the root cause of problems quickly, and now at a new lower price. The ability to connect to an Ethernet LAN provides an easy method of sharing data within the design team and provides remote access to the logic analyzer from a PC or workstation. A built-in 540 megabyte hard disk drive combined with the LAN connectivity now makes it possible to use the HP B3740A software analyzer for source line referencing; this is the ability to see correlated high-level C++ source code with the inverse assembled state listing.
    It adds two 1-GSA/s digitizing scope channels for viewing the analog behavior of your signals. Both channels capture non-repeating events simultaneously with 8K samples per channel. Characterize critical timing parameters with time interval measurements of better than 150 ps accuracy, or examine glitches in your system to determine if noise or loading is a problem.
    特性
    136 state and timing channels
    100 MHz state analysis with 2 state clocks/qualifiers
    Integrated 2-channel 1-GSA/s Oscilloscope
    Conventional timing offers resolution down to 2 ns
    Transitional timing captures data bursts separated by long time periods
    Independent time and voltage markers and channel labeling
    Edge, voltage level and pattern duration triggering and automatic pulse parameters
本公司是一家集仪器、仪表研发、生产、代理于一体的高科技企业。公司除电子仪器销售外,还有环境试验设备,分析仪器,质检仪器,计量仪器的销售及服务。现将部分产品介绍如下,如有需求,欢迎来电来函查询。1、电源线厂专用仪器和设备:二芯、…  更多>>
通诚电子仪器有限公司
联系人:谢冬梅
地址:深圳市福田区振华路
邮编:518031
电话:0755-83222025
传真:0755-83322550
公司网址:http://yintong.web.jonweb.net/
