上海步青商贸有限公司
  • 英国Penny + Giles 位移传感器
  • 发布时间:2009/10/29 21:37:42   修改时间:2007/4/2 17:57:00 浏览次数:6459
  • 英国PENNY + GILES
    Penny + Giles success in world markets results from innovative technology, creative design, manufacturing excellence and interactive customer support.
    Linear Potentiometer
    ICT080: Contactless In-Cylinder Linear Transducer
    With a body diameter of only 8mm the ICT080 is ideal for installation into hydraulic and pneumatic cylinder applications where space is at a premium. The ICT080 is ideal for use on small-bore actuators and offers a choice of internal or threaded flange mounting configurations to suit tie-rod, welded and rear clevis-mounted cylinder types in stroke ranges from 25 to 1000mm. With no electrical sliding contacts, the ICT080 has a working life which is almost limitless.
    ICT100: Contactless In-Cylinder Linear Transducer
    With a body diameter of only 10.1mm the ICT100 is ideal for installation into hydraulic and pneumatic cylinder applications where space is at a premium. The ICT100 is ideal for use on medium stroke actuators and offers a choice of internal or threaded flange mounting configurations to suit tie-rod, welded and rear clevis-mounted cylinder types in stroke ranges from 25 to 2000mm. With no electrical sliding contacts, the ICT100 has a working life which is almost limitless.
    EICT: Signal Conditioning Module for ICT Range
    This module, housed in a high strength IP66 enclosure, incorporates a high performance circuit that drives the transducer and provides a choice of output signals with zero and gain adjustment for simple user configuration. The enclosure includes a moulded detail to fit DIN rail EN50022 or EN50035, or can be bulkhead mounted via four M5 screws.
    The module operates from a 10-60 Vdc supply voltage and provides a range of outputs which can be configured by the user. The module is matched to the ICT transducer by a plug-in Sensor Calibration Module Card (SCMC).
    ICS 100 In-Cylinder Linear Displacement Sensor
    Designed specifically for use in hydraulic and pneumatic actuator applications, where the sensor is fitted inside the pressurized environment.
    HLP190FS: Spring Loaded Linear Potentiometer
    The HLP190 range provides the facility for single or dual electrical output with a body diameter of only 19mm. Stroke lengths are from 25mm to 150mm, with a choice of body clamp (BS) or flange (FS) mounting. This model is supplied with a spring loaded shaft, biased to the fully extended position.
    SLS095: Linear Displacement Sensor
    The SLS095 is an entirely new range of linear position sensors designed to provide maximum performance benefits within an extremely compact, lightweight package in stroke lengths from 10 to 100mm.
    SLS130: Linear Displacement Sensor
    SLS130 is an entirely new range of linear position sensors designed to provide maximum performance benefits within an extremely compact size. Using the proven benefits of Hybrid Track Technology and including a number of unique design features, the SLS130 range is ideally suited to high volume OEM manufacturers, where high performance and reliability with competitive pricing and rapid dispatch has paramount importance.
    MLS130: Linear Displacement Sensor
    The MLS130 sealed linear sensor is designed to provide superior performance within a compact, lightweight package in stroke lengths from 25 to 200mm, which is ideally suited to motorsport data acquisition applications on suspension and throttle position feedback. The sensor is supplied fully sealed to IP66, with an integrally molded DR25 sheathed multicore cable.
    SLS190: Linear Displacement Sensor
    SLS190 is an entirely new range of linear position sensors designed to provide maximum performance benefits within an extremely compact size. Using the proven benefits of Hybrid Track Technology and including a number of unique design features, the SLS190 range is ideally suited to high volume OEM manufacturers, where high performance and reliability with competitive pricing and rapid dispatch has paramount importance.
    SLS220: Linear Displacement Sensor
    The SLS220 is an entirely new linear position sensor in stroke lengths of 10 and 20mm, with a spring loaded operating shaft. With a mounting flange to allow easy installation and housed within a high strength Nylatron housing, providing good chemical resistance and low weight.
    Suited to OEM and process monitoring applications, this new sensor replaces the obsolete HLP220 model.
    SLS320: Linear Displacement Sensor
    The SLS320 is an entirely new range of linear position sensors designed to provide stroke lengths up to 1100mm in a compact, lightweight, easy to use design.
    LVDT
    AF111 - LVDT Displacement Transducer
    Suitable for clamp mounting, the AF111 range have a threaded, unguided core assembly to simplify installation.
    For optimum performance, we recommend the use of the purpose designed signal conditioning module (SCM100) to operate this LVDT.
    The design of this LVDT has evolved from technology and experience gained in over 30 years in the bespoke aerospace / military sensor market, where performance and reliability under extreme operating conditions are paramount. The transducer coil has been specifically designed to reduce overall transducer length and to enable high accuracy ratiometric operation, as well as being able to operate in the "Differential Output" configuration.
    Suited to numerous industrial applications such as vehicle research, test rigs and OEM machinery.
    AF145 - LVDT Displacement Transducer
    Mounting is by self-aligning rod end bearings, and the outer sliding sleeve protects the movable core whilst enhancing the rigidity of the transducer during operation.
    Suited to harsh automotive and industrial environments.
    SCM100: DC/DC Driver for LVDTs
    The SCM100 LVDT signal conditioning module has been designed specifically to operate with the AF111 and AF145 range of LVDTs, and to make using an LVDT as simple as using a linear potentiometer.
    This module incorporates a high performance circuit which drives the LVDT in a ratiometric configuration, thereby maximizing system accuracy by eliminating effects caused by temperature and supply current variations.
    Supplied in a DIN rail enclosure to suit EN50022/EN50035 rails, complete with a set-up guide.
    VRVT
    VRVT190: Contactless Linear Displacement Transducer
    The VRVT190 Linear Displacement Transducer combines the best features associated with LVDTs and potentiometers into one rugged, contactless and highly reliable displacement transducer.
    EM10: Signal Conditioning Module for VRVT range
    The EM-10 VRVT signal conditioning module has been designed specifically to operate with the VRVT range of contactless linear displacement transducers. Housed in a DIN rail enclosure to suit EN50022 or EN50035 rails, this module operates from a 18-30 Vdc supply voltage and provides a range of voltage (EM-10-V) or current (EM-10-I) outputs which can be configured by the user.
    EM-9: Signal Conditioning Module for VRVT range
    The EM-9 VRVT signal conditioning module has been designed specifically to operate with the VRVT range of contactless linear displacement transducers. Housed in a DIN rail enclosure to suit EN50022 or EN50035 rails, this module operates from a ±15 Vdc supply voltage and provides a range of voltage outputs which can be configured by the user.
    ROTARY POSITION SENSORS
    SRH280: Contactless Rotary Sensor
    SRH880: Submersible Rotary Sensor
    SRH280 provides reliable and accurate rotary measurement in extreme industrial environments where shock and vibration can occur. SRH280 uses the popular 28mm flanged housing with a protection rating upgraded to IP68.
    The sensor operates from 8-30Vdc unregulated supply and provides an electrical output over the full 360° range. For ease of configuration, it is available with an analogue (0.5 to 4.5Vdc) or digital (pulse width modulated) signal output.
    SRS880: Submersible Rotary Sensor
    The SRS880 submersible rotary sensor has been specially developed to meet the harsh operating requirements of todays heavy duty industrial position sensing applications, including construction, agricultural, military and utility vehicles, as well as a variety of uses in steelworks and power generating plants. This model can operate at a submerged depth of 2m (6.5 feet).
    SRS280: Sealed Rotary Sensor
    The SRS280 sealed rotary sensor has been specially developed to meet the harsh operating requirements of todays automotive and motorsport markets, with a number of innovative design features incorporated to overcome the shortcomings of existing products from other manufacturers.
    IAPS 762: Industrial Angular Position Sensor
    The 762 series Industrial Angular Position Sensor is designed to provide reliable performance in the most arduous operating conditions. It can be specified either as a voltage dividing potentiometer incorporating the high performance advantages of Penny & Giles hybrid track technology, or for variable resistance applications, with a wire-wound resistance track.
    RVDT (Industrial/Motorsport): RVDTs For Industrial/Motorsport applications
    The Penny + Giles rugged, high integrity RVDT displacement transducer is designed for operation in harsh automotive and motorsport environments.
    RVDTs (Aerospace): RVDTs for Aerospace applications
    Penny & Giles aerospace RVDTs have been developed for use in the most demanding aerospace applications where they withstand extremes of temperature, pressure and vibration. Aircraft include the AH-64 Apache Longbow Helicopter and the RJ45 regional jet. They are employed in numerous applications including flight recorder data acquisition tasks such as aileron, elevator, pitch trim, yaw damper and airbrake control.
    RCP09: Midpot Rotary Potentiometer
    Supplied in size 09 synchro mount size, automatic trimming of linearity and resistance by profiling of the resistive element maintains consistent high quality.
    Exact setting of pre-load on the stainless steel ball races supporting the shaft, eliminates shaft radial and axial play throughout the life of the potentiometer and provides excellent vibration and shock performance.
    RCP11: Rotary Potentiometer
    Supplied in size 11 synchro mount size (27.2mm body diameter), automatic trimming of linearity and resistance by profiling of the resistive element maintains consistent high quality. The RCP11 can accommodate up to 4 independent cups, ganged together on a common shaft. Suited to a wide range of applications in aerospace, defence and industrial markets.
    RCP15: Rotary Potentiometer
    Supplied in size 15 synchro mount size (36.7mm body diameter), automatic trimming of linearity and resistance by profiling of the resistive element maintains consistent high quality. The RCP15 can accommodate up to 6 independent cups, ganged together on a common shaft. Suited to a wide range of applications in aerospace, defence and industrial markets.
    RCP18: Rotary Potentiometer
    Supplied in size 18 synchro mount size (44.7mm body diameter), automatic trimming of linearity and resistance by profiling of the resistive element maintains consistent high quality. The RCP18 can accommodate up to 6 independent cups, ganged together on a common shaft. Suited to a wide range of applications in aerospace, defence and industrial markets.
    RCP30: Rotary Potentiometer
    Supplied in size 30 synchro mount size (76.2mm body diameter), automatic trimming of linearity and resistance by profiling of the resistive element maintains consistent high quality. A range of options exist to customise the standard range to suit specific customers requirements for linearity, track resistance, switch tracks, environmental sealing and shaft configurations. The RCP30 can accommodate up to 6 independent cups, ganged together on a common shaft. Suited to a wide range of applications in aerospace, defence and industrial markets.
    Joystick
    JC025: Single-Axis Fingertip Rocker
    Developed for those applications where compact size and minimal 'above panel' height is paramount, the JC025 rocker has a very low profile whilst still providing precise fingertip control in one axis.
    JC030: Single-Axis Fingertip Rocker
    Developed for those applications where compact size and min, imal 'above, , panel' height is paramount, the JC030 rocker has a very low profile whilst still providing precise fingertip control in one axis.
    JC100: Single Axis Fingertip Joystick
    Developed for applications where ergonomics and system integrity are paramount, the JC100 is a compact, low profile joystick that provides precise fingertip control in one axis.
    JC120: Single-Axis Fingertip Joystick
    Sealed to IP66, the JC120 is suitable for the most extreme environments. Installation time is reduced through the use of standard automotive connectors, whilst the removal of all micro switches and camshafts has eliminated the need to maintain the joystick throughout its operating life in excess of 5 million cycles.
    Typical applications include radio and infra-red remote control chest packs, robotics, remote camera controls and agricultural and material handling equipment.
    JC150: Rugged Single Axis Joystick
    Developed for use in those applications where lever strength and handle functionality are paramount, the JC150 is a large, robust, single-axis joystick that can be easily tailored to your application.
    JC200: Multi-Axis Inductive Joystick
    A compact, inductive joystick with a life in excess of 15 million operations and EMC immunity of 50 V/m, the JC200 offers fingertip control in two axes.
    JC300: Multi-Axis Fingertip Joystick
    Developed for those applications where weight and functionality are paramount, the JC300 offers switched or proportional fingertip control in up to three axes.
    JC400: Multi-Axis Fingertip Joystick
    Developed for use in those applications where compact size and functionality are paramount, the JC400 offers proportional or digital fingertip control in up to three axes.
    JC600: Rugged Multi-Axis Joystick
    Developed for use in those applications where lever strength and handle functionality are paramount, the JC600 is a large, robust, multi-axis joystick that can be easily tailored to your application.
    JC2000: Multi-Axis Contactless Joystick
    The JC2000s compact size, low operational force and high reliability are ideal for applications which include powered wheelchair controllers, disabled mobility vehicles, robotic teach controllers, co-ordinate measuring machines, medical and CCTV equipment, professional camera controls and radio or infra-red crane chest-pack controllers.
    JC6000: Rugged Multi-Axis Joystick
    The JC6000 is available with one or two axis configurations and can be supplied with non-contact Hall effect sensors or long life potentiometer tracks. The compact size, high lever strength and superb proportional control are ideal for applications which include operator controls on a wide range of off-highway vehicles, including cranes, loaders, excavators, access platforms, tractors and harvesters.
上海步青商贸有限公司 Shanghai Booqing Trading Co.,Ltd. 本公司嫡属于步青香港公司。步青香港成立于2001年,为方便国内的销售,在2006年成立了上海步青商贸有限公司,2007年成立上海迅霸贸易有限公司。 公司有多年的进口产品的销售经验,在德国、美国、…  更多>>
上海步青商贸有限公司
联系人:黄丽华
地址:周浦万达广场周康路26号1613室
邮编:201318
电话:021-51099328
传真:021-60911395
公司网址:http://www.booqing.com
  • 杨磊 在2011/7/26 16:16:00留言
  • 详细留言:了解一下pearson传感器的详细资料和价格,型号是MODEL 410和MODEL 110,麻烦先发我的邮箱,有需要的话我会联系销售人员。
