Incremental encoder (Digital Tacho) and their Key Data
OG 3, OG 6, OG 60, HOG 60, KOG 60, OG 71, HOG 71, AHE 7 / AFE 7, HOG 75 , OG 8 / HOG 8, OG 9, OG 90, ?HOG 9 / HOG 9G, FOG 9, POG 9 / POG 9G, POG 90, HOG 10 / HOG 10G, HOG 11 / HOG 11G, HOG 100, POG 10 ?POG 10G, POG 11 / POG 11G, HOG 12 , HOG 131, EGZ 14 / AG 14 , HOG 161, HOG 16 , HG 16 / HG 18 / HG 22, ?HOG 22 / HOG 220, MHG 400,
LowHarmonics? Sinewave Tacho and their Key Data
OGS 60, HOGS 60, KOGS 60, EGS 60 ... A, OGS 71 / HOGS 71, HOGS 75, HOGS 80 / HOGS 120 / HOGS 140, ?EGS 14 / AGS 14, HOGS 15,
Absolute encoder (Absolute-Tacho)
AMG 75 , AMG 81 / P / S / SS / PS, AMG 10, AMG 11 / P / S, HMG 11 / P / S, HMG 161 / P / S,
Analog-Tacho (DC-Tachos, Tachogenerator)
GT 3 , GT 5, GTL 5, GT 7, GTF 7 , GT 9, GTB 9, GTR 9, GT 16, TDP 0,03, TDP 0,09 , TDP 0,2 LT, TDP 0,2 LS ?GMP 1,0, TDP 13, TDPZ 0,09, TDPZ 0,2 , GMPZ 1,0, TDPZ 13,
Combinations
OG 60 + GT 5 , FOG 9 + GT 7, POG 9 + FSL / POG 9 + ESL, HOG 10 + FSL / HOG 10 + ESL, POG 10 + FSL ?POG 10 + ESL, TDP 0,2 + OG 60, TDP 0,2 / TDPZ 0,2 + OG 9, TDP 0,09 + FSL, TDP 0,2 + FSL, TDP 0,2 + ESL,?TDPZ 0,2 + FSL / ESL , HOG 22+ HTA 11 + ES 100,
Speed Switches
FS 90 (FSL), ES 90 (ESL), ES 93 with 3 switching speeds, DS 93 with 3 adjustable switching speeds, ?ES 90 / ES 93 + FSL,, EEx OG 9, EEx HOG 161, EEx ME 12, TG 74d,
Reference List
AC Tacho T701 DG A4 Bore:15H7 IP66 30V_/1000 1/min I-Nr.:L100-72001-01~Hubner~
APY 50 LONGLIFE DC ANALOG TACHO B10, shaft : 7,92?x20mm Uo="50V/1000" min
COUPLING K35 D1=?10H7 ( WITHOUT KEY ) D2=?11H7 ( WITH KEY ) ?I-NR.:ET.90.22850-06L BTN-Nr.:85030099~Huebner~
COUPLING MODEL K35
EEX OG 9 DN 1024 I MARKING: "II 2 Eex de IIC T6" TüV 02 ATEX 1922X Logic-Level: HTL; UB= +9…+30V
EEx OG 9 DN 360 I I-Nr.:73775-EEXOG9 PTB Nr.Ex-97.D.1044
FG 4 K-1200G-90G-NG Machinen No. G384047 Komm Nr.07-28764~Hubner~
FGH 4K-1200G-90G-NG/20P + FSE 102
FOG 6 DN 500 CI, HTL 6mm Shaft Cable 1M I-Nr.:73011B-FOG6
FS90 B10, 11k6 x 30 Switching Speed 2000min-1, IP:55 6A/230VAC, 1A/125VDC I-Nr.: 75050A-01-FS90
GMP 1,0 LS-4 SER NO.:L1064330 I-Nr.:L066-52200-04 BTN.Nr.:85013190
GMP 1,0 S4 ACCORDING TO SER NO:936749 I-Nr.:L066-52200-04 BTN-Nr.:85013190~Huebner~
GMP 1,0LT-10 B5/B14 Shaft:12k6x20/BS 10k6x15 IP55 I-Nr.:52275B1-GMP1,0 BTN-Nr.:85013190 40V/1000 1/min
GMP 1,0LT-4 B5 shaft;12k6x20 IP55 Uo = 100 V/1000 1/min I-Nr.: L045-52025B1-04~Hubner~
GMP 1,0LT-4 B5n, shaft 14k6x30 IP55 100V/1000 1/min I-Nr.:L066-52200B1-04
GMP-1.0 ls-4 I-Nr.:L066-52200-04 BTN Nr.85013190
GT 3.10L/405 I-Nr.:L160-81601B-01 same to S/N:1458375
GT 5,05L/407 I-Nr.:L182-80175-04 BTN.Nr.:85013190
GT 5.05 L/407 #L1146578 IP54 02614 ( ANALOG DC TACHO )~Huebner~
GT 9.06L/420 A4 bore 16H7 20V/1000 1/min I-Nr. L093-81101-02
GT 9.06L/420-K A4 bore 17 cone 1:10 20V/1000 1/min I-Nr. L094-81252-09~Hubner~
GT5.05L/407 I-Nr.:L182-80175-04 BTN-Nr.1146578~Compatibel to NO.L1146578 7V+-5%
GT7.08L/420, A4 Bore 14H7 IP55 20V / 1000 1/min I-Nr.L184-80529-05~1060507
GTB 9.06L/420 K I-Nr.:L099-81250-09
GTB 9.06L/420K
GTR9, 16L-460 60V 1000RPM I-Nr.:L277-81500-01 BTN.:85013190~Hubner~
HDG9D 1024 I, +-30V, 1024P, I-Nr.:L247-73500B1024 MAX 7000RPM, SER NO. 1178433 BTN-Nr.:90318034
HEAG 172 I-Nr.:ET.99.HEAG172
HEAG 172 I-Nr.: ET.99.HEAG172~Huebner~
HZAG 172 With Cable 200Meter
HEAG 174 I-Nr.: ET.99.HEAG174~Hubner~
HEAG 174 I-Nr.:ET.99.HEAG174
HEAG154
HOG
HOG 10 D 1000 I Bohre 16H7 x 53 IP66 HTL +9 - +30V
HOG 10 D 1024 I-Nr.: 74000C-HOG 10 HS.: 90318034
HOG 10 D 1024 I I-Nr.:L251-74050D1024
HOG 10 DN 1024 I I-Nr.:74000D-HOG10~Compatible to s/n: 1495888~Hubner~
HOG 10 DN 1024I I-Nr.:74000C-HOG10 SAME TO BE S/N: 1181363 Comm Nr.:9604-44759
HOG 10 G DN 1024 I / DN 1024 I I-Nr.:74015D-HOG10G~s/n: 1282438
HOG 10D 1024, I-Nr.74000B-HOG10 BTN-Nr.90318034~Huebner~
HOG 60 DN 1000 CI Hollow Shaft: 8H7mm, HTL 9-26V I-Nr.:73128D-HOG60
HOG 9 D 1000 I, HTL, 9-30VDC Nr.1469799, IP:56 I-Nr.:73522B-HOG9 HS.CODE: 90318034~Hubner~
HOG 9 D 1024 A4KR IP66 HTL: UB=+9 +30V, K1, K2 Z="1024" I-Nr.:73501B-2-HOG9
HOG 9 D 1024 I, HTL, 9-30VDC I-Nr.:73522B-HOG9 HS.CODE: 90318034
MODEL: HOG 10 D 1024 I-No.: 74000C-HOG10
MODEL: POG 10 D 600 I / DN 360 TTL TWIN-DIGITAL-TACHO WITH TWO SEPERATED ELECTRICAL SYSTEMS ?I-No.: 73950B-?POG10G MOUNTING ANGLE B3 I-Nr.ET.02.22131
OG 6 DN 500 CI, HTL 6mm Shaft Cable 1M I-Nr.:73000A-OG6
OG 60 DN 600 TTL + GT 5,05L/410 I-nr.:73050A-OG60+GT5+80051-GT5,05~Hubner~
OG 71 DN 1024 TTL (EVIT) shaft 6h6x10 IP56 TTL(RS422) +5V Z="1024" I-Nr.: L76-73131A61024
OG 9 D 1000 I DIGITAL-TACHO B10, shaft:11k6 x 30, IP55 I-Nr.:L220-7340041000 BTN-NR.90318034
OG 9 D 1000 I DIGITAL-TACHO B10, shaft:11k6 x 30, IP55, 7200RPM I-Nr.:L220-7340041000 BTN-NR.90318034
OG 9 D 500 B1O, 11k6 x 30 IP 55 Logikpegel: HTL; UB = +9...+30 V Rechteck-Ausg?nge: K1, K2 Imp./Umdr.: Z = 500
OG 9 D 80 for Digital Tachometer
OG 9 DN 100 I for Digital Tachometer~Huebner~
OG 9 DN 1000 I(Standard) B10, shaft 11k6x30 9-30V I-Nr.: L222-73400A1000
OG 9D 1000 B10 11k6x30 IP55 +9..+30VDC K1 K2 1000P I-Nr. L214-73400A1000 HS.90318034
OG 9D 1000 I B10, 11k6x30, IP55 HTL UB:+9V…+30V K1,K1,K2,K2 Z="000" I-Nr.:L220-73400A1000~Hubner~
OG 9D 1000 I, B10, 11k6x30, IP55, 9 - 30V K1,K1,K2,K2 100P I-Nr. L220-73400A1000
og71DN 200CI I-Nr.73131A-OG71~Huebner~
OG9DN 10241 B10 WeIle 11k6 x 30 IP 55 Logikpegel: HTL; UB = +9...+30 V_?Rechteck-Ausg?nge: K1,K1,K2,K2,K0,K0 (mit invertierten Signalen) imp./Umdr.: ?Z = 1024 l-Nr.: L221-73400A1 024 HS-Nr.: 90318034
POG 10 D 1000 I I-Nr.73910B-POG10 Ub:+9/30V, Ser No:1382519
POG 10 D 1000I 9-30V 60mA IP65
POG 10 D 1024 B10 Welle 11k6x30 1P66 Logikpegel: HTL; UB = +9...+30 V_ Rechteck-Ausg?nge: K1, K2?Imp./Umdr.: Z =1024 l-Nr.: L260-73910B1024
POG 10 D 1024 B10, Shaft 11x30, HTL 9-30V, K1,K2 L260-73910B1024
POG 10 D 1024 FSL
POG 10 D 1024 I + POG 10 D 100 I B10 shaft. 11k6 x 30 IP66~Huebner~
POG 10 D 1024 I + POG 100 I + FSL 1800RPM
POG 10 D 1024 I B10, Shaft 11k6x30,IP66, HTL 9-30V K1,K1,K2,K2 I-Nr.:73910B-POG10
POG 10 D 1024 I-Nr. 73910-1024 Ser Nr.1231918
POG 10 D 1024 I-Nr.:L260-73910B1024
POG 10 D 500 I
POG 10 D 500 I + ESL 90 I-Nr.73930-POG10 BTN-Nr.90318034
POG 10 D 500 I + FSL I-Nr.73925-POG10 BTN-Nr.90318034
POG 10 D 500 I + FSL I-Nr.:73925B-POG10~Hubner~
POG 10 D 500 I, I-Nr.73910-POG 10 BTN-Nr.90318034
POG 10 D 600 I B1O, 11 k6 x 30, IP 66 HTL: UB = -4-9..+30 V_ K1, K1, K2, K2(mit invertierten Signalen)?Imp./Umdr.: Z = 600 l-Nr.:73910B-POG1O
POG 10 DN 1000 + FSL I-Nr.:73925-POG10 BTN-Nr.:90318039
POG 10 DN 1000I B10, shaft:11k6x30 IP66 9-30V I-Nr.:73910B-POG10 HS.:90318034
POG 10 DN 1024 + FSL(1955RPM) I-Nr.:73925B-POG10~Huebner~
POG 10 DN 1024 I I-Nr. : L265-73910B1024 HS-Nr.: 90318034
POG 10 DN 1024 I + FSL B10 11k6x30 IP66 9+30V I-Nr.:73925B-POG10 SAME TO BE S/N 1455842
POG 10 DN 1024 I B10 11k6x30 IP66 9+30V I-Nr.: L265-73910B1024~Hubner~
POG 10 DN 1024 I I-Nr.: L265-73910B1024
POG 10 DN 1024 TTL
POG 10 DN 1024I + FSL
POG 10 DN-1024 TTL+FSL INCL. ENCODER+OVRSPEED S/W + COUPLING+BRAKET, LINE DRIVE TYPE
POG 10D 1000 I Digital-Tacho 11k6x30 IP66 HTL;9-30V K1,k1, k2,k2 1000P I-Nr:73910B-POG10, 9-
POG 10D 1024 I-Nr.73910-1024 100% Compatible to Ser.No.1231918
POG 10D 1024 I-Nr.L260-73910-1024 BTN-Nr.90318034 100% Compatible to Ser.No.1231918
POG 10D 1024 I-Nr.74000B-HOG10 100% Compatible to Ser.No.1194464
POG 10D 1024, I-Nr.L260-73910-1024 BTN-Nr.:90318034 According to Ser No.:1231918~Hubner~
POG 10D 1024I I-Nr.: L265-73910B1024
POG 10D 500 I I-Nr.:L261-73910B4500
POG 10DN 1024 I + FSL FSL ????? I-Nr.:73925B-POG10
POG 10DN 600I
POG 10G D1024 I/D100 I I-Nr.:73950-POG10G BTN-Nr.:90318039
POG 9 D 1024 I B10, 11k6x30 IP55 I-Nr.:L208-73700A1024 BTN-Nr. 90318034~Hubner~
POG 9 D 500 Type compatible to series NO.:686521
POG 9 D 500 B10 shaft 11k6x30 IP56 I-Nr.:L201-73700C-500~Huebner~
POG 9 D 500 Digital-Tacho B10 shaft 11k6x30 IP56 Logikpegel: HTL; UB = +9...+30 V Rechteck-Ausg?nge: K1, K2 ?Imp./Umdr.: Z =500 I-Nr.: L201-73700C-500
POG 9 D1024 + FSL FSL : ????? 1/min I-Nr.:73725C-POG9
POG 9 DN 1024 1 Digital-Tacho B1O Welle 11k6x30 lP56 Logikpegel: HTL,UB = +9..+30 VRechteck-Ausg?nge:?K1,K1,K2,K2,KO,KOlmp./Umdr.: Z = 1024 l-Nr.: L209-73700C1024
POG 9 DN 1024 l + FS B10, shaft 11k6x30 IP56 Z="1024" I-Nr.:73725C-POG9
POG 9 DN 1024 TTL + FSL 1800 SER NO, 130 7175 I-Nr.: 73725C-POG9
POG 9 DN 1024 TTL + FSL Digital-Tacho B1O 11k6 x 30 IP56 Tacho: Logikpegel: TTL (RS422); U?B = +5 V_ +1- 5 % Rechteck-Ausg?nge:Imp./Umdr.: Z = 1024 FSL: Schaltdrehzahl n = 1400 1/min ?I-Nr.: 73725C-POG9~Hubner~
POG 9 DN 1024I
POG 9 DN 1200 HTL + FSL 1320 B10,Shaft:11x30mm,9-30V,1200P I-Nr. 73725C-POG9~Huebner~
POG 9 DN 1200 HTL + FSL 924 B10,Shaft:11x30mm,9-30V,1200P I-Nr. 73725C-POG9
POG 9 DN 1200 I HTL, 9-30V, I-No.:73700C-POG9
POG 9 DN 2048 B1O, 11 k6 x 30, IP 56 HTL: UB = 9..+30 V_ K1, K1, K0 Imp./Umdr.: Z = 2048 l-Nr.: 73700C-POG9
POG 9 DN 500 I+FSL I Nr.:73700-POG9 BTN-Nr,:90318039
POG 9 DN1200 + FSL2370 B10, 11k6x30, IP56, 9-30V, 1200P
POG 9 DN1200 + FSL3250 B10, 11k6x30, IP56, 9-30V, 1200P
POG 9 DN1200 HTL + FSL1320 B10, 11k6x30, IP56, 9-30V, 1200P
POG 9 DN1200 HTL + FSL1650 B10, 11k6x30, IP56, 9-30V, 1200P
POG 9 DN1200 HTL + FSL924 B10, 11k6x30, IP56, 9-30V, 1200P~Hubner~
POG 90 DN 2048 Digital-Tacho B1O/B14, 11 k6 x 30 / BS 10k6 x 15, IP 56 HTL: UB = 9..+30 V_ K1, K1, K0 ?Imp./Umdr.: Z =2048 l-Nr.: 73650B-POG90
POG 90 DN 5000I Digital Tacho with 2nd shaft B10/B14 11k6x30 / 10k6x15 I-Nr. 73650B-POG90 9-30V
POG 90 DN 5000I, 9-30V I-Nr.: 73650B-POG90
POG 9D 1024 B10, 11k6x30 IP56 I-Nr. : L205-73700C1024
POG 9D 500I, DIGITAL-TACH B10, 11K6x30, 6-30V, 500P I-Nr.L206-73700A4500 BTN-Nr.:90318034
POG 9-D-500 B10, shaft : 11k6x30, IP56, Putput HTL : K1 K2 , Z="500" I-Nr. : L201-73700C-500
POG 9DN 1200 I #990155 I-Nr.:73700A-POG9 BTN-NR.:90318034~Huebner~
POG 9DN 1200I, UB:9-30V B10, 11k6x30, IP56, 9+30V, 1200P I-Nr.:73700A-POG9 BTN-Nr:90318304
POG 9DN/1024 I-Nr.:737000A-POG9 BTN-Nr.:90318034 according to ser no:1235713
POG 9-DN-500 B10 11k6 x 30 IP56, +9…+30V OUTPUT : K0 K1 K2 Z = 500
POG10 D 1024 1+ POG 10D 100 I + FSL I Nr.:73915-POG10+23544+73925-POG10~Hubner~
POG10DN 1024 I I-Nr.:L265-73910-1024
POG10DN 1024 I+FSL (1955 RPM ) I-Nr.73925-POG10
POG9DN 1024, B10, shaft: 11k6x30, IP56, HTL, 9-30V, 1024P, I-Nr.:73700C-POG9,
T 701 DG AC-hollow-Tacho A4; bore 15H7; IP 66 Uo = 30 V_/1000 1/min I-Nr.: L100-72001-01 same to S/N 707534
TDP 0,09LT-3 40V/1000 1/min B10 shaft: 6h6x15 IP56 I-Nr.:L113-60575B-03
TDP 0,2 LT-4 BTN BR:85013190 I-NR:L125-61101-A1-04
TDP 0,2 LT-4 + FSL BTN NR:85013190 I-NR:61356-A1-04
TDP 0,2 LT-4 + FSL Tacho B10 Shaft: 11k6 x 30 IP55 UO="60V/1000" 1/MIN FS: 828 1/min
TDP 0,2LT-1 B10 SHAFT 11k6 x 30 IP55, VOLTAGE 150V/1000RPM 1/min
TDP 0,2LT-4 B10 shaft:11k6x30 IP55 Uo="60V/1000" 1/min compatible to S/N: L1279544~Hubner~
TDP 0,2LT-4 60V/1000 B10 shaft:11?x30mm I-Nr.:L125-61101A1-04
TDP 0,2LT-4 + OG 9 D 1000 I B10, 11k6x30, IP55 Uo="60" V/1000 1/min I-Nr.:L229-61373C1-04
TDP 0,2LT4 + OG 9E 200 shaft 11k6 x 30 IP55 60V/1.000 1/min
TDP 0,2LT-4 B10 Shaft 11k6 x 30 IP 55 U_0 = 60 V/1000 1/min I.-No.: L125-61101B1-04
TDP 0,2LT-4 B10 SHAFT 11k6 x 30 IP55 Uo= 60V/1000 1/min
TDP 0,2LT-4 B10, shaft 11k6x30 IP55 60V/1000 1/min I-Nr.:L125-61101B1-04
TDP 0,2LT-4, B3 SHAFT 11k6 x 30 IP55, VOLTAGE 60V/1000RPM~Huebner~
TDP 0,2LT-5 + FSL Tacho B10, 11k6x30 IP55 Uo="40V" / 1000 1/min FS: 2100 RPM ?I-Nr.61356A1-05 BTB-Nr.:85013190
TDP 0,52L / 44H LongLife DC Analog Tacho A4 Shaftbore 16H/ IP55 Uo="40V/1000" 1/min
TDP 0.09LT-1 DC-Analog-Tacho B10, 6h6 x 15, IP56, 10V/1000 1/min I-Nr.L109-60575B-01 / 85013190~Hubner~
TDP 0.09LT-2, 20V/1000RPM No.L1075337, Max:5000min
TDP 0.09LT-3 + FSL B10 40V/1000 1/min FS:1850 1/min I-Nr.:60755A-TDP0.09
TDP 0.2 LT-4 B10 11k6x30 60V/1000 1/min L125-61101B1-04 SAME TO BE S/N : L893423
TDP 0.2LT-1, Long Life DC Analog Tacho B10, 11k6x30 IP55 Uo="150V/1000" 1/min ?I-Nr.:L123-61101A1-01 BTN-Nr,;85013190
TDP 0.2LT-4 + FSLI-No.: 61356C1-04
TDP 0.2LT-4 + OG 9 DN 120 I-Nr.:L223-61373C8-04
TDP 0.2LT-4 + OG 9DN 100 I,-Nr.:61373C1-04~Huebner~
TDP 0.2LT-4 + OG 9DN 1000, B10, 11k6x30 IP55 60V/1000 1/min, +9..+30V I-Nr.:61373C1-104
TDP 0.2LT-4 + OG 9DN 120 Longlife DC Analog Digital Tacho Kombi B10, ?11k6x30 OP55 Analog : 60V/1000 1/min UB:+9V…+30V,?K1,K2,K0 Z="120" I-Nr.L223-61373C8-04
TDP 0.2LT-4 + OG 9DN 72 I-Nr.: 61373C1-04~Hubner~
TDP 0.2LT-4 + OG9 DN 1250 I.-Nr.:61373D-04
TDP 0.2LT-4, 60V/1000RPM B10 shaft: 11k6x 30 IP55 L125-61101A-04~Huebner~
TDP 0.2LT-4, 60V/1000RPM B10 shaft: 11k6x 30 IP55 L125-61101A-04,
TDP 0.2LT-4, 60V/1000RPM B10 shaft: 11k6x 30 IP55 STANDARD
TDP 0.2LT-4+FSL B10, 11k6x30 IP55 60V/10001 /min FS n="2160" 1/min I-Nr :61356A1-04
TDP 0.2LT-4+FSL I-Nr.:L125-61101-1-04 BTN-Nr.:85013190
TDP 0.2LT-41 + OG 9 E 200 I-Nr.:L225-61373C1-04~Hubner~
TDP 0.2LT-5 + FSL ( ???? RPM ) B10 shaft:11K6x30 40V/1000 1/min IP55 I-Nr.L126-61101-1-05
TDP 0.2LT-5 B10 shaft:11K6x30 40V/1000 1/min IP55 I-Nr.L126-61101-1-05
TDP 02LT-4, B10, shaft:11k6x30 IP55 60V/1000RPM HS.85013190
TDP 13.06LT-6 I-Nr.:54025B1-TDP13~Huebner~
TDP O,2LT-4 LongLife-DC-AnaIog-Tacho B1O shaft 11 k6 x 30 IP 55 Uo6OV/1000 1/min ?I-Nr.: L125-61101A1-04
TDP O,2LT-4LongLife-DC-AnaIog-Tacho mit 2 Wellenenden B10/B14 ?Welle AS 11k6 x 30/BS 10k6 x 15 IP55 Uo="6OV/1000" 1/min I-Nr.: L135-61301C1-04 85013190
TDP O,2LT-5 LongLife-DC-AnaIog-Tacho B1O shaft 11 k6 x 30 IP 55 Uo4OV/1000 1/min I-Nr. L126-6110A1-05
TDP O.2 LT-4 LongLife-DC-AnaIog-Tacho B10 Welle AS 11k6 x 30 IP55 Uo="6OV/1000" 1/min ?I-Nr.: L125-61101B1-04 85013190
TDP O.2 LT-4LongLife-DC-AnaIog-Tacho 2 nd schaft B10/B14 ?Welle AS 11k6 x 30/BS 10k6 x 15 IP55 Uo="6OV/1000" 1/min I-Nr.:L135-61301C1-04 85013190
TDP-0,09LT-3 ~Hubner~
TDP-0,2LT-4 B10 Welle:11k6 x 30 IP55
TDP0,2LT-4 + OG9 DN 1000 I-Nr.: 61373C1-04~Huebner~
TDP-0.09 LT-2 (20V/1000RPM)
TDP-0.09 LT-3 (40V/1000RPM)
TDP0.2 LT-4 + OG9D5
TDP0.2 LT-4 + OG9D5 B10 11k6x30 IP55 U0=60V/1000 1/min +9-+30V K1,K2 Z="5"
TDP0.2LT-1 LONGLIFE DC Analog Tacho B10 11k6x30 IP55 Uo= 150V / 1000 1/min I-Nr.:L123-61101A1-01
TDP-0.2LT-4 + FSL B10 11k6x30 IP55 60V=1000 1/min FSL n="XXXXX" I-Nr.:61356D1-04
TDP0.2T-4 NR 0687827 60V 67MA max 200MA 1000min Max 9000min VDE 0535 IP55 ISKUP~Hubner~
TDPZ 0,2LT-4LongLife-DC-Analog-Doppel-TachoB10 shaft 11k6 x 30 IP55 Uo = 2x60 V/1000 1/min?l-Nr.: L130-61551Al-04
TDPZ 0,2LT-5 + FSL Tacho B10, 11k6x30 IP55 Uo="2x40V" / 1000 1/min FS: 2100 RPM I-Nr.61804A1-?TDPZ 0,2~Huebner~
TDPZ 0.2LT-4 B10 11k6x30 IP55 Uo="2x60" V/1000 1/min I-Nr.:L130-61551A1-04
TDPZ 0.2LT-5,40V + FSL ( ???? RPM ) B10 Shaft:11K6x30 2x40V/1000 1/min IP55 I-Nr.L131-61551A1-05?SN.:1179489
TDPZ 0.2LT-5,40V/1000RPM B10 Shaft:11K6x30 2x40V/1000 1/min IP55 I-Nr.L131-61551A1-05
TG74-6 A#185312 Type:TG74-6 d/15 EEX dell CT6 Nr.:185312, BTB Nr.:EX-82/1062~Huebner~
TOP 1,2-5Z MODEL:G334-660 25W/100V RPM1.000 MAX6.000RPM~Hubner~?TYPE: TDP 0.2 LT-4 + OG 9 DN 1000 I B10, shaft : 11k6x30, IP55 I-Nr. 61373D1-04? |
