上海步青商贸有限公司
  • 美国SERVO DYNAMIC产品
  • 发布时间:2009/10/29 21:47:41   修改时间:2007/4/2 17:56:36 浏览次数:1413
  • Brush Servo Amplifier
    l        Technical Data
    Model
    Continuous Torque
    Output (cont.)
    Current (peak)
    Supply (voltage)
    815-BR
    8
    15
    20-80
    1525-BR
    15
    25
    60-170
    1525-BRS
    15
    25
    45-120
    Analog Amplifiers
    Trapezoidal Brushless Amplifiers
    l         Technical Data
    Model
    Continuous Torque
    Output (cont.)
    Current (peak)
    Supply (voltage)
    815-BL
    8
    15
    20-80
    1525-BL
    15
    25
    60-170
    1525-BLS
    15
    25
    45-120
    1224-BL
    12
    24
    70-360
    1224-BLS
    12
    24
    50-260
    HJ Series Servomotor
    Model
    Technical data
    HJ96
    Continuous Stall Torque TENV, 3.0 - 5.5 Nm (27 - 49 lb-in)
    HJ116
    Continuous Stall Torque TENV, 5.0 - 11.8 Nm (44 - 104 lb-in)
    HJ130
    Continuous Stall Torque TENV, 2.8 - 8.4 Nm (25 - 74 lb-in)
    HJ155
    Continuous Stall Torque TENV, 11.5 - 32 Nm (102 - 283 lb-in)
    HR Series Servomotor
    Model
    Technical data
    HR55
    Continuous Stall Torque TENV, 0.2 - 0.8 Nm (1.8 - 7.1 lb-in)
    HR70
    Continuous Stall Torque TENV, 0.6 - 1.8 Nm (5.3 - 16 lb-in)
    HR92
    Continuous Stall Torque TENV, 1.5 - 3.8 Nm (13.3 - 34  lb-in)
    HR115
    Continuous Stall Torque TENV, 3.7 - 9.8 Nm (33 - 115 lb-in)
    HR142
    Continuous Stall Torque TENV, 11.3 - 25 Nm (100 - 220 lb-in)
    MT/MTS Series
    l        Technical Data
    Model
    Technical data
    MT22
    Continuous Stall Torque TENV, 0.5 -1.2 Nm (4.4 -10.6 lb-in)
    MT30
    Continuous Stall Torque TENV, 1.2 - 5.5 Nm (10.6 - 48 lb-in)
    MT40
    Continuous Stall Torque TENV, 6.0 -11 Nm (53.0 - 97 lb-in)
    MT52
    Continuous Stall Torque TENV, 8.0 - 37 Nm (70.0 - 330 lb-in)
    SD94P Digital Servo Drive
    l        Models and Ratings:
    Input Voltages
    Model
    Output Current [Amps]
    Dimensions [mm]
    Rated
    Max
    H
    W
    D
    80-264 VAC
    48-62 Hz
    3Φ or 1Φ  120/200/240(Nominal)
    SD94P020Y2N
    2
    6
    190
    69
    190
    SD94P040Y2N
    4
    12
    190
    69
    190
    SD94P080Y2N
    8
    24
    190
    95
    190
    SD94P100Y2N
    10
    30
    190
    , , 115
    190
    320-528VAC
    48-62Hz
    3Φ
    400/480(Nominal)
    SD94P020T4N
    2
    6
    190
    69
    190
    SD94P040T4N
    4
    12
    190
    95
    190
    SD94P050T4N
    5
    15
    190
    115
    190
上海步青商贸有限公司 Shanghai Booqing Trading Co.,Ltd. 本公司嫡属于步青香港公司。步青香港成立于2001年,为方便国内的销售,在2006年成立了上海步青商贸有限公司,2007年成立上海迅霸贸易有限公司。 公司有多年的进口产品的销售经验,在德国、美国、…  更多>>
上海步青商贸有限公司
联系人:黄丽华
地址:周浦万达广场周康路26号1613室
邮编:201318
电话:021-51099328
传真:021-60911395
公司网址:http://www.booqing.com
  • 杨磊 在2011/7/26 16:16:00留言
  • 详细留言:了解一下pearson传感器的详细资料和价格,型号是MODEL 410和MODEL 110,麻烦先发我的邮箱,有需要的话我会联系销售人员。
