中山市铭远自动化设备公司
  • q.light韩国可莱特信号灯/多层信号灯
  • 发布时间:2007/6/26 14:24:13   修改时间:2007/6/26 14:24:13 浏览次数:1184
  • 中山市铭远自动化设备有限公司-韩国工控产品总汇
    电话:0760-3896378/3896379 传真:0760-8581683
    联系人:杨桑(小姐)
    网址:http://www.mygkong.com
    品牌:QLIGHT(可来特-警报灯)
    使用电压  12:DC12V  24:DC24V  110:AC110V  220:AC220V
    灯罩颜色  R:红色   Y:黄色   G:绿色   B:蓝色
    BZ:蜂鸣器内装型
    S60R S60-LF S100D-W S100D-LF-W S100-S-W S80R S80-LF S125D-W S125D-LF-W S125-S-W S80U S100-LF SHD-W SHD-LF-W SHD-S-W S100U S125-LF SHD-HS-W S100R S150-LF SHD2-W SHD2-LF-W SHD2-S-W S100M S150U-LF SHD2-HS-W S100E S60-S STD-BF1-W STD-LF1-W  S125U S80-S STD-BF2-W STD-LF2-W  S125R S100-S STD-BF3-W STD-LF3-W  S125M S100-HS SJD1-W SJD-LF1-W SJD-S1-W S125E S150-S SJD2-W SJD-LF2-W SJD-S2-W SK S150-HS SJD3-W SJD-LF3-W SJD-S3-W SKM S150U-S SED-W SED-LF-W SED-S-W SKP S125-S SED-HS-W SKPM S125-HS SD-W SD-LF-W SD-S-W S150R SR-1 SD-HS-W S150M SR-2 SMD-W SMD-LF-W SMD-S-W S150U SR-3 SMD-HS-W S180 SJ-1 SAOM-3 SAOM-3 SES-LF(123DB) S180U SJ-2 SAOM-E1 SAOM-E1  S230 SJ-3 ESE SES(123DB) SEB-LF(90DB) SR-LF1 SR-S1 SE  SR-LF2 SR-S2 ESE-LF SEB(90DB) SPN25-WM-6 SR-LF3 SR-S3 SE-LF ST45B-1 SJ-LF1 SJ-S1 SE-S SH1 ST45B-2 SJ-LF2 SJ-S2 SES-S ST45B-3 SJ-LF3 SJ-S3 SES-HS SH1T ST45B-4 SH1-LF SH1-S SEB-S ST45B-5 SH1-HS SEB-HS SH2 ST56B-1 SH1T-LF SH1T-S SPN25-W ST56B-2 SH1T-HS SPN25-W SH2T ST56B-3 SH2-LF SH2-S ST45LF-1 ST56B-4 SH2-HS ST45LF-2 ST56B1-W ST56B-5 SH2T-LF SH2T-S ST45LF-3 ST56B2-W ST80B-1 SH2T-HS ST45LF-4 ST56B3-W ST80B-2 ST45BF-1 ST45L-1 ST45LF-5 ST56B4-W ST80B-3 ST45BF-2 ST45L-2 ST56LF/ELF-1 ST56B5-W ST80B-4 ST45BF-3 ST45L-3 ST56LF/ELF-2 ST80B1-W ST80B-5 ST45BF-4 ST45L-4 ST56LF/ELF-3 ST80B2-W ST56L1-W ST45BF-5 ST45L-5 ST56LF/ELF-4 ST80B3-W ST56L2-W ST56BF-1 ST56L/EL-1 ST56LF/ELF-5 ST80B4-W ST56L3-W ST56BF-2 ST56L/EL-2 ST80LF-1 ST80B5-W ST56LF1-W ST56BF-3 ST56L/EL-3 ST80LF-2 ST80L1-W ST56LF2-W ST56BF-4 ST56L/EL-4 ST80LF-3 ST80L2-W ST56LF3-W ST56BF-5 ST56L/EL-5 ST80LF-4 ST80L3-W  ST80BF-1 ST80L-1 ST80LF-5 ST80S1-W  ST80BF-2 ST80L-2 ST56BF1-W ST80S2-W ST80LF1-W ST80BF-3 ST80L-3 ST56BF2-W ST80S3-W ST80LF2-W ST80BF-4 ST80L-4 ST56BF3-W ST80S4-W ST80LF3-W ST80BF-5 ST80L-5 ST56BF4-W ST80S5-W SN15-WVR SN15-W SN15-W ST56BF5-W SN15-WVS SRN-WVR SRN-W SRN-W ST80BF1-W SRN-WVS SEN15-WVR SEN15-W SEN15-W ST80BF2-W SEN15-WVS SEN25-WVR SEN25-W SEN25-W ST80BF3-W SEN25-WVS SENH15-WVR SENH15-W SENH15-W ST80BF4-W SENH15-WVS SENH25-WVR SENH25-W SENH25-W ST80BF5-W SENH25-WVS SENH35-WVR SENH35-W SENH35-W SEN15-WM-6 SENH35-WVS SENH50-WVR SENH50-W SENH50-W SEN25-WM-6 SENH50-WVS SEWN30E-WVR SEWN30E-W SEWN30E-W SENH15-WM-6 SEWN30E-WVS SEWN30T-WVR SEWN30T-W SEWN30T-W SENH25-WM-6 SEWN30T-WVS SHDN-WVR SHDN-W SHDN-W SENH35-WM-6 SHDN-WVS SEWN50E-WVR SEWN50E-W SEWN50E-W SENH50-WM-6 SEWN50E-WVS SEWN50T-WVR SEWN50T-W SEWN50T-W SEWN30E-WM-6 SEWN50T-WVS SPN25-WVR SPN25-W SPN25-W SEWN30T-WM-6 SPN25-WVS  SHDN-WM-6  SEWN50E-WM-6  SEWN50T-WM-6  SPN25-WM-6
    三、重负荷/防暴型警示灯
    SH1/SH2/ESE/SE 系列
                     保护网  无指定:无保护网的标准型  P指定:保护网安装型
        SH1 -标准型灯泡反射镜旋转重负荷型警灯[外径125mm]     (SH1-(P)-220-Y)
        SH1-LR -标准型LED反射镜旋转重负荷型警灯[外径125mm]   (SH1 LR-(P)-220-Y)
        SH1-L/LF -标准型LED点亮/闪亮重负荷型警灯[外径125mm]  (SH1 LF-(P)-110-R)
        SH1-B/BF -标准型灯泡点亮/闪亮重负荷型警灯[外径125mm] (SH1 BF-(P)-220-Y)
        SH1-S -标准型氙灯管频闪型重负荷警灯[外径125mm]       (SH1 S-(P)-12-B)
        SH1T -标准型灯泡反射镜旋重负荷型警灯[外径125mm]接线箱(SH1T-(P)-220-Y)
        SH1T-LR -标准型LED反射镜旋转重负荷型警灯[外径125mm]接线箱 (SH1T LR-(P)-220-Y)
        SH1T-L/LF -标准型LED点亮/闪亮重负荷型警灯[外径125mm]接线箱 (SH1T LF-(P)-110-R)
        SH1T-B/BF -标准型灯泡点亮/闪亮重负荷型警灯[外径125mm]接线箱(SH1T BF-(P)-220-Y)
        SH1T-S -标准型氙灯管频型重负荷警灯[外径125mm]接线箱        (SH1T S-(P)-12-B)
        SH2 -大型灯泡么射镜旋重负荷型警灯[外径150mm]     (SH2-(P)-220-Y)
        SH2-LR -大型LED反射镜旋转重负荷型警灯[外径150mm] (SH2 LR-(P)-24-R)
        SH2-L/LF -大型LED点亮/闪亮重负荷型警灯[外径150mm](SH2 LF-(P)-220-R)
        SH2-BF -大型灯泡点亮/闪亮重负荷型警灯[外径150mm] (SH2 BF-(P)-12-G)
        SH2-S -标准型氙灯管频闪型重负荷警灯[外径150mm]   (SH2 S-(P)-220-R)
        SH2T -大型灯泡反射镜旋转重负荷型警灯[外径150mm]接线箱   (SH2T-(P)-110-R)
        SH2T-LR -大型LED反射镜旋转重负荷型警灯[外径150mm]接线箱 (SH2T LR-(P)-24-R)
        SH2T-L/LF -大型LED点亮/闪亮重负荷型警灯[外径150mm]接线箱(SH2T LF-(P)-110-Y)
        SH2T-B/BF -大型灯泡点亮/闪亮重负荷型警灯[外径150mm]接线箱(SH2T BF-(P)-220-G)
        SH2T-S -大型氙灯管频闪重负荷型警灯[外径150mm]接线箱      (SH2T S-(P)-110-R)
        SE/SE-LF -标准型内压防爆警灯(外径150mm)灯泡反射镜旋转型/LED 点亮型 防爆型ExdllBT6(SE-24-Y)
        ESE/ESE-LF -经济型内压防爆警灯(外径150mm)灯泡/LED 光源. 防爆型ExdllBT6 (ESE-24-Y)
    四、内带信号音警示灯
     S100D/S125D/SC 系列
          音调  WS-警告音3音  WM-音乐 3音  WA-警报2音, 音乐1音  WV-音声信号3音
          音调选择  无指定:内部开关选择型   LC指定:引出外部选择线,可外部接点选择型
        S100D -内装信号音小型灯泡反射镜旋转型警灯(外径100mm)3音   (S100D-WS-220-G-(LC))
        S100D-LR -内装信号音小型LED反射镜旋转型警灯(外径100mm)3音 (S100D LR-WM-110-R-(LC))
        S100D-L/LF -内装信号音小型LED点亮/闪亮型警灯(外径100mm)3音(S100D LF-WS-110-G-(LC))
        S100D-S -内装信号音小型频闪型警灯(外径100mm)氙灯管,3音   (S100D S-WA-220-B-(LC))
        S125D -内装信号音标准型灯泡反射镜旋转型警灯(外径125mm)3音 (S125D-WS-110-G-(LC))
        S125D-LR -内装信号音标准型LED反射镜旋转型警灯(外径125mm)3音(S125D LR-WM-110-R-(LC))
        S125D-L/LF -内装信号音标准型LED点亮/闪亮型警灯(外径125mm)3音(S125D LF-WA-220-R-(LC))
        S125D-S -内装信号音标准型频闪型警灯(外径125mm)氙灯管,3音   (S125D S-WM-220-Y-(LC))
        SC1 -组合型指示灯和扬声器 小型 组合式  (SC1-S100R-Y-SRN-110)
        SC2 -标准型组合式指示灯和扬声器        (SC2-S125R-Y-SEN-220)
        SC3 -重负荷型组合式指示灯和扬声器      (SC3-SH1T-R-SEWN30-220)
        SC3-S -重负荷经济型组合式指示灯和扬声器(SC3S-SH1T-R-SRN-220)
    五、内带信号音多层式警示灯
     SJD/125TD/STD 系列
     STD-L/STD-B/STD-S -信号音内装型多层式指示灯
    (STD LF-层数-WM-110-(R)(G)(Y)-(LC))
     SJD-内装信号音四角灯泡反射镜旋转多层式指示灯(90x90mm)
    (SJD-层数-WS-220-(G)(R)(Y)-(LC))
     SJD-L/SJD-B/SJD-S-信号音内装型四角多层式指示灯(90x90mm)
    (SJD LF-层数-WS-220-(R)(G)(Y)-(LC))
     125TD-L/125TD-B/125TD-S 信号音内装型四角多层式指示灯(外径125mm)
    (125TD LF-层数-WA-220-(R)(G)(Y)-(LC))
    ◆中山市铭远自动化设备有限公司是一家专业销售各国低压电气和代理韩国工业控制自动化产品的企业,我公司本着“以服务为宗旨,以诚信为原则,以客户为核心,以市场为导向”。主要从事工业自动化领域产品的推广及技术服务,致力于工业自动化控制领域。
    ◆龙声电机株式会社(YongSung Electric CO;ltd)中国指定代理商,台湾安良ANLY电机,韩国韩荣HANYOUNG电子,韩国建兴电机KOINO,韩国凯昆KACON等华南地区总代理!
    ◆我公司代理的工业工控自动化多种产品、各种开关、继电器、温控表、温度控制器、仪器仪表、时间继电器、固态继电器、按钮开关、转换开关、凸轮开关、同期开关、选择开关、万能转换开关、天车开关、控制开关、吊车开关、带灯急停开关、脚踏开关、微动开关、限位开关、十字开关、方向开关、行车开关、方向开关、液位开关、空气开关、光电开关、接近开关、天车开关、光纤开关、电源按钮开关、行程开关、防爆开关、电源开关、急停开关、脚踏调速器、脚踏控制器、传感器、信号灯、指示灯、组合光字排、按钮指示灯、组合指示灯、警示灯、多层信号灯、塔灯、层灯、旋转信号灯、多层带闪光信号灯、多种声音多层信号灯、报警灯、多音报警器、防爆信号灯、防爆报警灯、防爆灯、喇叭信号灯、声光报警灯、防爆声光一体灯、声光一体旋转灯、防爆报警器、蜂鸣器、多音蜂鸣器、防爆电子蜂鸣器、防爆喇叭、多音喇叭、计数器、计时器、编码器、旋转编码器、工业编码器、电流表、电压表、接触器、记录器、数字显示器、数字显示温控表、功率控制器、组合开关盒、密封开关盒、可控硅功率调整器、端子排、组合端子排、固定端子排、控制箱、边接器、面板表、转速计、数字转速表、按钮开关盒、过程温度控制器、有纸记录仪,无纸记录仪、电机保护器、马达保护器等.
    ◆中山市铭远自动化设备有限公司代理品牌:韩国龙声电机株式会社(YongSung Electric CO;ltd)中国指定代理;HANYOUNG(韩荣电子)华南地区总代理;AUTONICS(奥托尼克斯);KOINO(建兴);凯昆(KACON)自动制御与配电系统;Q.LIGHT(可莱特,克莱特-警报灯,信号灯,层灯);PATLITE日本派特莱;EOCR(韩国三和电机保护器); HEDSS(海德)旋转编码;WOONYOUNG(韩国云永);DAEYANG(韩国大洋);韩国成浩SUNGHO;KWANGWOO(光宇);TEND(台湾天得电机);MOUJEN(台湾茂仁);SICK(德国施克);韩国KONICS;美国HONEYWELL(霍尼韦尔);SAMYOUNG(韩国三荣SAMWON);日本富士FUJI、AP(台湾汉鼎);FOX(DAESUNG韩国大成);韩国FAS;日本SMC气动;德国伟马快德WERMA(威马信号灯,警示灯,防爆声光信号器材);台湾HIWIN直线导轨;日本和泉(IDEC);台湾ANLY(安良机电);台湾普耐PUNA;意大利宝马斯BREMAS(必文士);HIBOX(韩国海博开关盒/接线盒);HEDSS海德编码器/连轴器等多个品牌。全方位低价供应,为各企业服务!欢迎联系。
◆中山市铭远自动化设备有限公司是一家专业销售各国低压电气和代理韩国工业控制自动化产品的企业,我公司本着“以服务为宗旨,以诚信为原则,以客户为核心,以市场为导向”。主要从事工业自动化领域产品的推广及技术服务,致力于工业自动化控制领…  更多>>
中山市铭远自动化设备公司
联系人:杨桑
地址:广东省中山市东区兴中道
邮编:528400
电话:0760-88332295
传真:0760-88581683
公司网址:http://www.mygkong.com
  • 丁小姐 在2024/3/19 13:58:00留言
  • 详细留言:客户需要SF-60M这款产品
  • 刘工 在2023/12/30 8:57:00留言
  • 详细留言:需用采购天车调度指挥仪
  • 王小姐 在2023/1/3 11:54:00留言
  • 详细留言:Koino RELAY W/BASE 24V 14 PIN KH-103-4C, Koino RELAY W/BASE 220V 14 PIN KH-103-4C
  • 在2022/8/30 15:37:00留言
  • 详细留言:韩国云永接近开关
  • 在2022/6/1 15:07:00留言
  • 详细留言:需采购韩国建兴KH-513TL按钮开关
