*Power Supply 工作电压: DC 12~240V or AC 24~240V *高容量继电器输出 3A/250VAC *High compact structure IP-66 *Multi surge killer circuit effectively protects from surge damage *B type ( Normal close type ) have no stock maybe ,accepted order to manufacture *Model : A3R-30XB , A3R-1MXB , A3R-2MXB,A3G-2MRB , A3G-4MXBA3T-10MXB , A3T-20MXB General Specification Specification Data Operating Voltage 12~240 VDC ; 24~240 VAC , 50/60HZ Current Consumption 2VA max. Output Method Relay Contact Current 3A/250 VAC Noise Resistance 1500Vp - p/1s Surge Resistance 2 KV/1S Vibration Resistance 10~55Hz / 1.5mm , 2 Hour In X.Y.Z. Direction Housing Material Case : Intensive ABS ; Lens : PC Operating Temp./Hum. -20C ~ +60C ; 35% ~ 85% RH
联系人:张东海
地址:上海市宛平南路255弄徐家汇花园16号2层
邮编:200032
电话:021-54594618
传真:021-54594616
公司网址:http://www.dmxtech.com
