龙人旗下深圳市龙芯世纪科技有限公司
  • Intersil数字电路
  • 发布时间:2011/9/17 14:56:53   修改时间:2008/9/21 22:03:17 浏览次数:648
  • DSP Function-Specific 特定功能 DSP
    Demodulators
    Digital Filters
    Down Converters
    Modulators
    Pre-Distortion Linearizers
    Programmable Data Buffer
    Synthesizers (NCO)
    Up Converters
    Video Decoder/Encoder
    Demodulators
    型号 数据手册DataSheet下载 Clock (MHz) Data (Bits) Decimation Factors Filtering 温度范围
    HSP50110 HSP50110 52 10 (Real or Complex)   Third Order CIC Compensation 84 Ld PLCC
    HSP50210 HSP50210 52 10 (Real or Complex) -201 RRC 84 Ld PLCC
    Digital Filters
    型号 数据手册DataSheet下载 Subtype Max Attenuation (dB) Compute Rate (Taps/sec) Filter Taps Data (Bits) Coefficient (Bits) Rate Change (Decimation or Interpolation) Control/μP Interface 温度范围
    HSP43124 HSP43124 HB FIR 140 90 Up to 256 (FIR) 24 32 1 to 256 8-Bit Data 3-Bit Address WR RD 28 Ld SOIC
    HSP43168 HSP43168 FIR 60 720 -240 10 10 -15 10-Bit Data 9-Bit Address 100 Ld MQFP,84 Ld PLCC
    HSP43216 HSP43216 HB 90 3484   16 20 1/2 2 Individual Control Lines 100 Ld MQFP,84 Ld PLCC
    HSP43220 HSP43220 CIC FIR 96 66 Up to 512 16 20 Up to 16,384 16-Bit Data 84 Ld PLCC
    Down Converters
    HSP50016 HSP50016 75 16 32 to 131,072 CIC 44 Ld PLCC
    HSP50214B HSP50214B 65MHz CLKIN 55MHzPROCCLK (Back End) 14 4 to 16,384 Fixed CIC Fixed Halfband Programmable FIR Fixed Re-Sampler 120 Ld MQFP
    HSP50216 HSP50216 70 16 4 to >16k CIC HB Programmable FIR Re-Sampler 196 Ld BGA
    ISL5216 ISL5216 95 16 4 to >16k CIC HB Programmable FIR Re-Sampler 196 Ld BGA
    ISL5416 ISL5416 95 16 4 to >16k CIC HB Programmable FIR Re-Sampler 256 Ld BGA
    Modulators
    型号 数据手册DataSheet下载 Subtype Modulation Formats Input Rate (MSPS) Input Data (Bits) Spectral Purity (dBc) Frequency Resolution (Hz) Output Filtering 温度范围
    HSP50415 HSP50415 Modulator QPSK QAM AM 25MSym/S for QPSK 16   0.023 14-Bits/12-Bits IF 50+MHz Programmable Shaping Interpolation 100 Ld MQFP
    型号 数据手册DataSheet下载 产品概述 温度范围
    ISL5239 ISL5239 Pre-Distortion Linearizer 196 Ld BGA
    型号 数据手册DataSheet下载 Clock (MHz) Delay Buffer Length Max. Data Word Length 温度范围
    HSP9501 HSP9501 32 2 to 1281 Data Word Delays 10 44 Ld PLCC
    Synthesizers (NCO)
    HSP45102 HSP45102 NCO QPSK, FSK 40 12 69 0.009 @ 32-Bits 12-Bits, Sine 40MHz None 28 Ld SOIC
    HSP45116A HSP45116A NCOM AM, FM, PM, PSK, FSK, QAM   16 90 <0.008 (32-Bits) 16-Bits I/Q33MHz None 160 Ld MQFP
    ISL5314 ISL5314 DDS QPSK, FSK 125 14   48 Analog None 48 Ld MQFP
    Up Converters
    ISL5217 ISL5217 Digital Upconverter QASK/FM Mod/FDM 6.5 16 >100 3.69e-7 (48-Bits) 4x20-Bits Programmable ShapingInterpolation 196 Ld BGA
    HMP8117 HMP8117 NTSC/PAL Video Decoder 80 Ld QFN
    HMP8156A HMP8156A NTSC/PAL Video Encoder 64 Ld MQFP
    HMP8170 HMP8170 NTSC/PAL Video Encoder 64 Ld QFP
    Intersil 英特矽尔应用技术支持与电子电路设计开发资源下载
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
