龙人旗下深圳市龙芯世纪科技有限公司
  • MSP430F2417 16 位超低功耗微控制器
  • 发布时间:2015/3/20 15:33:57   修改时间:2015/3/20 15:33:57 浏览次数:2228
  • 具有 92KB 闪存、8KB RAM、12 位 ADC、2 个 USCI 和 HW 乘法器
    The Texas Instruments MSP430 family of ultralow-power microcontrollers consists of several devices featuring different sets of peripherals targeted for various applications. The architecture, combined with five low-power modes is optimized to achieve extended battery life in portable measurement applications. The device features a powerful 16-bit RISC CPU, 16-bit registers, and constant generators that contribute to maximum code efficiency. The calibrated digitally controlled oscillator (DCO) allows wake-up from low-power modes to active mode in less than 1 μs.
    The MSP430F261x and MSP430F241x series are microcontroller configurations with two built-in 16-bit timers, a fast 12-bit A/D converter, a comparator, dual 12-bit D/A converters, four universal serial communication interface (USCI) modules, DMA, and up to 64 I/O pins
    MSP430F2417 特性
    • Low Supply Voltage Range 1.8 V to 3.6 V
    • Ultra-Low Power Consumption
      • Active Mode: 365 μA at 1 MHz, 2.2 V
      • Standby Mode (VLO): 0.5 μA
      • Off Mode (RAM Retention): 0.1 μA
    • Wake-Up From Standby Mode in Less Than 1 μs
    • 16-Bit RISC Architecture, 62.5-ns Instruction Cycle Time
    • Three-Channel Internal DMA
    • 12-Bit Analog-to-Digital (A/D) Converter With Internal Reference, Sample-and-Hold, and Autoscan Feature
    • Dual 12-Bit Digital-to-Analog (D/A) Converters With Synchronization
    • 16-Bit Timer_A With Three Capture/Compare Registers
    • 16-Bit Timer_B With Seven Capture/Compare-With-Shadow Registers
    • On-Chip Comparator
    • Four Universal Serial Communication Interfaces (USCIs)
      • USCI_A0 and USCI_A1: Enhanced UART Supporting Auto-Baudrate Detection, IrDA Encoder and Decoder, Synchronous SPI
      • USCI_B0 and USCI_B1: I2C, Synchronous SPI
    • Supply Voltage Supervisor/Monitor With Programmable Level Detection
    • Brownout Detector
    • Bootstrap Loader
    • Serial Onboard Programming, No External Programming Voltage Needed, Programmable Code Protection by Security Fuse
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
