龙人旗下深圳市龙芯世纪科技有限公司
  • TLC2254A 轨至轨双路运算放大器
  • 发布时间:2015/3/20 15:35:39   修改时间:2015/3/20 15:35:39 浏览次数:2370
  • The TLC2252 and TLC2254 are dual and quadruple operational amplifiers from Texas Instruments. Both devices exhibit rail-to-rail output performance for increased dynamic range in single- or split-supply applications. The TLC225x family consumes only 35 uA of supply current per channel. This micropower operation makes them good choices for battery-powered applications. The noise performance has been dramatically improved over previous generations of CMOS amplifiers. Looking at Figure 1, the TLC225x has a noise level of 19 nV/Hz\ at 1kHz; four times lower than competitive micropower solutions.
    The TLC225x amplifiers, exhibiting high input impedance and low noise, are excellent for small-signal conditioning for high-impedance sources, such as piezoelectric transducers
    TLC2254A
    Number of Channels4
    Total Supply Voltage (V)(Min)(+5V=5, +/-5V=10)4.4
    Total Supply Voltage (V)(Max)(+5V=5, +/-5V=10)16
    Iq per channel(Max)(mA)0.0625
    GBW(Typ)(MHz)0.2
    Slew Rate(Typ)(V/us)0.12
    VIO (25 deg C)(Max)(mV)0.85
    Offset Drift(Typ)(uV/C)0.5
    IIB(Max)(pA)60
    CMRR(Min)(dB)70
    Vn at 1kHz(Typ)(nV/rtHz)19
    Rail-RailOut
    RatingCatalog
    Pin/Package14PDIP, 14SOIC, 14TSSOP
    Approx. Price (US$)0.80 | 1ku
    Operating Temperature Range(C)-40 to 125
    TLC2254A 特性
    • Output Swing Includes Both Supply Rails
    • Low Noise...19 nV/Hz\ Typ at f = 1 kHz
    • Low Input Bias Current...1 pA Typ
    • Fully Specified for Both Single-Supply and Split-Supply Operation
    • Very Low Power...35 uA Per Channel Typ
    • Common-Mode Input Voltage Range Includes Negative Rail
    • Low Input Offset Voltage
      850 uV Max at TA = 25°C (TLC225xA)
    • Macromodel Included
    • Performance Upgrades for the TS27L2/L4 and TLC27L2/L4
    • Available in Q-Temp Automotive
      HighRel Automotive Applications
      Configuration Control / Print Support
      Qualification to Automotive Standards
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
