龙人旗下深圳市龙芯世纪科技有限公司
  • TLC2254A 轨至轨双路运算放大器
  • 发布时间:2015/4/18 10:44:11   修改时间:2015/4/18 10:44:11 浏览次数:3138
  • The TLC2252 and TLC2254 are dual and quadruple operational amplifiers from Texas Instruments. Both devices exhibit rail-to-rail output performance for increased dynamic range in single- or split-supply applications. The TLC225x family consumes only 35 uA of supply current per channel. This micropower operation makes them good choices for battery-powered applications. The noise performance has been dramatically improved over previous generations of CMOS amplifiers. Looking at Figure 1, the TLC225x has a noise level of 19 nV/Hz\ at 1kHz; four times lower than competitive micropower solutions.
    The TLC225x amplifiers, exhibiting high input impedance and low noise, are excellent for small-signal conditioning for high-impedance sources, such as piezoelectric transducers
    TLC2254A
    Number of Channels4
    Total Supply Voltage (V)(Min)(+5V=5, +/-5V=10)4.4
    Total Supply Voltage (V)(Max)(+5V=5, +/-5V=10)16
    Iq per channel(Max)(mA)0.0625
    GBW(Typ)(MHz)0.2
    Slew Rate(Typ)(V/us)0.12
    VIO (25 deg C)(Max)(mV)0.85
    Offset Drift(Typ)(uV/C)0.5
    IIB(Max)(pA)60
    CMRR(Min)(dB)70
    Vn at 1kHz(Typ)(nV/rtHz)19
    Rail-RailOut
    RatingCatalog
    Pin/Package14PDIP, 14SOIC, 14TSSOP
    Approx. Price (US$)0.80 | 1ku
    Operating Temperature Range(C)-40 to 125
    TLC2254A 特性
    • Output Swing Includes Both Supply Rails
    • Low Noise...19 nV/Hz\ Typ at f = 1 kHz
    • Low Input Bias Current...1 pA Typ
    • Fully Specified for Both Single-Supply and Split-Supply Operation
    • Very Low Power...35 uA Per Channel Typ
    • Common-Mode Input Voltage Range Includes Negative Rail
    • Low Input Offset Voltage
      850 uV Max at TA = 25°C (TLC225xA)
    • Macromodel Included
    • Performance Upgrades for the TS27L2/L4 and TLC27L2/L4
    • Available in Q-Temp Automotive
      HighRel Automotive Applications
      Configuration Control / Print Support
      Qualification to Automotive Standards
    TLC2254A 芯片订购指南
    器件状态温度价格(美元)封装 | 引脚封装数量 | 封装载体丝印标记
    TLC2254AIDACTIVE 0.95 | 1kuSOIC (D) | 1450 | TUBE
    TLC2254AIDG4ACTIVE 0.95 | 1kuSOIC (D) | 1450 | TUBE
    TLC2254AIDRACTIVE 0.80 | 1kuSOIC (D) | 142500 | LARGE T&R
    TLC2254AIDRG4ACTIVE 0.80 | 1kuSOIC (D) | 142500 | LARGE T&R
    TLC2254AINACTIVE 0.80 | 1kuPDIP (N) | 1425 | TUBE
    TLC2254AINE4ACTIVE 0.80 | 1kuPDIP (N) | 1425 | TUBE
    TLC2254AIPWACTIVE 0.95 | 1kuTSSOP (PW) | 1490 | TUBE
    TLC2254AIPWG4ACTIVE 0.95 | 1kuTSSOP (PW) | 1490 | TUBE
    TLC2254AIPWRACTIVE 0.80 | 1kuTSSOP (PW) | 142000 | LARGE T&R
    TLC2254AIPWRG4ACTIVE 0.80 | 1kuTSSOP (PW) | 142000 | LARGE T&R
    TLC2254AQDACTIVE-40 to 1250.85 | 1kuSOIC (D) | 1450
    TLC2254AQDG4ACTIVE 0.85 | 1kuSOIC (D) | 1450
    TLC2254AQDRACTIVE-40 to 1250.85 | 1kuSOIC (D) | 142500 | LARGE T&R
    TLC2254AQDRG4ACTIVE 0.85 | 1kuSOIC (D) | 142500
    TLC2254A 质量与无铅数据
    器件环保计划*铅/焊球涂层MSL 等级/回流焊峰环保信息与无铅 (Pb-free)DPPM / MTBF / FIT 率
    TLC2254AIDGreen (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIMTLC2254AIDTLC2254AID
    TLC2254AIDG4Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIMTLC2254AIDG4TLC2254AIDG4
    TLC2254AIDRGreen (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIMTLC2254AIDRTLC2254AIDR
    TLC2254AIDRG4Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIMTLC2254AIDRG4TLC2254AIDRG4
    TLC2254AINPb-Free (RoHS) CU NIPDAU N/A for Pkg TypeTLC2254AINTLC2254AIN
    TLC2254AINE4Pb-Free (RoHS) CU NIPDAU N/A for Pkg TypeTLC2254AINE4TLC2254AINE4
    TLC2254AIPWGreen (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIMTLC2254AIPWTLC2254AIPW
    TLC2254AIPWG4Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIMTLC2254AIPWG4TLC2254AIPWG4
    TLC2254AIPWRGreen (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIMTLC2254AIPWRTLC2254AIPWR
    TLC2254AIPWRG4Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIMTLC2254AIPWRG4TLC2254AIPWRG4
    TLC2254AQDTBD CU NIPDAU Level-1-220C-UNLIMTLC2254AQDTLC2254AQD
    TLC2254AQDG4Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIMTLC2254AQDG4TLC2254AQDG4
    TLC2254AQDRTBD CU NIPDAU Level-1-220C-UNLIMTLC2254AQDRTLC2254AQDR
    TLC2254AQDRG4Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIMTLC2254AQDRG4TLC2254AQDRG4
    TLC2254A 应用技术支持与电子电路设计开发资源下载
    1. TLC2254A 数据资料 dataSheet 下载.PDF
    2. TI 德州仪器仪运算放大器 (Op Amp)产品选型与价格 . xls
    3. 所选封装材料的热学和电学性质 (PDF 645 KB)
    4. 高速数据转换 (PDF 1967 KB)
    5. 在 PSPICE 中使用德州仪器 (TI) SPICE 模型 (zhca088.HTM, 8 KB)
    6. PowerPAD? Thermally Enhanced Package (slma002g.HTM, 8 KB)
    7. 运算放大器的单电源操作 (PDF 2174 KB)
    8. Tuning in Amplifiers (PDF 44 KB)
    9. Op Amp Performance Analysis (PDF 76 KB)
    10. An Error Analysis of the ISO102 in a Small Signal Measuring Application (PDF 29 KB)
    11. Level Shifting Signals with Differential Amplifiers (PDF 23 KB)
    12. Operational Amplifier Macromodels: A Comparison (PDF 59 KB)
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
